Is there a way to see since I setup my account last week the exact jobs I have under my account and which have completed successfully and which may have failed? I currently have 13 workstations setup with the same doner name and passkey. I can see how many WU and PPD I have completed overall but not a statistic showing if any have failed or the success rate for the WU the computers have received.
Thanks for your help.
Status of work units - Completed vs Failed
bikeaddict
Re: Status of work units - Completed vs Failed
The Bonus Status page can be used to see % finished for your account.
https://apps.foldingathome.org/bonus
The Recent CPUs page can be used to see if a bonus was earned on recent WUs.
https://apps.foldingathome.org/cpu
I'm not aware of a way to see more details of WU history besides using a script to parse the local logs generated by the client.
Thank you. This was exactly what I was looking for. Thanks for the quick reply.
BobWilliams757
Ryzen 2400G APU
32 GB DDR4-3200
MSI GTX 1660 Super Gaming X
If you are using version 7.6.x you can also use an app called HFM.
https://foldingforum.org/viewtopic.php?t=9903
It shows work unit completion or failure, points per day, dates and times of the work unit and other useful information.
Fold them if you get them!
