Project: 2665 (Run 3, Clone 642, Gen 24)
Leoslocks
Hardware configuration: Q6600 | P35-DQ6 | Crucial 2 x 1 GB ram | VisionTek 3870
GPU2 Version 6.20| CPU three 6.20 Clients
Post by Leoslocks »
Three consecutive EUEs @ 40%.
[03:59:42] Writing local files
[03:59:42] Completed 100000 out of 250000 steps  (40 percent)
[04:13:48] Warning:  long 1-4 interactions
[04:13:48] Gromacs cannot continue further.
[04:13:48] Going to send back what have done.
[04:13:48] logfile size: 84069
[04:13:48] - Writing 84605 bytes of core data to disk...
[04:13:48]   ... Done.
[04:13:48] - Failed to delete work/wudata_07.sas
[04:13:48] - Failed to delete work/wudata_07.goe
[04:13:48] Warning:  check for stray files
[04:15:48]
[04:15:48] Folding@home Core Shutdown: EARLY_UNIT_END
[04:15:48]
[04:15:51] CoreStatus = 7B (123)
[04:15:51] Client-core communications error: ERROR 0x7b
[04:15:51] Deleting current work unit & continuing...
[04:17:55] - Preparing to get new work unit...
[04:17:55] + Attempting to get work packet
[04:17:55] - Connecting to assignment server
[04:17:55] - Successful: assigned to (171.64.65.63).
[04:17:55] + News From Folding@Home: Welcome to Folding@Home
[04:17:55] Loaded queue successfully.
[04:17:58] + Closed connections
Free air temps are quite high (close to 100F).
qFixed the results, On to higher things.
Re: Project: 2665 (Run 3, Clone 642, Gen 24)
I see a partial credit for that WU ... but not with Leoslocks as username ...
Leoslocks
Post by Leoslocks »
I am managing two accounts. I believe the credit goes to rangeral. After EUE on three consecutive tries, the client HUNG on the next (different) WU. Just reporting the facts.....
I see you have your PPD average up to 45K, quite impressive. Your team is on the move also. Cheers.
Leoslocks wrote:I believe the credit goes to rangeral.
Indeed ©
