Some errors and no points from GPU workload
Monok
Post by Monok »
I'm running Windows 10 with a 7800X3D and 3080ti. Latest drivers (updated today manually to be 100% sure) on motherboard, chipset, GPU. GPU is undervolted, not overclocked because quite unstable (very bad luck with silicon lottery, hehe).
Whenever I fold, GPU WU don't award me any point, so I decided to clear the logs and start fresh to see what is wrong, and apparently I have some errors and questions:
How do I solve the time skew issue? I knew about this error because I checked on the forum before, but before doing this test I checked and time was synced perfectly via Windows automatic sync. To be 100% sure I also used the "Sync now" button.
The port 8080 fails and returns automatically to 80: how do I set it up to go to 80 directly?
"WARNING:WU02:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)" does this mean that the folding failed somehow, or what does it mean? How do I solve this?
Here's the whole log trimmed of everything between 2% and 99% as per reccomendations. I've left one line that says something about connecting to 127.0.0.1, is it because I opened the client . foldingathome . org manually and it made the connection to localhost to check data?
*********************** Log Started 2024-03-16T22:47:22Z ***********************
22:47:22:******************************* libFAH ********************************
22:47:22:           Date: Oct 20 2020
22:47:22:           Time: 13:36:55
22:47:22:       Revision: 5ca109d295a6245e2a2f590b3d0085ad5e567aeb
22:47:22:         Branch: master
22:47:22:       Compiler: Visual C++ 2015
22:47:22:        Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
22:47:22:       Platform: win32 10
22:47:22:           Bits: 32
22:47:22:           Mode: Release
22:47:22:****************************** FAHClient ******************************
22:47:22:        Version: 7.6.21
22:47:22:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
22:47:22:      Copyright: 2020 foldingathome.org
22:47:22:       Homepage: https://foldingathome.org/
22:47:22:           Time: 13:41:04
22:47:22:       Revision: 6efbf0e138e22d3963e6a291f78dcb9c6422a278
22:47:22:           Bits: 32
22:47:22:           Args: --open-web-control
22:47:22:         Config: C:\ProgramData\FAHClient\config.xml
22:47:22:******************************** CBang ********************************
22:47:22:           Time: 11:36:18
22:47:22:       Revision: 7e4ce85225d7eaeb775e87c31740181ca603de60
22:47:22:           Bits: 32
22:47:22:******************************* System ********************************
22:47:22:            CPU: AMD Ryzen 7 7800X3D 8-Core Processor
22:47:22:         CPU ID: AuthenticAMD Family 25 Model 97 Stepping 2
22:47:22:           CPUs: 16
22:47:22:         Memory: 31.16GiB
22:47:22:    Free Memory: 28.34GiB
22:47:22:        Threads: WINDOWS_THREADS
22:47:22:     OS Version: 6.2
22:47:22:    Has Battery: false
22:47:22:     On Battery: false
22:47:22:     UTC Offset: 1
22:47:22:            PID: 10376
22:47:22:            CWD: C:\ProgramData\FAHClient
22:47:22:  Win32 Service: false
22:47:22:             OS: Windows 10 Enterprise
22:47:22:        OS Arch: AMD64
22:47:22:           GPUs: 2
22:47:22:          GPU 0: Bus:1 Slot:0 Func:0 NVIDIA:8 GA102 [GeForce RTX 3080 Ti]
22:47:22:          GPU 1: Bus:16 Slot:0 Func:0 AMD:2 Raphael [Ryzen 7000 Series iGPU]
22:47:22:  CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:8.6 Driver:12.4
22:47:22:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:3.0 Driver:551.76
22:47:22:***********************************************************************
22:47:22:<config>
22:47:22:  <!-- Folding Core -->
22:47:22:  <checkpoint v='30'/>
22:47:22:  <core-priority v='low'/>
22:47:22:
22:47:22:  <!-- Folding Slot Configuration -->
22:47:22:  <cause v='HIGH_PRIORITY'/>
22:47:22:
22:47:22:  <!-- Network -->
22:47:22:  <proxy v=':8080'/>
22:47:22:
22:47:22:  <!-- Slot Control -->
22:47:22:  <power v='FULL'/>
22:47:22:
22:47:22:  <!-- User Information -->
22:47:22:  <passkey v='*****'/>
22:47:22:  <team v='32'/>
22:47:22:  <user v='Monok'/>
22:47:22:
22:47:22:  <!-- Folding Slots -->
22:47:22:  <slot id='0' type='CPU'>
22:47:22:    <cpus v='12'/>
22:47:22:  </slot>
22:47:22:  <slot id='1' type='GPU'>
22:47:22:    <pci-bus v='1'/>
22:47:22:    <pci-slot v='0'/>
22:47:22:  </slot>
22:47:22:  <slot id='2' type='GPU'>
22:47:22:    <pci-bus v='16'/>
22:47:22:  </slot>
22:47:22:</config>
22:47:22:Trying to access database...
22:47:22:Successfully acquired database lock
22:47:22:FS00:Initialized folding slot 00: cpu:12
22:47:22:FS01:Initialized folding slot 01: gpu:1:0 GA102 [GeForce RTX 3080 Ti]
22:47:22:WARNING:FS02:No CUDA or OpenCL 1.2+ support detected for GPU slot 02: gpu:16:0 Raphael [Ryzen 7000 Series iGPU].  Disabling.
22:47:22:WU01:FS00:Starting
22:47:22:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/gromacs-core-a9/windows-10-64bit/cpu-avx2_256-release/0xa9-0.0.12/Core_a9.fah/FahCore_a9.exe -dir 01 -suffix 01 -version 706 -lifeline 10376 -checkpoint 30 -np 12
22:47:22:WU01:FS00:Started FahCore on PID 11232
22:47:22:WU01:FS00:Core PID:1484
22:47:22:WU01:FS00:FahCore 0xa9 started
22:47:23:WU01:FS00:0xa9:*********************** Log Started 2024-03-16T22:47:22Z ***********************
22:47:23:WU01:FS00:0xa9:************************** Gromacs Folding@home Core ***************************
22:47:23:WU01:FS00:0xa9:       Core: Gromacs
22:47:23:WU01:FS00:0xa9:       Type: 0xa9
22:47:23:WU01:FS00:0xa9:    Version: 0.0.12
22:47:23:WU01:FS00:0xa9:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
22:47:23:WU01:FS00:0xa9:  Copyright: 2022 foldingathome.org
22:47:23:WU01:FS00:0xa9:   Homepage: https://foldingathome.org/
22:47:23:WU01:FS00:0xa9:       Date: Nov 15 2022
22:47:23:WU01:FS00:0xa9:       Time: 13:31:08
22:47:23:WU01:FS00:0xa9:   Compiler: Visual C++
22:47:23:WU01:FS00:0xa9:    Options: /TP /std:c++17 /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
22:47:23:WU01:FS00:0xa9:   Platform: win32 10
22:47:23:WU01:FS00:0xa9:       Bits: 64
22:47:23:WU01:FS00:0xa9:       Mode: Release
22:47:23:WU01:FS00:0xa9:       SIMD: avx2_256
22:47:23:WU01:FS00:0xa9:     OpenMP: ON
22:47:23:WU01:FS00:0xa9:       CUDA: OFF
22:47:23:WU01:FS00:0xa9:     OpenCL: OFF
22:47:23:WU01:FS00:0xa9:       Args: -dir 01 -suffix 01 -version 706 -lifeline 11232 -checkpoint 30 -np
22:47:23:WU01:FS00:0xa9:             12
22:47:23:WU01:FS00:0xa9:************************************ libFAH ************************************
22:47:23:WU01:FS00:0xa9:       Time: 13:30:33
22:47:23:WU01:FS00:0xa9:    Options: /TP /std:c++14 /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
22:47:23:WU01:FS00:0xa9:************************************ CBang *************************************
22:47:23:WU01:FS00:0xa9:       Time: 13:29:57
22:47:23:WU01:FS00:0xa9:************************************ System ************************************
22:47:23:WU01:FS00:0xa9:        CPU: AMD Ryzen 7 7800X3D 8-Core Processor
22:47:23:WU01:FS00:0xa9:     CPU ID: AuthenticAMD Family 25 Model 97 Stepping 2
22:47:23:WU01:FS00:0xa9:       CPUs: 16
22:47:23:WU01:FS00:0xa9:     Memory: 31.16GiB
22:47:23:WU01:FS00:0xa9:Free Memory: 28.30GiB
22:47:23:WU01:FS00:0xa9:    Threads: WINDOWS_THREADS
22:47:23:WU01:FS00:0xa9: OS Version: 6.2
22:47:23:WU01:FS00:0xa9:Has Battery: false
22:47:23:WU01:FS00:0xa9: On Battery: false
22:47:23:WU01:FS00:0xa9: UTC Offset: 1
22:47:23:WU01:FS00:0xa9:        PID: 1484
22:47:23:WU01:FS00:0xa9:        CWD: C:\ProgramData\FAHClient\work
22:47:23:WU01:FS00:0xa9:       Exec: C:\ProgramData\FAHClient\cores\cores.foldingathome.org\gromacs-core-a9\windows-10-64bit\cpu-avx2_256-release\0xa9-0.0.12\Core_a9.fah\FahCore_a9.exe
22:47:23:WU01:FS00:0xa9:********************************************************************************
22:47:23:WU01:FS00:0xa9:Project: 18806 (Run 34, Clone 17, Gen 154)
22:47:23:WU01:FS00:0xa9:Digital signatures verified
22:47:23:WU01:FS00:0xa9:Calling: mdrun -c frame154.gro -s frame154.tpr -x frame154.xtc -cpi state.cpt -cpt 30 -nt 12 -ntmpi 1 -update cpu -nb cpu -bonded cpu -pme cpu -pmefft cpu
22:47:23:WU01:FS00:0xa9:Steps: first=38500000 total=38750000
22:47:24:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:18220 run:225 clone:0 gen:11 core:0x23 unit:0x000000000000000b0000472c000000e1
22:47:24:WU00:FS01:Uploading 23.83MiB to 158.130.118.26
22:47:24:WU00:FS01:Connecting to 158.130.118.26:8080
22:47:27:WU01:FS00:0xa9:Completed 164162 out of 250000 steps (65%)
22:47:45:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
22:47:45:WU00:FS01:Connecting to 158.130.118.26:80
22:48:28:WU01:FS00:0xa9:Completed 165000 out of 250000 steps (66%)
22:48:33:WARNING:WU01:FS00:Detected clock skew (1 mins 09 secs), I/O delay, laptop hibernation or other slowdown noted, adjusting time estimates
22:48:33:WU02:FS01:Starting
22:48:33:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/openmm-core-23/windows-10-64bit/release/0x23-8.0.3/Core_23.fah/FahCore_23.exe -dir 02 -suffix 01 -version 706 -lifeline 10376 -checkpoint 30 -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100
22:48:33:WU02:FS01:Started FahCore on PID 4536
22:48:33:WU02:FS01:Core PID:10916
22:48:33:WU02:FS01:FahCore 0x23 started
22:48:33:WARNING:WU02:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
22:48:36:WU02:FS01:Starting
22:48:36:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/openmm-core-23/windows-10-64bit/release/0x23-8.0.3/Core_23.fah/FahCore_23.exe -dir 02 -suffix 01 -version 706 -lifeline 10376 -checkpoint 30 -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100
22:48:36:WU02:FS01:Started FahCore on PID 11780
22:48:36:WU02:FS01:Core PID:10776
22:48:36:WU02:FS01:FahCore 0x23 started
22:48:36:WARNING:WU00:FS01:Exception: Failed to send results to work server: Failed to connect to 158.130.118.26:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
22:48:36:WU00:FS01:Trying to send results to collection server
22:48:36:WU00:FS01:Uploading 23.83MiB to 158.130.118.25
22:48:36:WU00:FS01:Connecting to 158.130.118.25:8080
22:48:36:WARNING:WU02:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
22:48:57:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
22:48:57:WU00:FS01:Connecting to 158.130.118.25:80
22:49:19:ERROR:WU00:FS01:Exception: Failed to connect to 158.130.118.25:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
22:49:19:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:18220 run:225 clone:0 gen:11 core:0x23 unit:0x000000000000000b0000472c000000e1
22:49:19:WU00:FS01:Uploading 23.83MiB to 158.130.118.26
22:49:19:WU00:FS01:Connecting to 158.130.118.26:8080
22:49:36:WU02:FS01:Starting
22:49:36:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/openmm-core-23/windows-10-64bit/release/0x23-8.0.3/Core_23.fah/FahCore_23.exe -dir 02 -suffix 01 -version 706 -lifeline 10376 -checkpoint 30 -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100
22:49:36:WU02:FS01:Started FahCore on PID 3580
22:49:36:WU02:FS01:Core PID:11620
22:49:36:WU02:FS01:FahCore 0x23 started
22:49:37:WARNING:WU02:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
22:49:40:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
22:49:40:WU00:FS01:Connecting to 158.130.118.26:80
22:50:02:WARNING:WU00:FS01:Exception: Failed to send results to work server: Failed to connect to 158.130.118.26:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
22:50:02:WU00:FS01:Trying to send results to collection server
22:50:02:WU00:FS01:Uploading 23.83MiB to 158.130.118.25
22:50:02:WU00:FS01:Connecting to 158.130.118.25:8080
22:50:17:WU00:FS01:Upload 0.26%
22:50:25:WU00:FS01:Upload 9.18%
22:50:31:WU00:FS01:Upload 32.78%
22:50:36:WU02:FS01:Starting
22:50:36:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/openmm-core-23/windows-10-64bit/release/0x23-8.0.3/Core_23.fah/FahCore_23.exe -dir 02 -suffix 01 -version 706 -lifeline 10376 -checkpoint 30 -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100
22:50:36:WU02:FS01:Started FahCore on PID 8880
22:50:36:WU02:FS01:Core PID:2212
22:50:36:WU02:FS01:FahCore 0x23 started
22:50:37:WARNING:WU02:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
22:50:37:WU00:FS01:Upload 44.58%
22:50:43:WU00:FS01:Upload 67.40%
22:50:49:WU00:FS01:Upload 94.94%
22:50:51:WU00:FS01:Upload complete
22:50:51:WU00:FS01:Server responded WORK_ACK (400)
22:50:51:WU00:FS01:Final credit estimate, 287985.00 points
22:50:51:WU00:FS01:Cleaning up
22:51:31:WU01:FS00:0xa9:Completed 167500 out of 250000 steps (67%)
22:51:36:WU02:FS01:Starting
22:51:36:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/openmm-core-23/windows-10-64bit/release/0x23-8.0.3/Core_23.fah/FahCore_23.exe -dir 02 -suffix 01 -version 706 -lifeline 10376 -checkpoint 30 -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100
22:51:36:WU02:FS01:Started FahCore on PID 10320
22:51:36:WU02:FS01:Core PID:8716
22:51:36:WU02:FS01:FahCore 0x23 started
22:51:37:WARNING:WU02:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
22:51:37:WARNING:WU02:FS01:Too many errors, failing
22:51:37:WU02:FS01:Sending unit results: id:02 state:SEND error:FAILED project:18219 run:3666 clone:1 gen:10 core:0x23 unit:0x000000010000000a0000472b00000e52
22:51:37:WU02:FS01:Connecting to 158.130.118.24:8080
22:51:37:WU02:FS01:Server responded WORK_ACK (400)
22:51:37:WU02:FS01:Cleaning up
22:51:37:WU00:FS01:Connecting to assign1.foldingathome.org:80
22:51:38:WU00:FS01:Assigned to work server 158.130.118.24
22:51:38:WU00:FS01:Requesting new work unit for slot 01: gpu:1:0 GA102 [GeForce RTX 3080 Ti] from 158.130.118.24
22:51:38:WU00:FS01:Connecting to 158.130.118.24:8080
22:51:38:WU00:FS01:Downloading 23.42MiB
22:51:42:WU00:FS01:Download complete
22:51:42:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:18219 run:3793 clone:1 gen:10 core:0x23 unit:0x000000010000000a0000472b00000ed1
22:51:42:WU00:FS01:Starting
22:51:42:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/openmm-core-23/windows-10-64bit/release/0x23-8.0.3/Core_23.fah/FahCore_23.exe -dir 00 -suffix 01 -version 706 -lifeline 10376 -checkpoint 30 -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100
22:51:42:WU00:FS01:Started FahCore on PID 10620
22:51:42:WU00:FS01:Core PID:4152
22:51:42:WU00:FS01:FahCore 0x23 started
22:51:42:WU00:FS01:0x23:*********************** Log Started 2024-03-16T22:51:42Z ***********************
22:51:42:WU00:FS01:0x23:*************************** Core23 Folding@home Core ***************************
22:51:42:WU00:FS01:0x23:       Core: Core23
22:51:42:WU00:FS01:0x23:       Type: 0x23
22:51:42:WU00:FS01:0x23:    Version: 8.0.3
22:51:42:WU00:FS01:0x23:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
22:51:42:WU00:FS01:0x23:  Copyright: 2022 foldingathome.org
22:51:42:WU00:FS01:0x23:   Homepage: https://foldingathome.org/
22:51:42:WU00:FS01:0x23:       Date: Aug 3 2023
22:51:42:WU00:FS01:0x23:       Time: 08:39:06
22:51:42:WU00:FS01:0x23:   Compiler: Visual C++
22:51:42:WU00:FS01:0x23:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
22:51:42:WU00:FS01:0x23:             -DOPENMM_VERSION="\"8.0.0\""
22:51:42:WU00:FS01:0x23:   Platform: win32 10
22:51:42:WU00:FS01:0x23:       Bits: 64
22:51:42:WU00:FS01:0x23:       Mode: Release
22:51:42:WU00:FS01:0x23:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
22:51:42:WU00:FS01:0x23:             <peastman@stanford.edu>
22:51:42:WU00:FS01:0x23:       Args: -dir 00 -suffix 01 -version 706 -lifeline 10620 -checkpoint 30
22:51:42:WU00:FS01:0x23:             -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor
22:51:42:WU00:FS01:0x23:             nvidia -gpu 0 -gpu-usage 100
22:51:42:WU00:FS01:0x23:************************************ libFAH ************************************
22:51:42:WU00:FS01:0x23:       Time: 08:37:55
22:51:42:WU00:FS01:0x23:************************************ CBang *************************************
22:51:42:WU00:FS01:0x23:    Version: 1.7.2
22:51:42:WU00:FS01:0x23:        Org: Cauldron Development LLC
22:51:42:WU00:FS01:0x23:  Copyright: Cauldron Development LLC, 2003-2023
22:51:42:WU00:FS01:0x23:   Homepage: https://cauldrondevelopment.com/
22:51:42:WU00:FS01:0x23:    License: GPL 2+
22:51:42:WU00:FS01:0x23:       Time: 08:37:14
22:51:42:WU00:FS01:0x23:************************************ System ************************************
22:51:42:WU00:FS01:0x23:        CPU: AMD Ryzen 7 7800X3D 8-Core Processor
22:51:42:WU00:FS01:0x23:     CPU ID: AuthenticAMD Family 25 Model 97 Stepping 2
22:51:42:WU00:FS01:0x23:       CPUs: 16
22:51:42:WU00:FS01:0x23:     Memory: 31.16GiB
22:51:42:WU00:FS01:0x23:Free Memory: 24.51GiB
22:51:42:WU00:FS01:0x23:    Threads: WINDOWS_THREADS
22:51:42:WU00:FS01:0x23: OS Version: 6.2
22:51:42:WU00:FS01:0x23:Has Battery: false
22:51:42:WU00:FS01:0x23: On Battery: false
22:51:42:WU00:FS01:0x23: UTC Offset: 1
22:51:42:WU00:FS01:0x23:        PID: 4152
22:51:42:WU00:FS01:0x23:        CWD: C:\ProgramData\FAHClient\work
22:51:42:WU00:FS01:0x23:       Exec: C:\ProgramData\FAHClient\cores\cores.foldingathome.org\openmm-core-23\windows-10-64bit\release\0x23-8.0.3\Core_23.fah\FahCore_23.exe
22:51:42:WU00:FS01:0x23:************************************ OpenMM ************************************
22:51:42:WU00:FS01:0x23:    Version: 8.0.0
22:51:42:WU00:FS01:0x23:********************************************************************************
22:51:42:WU00:FS01:0x23:Project: 18219 (Run 3793, Clone 1, Gen 10)
22:51:42:WU00:FS01:0x23:Reading tar file core.xml
22:51:42:WU00:FS01:0x23:Reading tar file integrator.xml
22:51:42:WU00:FS01:0x23:Reading tar file state.xml.bz2
22:51:42:WU00:FS01:0x23:Reading tar file system.xml.bz2
22:51:42:WU00:FS01:0x23:Digital signatures verified
22:51:42:WU00:FS01:0x23:Folding@home GPU Core23 Folding@home Core
22:51:42:WU00:FS01:0x23:Version 8.0.3
22:51:42:WU00:FS01:0x23:  Checkpoint write interval: 25000 steps (2%) [50 total]
22:51:42:WU00:FS01:0x23:  JSON viewer frame write interval: 12500 steps (1%) [100 total]
22:51:42:WU00:FS01:0x23:  XTC frame write interval: 10000 steps (0.8%) [125 total]
22:51:42:WU00:FS01:0x23:  Global context and integrator variables write interval: disabled
22:51:43:WU00:FS01:0x23:There are 4 platforms available.
22:51:43:WU00:FS01:0x23:Platform 0: Reference
22:51:43:WU00:FS01:0x23:Platform 1: CPU
22:51:43:WU00:FS01:0x23:Platform 2: OpenCL
22:51:43:WU00:FS01:0x23:  opencl-device 0 specified
22:51:43:WU00:FS01:0x23:Platform 3: CUDA
22:51:43:WU00:FS01:0x23:  cuda-device 0 specified
22:52:04:WU00:FS01:0x23:Attempting to create CUDA context:
22:52:04:WU00:FS01:0x23:  Configuring platform CUDA
22:52:10:WU00:FS01:0x23:  Using CUDA on CUDA Platform and gpu 0
22:52:10:WU00:FS01:0x23:  GPU info: Platform: CUDA
22:52:10:WU00:FS01:0x23:  GPU info: PlatformIndex: 0
22:52:10:WU00:FS01:0x23:  GPU info: Device: NVIDIA GeForce RTX 3080 Ti
22:52:10:WU00:FS01:0x23:  GPU info: DeviceIndex: 0
22:52:10:WU00:FS01:0x23:  GPU info: Vendor: 0x10de
22:52:10:WU00:FS01:0x23:  GPU info: PCI: 01:00:00
22:52:10:WU00:FS01:0x23:  GPU info: Compute: 8.6
22:52:10:WU00:FS01:0x23:  GPU info: Driver: 12.4
22:52:10:WU00:FS01:0x23:  GPU info: GPU: true
22:52:10:WU00:FS01:0x23:Completed 0 out of 1250000 steps (0%)
22:52:11:WU00:FS01:0x23:Checkpoint completed at step 0
22:53:03:WU00:FS01:0x23:Completed 12500 out of 1250000 steps (1%)
23:03:45:26:127.0.0.1:New Web session
00:25:03:WU00:FS01:0x23:Completed 1237500 out of 1250000 steps (99%)
00:25:04:WU02:FS01:Connecting to assign1.foldingathome.org:80
00:25:05:WU02:FS01:Assigned to work server 206.223.170.146
00:25:05:WU02:FS01:Requesting new work unit for slot 01: gpu:1:0 GA102 [GeForce RTX 3080 Ti] from 206.223.170.146
00:25:05:WU02:FS01:Connecting to 206.223.170.146:8080
00:25:05:ERROR:WU02:FS01:Exception: Server did not assign work unit
00:25:05:WU02:FS01:Connecting to assign1.foldingathome.org:80
00:25:06:WU02:FS01:Assigned to work server 158.130.118.25
00:25:06:WU02:FS01:Requesting new work unit for slot 01: gpu:1:0 GA102 [GeForce RTX 3080 Ti] from 158.130.118.25
00:25:06:WU02:FS01:Connecting to 158.130.118.25:8080
00:25:07:WU02:FS01:Downloading 23.42MiB
00:25:10:WU02:FS01:Download complete
00:25:10:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:18218 run:11806 clone:1 gen:12 core:0x23 unit:0x000000010000000c0000472a00002e1e
00:25:57:WU00:FS01:0x23:Completed 1250000 out of 1250000 steps (100%)
00:25:57:WU00:FS01:0x23:Average performance: 81.5094 ns/day
00:25:58:WU00:FS01:0x23:Checkpoint completed at step 1250000
00:26:10:WU00:FS01:0x23:Saving result file ..\logfile_01.txt
00:26:10:WU00:FS01:0x23:Saving result file checkpointIntegrator.xml
00:26:10:WU00:FS01:0x23:Saving result file checkpointState.xml.bz2
00:26:10:WU00:FS01:0x23:Saving result file positions.xtc
00:26:10:WU00:FS01:0x23:Saving result file science.log
00:26:10:WU00:FS01:0x23:Saving result file xtcAtoms.csv.bz2
00:26:10:WU00:FS01:0x23:Folding@home Core Shutdown: FINISHED_UNIT
00:26:11:WU00:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
00:26:11:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:18219 run:3793 clone:1 gen:10 core:0x23 unit:0x000000010000000a0000472b00000ed1
00:26:11:WU00:FS01:Uploading 23.80MiB to 158.130.118.24
00:26:11:WU00:FS01:Connecting to 158.130.118.24:8080
00:26:11:WU02:FS01:Starting
00:26:11:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/openmm-core-23/windows-10-64bit/release/0x23-8.0.3/Core_23.fah/FahCore_23.exe -dir 02 -suffix 01 -version 706 -lifeline 10376 -checkpoint 30 -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100
00:26:11:WU02:FS01:Started FahCore on PID 13784
00:26:11:WU02:FS01:Core PID:15160
00:26:11:WU02:FS01:FahCore 0x23 started
00:26:12:WU02:FS01:0x23:*********************** Log Started 2024-03-17T00:26:11Z ***********************
00:26:12:WU02:FS01:0x23:*************************** Core23 Folding@home Core ***************************
00:26:12:WU02:FS01:0x23:       Core: Core23
00:26:12:WU02:FS01:0x23:       Type: 0x23
00:26:12:WU02:FS01:0x23:    Version: 8.0.3
00:26:12:WU02:FS01:0x23:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
00:26:12:WU02:FS01:0x23:  Copyright: 2022 foldingathome.org
00:26:12:WU02:FS01:0x23:   Homepage: https://foldingathome.org/
00:26:12:WU02:FS01:0x23:       Date: Aug 3 2023
00:26:12:WU02:FS01:0x23:       Time: 08:39:06
00:26:12:WU02:FS01:0x23:   Compiler: Visual C++
00:26:12:WU02:FS01:0x23:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
00:26:12:WU02:FS01:0x23:             -DOPENMM_VERSION="\"8.0.0\""
00:26:12:WU02:FS01:0x23:   Platform: win32 10
00:26:12:WU02:FS01:0x23:       Bits: 64
00:26:12:WU02:FS01:0x23:       Mode: Release
00:26:12:WU02:FS01:0x23:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
00:26:12:WU02:FS01:0x23:             <peastman@stanford.edu>
00:26:12:WU02:FS01:0x23:       Args: -dir 02 -suffix 01 -version 706 -lifeline 13784 -checkpoint 30
00:26:12:WU02:FS01:0x23:             -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor
00:26:12:WU02:FS01:0x23:             nvidia -gpu 0 -gpu-usage 100
00:26:12:WU02:FS01:0x23:************************************ libFAH ************************************
00:26:12:WU02:FS01:0x23:       Time: 08:37:55
00:26:12:WU02:FS01:0x23:************************************ CBang *************************************
00:26:12:WU02:FS01:0x23:    Version: 1.7.2
00:26:12:WU02:FS01:0x23:        Org: Cauldron Development LLC
00:26:12:WU02:FS01:0x23:  Copyright: Cauldron Development LLC, 2003-2023
00:26:12:WU02:FS01:0x23:   Homepage: https://cauldrondevelopment.com/
00:26:12:WU02:FS01:0x23:    License: GPL 2+
00:26:12:WU02:FS01:0x23:       Time: 08:37:14
00:26:12:WU02:FS01:0x23:************************************ System ************************************
00:26:12:WU02:FS01:0x23:        CPU: AMD Ryzen 7 7800X3D 8-Core Processor
00:26:12:WU02:FS01:0x23:     CPU ID: AuthenticAMD Family 25 Model 97 Stepping 2
00:26:12:WU02:FS01:0x23:       CPUs: 16
00:26:12:WU02:FS01:0x23:     Memory: 31.16GiB
00:26:12:WU02:FS01:0x23:Free Memory: 22.86GiB
00:26:12:WU02:FS01:0x23:    Threads: WINDOWS_THREADS
00:26:12:WU02:FS01:0x23: OS Version: 6.2
00:26:12:WU02:FS01:0x23:Has Battery: false
00:26:12:WU02:FS01:0x23: On Battery: false
00:26:12:WU02:FS01:0x23: UTC Offset: 1
00:26:12:WU02:FS01:0x23:        PID: 15160
00:26:12:WU02:FS01:0x23:        CWD: C:\ProgramData\FAHClient\work
00:26:12:WU02:FS01:0x23:       Exec: C:\ProgramData\FAHClient\cores\cores.foldingathome.org\openmm-core-23\windows-10-64bit\release\0x23-8.0.3\Core_23.fah\FahCore_23.exe
00:26:12:WU02:FS01:0x23:************************************ OpenMM ************************************
00:26:12:WU02:FS01:0x23:    Version: 8.0.0
00:26:12:WU02:FS01:0x23:********************************************************************************
00:26:12:WU02:FS01:0x23:Project: 18218 (Run 11806, Clone 1, Gen 12)
00:26:12:WU02:FS01:0x23:Reading tar file core.xml
00:26:12:WU02:FS01:0x23:Reading tar file integrator.xml
00:26:12:WU02:FS01:0x23:Reading tar file state.xml.bz2
00:26:12:WU02:FS01:0x23:Reading tar file system.xml.bz2
00:26:12:WU02:FS01:0x23:Digital signatures verified
00:26:12:WU02:FS01:0x23:Folding@home GPU Core23 Folding@home Core
00:26:12:WU02:FS01:0x23:Version 8.0.3
00:26:12:WU02:FS01:0x23:  Checkpoint write interval: 25000 steps (2%) [50 total]
00:26:12:WU02:FS01:0x23:  JSON viewer frame write interval: 12500 steps (1%) [100 total]
00:26:12:WU02:FS01:0x23:  XTC frame write interval: 10000 steps (0.8%) [125 total]
00:26:12:WU02:FS01:0x23:  Global context and integrator variables write interval: disabled
00:26:12:WU02:FS01:0x23:There are 4 platforms available.
00:26:12:WU02:FS01:0x23:Platform 0: Reference
00:26:12:WU02:FS01:0x23:Platform 1: CPU
00:26:12:WU02:FS01:0x23:Platform 2: OpenCL
00:26:12:WU02:FS01:0x23:  opencl-device 0 specified
00:26:12:WU02:FS01:0x23:Platform 3: CUDA
00:26:12:WU02:FS01:0x23:  cuda-device 0 specified
00:26:20:WU01:FS00:0xa9:Completed 242500 out of 250000 steps (97%)
00:26:29:WU00:FS01:Upload 8.66%
00:26:33:WU02:FS01:0x23:Attempting to create CUDA context:
00:26:33:WU02:FS01:0x23:  Configuring platform CUDA
00:26:40:WU02:FS01:0x23:  Using CUDA on CUDA Platform and gpu 0
00:26:40:WU02:FS01:0x23:  GPU info: Platform: CUDA
00:26:40:WU02:FS01:0x23:  GPU info: PlatformIndex: 0
00:26:40:WU02:FS01:0x23:  GPU info: Device: NVIDIA GeForce RTX 3080 Ti
00:26:40:WU02:FS01:0x23:  GPU info: DeviceIndex: 0
00:26:40:WU02:FS01:0x23:  GPU info: Vendor: 0x10de
00:26:40:WU02:FS01:0x23:  GPU info: PCI: 01:00:00
00:26:40:WU02:FS01:0x23:  GPU info: Compute: 8.6
00:26:40:WU02:FS01:0x23:  GPU info: Driver: 12.4
00:26:40:WU02:FS01:0x23:  GPU info: GPU: true
00:26:40:WU02:FS01:0x23:Completed 0 out of 1250000 steps (0%)
00:26:40:WU02:FS01:0x23:Checkpoint completed at step 0
00:26:46:WU00:FS01:Upload 8.93%
00:26:59:WU00:FS01:Upload 9.19%
00:27:10:WU00:FS01:Upload 11.03%
00:27:28:WU00:FS01:Upload 11.29%
00:27:34:WU00:FS01:Upload 24.68%
00:27:34:WU02:FS01:0x23:Completed 12500 out of 1250000 steps (1%)
00:27:40:WU00:FS01:Upload 40.43%
00:27:46:WU00:FS01:Upload 68.00%
00:27:52:WU00:FS01:Upload 75.35%
00:27:58:WU00:FS01:Upload complete
00:27:58:WU00:FS01:Server responded WORK_ACK (400)
00:27:58:WU00:FS01:Final credit estimate, 502844.00 points
00:27:58:WU00:FS01:Cleaning up
00:28:27:WU02:FS01:0x23:Completed 25000 out of 1250000 steps (2%)
00:28:28:WU02:FS01:0x23:Checkpoint completed at step 25000
BobWilliams757
Ryzen 2400G APU
32 GB DDR4-3200
MSI GTX 1660 Super Gaming X
Re: Some errors and no points from GPU workload
Post by BobWilliams757 »
If your GPU or any part of your system is unstable, FAH will find the instability. It appears that after repeated failures it returned a bad work unit as failed for 18219, 3666, 1, 10 while is was work unit 02 for folding slot 01 (GPU). This work unit completed successfully for another user, so most likely an instability in your system created the excessive errors that resulted in it failing.
But you successfully completed the other work unit, 18220, 225, 0, 11, so you may have either an intermittent issue, or one was performed without the undervolt and the other wasn't.
Keep in mind it is quite possible that an assumed "stable" setting might be stable much of the time, but since each project is different it is not stable for all projects. I had one project that would frequently toss errors and sometimes fail on my gear, while all others were rock solid. Over time I figured out that it happened more often with lower power limits, and less with higher power limits. By adjusting my minimum power settings higher, I got rid of any more of them failing IIRC. They (projects) are not all the same, and some create different loads on your components which in some cases can cause errors.
My suggestion would be to remove the undervolt you are running and watch for warnings and errors. This is easy to do in advanced control, simply click on the logs tab, then check the box for warnings and errors. You can easily see them as they pop up, if they do. Also keep track of which project(s) you get errors on. If there is a trend you can be more watchful when those projects run in hopes of finding a solution.
If any work unit errors 5 times it will fail rather than going through a constant loop of retries.
As for the clock skew error, I've had it before and it corrects itself without action. But much like you, the clocks always seem to be in sync so I'm not sure of the cause.
Fold them if you get them!
Post by calxalot »
I believe I have only seen clock skew from the system sleeping.
Besides a system sleeping, I have seen clock skew reported on a machine that had I/O stall. In this case the ribbon cable connecting the hard drive to the logic board of a laptop had gone bad, replacing the cable fixed the problem. There were reports in th system log of delayed reads and writes to the drive, and many errors recorded on the drive's SMART status of ECC errors.
Monok
Post by Monok »
Update: the issue resolved itself. All I did was re-syncing. Was that the issue? To be completely honest, I have no clue. The issue reassorbed itself after posting here and syncing, so either the sync really did something, or the poltergeist got scared of the forum. :D
About nVidia and undervolting, replying to BobWilliams757:
Thing is, Ampere cards (series 30xx nVidia) loves to consume too much wattage for small computations, and even more for big/long ones. Undervolting makes the whole series way more stable because if you don't undervolt the card will almost always go thermal throttling after a while. Even downloading MSI Afterburner and increasing the temperature and power limit to their max is a must, else the card will start throttling down at 85°, losing about 10% of the total raw power.
I've been stress-testing Ampere cards for almost two year so far (I'm an avid overclocker and I help two shops in town with overclocking services) and all of them gave me weird artifacts and issues as soon as I pushed them a little too far on computations, rendering, and even folding whenever I didn't use undervolt. I tested with F@H, stock card with power and temperature limit raised to the max but no undervolt and no overclock: average of three errors per WU, then after five hours it started to have five errors and therefore quitting the WU. As soon as I undervolted them I could do WUs for the same projects and they went just fine with 0 errors.
I've tested three more Ampere cards (one 3070, one 3080ti, one 3060) and one of them (the 3080ti) has gold standard overclocking silicone, and they all share the same issue. Undervolting is necessary on series 30xx. Overclocking stability depends on silicone and, as usual, on overclocking quality. F@H is a very fine tuned test for high overclocking, I agree.
About Ada Lovelace (series 40xx), I didn't test any card of this series on folding, but they share the necessity of undervolting in every other aspect. They are somewhat better on dealing with thermal throttling, but they still waste tons of electricity and generate too much heat for themselves, so I'd advise anyone to undervolt them.
And of course, do it at your own risk, do it only if you know what you're doing, do it if you're sure about it, do it because you read proper guides and understood the idea behind overclocking, undervolting, and everything. Do not try to go past the limits of your GPU, CPU, motherboard, cooling system, and always make sure to know when you're voiding your warranty (or not :D).
bikeaddict
Post by bikeaddict »
My folding setup previously had RTX 3050, 2x 3060, 3060 Ti, 3070 and 3070 Ti at various times. I never saw errors with stock clock and voltage. They also never thermal throttled, even at full power limit. You can get the GPU clock to boost a little higher with the fan speed increased.
Same story for my current RTX 4060 Ti, 4070 Super and 2x 4070 Ti. They are actually dramatically more efficient than all previous generations.
Overclocking is generally not recommended for folding. It only gives a couple percent more performance but a major increase in heat and power use. Some people are fanatical about efficiency and reduce the power limit or GPU clock to save power.
Folders who are serious about maximum performance use Linux rather than Windows. There is no undervolting currently supported on Linux. My own comparison of the same exact machine with Windows 10 vs. Linux showed about 6M PPD on Windows vs. 7M PPD on Linux.
Monok wrote: Sun Mar 17, 2024 12:50 am GPU is undervolted
GPU is unstable at you settings, please to not undervolt it. FAH is very sensitive with hardware stability. If you want to limit power consumption, use the Power Limit setting (in MSI Afterburner for instance) and let nVidia algorithms do the job.
BobWilliams757
Ryzen 2400G APU
32 GB DDR4-3200
calxalot wrote: Sun Mar 17, 2024 5:01 am I believe I have only seen clock skew from the system sleeping.
Joe_H wrote: Sun Mar 17, 2024 5:12 am Besides a system sleeping, I have seen clock skew reported on a machine that had I/O stall. In this case the ribbon cable connecting the hard drive to the logic board of a laptop had gone bad, replacing the cable fixed the problem. There were reports in th system log of delayed reads and writes to the drive, and many errors recorded on the drive's SMART status of ECC errors.
I've had it happen on a desktop, and never figured out why the clock skew error took place. I noticed it due to reporting abnormal PPD and the clock skew was what caused it. I had looked for errors or other anomalies in the logs and saw the clock skew error. On the next frame after the clock adjustment, PPD went back to normal.
No sleep, hibernation, I/O errors or anything else I could find when digging.
