No WU for Intel HD 520
mr-victory
Post by mr-victory »
A few years ago Intel HD 520 was asigned benchmark WUs which I used for stress testing. Now I set up the iGPU again but no WUs are assigned. The GPU appears in web panel as "ready" but there is no WU info. Is beta testing for Intel iGPUs discontinued?
I currently paused folding because there isn't a "fold with GPU, pause the CPU" option on the web interface.
Config:
<config>
  <gpu-beta v='true'/>
  <!-- Slot Control -->
  <power v='FULL'/>
  <!-- User Information -->
  <team v='45032'/>
  <user v='mr-victory'/>
  <!-- Folding Slots -->
  <slot id='0' type='CPU'/>
  <slot id='1' type='GPU'>
    <pci-bus v='0'/>
    <pci-slot v='2'/>
  </slot>
</config>
Log:
*********************** Log Started 2024-02-25T15:50:45Z ***********************
15:50:45:******************************* libFAH ********************************
15:50:45:           Date: Oct 20 2020
15:50:45:           Time: 20:36:39
15:50:45:       Revision: 5ca109d295a6245e2a2f590b3d0085ad5e567aeb
15:50:45:         Branch: master
15:50:45:       Compiler: GNU 8.3.0
15:50:45:        Options: -faligned-new -std=c++11 -fsigned-char -ffunction-sections
15:50:45:                 -fdata-sections -O3 -funroll-loops -fno-pie
15:50:45:       Platform: linux2 5.8.0-1-amd64
15:50:45:           Bits: 64
15:50:45:           Mode: Release
15:50:45:****************************** FAHClient ******************************
15:50:45:        Version: 7.6.21
15:50:45:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
15:50:45:      Copyright: 2020 foldingathome.org
15:50:45:       Homepage: https://foldingathome.org/
15:50:45:           Time: 20:39:00
15:50:45:       Revision: 6efbf0e138e22d3963e6a291f78dcb9c6422a278
15:50:45:           Bits: 64
15:50:45:           Args: --config /etc/foldingathome/config.xml --log
15:50:45:                 /var/log/foldingathome/log.txt --log-rotate-dir
15:50:45:         Config: /etc/foldingathome/config.xml
15:50:45:******************************** CBang ********************************
15:50:45:           Time: 18:37:59
15:50:45:       Revision: 7e4ce85225d7eaeb775e87c31740181ca603de60
15:50:45:                 -fdata-sections -O3 -funroll-loops -fno-pie -fPIC
15:50:45:           Bits: 64
15:50:45:******************************* System ********************************
15:50:45:            CPU: Intel(R) Core(TM) i3-6100U CPU @ 2.30GHz
15:50:45:         CPU ID: GenuineIntel Family 6 Model 78 Stepping 3
15:50:45:           CPUs: 4
15:50:45:         Memory: 7.64GiB
15:50:45:    Free Memory: 2.69GiB
15:50:45:        Threads: POSIX_THREADS
15:50:45:     OS Version: 6.6
15:50:45:    Has Battery: false
15:50:45:     On Battery: false
15:50:45:     UTC Offset: 3
15:50:45:            PID: 6065
15:50:45:            CWD: /var/lib/private/fah
15:50:45:             OS: Linux 6.6.1-zen1-1-zen x86_64
15:50:45:        OS Arch: AMD64
15:50:45:           GPUs: 1
15:50:45:          GPU 0: Bus:0 Slot:2 Func:0 INTEL:1 SKL GT2 [HD Graphics 520]
15:50:45:           CUDA: Not detected: Failed to open dynamic library 'libcuda.so':
15:50:45:                 libcuda.so: cannot open shared object file: No such file or
15:50:45:                 directory
15:50:45:OpenCL Device 0: Platform:0 Device:0 Bus:NA Slot:NA Compute:3.0 Driver:23.22
15:50:45:***********************************************************************
15:50:45:<config>
15:50:45:  <!-- Folding Slot Configuration -->
15:50:45:  <gpu-beta v='true'/>
15:50:45:
15:50:45:  <!-- Slot Control -->
15:50:45:  <power v='FULL'/>
15:50:45:
15:50:45:  <!-- User Information -->
15:50:45:  <user v='anonymous'/>
15:50:45:
15:50:45:  <!-- Folding Slots -->
15:50:45:  <slot id='0' type='CPU'>
15:50:45:    <paused v='true'/>
15:50:45:  </slot>
15:50:45:  <slot id='1' type='GPU'>
15:50:45:    <pci-bus v='0'/>
15:50:45:    <pci-slot v='2'/>
15:50:45:  </slot>
15:50:45:</config>
15:50:45:Trying to access database...
15:50:45:Successfully acquired database lock
15:50:45:FS00:Initialized folding slot 00: cpu:3
15:50:45:WARNING:FS01:Guessing ambiguous GPU to OpenCL device mapping for 01: gpu:0:2 SKL GT2 [HD Graphics 520].  Consider upgrading your graphics driver or manually setting ``opencl-index`` in this slot's configuration.
15:50:45:FS01:Initialized folding slot 01: gpu:0:2 SKL GT2 [HD Graphics 520]
15:50:47:17:127.0.0.1:New Web session
15:53:39:Saving configuration to /etc/foldingathome/config.xml
15:53:39:<config>
15:53:39:  <!-- Folding Slot Configuration -->
15:53:39:  <gpu-beta v='true'/>
15:53:39:
15:53:39:  <!-- Slot Control -->
15:53:39:  <power v='FULL'/>
15:53:39:
15:53:39:  <!-- User Information -->
15:53:39:  <team v='45032'/>
15:53:39:  <user v='mr-victory'/>
15:53:39:
15:53:39:  <!-- Folding Slots -->
15:53:39:  <slot id='0' type='CPU'>
15:53:39:    <paused v='true'/>
15:53:39:  </slot>
15:53:39:  <slot id='1' type='GPU'>
15:53:39:    <pci-bus v='0'/>
15:53:39:    <pci-slot v='2'/>
15:53:39:  </slot>
15:53:39:</config>
16:00:15:44:127.0.0.1:New Web session
16:05:15:57:127.0.0.1:New Web session
16:07:31:66:127.0.0.1:New Web session
16:12:48:77:127.0.0.1:New Web session
16:14:53:85:127.0.0.1:New Web session
16:16:12:FS00:Unpaused
16:16:12:FS01:Unpaused
16:16:13:WU00:FS00:Starting
16:16:13:WARNING:WU00:FS00:AS lowered CPUs from 3 to 2
16:16:13:WU00:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/private/fah/cores/cores.foldingathome.org/lin/64bit-avx2-256/a8-0.0.12/Core_a8.fah/FahCore_a8 -dir 00 -suffix 01 -version 706 -lifeline 6065 -checkpoint 15 -np 2
16:16:13:WU00:FS00:Started FahCore on PID 13260
16:16:13:WU00:FS00:Core PID:13264
16:16:13:WU00:FS00:FahCore 0xa8 started
16:16:13:WU01:FS01:Connecting to assign1.foldingathome.org:80
16:16:13:WU00:FS00:0xa8:*********************** Log Started 2024-02-25T16:16:13Z ***********************
16:16:13:WU00:FS00:0xa8:************************** Gromacs Folding@home Core ***************************
16:16:13:WU00:FS00:0xa8:       Core: Gromacs
16:16:13:WU00:FS00:0xa8:       Type: 0xa8
16:16:13:WU00:FS00:0xa8:    Version: 0.0.12
16:16:13:WU00:FS00:0xa8:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
16:16:13:WU00:FS00:0xa8:  Copyright: 2020 foldingathome.org
16:16:13:WU00:FS00:0xa8:   Homepage: https://foldingathome.org/
16:16:13:WU00:FS00:0xa8:       Date: Jan 16 2021
16:16:13:WU00:FS00:0xa8:       Time: 19:24:44
16:16:13:WU00:FS00:0xa8:   Compiler: GNU 8.3.0
16:16:13:WU00:FS00:0xa8:    Options: -faligned-new -std=c++14 -fsigned-char -ffunction-sections
16:16:13:WU00:FS00:0xa8:             -fdata-sections -O3 -funroll-loops -fno-pie
16:16:13:WU00:FS00:0xa8:   Platform: linux2 4.15.0-128-generic
16:16:13:WU00:FS00:0xa8:       Bits: 64
16:16:13:WU00:FS00:0xa8:       Mode: Release
16:16:13:WU00:FS00:0xa8:       SIMD: avx2_256
16:16:13:WU00:FS00:0xa8:     OpenMP: ON
16:16:13:WU00:FS00:0xa8:       CUDA: OFF
16:16:13:WU00:FS00:0xa8:       Args: -dir 00 -suffix 01 -version 706 -lifeline 13260 -checkpoint 15 -np
16:16:13:WU00:FS00:0xa8:             2
16:16:13:WU00:FS00:0xa8:************************************ libFAH ************************************
16:16:13:WU00:FS00:0xa8:       Time: 19:21:38
16:16:13:WU00:FS00:0xa8:************************************ CBang *************************************
16:16:13:WU00:FS00:0xa8:       Time: 19:21:24
16:16:13:WU00:FS00:0xa8:             -fdata-sections -O3 -funroll-loops -fno-pie -fPIC
16:16:13:WU00:FS00:0xa8:************************************ System ************************************
16:16:13:WU00:FS00:0xa8:        CPU: Intel(R) Core(TM) i3-6100U CPU @ 2.30GHz
16:16:13:WU00:FS00:0xa8:     CPU ID: GenuineIntel Family 6 Model 78 Stepping 3
16:16:13:WU00:FS00:0xa8:       CPUs: 4
16:16:13:WU00:FS00:0xa8:     Memory: 7.64GiB
16:16:13:WU00:FS00:0xa8:Free Memory: 1.55GiB
16:16:13:WU00:FS00:0xa8:    Threads: POSIX_THREADS
16:16:13:WU00:FS00:0xa8: OS Version: 6.6
16:16:13:WU00:FS00:0xa8:Has Battery: false
16:16:13:WU00:FS00:0xa8: On Battery: false
16:16:13:WU00:FS00:0xa8: UTC Offset: 3
16:16:13:WU00:FS00:0xa8:        PID: 13264
16:16:13:WU00:FS00:0xa8:        CWD: /var/lib/private/fah/work
16:16:13:WU00:FS00:0xa8:********************************************************************************
16:16:13:WU00:FS00:0xa8:Project: 18428 (Run 20, Clone 44, Gen 111)
16:16:13:WU00:FS00:0xa8:Unit: 0x00000000000000000000000000000000
16:16:13:WU00:FS00:0xa8:Digital signatures verified
16:16:13:WU00:FS00:0xa8:Calling: mdrun -c frame111.gro -s frame111.tpr -x frame111.xtc -cpi state.cpt -cpt 15 -nt 2 -ntmpi 1
16:16:13:WU00:FS00:0xa8:Steps: first=277500000 total=280000000
16:16:14:WARNING:WU01:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
16:16:14:WU01:FS01:Connecting to assign2.foldingathome.org:80
16:16:14:WARNING:WU01:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
16:16:14:WU01:FS01:Connecting to assign3.foldingathome.org:80
16:16:14:WU00:FS00:0xa8:Completed 5752 out of 2500000 steps (0%)
16:16:15:WARNING:WU01:FS01:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
16:16:15:WU01:FS01:Connecting to assign4.foldingathome.org:80
16:16:16:WARNING:WU01:FS01:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
16:16:16:ERROR:WU01:FS01:Exception: Could not get an assignment
16:16:16:WU01:FS01:Connecting to assign1.foldingathome.org:80
16:16:17:WARNING:WU01:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
16:16:17:WU01:FS01:Connecting to assign2.foldingathome.org:80
16:16:18:WARNING:WU01:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
16:16:18:WU01:FS01:Connecting to assign3.foldingathome.org:80
16:16:18:WARNING:WU01:FS01:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
16:16:18:WU01:FS01:Connecting to assign4.foldingathome.org:80
16:16:19:WARNING:WU01:FS01:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
16:16:19:ERROR:WU01:FS01:Exception: Could not get an assignment
16:17:02:Saving configuration to /etc/foldingathome/config.xml
16:17:02:<config>
16:17:02:  <!-- Folding Slot Configuration -->
16:17:02:  <gpu-beta v='true'/>
16:17:02:
16:17:02:  <!-- Slot Control -->
16:17:02:  <power v='FULL'/>
16:17:02:
16:17:02:  <!-- User Information -->
16:17:02:  <team v='45032'/>
16:17:02:  <user v='mr-victory'/>
16:17:02:
16:17:02:  <!-- Folding Slots -->
16:17:02:  <slot id='0' type='CPU'/>
16:17:02:  <slot id='1' type='GPU'>
16:17:02:    <pci-bus v='0'/>
16:17:02:    <pci-slot v='2'/>
16:17:02:  </slot>
16:17:02:</config>
16:17:17:WU01:FS01:Connecting to assign1.foldingathome.org:80
16:17:18:WARNING:WU01:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
16:17:18:WU01:FS01:Connecting to assign2.foldingathome.org:80
16:17:19:WARNING:WU01:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
16:17:19:WU01:FS01:Connecting to assign3.foldingathome.org:80
16:17:20:WARNING:WU01:FS01:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
16:17:20:WU01:FS01:Connecting to assign4.foldingathome.org:80
16:17:20:WARNING:WU01:FS01:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
16:17:20:ERROR:WU01:FS01:Exception: Could not get an assignment
16:17:22:FS00:Paused
16:17:22:FS01:Paused
16:17:23:FS00:Shutting core down
16:17:23:WU00:FS00:0xa8:Caught signal SIGINT(2) on PID 13264
16:17:23:WU00:FS00:0xa8:Exiting, please wait. . .
16:17:24:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
16:18:03:Saving configuration to /etc/foldingathome/config.xml
16:18:03:<config>
16:18:03:  <!-- Folding Slot Configuration -->
16:18:03:  <gpu-beta v='true'/>
16:18:03:
16:18:03:  <!-- Slot Control -->
16:18:03:  <power v='FULL'/>
16:18:03:
16:18:03:  <!-- User Information -->
16:18:03:  <team v='45032'/>
16:18:03:  <user v='mr-victory'/>
16:18:03:
16:18:03:  <!-- Folding Slots -->
16:18:03:  <slot id='0' type='CPU'>
16:18:03:    <paused v='true'/>
16:18:03:  </slot>
16:18:03:  <slot id='1' type='GPU'>
16:18:03:    <pci-bus v='0'/>
16:18:03:    <pci-slot v='2'/>
16:18:03:  </slot>
16:18:03:</config>
Re: No WU for Intel HD 520
Here's a summary about Intel GPUs :
  • iGPUs : work well but too weak for most FAH projects
  • dGPUs : no hardware FP64 support and last time it was tried, software emulation wasn't reliable enough for FAH
Post by calxalot »
You can control slots individually via FAHControl
