8.3.6 runs well
promeneur
Hardware configuration: openSUSE Tumbleweed, x86_64,Asrock B760M-HDV/M.2 D4, Intel Core i3-12100, 16 GB, Intel UHD Graphics 730, NVIDIA GeForce GT 1030, Edup-Love EP-9651GS Wi-Fi Bluetooth, multicard reader USB 3.0 startech.com 35fcreadbu3, Epson XP 7100, Headset Bluetooth 3.0 Philips SHQ7300
8.3.6 runs well
Post by promeneur »
Since one week I experiment 8.3.6.
As good as the 8.3.5.
I will try the 8.3.7
you can find the latest build here
Bleeding Edge Builds
https://master.foldingathome.org/builds/fah-client/
Re: 8.3.6 runs well
Post by calxalot »
Note that bleeding edge builds are often broken.
Re: 8.3.6 runs well
calxalot wrote: Fri Mar 15, 2024 6:33 pm Note that bleeding edge builds are often broken.
...and are not public beta releases, just candidates for that.
Re: 8.3.6 runs well
Post by calxalot »
They are internal pre-alpha.
If you are not a developer or active alpha tester with a high pain tolerance, you should not use bleeding edge builds.
Re: 8.3.6 runs well
Post by calxalot »
I shortened your link to just the bleeding edge builds landing page.
I thought people should know what they're downloading.
Hope you don't mind.
