Integrated GFX utilization in 8.3.5
jrweiss
Post by jrweiss »
Just uninstalled 7.6 and installed 8.3.5: AMD Ryzen 7 5600G Cezanne on MSI MPG X570 gaming Plus MoBo, 32 GB RAM, MSI GTX 1050ti Aero ITX 4G. Monitor attached to Integrated GFX.
With Integrated GFX disabled, Folding on CPU and 1050ti, still see significant resource utilization and temperature rise on Integrated GFX using HWMonitor. When I enable Integrated GFX and it starts Folding also, there is marginal additional utilization and temperature rise.
Does F@H Client allow sharing of GPU resources even when one GPU is disabled? Can this be controlled?
I also cannot find a FINISH option to finish 1 work unit so I can again disable the Integrated GFX for further testing. I don't want to dump the WU...
Log:
*********************** Log Started 2024-02-28T00:48:44Z ***********************
00:48:44:I1:*********************** Folding@home Client ***********************
00:48:44:I1: Version: 8.3.5
00:48:44:I1: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
00:48:44:I1: Org: foldingathome.org
00:48:44:I1: Copyright: 2023-2024, foldingathome.org
00:48:44:I1: Homepage: https://foldingathome.org/
00:48:44:I1: License: GPL-3.0-or-later
00:48:44:I1: URL: https://beta.foldingathome.org/
00:48:44:I1: Date: Feb 14 2024
00:48:44:I1: Time: 14:09:24
00:48:44:I1: Revision: 652c05f093c7d9542ec3d2effdfa693c80a77e8d
00:48:44:I1: Branch: master
00:48:44:I1: Compiler: Visual C++
00:48:44:I1: Options: $( /TP $) /std:c++14 /nologo /EHa /wd4297 /wd4103 /O2
00:48:44:I1: /Zc:throwingNew /MT
00:48:44:I1: Platform: win32 10
00:48:44:I1: Bits: 64
00:48:44:I1: Mode: Release
00:48:44:I1: Args: --open-web-control
00:48:44:I1: Config: C:\Apps\FAH\Data\config.xml
00:48:44:I1:****************************** CBang ******************************
00:48:44:I1: Version: 1.7.2
00:48:44:I1: Org: Cauldron Development LLC
00:48:44:I1: Copyright: Cauldron Development LLC, 2003-2024
00:48:44:I1: Homepage: https://cauldrondevelopment.com/
00:48:44:I1: License: LGPL-2.1-or-later
00:48:44:I1: Time: 13:51:07
00:48:44:I1: Revision: 8f6145ef68f2c46b23df4487130e8f7e4fc8c757
00:48:44:I1:***************************** System ******************************
00:48:44:I1: CPU: AMD Ryzen 7 5700G with Radeon Graphics
00:48:44:I1: CPU ID: AuthenticAMD Family 25 Model 80 Stepping 0
00:48:44:I1: CPUs: 16
00:48:44:I1: Memory: 27.89GiB
00:48:44:I1:Free Memory: 20.33GiB
00:48:44:I1: OS Version: 10.0
00:48:44:I1:Has Battery: true
00:48:44:I1: On Battery: false
00:48:44:I1: Hostname: Menolly
00:48:44:I1: UTC Offset: -8
00:48:44:I1: PID: 2224
00:48:44:I1: CWD: C:\Apps\FAH\Data
00:48:44:I1: Exec: C:\Apps\FAH\FAHClient\FAHClient.exe
00:48:44:I1:*******************************************************************
00:48:44:I2:<config>
00:48:44:I2: <!-- Resource Settings -->
00:48:44:I2: <cpus v='8'/>
00:48:44:I2:
00:48:44:I2: <!-- User Information -->
00:48:44:I2: <passkey v='*****'/>
00:48:44:I2: <team v='3074'/>
00:48:44:I2: <user v='jrweiss'/>
00:48:44:I2:</config>
00:48:44:I1:Opening Database
00:48:44:I1:F@H ID = pZO199iIos7xijguJqOovOJKtXFhCndormNpMuYwNN0
00:48:44:I3:Loading default group
00:48:44:I3:Loading default resource group
00:48:44:I1:Listening for HTTP on 127.0.0.1:7396
00:48:44:I3:WU16:Loading work unit 16 with ID vGH6wvfFI4NzlZ-nVO5XPMx4uEARFnmOyaolLaU4-O0
00:48:44:I3:WU18:Loading work unit 18 with ID 0GyRcjftXiw2NOMllrAGluga-plAW-vMFn5WR9Z2pZY
00:48:44:I3:Loaded 2 wus.
00:48:44:I1:Started Windows systray control
00:48:44:I3:gpus = {
00:48:44:I3: "gpu:16:00:00": {
00:48:44:I3: "vendor": 4318,
00:48:44:I3: "type": "nvidia",
00:48:44:I3: "description": "NVIDIA GeForce GTX 1050 Ti",
00:48:44:I3: "uuid": "6a2602db-4cd8-0f4d-b24f-88ede339869e",
00:48:44:I3: "opencl": {"platform": 1, "device": 0, "compute": "3.0", "driver": "551.23"},
00:48:44:I3: "cuda": {"platform": 0, "device": 0, "compute": "6.1", "driver": "12.4"},
00:48:44:I3: "device": 7298,
00:48:44:I3: "supported": true
00:48:44:I3: },
00:48:44:I3: "gpu:48:00:00": {
00:48:44:I3: "vendor": 4098,
00:48:44:I3: "type": "amd",
00:48:44:I3: "description": "gfx90c",
00:48:44:I3: "opencl": {"platform": 0, "device": 0, "compute": "2.0", "driver": "3516.0"},
00:48:44:I3: "device": 5688,
00:48:44:I3: }
00:48:44:I3:}
00:48:44:I3:Connecting to node1.foldingathome.org:443
00:48:44:I1:Loaded cores/openmm-core-22/fahcore-22-windows-64bit-release-0.0.20/FahCore_22.exe
00:48:44:I1:Loaded cores/fahcore-a8-win-64bit-avx2_256-0.0.12/FahCore_a8.exe
00:48:44:I3:WU16:Running FahCore: C:\Apps\FAH\Data\cores/openmm-core-22/fahcore-22-windows-64bit-release-0.0.20/FahCore_22.exe -dir vGH6wvfFI4NzlZ-nVO5XPMx4uEARFnmOyaolLaU4-O0 -suffix 01 -version 8.3.5 -lifeline 2224 -gpu-vendor nvidia -opencl-platform 1 -opencl-device 0 -cuda-platform 0 -cuda-device 0 -gpu 0
00:48:44:I3:WU16:Started FahCore on PID 8292
00:48:44:I3:WU18:Running FahCore: C:\Apps\FAH\Data\cores/fahcore-a8-win-64bit-avx2_256-0.0.12/FahCore_a8.exe -dir 0GyRcjftXiw2NOMllrAGluga-plAW-vMFn5WR9Z2pZY -suffix 01 -version 8.3.5 -lifeline 2224 -np 7
00:48:44:I3:WU18:Started FahCore on PID 10820
00:48:44:I1:OUT1:> GET wss://node1.foldingathome.org/ws/client HTTP/1.1
00:48:45:I1:OUT1:< HTTP/1.1 101 HTTP_SWITCHING_PROTOCOLS
00:48:45:I1:Logging into node account
00:48:45:I1:WU16:*********************** Log Started 2024-02-28T00:48:45Z ***********************
00:48:45:I1:WU16:*************************** Core22 Folding@home Core ***************************
00:48:45:I1:WU16: Core: Core22
00:48:45:I1:WU16: Type: 0x22
00:48:45:I1:WU16: Version: 0.0.20
00:48:45:I1:WU16: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
00:48:45:I1:WU16: Copyright: 2020 foldingathome.org
00:48:45:I1:WU16: Homepage: https://foldingathome.org/
00:48:45:I1:WU16: Date: Jan 20 2022
00:48:45:I1:WU16: Time: 01:15:36
00:48:45:I1:WU16: Revision: 3f211b8a4346514edbff34e3cb1c0e0ec951373c
00:48:45:I1:WU16: Branch: HEAD
00:48:45:I1:WU16: Compiler: Visual C++
00:48:45:I1:WU16: Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
00:48:45:I1:WU16: -DOPENMM_VERSION="\"7.7.0\""
00:48:45:I1:WU16: Platform: win32 10
00:48:45:I1:WU16: Bits: 64
00:48:45:I1:WU16: Mode: Release
00:48:45:I1:WU16:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
00:48:45:I1:WU16: <peastman@stanford.edu>
00:48:45:I1:WU16: Args: -dir vGH6wvfFI4NzlZ-nVO5XPMx4uEARFnmOyaolLaU4-O0 -suffix 01
00:48:45:I1:WU16: -version 8.3.5 -lifeline 2224 -gpu-vendor nvidia -opencl-platform 1
00:48:45:I1:WU16: -opencl-device 0 -cuda-platform 0 -cuda-device 0 -gpu 0
00:48:45:I1:WU16:************************************ libFAH ************************************
00:48:45:I1:WU16: Time: 01:14:17
00:48:45:I1:WU16: Revision: 9f4ad694e75c2350d4bb6b8b5b769ba27e483a2f
00:48:45:I1:WU18:*********************** Log Started 2024-02-28T00:48:44Z ***********************
00:48:45:I1:WU18:************************** Gromacs Folding@home Core ***************************
00:48:45:I1:WU16:************************************ CBang *************************************
00:48:45:I1:WU18: Core: Gromacs
00:48:45:I1:WU18: Type: 0xa8
00:48:45:I1:WU16: Time: 01:13:20
00:48:45:I1:WU18: Version: 0.0.12
00:48:45:I1:WU16: Revision: ab023d155b446906d55b0f6c9a1eedeea04f7a1a
00:48:45:I1:WU18: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
00:48:45:I1:WU18: Copyright: 2020 foldingathome.org
00:48:45:I1:WU18: Homepage: https://foldingathome.org/
00:48:45:I1:WU18: Date: Jan 16 2021
00:48:45:I1:WU18: Time: 12:29:40
00:48:45:I1:WU18: Revision: c5816759c404e4b65f9f364c3d1ef554a67c4225
00:48:45:I1:WU18: Branch: master
00:48:45:I1:WU16:************************************ System ************************************
00:48:45:I1:WU18: Compiler: Visual C++ 2019 16.7
00:48:45:I1:WU16: CPU: AMD Ryzen 7 5700G with Radeon Graphics
00:48:45:I1:WU18: Options: /TP /std:c++14 /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
00:48:45:I1:WU16: CPU ID: AuthenticAMD Family 25 Model 80 Stepping 0
00:48:45:I1:WU18: Platform: win32 10
00:48:45:I1:WU16: CPUs: 16
00:48:45:I1:WU18: Bits: 64
00:48:45:I1:WU16: Memory: 27.89GiB
00:48:45:I1:WU18: Mode: Release
00:48:45:I1:WU16:Free Memory: 20.23GiB
00:48:45:I1:WU18: SIMD: avx2_256
00:48:45:I1:WU16: Threads: WINDOWS_THREADS
00:48:45:I1:WU18: OpenMP: ON
00:48:45:I1:WU16: OS Version: 6.2
00:48:45:I1:WU18: CUDA: OFF
00:48:45:I1:WU16:Has Battery: true
00:48:45:I1:WU18: Args: -dir 0GyRcjftXiw2NOMllrAGluga-plAW-vMFn5WR9Z2pZY -suffix 01
00:48:45:I1:WU16: On Battery: false
00:48:45:I1:WU18: -version 8.3.5 -lifeline 2224 -np 7
00:48:45:I1:WU16: UTC Offset: -8
00:48:45:I1:WU18:************************************ libFAH ************************************
00:48:45:I1:WU16: PID: 8292
00:48:45:I1:WU16: CWD: C:\Apps\FAH\Data\work
00:48:45:I1:WU18: Time: 11:24:13
00:48:45:I1:WU16:************************************ OpenMM ************************************
00:48:45:I1:WU16: Version: 7.7.0
00:48:45:I1:WU16:********************************************************************************
00:48:45:I1:WU16:Project: 12437 (Run 15, Clone 0, Gen 502)
00:48:45:I1:WU16:Digital signatures verified
00:48:45:I1:WU16:Folding@home GPU Core22 Folding@home Core
00:48:45:I1:WU16:Version 0.0.20
00:48:45:I1:WU16: Checkpoint write interval: 50000 steps (2%) [50 total]
00:48:45:I1:WU18:************************************ CBang *************************************
00:48:45:I1:WU16: JSON viewer frame write interval: 25000 steps (1%) [100 total]
00:48:45:I1:WU16: XTC frame write interval: 500000 steps (20%) [5 total]
00:48:45:I1:WU18: Time: 11:23:53
00:48:45:I1:WU16: Global context and integrator variables write interval: disabled
00:48:45:I1:WU16:There are 4 platforms available.
00:48:45:I1:WU16:Platform 0: Reference
00:48:45:I1:WU16:Platform 1: CPU
00:48:45:I1:WU16:Platform 2: OpenCL
00:48:45:I1:WU16: opencl-device 0 specified
00:48:45:I1:WU16:Platform 3: CUDA
00:48:45:I1:WU16: cuda-device 0 specified
00:48:45:I1:WU18:************************************ System ************************************
00:48:45:I1:WU18: CPU: AMD Ryzen 7 5700G with Radeon Graphics
00:48:45:I1:WU18: CPU ID: AuthenticAMD Family 25 Model 80 Stepping 0
00:48:45:I1:WU18: CPUs: 16
00:48:45:I1:WU18: Memory: 27.89GiB
00:48:45:I1:WU18:Free Memory: 20.22GiB
00:48:45:I1:WU18: Threads: WINDOWS_THREADS
00:48:45:I1:WU18: OS Version: 6.2
00:48:45:I1:WU18:Has Battery: true
00:48:45:I1:WU18: On Battery: false
00:48:45:I1:WU18: UTC Offset: -8
00:48:45:I1:WU18: PID: 10820
00:48:45:I1:WU18: CWD: C:\Apps\FAH\Data\work
00:48:45:I1:WU18:********************************************************************************
00:48:45:I1:WU18:Project: 12435 (Run 5, Clone 107, Gen 114)
00:48:45:I1:WU18:Unit: 0x00000000000000000000000000000000
00:48:45:I1:WU18:Digital signatures verified
00:48:45:I1:WU18:Calling: mdrun -c frame114.gro -s frame114.tpr -x frame114.xtc -cpi state.cpt -cpt 5 -nt 7 -ntmpi 1
00:48:45:I1:WU18:Steps: first=285000000 total=287500000
00:48:45:I1:WU18:Completed 33102 out of 2500000 steps (1%)
00:48:50:I1:WU16:Attempting to create CUDA context:
00:48:50:I1:WU16: Configuring platform CUDA
00:48:51:I1:WU16: Using CUDA and gpu 0
00:48:51:I1:WU16:Completed 1400000 out of 2500000 steps (56%)
00:49:41:I1:Default:Added new work unit: cpus:0 gpus:gpu:48:00:00
00:49:41:I1:WU19:Requesting WU assignment for user jrweiss team 3074
00:49:41:I3:Connecting to assign1.foldingathome.org:443
00:49:41:I1:OUT4:> POST https://assign1.foldingathome.org/api/assign HTTP/1.1
00:49:41:I1:OUT4:< HTTP/1.1 200 HTTP_OK
00:49:41:I1:WU19:Received WU assignment sWtCRDJJv9qUGR_szDUccrjJPsvvJfm-19Lh3pEEX8E
00:49:41:I1:WU19:Downloading WU
00:49:41:I3:Connecting to vav19.fah.temple.edu:443
00:49:41:I1:WU18:WARNING:Console control signal 1 on PID 10820
00:49:41:I1:WU18:Exiting, please wait. . .
00:49:41:I1:OUT5:> POST https://vav19.fah.temple.edu/api/assign HTTP/1.1
00:49:41:I1:WU18:Folding@home Core Shutdown: INTERRUPTED
00:49:42:I1:WU18:Core returned INTERRUPTED (102)
00:49:42:I3:WU18:Running FahCore: C:\Apps\FAH\Data\cores/fahcore-a8-win-64bit-avx2_256-0.0.12/FahCore_a8.exe -dir 0GyRcjftXiw2NOMllrAGluga-plAW-vMFn5WR9Z2pZY -suffix 01 -version 8.3.5 -lifeline 2224 -np 6
00:49:42:I3:WU18:Started FahCore on PID 4044
00:49:43:I1:WU18:*********************** Log Started 2024-02-28T00:49:42Z ***********************
00:49:43:I1:WU18:************************** Gromacs Folding@home Core ***************************
00:49:43:I1:WU18: Core: Gromacs
00:49:43:I1:WU18: Type: 0xa8
00:49:43:I1:WU18: Version: 0.0.12
00:49:43:I1:WU18: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
00:49:43:I1:WU18: Copyright: 2020 foldingathome.org
00:49:43:I1:WU18: Homepage: https://foldingathome.org/
00:49:43:I1:WU18: Date: Jan 16 2021
00:49:43:I1:WU18: Time: 12:29:40
00:49:43:I1:WU18: Revision: c5816759c404e4b65f9f364c3d1ef554a67c4225
00:49:43:I1:WU18: Branch: master
00:49:43:I1:WU18: Compiler: Visual C++ 2019 16.7
00:49:43:I1:WU18: Options: /TP /std:c++14 /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
00:49:43:I1:WU18: Platform: win32 10
00:49:43:I1:WU18: Bits: 64
00:49:43:I1:WU18: Mode: Release
00:49:43:I1:WU18: SIMD: avx2_256
00:49:43:I1:WU18: OpenMP: ON
00:49:43:I1:WU18: CUDA: OFF
00:49:43:I1:WU18: Args: -dir 0GyRcjftXiw2NOMllrAGluga-plAW-vMFn5WR9Z2pZY -suffix 01
00:49:43:I1:WU18: -version 8.3.5 -lifeline 2224 -np 6
00:49:43:I1:WU18:************************************ libFAH ************************************
00:49:43:I1:WU18: Time: 11:24:13
00:49:43:I1:WU18:************************************ CBang *************************************
00:49:43:I1:WU18: Time: 11:23:53
00:49:43:I1:WU18:************************************ System ************************************
00:49:43:I1:WU18: CPU: AMD Ryzen 7 5700G with Radeon Graphics
00:49:43:I1:WU18: CPU ID: AuthenticAMD Family 25 Model 80 Stepping 0
00:49:43:I1:WU18: CPUs: 16
00:49:43:I1:WU18: Memory: 27.89GiB
00:49:43:I1:WU18:Free Memory: 19.81GiB
00:49:43:I1:WU18: Threads: WINDOWS_THREADS
00:49:43:I1:WU18: OS Version: 6.2
00:49:43:I1:WU18:Has Battery: true
00:49:43:I1:WU18: On Battery: false
00:49:43:I1:WU18: UTC Offset: -8
00:49:43:I1:WU18: PID: 4044
00:49:43:I1:WU18: CWD: C:\Apps\FAH\Data\work
00:49:43:I1:WU18:********************************************************************************
00:49:43:I1:WU18:Project: 12435 (Run 5, Clone 107, Gen 114)
00:49:43:I1:WU18:Unit: 0x00000000000000000000000000000000
00:49:43:I1:WU18:Digital signatures verified
00:49:43:I1:WU18:Calling: mdrun -c frame114.gro -s frame114.tpr -x frame114.xtc -cpi state.cpt -cpt 5 -nt 6 -ntmpi 1
00:49:43:I1:WU18:Steps: first=285000000 total=287500000
00:49:43:I1:WU18:Completed 47002 out of 2500000 steps (1%)
00:49:43:I1:OUT5:< HTTP/1.1 200 HTTP_OK
00:49:43:I1:WU19:Received WU
00:49:44:I3:WU19:Running FahCore: C:\Apps\FAH\Data\cores/openmm-core-22/fahcore-22-windows-64bit-release-0.0.20/FahCore_22.exe -dir sWtCRDJJv9qUGR_szDUccrjJPsvvJfm-19Lh3pEEX8E -suffix 01 -version 8.3.5 -lifeline 2224 -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
00:49:44:I3:WU19:Started FahCore on PID 6656
00:49:44:I1:WU19:*********************** Log Started 2024-02-28T00:49:44Z ***********************
00:49:44:I1:WU19:*************************** Core22 Folding@home Core ***************************
00:49:44:I1:WU19: Core: Core22
00:49:44:I1:WU19: Type: 0x22
00:49:44:I1:WU19: Version: 0.0.20
00:49:44:I1:WU19: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
00:49:44:I1:WU19: Copyright: 2020 foldingathome.org
00:49:44:I1:WU19: Homepage: https://foldingathome.org/
00:49:44:I1:WU19: Date: Jan 20 2022
00:49:44:I1:WU19: Time: 01:15:36
00:49:44:I1:WU19: Revision: 3f211b8a4346514edbff34e3cb1c0e0ec951373c
00:49:44:I1:WU19: Branch: HEAD
00:49:44:I1:WU19: Compiler: Visual C++
00:49:44:I1:WU19: Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
00:49:44:I1:WU19: -DOPENMM_VERSION="\"7.7.0\""
00:49:44:I1:WU19: Platform: win32 10
00:49:44:I1:WU19: Bits: 64
00:49:44:I1:WU19: Mode: Release
00:49:44:I1:WU19:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
00:49:44:I1:WU19: <peastman@stanford.edu>
00:49:44:I1:WU19: Args: -dir sWtCRDJJv9qUGR_szDUccrjJPsvvJfm-19Lh3pEEX8E -suffix 01
00:49:44:I1:WU19: -version 8.3.5 -lifeline 2224 -gpu-vendor amd -opencl-platform 0
00:49:44:I1:WU19: -opencl-device 0 -gpu 0
00:49:44:I1:WU19:************************************ libFAH ************************************
00:49:44:I1:WU19: Time: 01:14:17
00:49:44:I1:WU19: Revision: 9f4ad694e75c2350d4bb6b8b5b769ba27e483a2f
00:49:44:I1:WU19:************************************ CBang *************************************
00:49:44:I1:WU19: Time: 01:13:20
00:49:44:I1:WU19: Revision: ab023d155b446906d55b0f6c9a1eedeea04f7a1a
00:49:44:I1:WU19:************************************ System ************************************
00:49:44:I1:WU19: CPU: AMD Ryzen 7 5700G with Radeon Graphics
00:49:44:I1:WU19: CPU ID: AuthenticAMD Family 25 Model 80 Stepping 0
00:49:44:I1:WU19: CPUs: 16
00:49:44:I1:WU19: Memory: 27.89GiB
00:49:44:I1:WU19:Free Memory: 19.75GiB
00:49:44:I1:WU19: Threads: WINDOWS_THREADS
00:49:44:I1:WU19: OS Version: 6.2
00:49:44:I1:WU19:Has Battery: true
00:49:44:I1:WU19: On Battery: false
00:49:44:I1:WU19: UTC Offset: -8
00:49:44:I1:WU19: PID: 6656
00:49:44:I1:WU19: CWD: C:\Apps\FAH\Data\work
00:49:44:I1:WU19:************************************ OpenMM ************************************
00:49:44:I1:WU19: Version: 7.7.0
00:49:44:I1:WU19:********************************************************************************
00:49:44:I1:WU19:Project: 18454 (Run 10, Clone 29, Gen 905)
00:49:44:I1:WU19:Reading tar file core.xml
00:49:44:I1:WU19:Reading tar file integrator.xml
00:49:44:I1:WU19:Reading tar file state.xml
00:49:44:I1:WU19:Reading tar file system.xml
00:49:44:I1:WU19:Digital signatures verified
00:49:44:I1:WU19:Folding@home GPU Core22 Folding@home Core
00:49:44:I1:WU19:Version 0.0.20
00:49:44:I1:WU19: Checkpoint write interval: 100000 steps (2%) [50 total]
00:49:44:I1:WU19: JSON viewer frame write interval: 50000 steps (1%) [100 total]
00:49:44:I1:WU19: XTC frame write interval: 500000 steps (10%) [10 total]
00:49:44:I1:WU19: Global context and integrator variables write interval: disabled
00:49:44:I1:WU19:There are 3 platforms available.
00:49:44:I1:WU19:Platform 0: Reference
00:49:44:I1:WU19:Platform 1: CPU
00:49:44:I1:WU19:Platform 2: OpenCL
00:49:44:I1:WU19: opencl-device 0 specified
00:49:47:I1:WU19:Attempting to create OpenCL context:
00:49:47:I1:WU19: Configuring platform OpenCL
00:49:51:I1:WU19: Using OpenCL on platformId 0 and gpu 0
00:49:51:I1:WU19:Completed 0 out of 5000000 steps (0%)
00:49:52:I1:WU19:Checkpoint completed at step 0
00:49:56:I1:WU18:Completed 50000 out of 2500000 steps (2%)
Re: Integrated GFX utilization in 8.3.5
Post by calxalot »
If you click the pause button, you get a dialog box to finish and pause or pause now.
jrweiss
Post by jrweiss »
Pause appears to work only globally, not for a single WU.
Post by calxalot »
Correct. Unless you use resource groups.
See guide section Advanced:
https://foldingathome.org/v8-3-client-guide/
