Problem with WU 18806 (19, 5, 167)
jdkdomain
Post by jdkdomain »
My computer is getting "stuck" on this WU at 99% and not finishing. I can't find a way to abort or end this work unit and the workstation cant seem to get a new WU. Tried shutting down and restarting but did not fix. Tried to go into FAHControl but dont see anything to about WU. Any suggestions on how to fix? Thanks.
jdkdomain
Re: Problem with WU 18806 (19, 5, 167)
Post by jdkdomain »
The WU finally reset after about another 15 mins after I sent this - computer appears to be working on a new WU now.
Badsinger
Post by Badsinger »
I got a 18806 this evening with the 0xa9 core and the WU would not even start. After several fails it reported the failure and downloaded a 0x23 WU. I've copied the 0xa9 portion of the log. Do I need to send it somewhere or is the info it reported back sufficient? Thanks.
BobWilliams757
Ryzen 2400G APU
32 GB DDR4-3200
MSI GTX 1660 Super Gaming X
Post by BobWilliams757 »
Badsinger,
Please check your log to see if you got a work unit starting from a checkpoint. See the below, it sounds similar.
https://foldingforum.org/viewtopic.php?t=41731
I wasn't sure if it was a project problem or a server problem. In either case it is also been reported by another user on the discord channel.
Fold them if you get them!
Badsinger
Post by Badsinger »
BobWilliams757 wrote: Wed Jul 24, 2024 2:01 am Badsinger,
My problem, with different points is identical.
FSO1:0xa9:steps first=38500000 total=38750000
same error message after start and after a few tries it went back to the 0x23 core and tasks.
BobWilliams757
Ryzen 2400G APU
32 GB DDR4-3200
Interesting. I know that the user on Discord had the same issue, and that the specific work unit he had also failed for another user. You might want to see if the one you have also failed for someone else.
https://apps.foldingathome.org/wu
BobWilliams757
Ryzen 2400G APU
32 GB DDR4-3200
And just passed for info, I've emailed and PM'd the scientist via the links here. I'll update if I get any response. BUT, I'm not sure if this has anything to do with that project, or somehow is related to the core update, and I have no idea who is the driving force behind that update, thus no way to contact them.
If anyone gets any scoop, please pass it on.
Post by muziqaz »
Researcher has been informed, though it is possible it is not their fault
FAH Omega tester
Badsinger
Post by Badsinger »
18806 has just failed for me again on a different machine. The core downloads fine, it fails to start 3 times then grabs a different WU and off it goes.
18:48:01:WU00:FS01:0xa9:********************************************************************************
18:48:01:WU00:FS01:0xa9:Project: 18806 (Run 29, Clone 59, Gen 8)
18:48:01:WU00:FS01:0xa9:Reading tar file core.xml
18:48:01:WU00:FS01:0xa9:Reading tar file frame8.tpr
18:48:01:WU00:FS01:0xa9:Digital signatures verified
18:48:01:WU00:FS01:0xa9:Calling: mdrun -c frame8.gro -s frame8.tpr -x frame8.xtc -cpt 15 -nt 1 -ntmpi 1 -update gpu -nb gpu -bonded gpu -pme gpu -pmefft gpu -gpu_id 0
18:48:01:WU00:FS01:0xa9:Steps: first=2000000 total=2250000
18:48:01:WARNING:WU00:FS01:FahCore returned an unknown error code which probably indicates that it crashed
18:48:01:WARNING:WU00:FS01:FahCore returned: UNKNOWN_ERROR (121 = 0x79)
18:48:01:WARNING:WU00:FS01:Too many errors, failing
18:48:01:WU00:FS01:Sending unit results: id:00 state:SEND error:FAILED project:18806 run:29 clone:59 gen:8 core:0xa9 unit:0x080000003b0000001d00000076490000
Post by muziqaz »
I sent the researcher an email. Hopefully they read emails more frequently than our internal communication channels :D
FAH Omega tester
Post by muziqaz »
Things should be fixed now.
Hopefully
FAH Omega tester
Demmers
Post by Demmers »
Thought i'd "re-open" this thread, as I had this WU fail on me today. Unfortunately I haven't been able to copy the logs, but I do know that at around 90% I noticed it had stopped (was monitoring on my phone), and upon checking the logs, "bad unit" was mentioned. Interestingly, before this happened, the last thing I noticed today when I left the PC was that FAHClient.exe was using a mammoth amount of memory, about 6GB, but fortunately I run with 16. I've never seen that before, but I didn't want to change anything in case I myself failed the WU. But for what ever reason, it eventually crashed itself.
Post by muziqaz »
High RAM usage has been observed before. This is Windows only, though.
Funny enough, system which was showing high RAM usage before now is showing 1.2MB used for Fahclient.exe
FAH Omega tester
Post by muziqaz »
Demmers wrote: Wed Oct 30, 2024 8:33 pm Thought i'd "re-open" this thread, as I had this WU fail on me today. Unfortunately I haven't been able to copy the logs, but I do know that at around 90% I noticed it had stopped (was monitoring on my phone), and upon checking the logs, "bad unit" was mentioned. Interestingly, before this happened, the last thing I noticed today when I left the PC was that FAHClient.exe was using a mammoth amount of memory, about 6GB, but fortunately I run with 16. I've never seen that before, but I didn't want to change anything in case I myself failed the WU. But for what ever reason, it eventually crashed itself.
If you could report your full system details in this issue tracker, that would be great:
https://github.com/FoldingAtHome/fah-cl ... issues/291
Alternatively, you can list your system details here, in this thread (please include OS + build, CPU, GPU, motherboard and RAM used)
Thanks
FAH Omega tester
Demmers
Post by Demmers »
muziqaz wrote: Wed Oct 30, 2024 9:08 pm If you could report your full system details in this issue tracker, that would be great:
Thanks
Thanks, i've submitted details in github.
