There's a ton of projects waiting to get done with various deadlines.The field that says "I support research fighting ____" is clearly ignore and even if it wasn't I want to target a project I care about or just not waste computer time on projects I can see from the road are flawed, aren't something I care about at all, really shouldn't be my top priority.
Is there some way to do that or do you need to add that feature?
Changing Project
PaulTV
- Hardware configuration: Fedora Linux w/ v8.5.6
Ryzen 9800X3D / RTX 4090
Ryzen 9800X3D / RTX 5070 Ti
Ryzen 5600 / RTX 3070 Ti - Location: Netherlands
Re: Changing Project
The 'I support research' is a preference, that means if there are projects active for the selected cause, you'll get a WU for that. If there are no WUs available for that cause (and your hardware), you'll just get a random WU. There is no option to stop folding if there are no jobs available for the selected cause.
