Is there a way to setup the client and control to access a client over the internet? I know how to do it locally on the LAN.
I know it will have to use proxy, just need examples using 7.6.21 F@H.
Remote Management over Internet
bikeaddict
Re: Remote Management over Internet
Free remote desktop software is probably the best way to access one computer. Running your own VPN server is more complex. You wouldn't want to use port forwarding to expose the F@H client's port to the public internet.
Do you want to control a system that is already a server that can be easily reachable from the internet or a home machine that will have to deal with opening ports in your home router ?
WhitehawkEQ
No no, all I want to do is access F@H client on another PC over the internet so I can manage it, I don't need to control the PC it's self.
