Please add NVIDIA GeForce RTX 3050 to the supported GPU list
TakuyaOkamoto
Post by TakuyaOkamoto »
Hello,
Please add NVIDIA GeForce RTX 3050 (6GB) to the supported GPU list.
This GPU is launched on February 2nd, 2024.
It has different device ID compared to 8GB version.
Thank you.
Info from GPU-Z:
10DE 2584 - 10DE 2584
*********************** Log Started 2024-03-03T05:08:21Z ***********************
05:08:21:******************************* libFAH ********************************
05:08:21:           Date: Oct 20 2020
05:08:21:           Time: 13:36:55
05:08:21:       Revision: 5ca109d295a6245e2a2f590b3d0085ad5e567aeb
05:08:21:         Branch: master
05:08:21:       Compiler: Visual C++ 2015
05:08:21:        Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
05:08:21:       Platform: win32 10
05:08:21:           Bits: 32
05:08:21:           Mode: Release
05:08:21:****************************** FAHClient ******************************
05:08:21:        Version: 7.6.21
05:08:21:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
05:08:21:      Copyright: 2020 foldingathome.org
05:08:21:       Homepage: https://foldingathome.org/
05:08:21:           Time: 13:41:04
05:08:21:       Revision: 6efbf0e138e22d3963e6a291f78dcb9c6422a278
05:08:21:           Bits: 32
05:08:21:           Args: --open-web-control
05:08:21:         Config: C:\ProgramData\FAHClient\config.xml
05:08:21:******************************** CBang ********************************
05:08:21:           Time: 11:36:18
05:08:21:       Revision: 7e4ce85225d7eaeb775e87c31740181ca603de60
05:08:21:           Bits: 32
05:08:21:******************************* System ********************************
05:08:21:            CPU: AMD Ryzen 5 4500 6-Core Processor
05:08:21:         CPU ID: AuthenticAMD Family 23 Model 96 Stepping 1
05:08:21:           CPUs: 12
05:08:21:         Memory: 31.87GiB
05:08:21:    Free Memory: 24.41GiB
05:08:21:        Threads: WINDOWS_THREADS
05:08:21:     OS Version: 6.2
05:08:21:    Has Battery: false
05:08:21:     On Battery: false
05:08:21:     UTC Offset: 9
05:08:21:            PID: 15808
05:08:21:            CWD: C:\ProgramData\FAHClient
05:08:21:  Win32 Service: false
05:08:21:             OS: Windows 10 Enterprise
05:08:21:        OS Arch: AMD64
05:08:21:           GPUs: 1
05:08:21:          GPU 0: Bus:1 Slot:0 Func:0 NVIDIA:1
05:08:21:  CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:8.6 Driver:12.4
05:08:21:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:3.0 Driver:551.52
05:08:21:***********************************************************************
05:08:21:<config>
05:08:21:  <!-- Network -->
05:08:21:  <proxy v=':8080'/>
05:08:21:
05:08:21:  <!-- User Information -->
05:08:21:  <passkey v='*****'/>
05:08:21:  <user v='TakuyaOkamoto'/>
05:08:21:
05:08:21:  <!-- Folding Slots -->
05:08:21:  <slot id='0' type='CPU'>
05:08:21:    <paused v='true'/>
05:08:21:  </slot>
05:08:21:  <slot id='1' type='GPU'>
05:08:21:    <pci-bus v='1'/>
05:08:21:    <pci-slot v='0'/>
05:08:21:  </slot>
05:08:21:</config>
05:08:21:Trying to access database...
05:08:21:Successfully acquired database lock
05:08:21:FS00:Initialized folding slot 00: cpu:10
05:08:21:WARNING:FS01:Disabling beta GPU slot 01: gpu:1:0.  Beta GPUs can be tested for no points by setting ``gpu-beta=true`` in the configuration.
Re: Please add NVIDIA GeForce RTX 3050 to the supported GPU list
In Windows, GPU-Z can tell us the Device ID. That will give them enough data to enter it in the server. Once in the server you can .update your copy
0x2584 / GA107 [GeForce RTX 3050 6GB] was added to the list of supported GPUs.
TakuyaOkamoto
Thank you for your support.
I deleted the old GPUs.txt from my computer and restarted the software.
Geforce RTX 3050 6GB is working with folding@home software.
