8.3.5 versus 7.6
thiblec71
8.3.5 versus 7.6
Post by thiblec71 »
Is the version 8.3.5 folding faster than 7.6 on Ubuntu?
Re: 8.3.5 versus 7.6
No.
The client doesn't do any of the actual folding work, just handles WU downloads and uploads and provides monitoring and control functions. The actual work is done by the downloaded folding cores and v8 uses the same ones as v7.
Post by calxalot »
V8 is faster on Apple Silicon, because the client and cores are compiled native.
jonault
Post by jonault »
Are there GPU cores for Apple Silicon now, or is Mac folding still CPU only?
Post by calxalot »
Still no GPU folding on macOS.
OpenMM now has a Metal3 plugin, but I don't think anyone has tried to build a mac fahcore, let alone tested it.
The client would need code to look for and whitelist Metal gpus.
There might also be different args to pass to such a core.
Don't hold your breath. It may never happen.
thiblec71
Post by thiblec71 »
Thanks for your answers. I thought it was an update of the client and the core.
calxalot wrote: Fri Feb 23, 2024 9:03 pm V8 is faster on Apple Silicon, because the client and cores are compiled native.
To clarify, the v7 client doe not have the necessary options to identify an Apple Silicon processor to the Assignment and Work Servers to download the native core. So the Intel core ends up being downloaded and used when a CPU WU is processed with the v7 client running on macOS. It does work well with a large fraction of the performance of the native core while running under Rosetta 2.
Post by calxalot »
With bonus points, the difference in PPD can be significant.
I’m not running v7 anymore, and projects vary wildly. But I believe I’m getting +25% PPD vs intel cores under Rosetta.
favrepeoria
Post by favrepeoria »
calxalot wrote: Sun Feb 25, 2024 2:25 am With bonus points, the difference in PPD can be significant.
I can confirm the difference between similar projects from V7 to V8 on a M2 Mac mini is 48% increased PPD so nothing to laugh at. I will track it a bit more but my last V7 and first V8 project were the same so it is likely as close to 1:1 as possible.
Demmers
Post by Demmers »
favrepeoria wrote: Thu Apr 25, 2024 12:40 am
I'm thinking of getting the new M4 Mini, so of course i'm wondering what the WU/PPD looks like. I see you mention using the M2 Mini, and just had a look at your numbers in https://folding.extremeoverclocking.com ... =&u=930268 Surely they're not from just that one machine?!
favrepeoria
Demmers wrote: Tue Nov 26, 2024 10:29 pm
Oh no not from one machine. I have a couple machines running various hardware. I have one M2 mini, a Ryzen 7700 machine, 5950x machine, and the kicker is a 4070 super. That does the vast majority of the points. Range of 12 to 14 million ppd there. The mini does 180k or so, 7700 does 650k, 5950x does 500k.
