Re: log file posting.
sweldon001
log file posting.
Post by sweldon001 »
*********************** Log Started 2024-02-06T13:43:35Z ***********************
13:43:35:******************************* libFAH ********************************
13:43:35:           Date: Oct 20 2020
13:43:35:           Time: 13:36:55
13:43:35:       Revision: 5ca109d295a6245e2a2f590b3d0085ad5e567aeb
13:43:35:         Branch: master
13:43:35:       Compiler: Visual C++ 2015
13:43:35:        Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
13:43:35:       Platform: win32 10
13:43:35:           Bits: 32
13:43:35:           Mode: Release
13:43:35:****************************** FAHClient ******************************
13:43:35:        Version: 7.6.21
13:43:35:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
13:43:35:      Copyright: 2020 foldingathome.org
13:43:35:       Homepage: https://foldingathome.org/
13:43:35:           Time: 13:41:04
13:43:35:       Revision: 6efbf0e138e22d3963e6a291f78dcb9c6422a278
13:43:35:           Bits: 32
13:43:35:           Args: --open-web-control
13:43:35:         Config: C:\ProgramData\FAHClient\config.xml
13:43:35:******************************** CBang ********************************
13:43:35:           Time: 11:36:18
13:43:35:       Revision: 7e4ce85225d7eaeb775e87c31740181ca603de60
13:43:35:           Bits: 32
13:43:35:******************************* System ********************************
13:43:35:            CPU: AMD Ryzen 9 7900X 12-Core Processor
13:43:35:         CPU ID: AuthenticAMD Family 25 Model 97 Stepping 2
13:43:35:           CPUs: 24
13:43:35:         Memory: 31.71GiB
13:43:35:    Free Memory: 18.75GiB
13:43:35:        Threads: WINDOWS_THREADS
13:43:35:     OS Version: 6.2
13:43:35:    Has Battery: true
13:43:35:     On Battery: false
13:43:35:     UTC Offset: -5
13:43:35:            PID: 4544
13:43:35:            CWD: C:\ProgramData\FAHClient
13:43:35:  Win32 Service: false
13:43:35:             OS: Windows 10 Enterprise
13:43:35:        OS Arch: AMD64
13:43:35:           GPUs: 1
13:43:35:          GPU 0: Bus:1 Slot:0 Func:0 NVIDIA:9 AD104 [GeForce RTX 4070]
13:43:35:  CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:8.9 Driver:12.3
13:43:35:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:3.0 Driver:546.33
13:43:35:***********************************************************************
Reason: added code tags to log
sweldon001
13:43:35:<config>
13:43:35:  <!-- Folding Slot Configuration -->
13:43:35:  <cause v='COVID_19'/>
13:43:35:
13:43:35:  <!-- Network -->
13:43:35:  <proxy v=':8080'/>
13:43:35:
13:43:35:  <!-- Slot Control -->
13:43:35:  <power v='MEDIUM'/>
13:43:35:
13:43:35:  <!-- User Information -->
13:43:35:  <team v='1'/>
13:43:35:  <user v='sweldon001'/>
13:43:35:
13:43:35:  <!-- Folding Slots -->
13:43:35:  <slot id='0' type='CPU'>
13:43:35:    <idle v='true'/>
13:43:35:    <paused v='true'/>
13:43:35:  </slot>
13:43:35:  <slot id='1' type='GPU'>
13:43:35:    <pci-bus v='1'/>
13:43:35:    <pci-slot v='0'/>
13:43:35:  </slot>
13:43:35:</config>
13:43:35:Trying to access database...
13:43:35:Successfully acquired database lock
13:43:35:FS00:Initialized folding slot 00: cpu:22
13:43:35:FS01:Initialized folding slot 01: gpu:1:0 AD104 [GeForce RTX 4070]
13:43:48:12:127.0.0.1:New Web session
13:43:54:FS00:Unpaused
13:43:54:FS01:Unpaused
13:44:10:WU00:FS00:Connecting to assign1.foldingathome.org:80
13:44:10:WU01:FS01:Connecting to assign1.foldingathome.org:80
13:44:11:WU01:FS01:Connecting to assign1.foldingathome.org:80
13:44:11:WU00:FS00:Assigned to work server 129.32.209.203
13:44:11:WU00:FS00:Requesting new work unit for slot 00: cpu:22 from 129.32.209.203
13:44:11:WU00:FS00:Connecting to 129.32.209.203:8080
13:44:11:WU01:FS01:Assigned to work server 131.239.113.97
13:44:11:WU01:FS01:Requesting new work unit for slot 01: gpu:1:0 AD104 [GeForce RTX 4070] from 131.239.113.97
13:44:11:WU01:FS01:Connecting to 131.239.113.97:8080
13:44:11:WU00:FS00:Downloading 540.00KiB
13:44:11:WU00:FS00:Download complete
13:44:11:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:12408 run:36 clone:1 gen:105 core:0xa8 unit:0x69000000010000002400000078300000
13:44:13:WU00:FS00:Downloading core from http://cores.foldingathome.org/win/64bit-avx2-256/a8-0.0.12/Core_a8.fah
13:44:13:WU01:FS01:Downloading 6.37MiB
13:44:13:WU00:FS00:Connecting to cores.foldingathome.org:80
13:44:13:FS00:Paused
13:44:13:FS01:Paused
13:44:13:WU01:FS01:Download complete
13:44:13:WU00:FS00:FahCore a8: Downloading 7.72MiB
13:44:14:WU00:FS00:FahCore a8: Download complete
13:44:13:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:18725 run:0 clone:2341 gen:733 core:0x22 unit:0xdd020000250900000000000025490000
13:44:15:WU00:FS00:Valid core signature
13:44:15:WU00:FS00:Unpacked 20.93MiB to cores/cores.foldingathome.org/win/64bit-avx2-256/a8-0.0.12/Core_a8.fah/FahCore_a8.exe
13:44:15:WU00:FS00:Unpacked 2.64MiB to cores/cores.foldingathome.org/win/64bit-avx2-256/a8-0.0.12/Core_a8.fah/libfftw3f-3.dll
13:44:15:WU00:FS00:Unpacked 172.88KiB to cores/cores.foldingathome.org/win/64bit-avx2-256/a8-0.0.12/Core_a8.fah/vcomp140.dll
13:44:19:FS00:Unpaused
13:44:19:FS01:Unpaused
13:44:19:WU00:FS00:Starting
13:44:19:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit-avx2-256/a8-0.0.12/Core_a8.fah/FahCore_a8.exe -dir 00 -suffix 01 -version 706 -lifeline 4544 -checkpoint 15 -np 22
13:44:19:WU00:FS00:Started FahCore on PID 13716
13:44:20:WU00:FS00:Core PID:10636
13:44:20:WU00:FS00:FahCore 0xa8 started
13:44:21:WU01:FS01:Downloading core from http://cores.foldingathome.org/win/64bit/22-0.0.20/Core_22.fah
13:44:21:WU01:FS01:Connecting to cores.foldingathome.org:80
13:44:21:WU00:FS00:0xa8:*********************** Log Started 2024-02-06T13:44:21Z ***********************
13:44:21:WU00:FS00:0xa8:************************** Gromacs Folding@home Core ***************************
13:44:21:WU00:FS00:0xa8:       Core: Gromacs
sweldon001
13:44:21:WU00:FS00:0xa8:       Type: 0xa8
13:44:21:WU00:FS00:0xa8:    Version: 0.0.12
13:44:21:WU00:FS00:0xa8:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
13:44:21:WU00:FS00:0xa8:  Copyright: 2020 foldingathome.org
13:44:21:WU00:FS00:0xa8:   Homepage: https://foldingathome.org/
13:44:21:WU00:FS00:0xa8:       Date: Jan 16 2021
13:44:21:WU00:FS00:0xa8:       Time: 12:29:40
13:44:21:WU00:FS00:0xa8:   Revision: c5816759c404e4b65f9f364c3d1ef554a67c4225
13:44:21:WU00:FS00:0xa8:     Branch: master
13:44:21:WU00:FS00:0xa8:   Compiler: Visual C++ 2019 16.7
13:44:21:WU00:FS00:0xa8:    Options: /TP /std:c++14 /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
13:44:21:WU00:FS00:0xa8:   Platform: win32 10
13:44:21:WU00:FS00:0xa8:       Bits: 64
13:44:21:WU00:FS00:0xa8:       Mode: Release
13:44:21:WU00:FS00:0xa8:       SIMD: avx2_256
13:44:21:WU00:FS00:0xa8:     OpenMP: ON
13:44:21:WU00:FS00:0xa8:       CUDA: OFF
13:44:21:WU00:FS00:0xa8:       Args: -dir 00 -suffix 01 -version 706 -lifeline 13716 -checkpoint 15 -np
13:44:21:WU00:FS00:0xa8:             22
13:44:21:WU00:FS00:0xa8:************************************ libFAH ************************************
13:44:21:WU00:FS00:0xa8:       Time: 11:24:13
13:44:21:WU00:FS00:0xa8:************************************ CBang *************************************
13:44:21:WU00:FS00:0xa8:       Time: 11:23:53
13:44:21:WU00:FS00:0xa8:************************************ System ************************************
13:44:21:WU00:FS00:0xa8:        CPU: AMD Ryzen 9 7900X 12-Core Processor
13:44:21:WU00:FS00:0xa8:     CPU ID: AuthenticAMD Family 25 Model 97 Stepping 2
13:44:21:WU00:FS00:0xa8:       CPUs: 24
13:44:21:WU00:FS00:0xa8:     Memory: 31.71GiB
13:44:21:WU00:FS00:0xa8:Free Memory: 18.20GiB
13:44:21:WU00:FS00:0xa8:    Threads: WINDOWS_THREADS
13:44:21:WU00:FS00:0xa8: OS Version: 6.2
13:44:21:WU00:FS00:0xa8:Has Battery: true
13:44:21:WU00:FS00:0xa8: On Battery: false
13:44:21:WU00:FS00:0xa8: UTC Offset: -5
13:44:21:WU00:FS00:0xa8:        PID: 10636
13:44:21:WU00:FS00:0xa8:        CWD: C:\ProgramData\FAHClient\work
13:44:21:WU00:FS00:0xa8:********************************************************************************
13:44:21:WU00:FS00:0xa8:Project: 12408 (Run 36, Clone 1, Gen 105)
13:44:21:WU00:FS00:0xa8:Unit: 0x00000000000000000000000000000000
13:44:21:WU00:FS00:0xa8:Reading tar file core.xml
13:44:21:WU00:FS00:0xa8:Reading tar file frame105.tpr
13:44:21:WU00:FS00:0xa8:Digital signatures verified
13:44:21:WU00:FS00:0xa8:Calling: mdrun -c frame105.gro -s frame105.tpr -x frame105.xtc -cpt 15 -nt 22 -ntmpi 1
13:44:21:WU00:FS00:0xa8:Steps: first=525000000 total=530000000
13:44:22:WU01:FS01:FahCore 22: Downloading 156.61MiB
13:44:23:WU00:FS00:0xa8:Completed 1 out of 5000000 steps (0%)
13:44:28:WU01:FS01:FahCore 22: 44.46%
13:44:33:WU01:FS01:FahCore 22: Download complete
13:44:33:WU01:FS01:Valid core signature
13:44:33:WU01:FS01:Unpacked 5.52MiB to cores/cores.foldingathome.org/win/64bit/22-0.0.20/Core_22.fah/FahCore_22.exe
13:44:33:WU01:FS01:Unpacked 24.45KiB to cores/cores.foldingathome.org/win/64bit/22-0.0.20/Core_22.fah/api-ms-win-crt-runtime-l1-1-0.dll
13:44:33:WU01:FS01:Unpacked 179.58MiB to cores/cores.foldingathome.org/win/64bit/22-0.0.20/Core_22.fah/cufft64_10.dll
13:44:34:WU01:FS01:Unpacked 3.25MiB to cores/cores.foldingathome.org/win/64bit/22-0.0.20/Core_22.fah/libcrypto-1_1-x64.dll
13:44:34:WU01:FS01:Unpacked 667.00KiB to cores/cores.foldingathome.org/win/64bit/22-0.0.20/Core_22.fah/libssl-1_1-x64.dll
13:44:34:WU01:FS01:Unpacked 552.38KiB to cores/cores.foldingathome.org/win/64bit/22-0.0.20/Core_22.fah/msvcp140.dll
13:44:34:WU01:FS01:Unpacked 23.38KiB to cores/cores.foldingathome.org/win/64bit/22-0.0.20/Core_22.fah/msvcp140_1.dll
13:44:34:WU01:FS01:Unpacked 181.38KiB to cores/cores.foldingathome.org/win/64bit/22-0.0.20/Core_22.fah/msvcp140_2.dll
13:44:34:WU01:FS01:Unpacked 54.88KiB to cores/cores.foldingathome.org/win/64bit/22-0.0.20/Core_22.fah/msvcp140_atomic_wait.dll
13:44:34:WU01:FS01:Unpacked 19.88KiB to cores/cores.foldingathome.org/win/64bit/22-0.0.20/Core_22.fah/msvcp140_codecvt_ids.dll
13:44:34:WU01:FS01:Unpacked 5.29MiB to cores/cores.foldingathome.org/win/64bit/22-0.0.20/Core_22.fah/nvrtc-builtins64_112.dll
13:44:34:WU01:FS01:Unpacked 30.51MiB to cores/cores.foldingathome.org/win/64bit/22-0.0.20/Core_22.fah/nvrtc64_112_0.dll
13:44:34:WU01:FS01:Unpacked 2.81MiB to cores/cores.foldingathome.org/win/64bit/22-0.0.20/Core_22.fah/OpenMM.dll
13:44:34:WU01:FS01:Unpacked 302.00KiB to cores/cores.foldingathome.org/win/64bit/22-0.0.20/Core_22.fah/OpenMMAmoeba.dll
13:44:34:WU01:FS01:Unpacked 1.04MiB to cores/cores.foldingathome.org/win/64bit/22-0.0.20/Core_22.fah/OpenMMAmoebaCUDA.dll
13:44:34:WU01:FS01:Unpacked 952.00KiB to cores/cores.foldingathome.org/win/64bit/22-0.0.20/Core_22.fah/OpenMMAmoebaOpenCL.dll
13:44:34:WU01:FS01:Unpacked 458.50KiB to cores/cores.foldingathome.org/win/64bit/22-0.0.20/Core_22.fah/OpenMMAmoebaReference.dll
13:44:34:WU01:FS01:Unpacked 517.50KiB to cores/cores.foldingathome.org/win/64bit/22-0.0.20/Core_22.fah/OpenMMCPU.dll
13:44:34:WU01:FS01:Unpacked 1.78MiB to cores/cores.foldingathome.org/win/64bit/22-0.0.20/Core_22.fah/OpenMMCUDA.dll
13:44:34:WU01:FS01:Unpacked 60.50KiB to cores/cores.foldingathome.org/win/64bit/22-0.0.20/Core_22.fah/OpenMMCudaCompiler.dll
13:44:34:WU01:FS01:Unpacked 99.50KiB to cores/cores.foldingathome.org/win/64bit/22-0.0.20/Core_22.fah/OpenMMDrude.dll
13:44:34:WU01:FS01:Unpacked 118.00KiB to cores/cores.foldingathome.org/win/64bit/22-0.0.20/Core_22.fah/OpenMMDrudeCUDA.dll
13:44:34:WU01:FS01:Unpacked 118.00KiB to cores/cores.foldingathome.org/win/64bit/22-0.0.20/Core_22.fah/OpenMMDrudeOpenCL.dll
13:44:34:WU01:FS01:Unpacked 87.00KiB to cores/cores.foldingathome.org/win/64bit/22-0.0.20/Core_22.fah/OpenMMDrudeReference.dll
13:44:34:WU01:FS01:Unpacked 1.81MiB to cores/cores.foldingathome.org/win/64bit/22-0.0.20/Core_22.fah/OpenMMOpenCL.dll
13:44:34:WU01:FS01:Unpacked 61.00KiB to cores/cores.foldingathome.org/win/64bit/22-0.0.20/Core_22.fah/OpenMMPME.dll
13:44:34:WU01:FS01:Unpacked 57.00KiB to cores/cores.foldingathome.org/win/64bit/22-0.0.20/Core_22.fah/OpenMMRPMD.dll
13:44:34:WU01:FS01:Unpacked 138.50KiB to cores/cores.foldingathome.org/win/64bit/22-0.0.20/Core_22.fah/OpenMMRPMDCUDA.dll
13:44:34:WU01:FS01:Unpacked 138.50KiB to cores/cores.foldingathome.org/win/64bit/22-0.0.20/Core_22.fah/OpenMMRPMDOpenCL.dll
13:44:34:WU01:FS01:Unpacked 75.50KiB to cores/cores.foldingathome.org/win/64bit/22-0.0.20/Core_22.fah/OpenMMRPMDReference.dll
13:44:34:WU01:FS01:Unpacked 94.88KiB to cores/cores.foldingathome.org/win/64bit/22-0.0.20/Core_22.fah/vcruntime140.dll
13:44:34:WU01:FS01:Unpacked 36.38KiB to cores/cores.foldingathome.org/win/64bit/22-0.0.20/Core_22.fah/vcruntime140_1.dll
13:44:35:WU01:FS01:Starting
13:44:35:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.20/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 706 -lifeline 4544 -checkpoint 15 -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100
13:44:35:WU01:FS01:Started FahCore on PID 16084
13:44:35:WU01:FS01:Core PID:29024
13:44:35:WU01:FS01:FahCore 0x22 started
13:44:37:Saving configuration to config.xml
13:44:37:<config>
13:44:37:  <!-- Folding Slot Configuration -->
13:44:37:  <cause v='COVID_19'/>
13:44:37:
13:44:37:  <!-- Network -->
13:44:37:  <proxy v=':8080'/>
13:44:37:
13:44:37:  <!-- Slot Control -->
13:44:37:  <power v='MEDIUM'/>
13:44:37:
13:44:37:  <!-- User Information -->
13:44:37:  <team v='1'/>
13:44:37:  <user v='sweldon001'/>
13:44:37:
13:44:37:  <!-- Folding Slots -->
13:44:37:  <slot id='0' type='CPU'/>
13:44:37:  <slot id='1' type='GPU'>
13:44:37:    <pci-bus v='1'/>
13:44:37:    <pci-slot v='0'/>
13:44:37:  </slot>
13:44:37:</config>
13:44:39:WU01:FS01:0x22:*********************** Log Started 2024-02-06T13:44:38Z ***********************
13:44:39:WU01:FS01:0x22:*************************** Core22 Folding@home Core ***************************
sweldon001
13:44:39:WU01:FS01:0x22:       Core: Core22
13:44:39:WU01:FS01:0x22:       Type: 0x22
13:44:39:WU01:FS01:0x22:    Version: 0.0.20
13:44:39:WU01:FS01:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
13:44:39:WU01:FS01:0x22:  Copyright: 2020 foldingathome.org
13:44:39:WU01:FS01:0x22:   Homepage: https://foldingathome.org/
13:44:39:WU01:FS01:0x22:       Date: Jan 20 2022
13:44:39:WU01:FS01:0x22:       Time: 01:15:36
13:44:39:WU01:FS01:0x22:   Revision: 3f211b8a4346514edbff34e3cb1c0e0ec951373c
13:44:39:WU01:FS01:0x22:     Branch: HEAD
13:44:39:WU01:FS01:0x22:   Compiler: Visual C++
13:44:39:WU01:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
13:44:39:WU01:FS01:0x22:             -DOPENMM_VERSION="\"7.7.0\""
13:44:39:WU01:FS01:0x22:   Platform: win32 10
13:44:39:WU01:FS01:0x22:       Bits: 64
13:44:39:WU01:FS01:0x22:       Mode: Release
13:44:39:WU01:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
13:44:39:WU01:FS01:0x22:             <peastman@stanford.edu>
13:44:39:WU01:FS01:0x22:       Args: -dir 01 -suffix 01 -version 706 -lifeline 16084 -checkpoint 15
13:44:39:WU01:FS01:0x22:             -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor
13:44:39:WU01:FS01:0x22:             nvidia -gpu 0 -gpu-usage 100
13:44:39:WU01:FS01:0x22:************************************ libFAH ************************************
13:44:39:WU01:FS01:0x22:       Time: 01:14:17
13:44:39:WU01:FS01:0x22:   Revision: 9f4ad694e75c2350d4bb6b8b5b769ba27e483a2f
13:44:39:WU01:FS01:0x22:************************************ CBang *************************************
13:44:39:WU01:FS01:0x22:       Time: 01:13:20
13:44:39:WU01:FS01:0x22:   Revision: ab023d155b446906d55b0f6c9a1eedeea04f7a1a
13:44:39:WU01:FS01:0x22:************************************ System ************************************
13:44:39:WU01:FS01:0x22:        CPU: AMD Ryzen 9 7900X 12-Core Processor
13:44:39:WU01:FS01:0x22:     CPU ID: AuthenticAMD Family 25 Model 97 Stepping 2
13:44:39:WU01:FS01:0x22:       CPUs: 24
13:44:39:WU01:FS01:0x22:     Memory: 31.71GiB
13:44:39:WU01:FS01:0x22:Free Memory: 17.63GiB
13:44:39:WU01:FS01:0x22:    Threads: WINDOWS_THREADS
13:44:39:WU01:FS01:0x22: OS Version: 6.2
13:44:39:WU01:FS01:0x22:Has Battery: true
13:44:39:WU01:FS01:0x22: On Battery: false
13:44:39:WU01:FS01:0x22: UTC Offset: -5
13:44:39:WU01:FS01:0x22:        PID: 29024
13:44:39:WU01:FS01:0x22:        CWD: C:\ProgramData\FAHClient\work
13:44:39:WU01:FS01:0x22:************************************ OpenMM ************************************
13:44:39:WU01:FS01:0x22:    Version: 7.7.0
13:44:39:WU01:FS01:0x22:********************************************************************************
13:44:39:WU01:FS01:0x22:Project: 18725 (Run 0, Clone 2341, Gen 733)
13:44:39:WU01:FS01:0x22:Reading tar file core.xml
13:44:39:WU01:FS01:0x22:Reading tar file integrator.xml.bz2
13:44:39:WU01:FS01:0x22:Reading tar file state.xml.bz2
13:44:39:WU01:FS01:0x22:Reading tar file system.xml.bz2
13:44:39:WU01:FS01:0x22:Digital signatures verified
13:44:39:WU01:FS01:0x22:Folding@home GPU Core22 Folding@home Core
13:44:39:WU01:FS01:0x22:Version 0.0.20
13:44:41:WU01:FS01:0x22:  Checkpoint write interval: 250000 steps (5%) [20 total]
13:44:41:WU01:FS01:0x22:  JSON viewer frame write interval: 50000 steps (1%) [100 total]
13:44:41:WU01:FS01:0x22:  XTC frame write interval: 50000 steps (1%) [100 total]
13:44:41:WU01:FS01:0x22:  Global context and integrator variables write interval: disabled
13:44:47:WU01:FS01:0x22:There are 4 platforms available.
13:44:47:WU01:FS01:0x22:Platform 0: Reference
13:44:47:WU01:FS01:0x22:Platform 1: CPU
13:44:47:WU01:FS01:0x22:Platform 2: OpenCL
13:44:47:WU01:FS01:0x22:  opencl-device 0 specified
13:44:47:WU01:FS01:0x22:Platform 3: CUDA
13:44:47:WU01:FS01:0x22:  cuda-device 0 specified
13:44:54:WU01:FS01:0x22:Attempting to create CUDA context:
13:44:54:WU01:FS01:0x22:  Configuring platform CUDA
13:45:01:WU01:FS01:0x22:  Using CUDA and gpu 0
13:45:01:WU01:FS01:0x22:Completed 0 out of 5000000 steps (0%)
13:45:02:WU01:FS01:0x22:Checkpoint completed at step 0
13:46:28:WU01:FS01:0x22:Completed 50000 out of 5000000 steps (1%)
13:46:28:WU00:FS00:0xa8:Completed 50000 out of 5000000 steps (1%)
13:47:49:WU01:FS01:0x22:Completed 100000 out of 5000000 steps (2%)
13:48:48:WU00:FS00:0xa8:Completed 100000 out of 5000000 steps (2%)
13:49:09:WU01:FS01:0x22:Completed 150000 out of 5000000 steps (3%)
13:50:30:WU01:FS01:0x22:Completed 200000 out of 5000000 steps (4%)
13:51:07:WU00:FS00:0xa8:Completed 150000 out of 5000000 steps (3%)
13:51:50:WU01:FS01:0x22:Completed 250000 out of 5000000 steps (5%)
13:51:51:WU01:FS01:0x22:Checkpoint completed at step 250000
13:53:11:WU01:FS01:0x22:Completed 300000 out of 5000000 steps (6%)
13:53:26:WU00:FS00:0xa8:Completed 200000 out of 5000000 steps (4%)
13:54:31:WU01:FS01:0x22:Completed 350000 out of 5000000 steps (7%)
13:55:46:WU00:FS00:0xa8:Completed 250000 out of 5000000 steps (5%)
13:55:51:WU01:FS01:0x22:Completed 400000 out of 5000000 steps (8%)
13:57:11:WU01:FS01:0x22:Completed 450000 out of 5000000 steps (9%)
13:58:05:WU00:FS00:0xa8:Completed 300000 out of 5000000 steps (6%)
13:58:31:WU01:FS01:0x22:Completed 500000 out of 5000000 steps (10%)
13:58:32:WU01:FS01:0x22:Checkpoint completed at step 500000
13:59:51:WU01:FS01:0x22:Completed 550000 out of 5000000 steps (11%)
14:00:24:WU00:FS00:0xa8:Completed 350000 out of 5000000 steps (7%)
14:01:13:WU01:FS01:0x22:Completed 600000 out of 5000000 steps (12%)
14:02:34:WU01:FS01:0x22:Completed 650000 out of 5000000 steps (13%)
14:02:51:WU00:FS00:0xa8:Completed 400000 out of 5000000 steps (8%)
14:03:35:ERROR:Receive error: 10054: An existing connection was forcibly closed by the remote host.
14:03:55:WU01:FS01:0x22:Completed 700000 out of 5000000 steps (14%)
14:05:13:WU00:FS00:0xa8:Completed 450000 out of 5000000 steps (9%)
14:05:16:WU01:FS01:0x22:Completed 750000 out of 5000000 steps (15%)
14:05:16:WU01:FS01:0x22:Checkpoint completed at step 750000
14:06:39:WU01:FS01:0x22:Completed 800000 out of 5000000 steps (16%)
14:07:42:WU00:FS00:0xa8:Completed 500000 out of 5000000 steps (10%)
14:08:02:WU01:FS01:0x22:Completed 850000 out of 5000000 steps (17%)
14:09:25:WU01:FS01:0x22:Completed 900000 out of 5000000 steps (18%)
14:10:10:WU00:FS00:0xa8:Completed 550000 out of 5000000 steps (11%)
14:10:47:WU01:FS01:0x22:Completed 950000 out of 5000000 steps (19%)
14:12:10:WU01:FS01:0x22:Completed 1000000 out of 5000000 steps (20%)
14:12:11:WU01:FS01:0x22:Checkpoint completed at step 1000000
14:12:38:WU00:FS00:0xa8:Completed 600000 out of 5000000 steps (12%)
14:13:33:WU01:FS01:0x22:Completed 1050000 out of 5000000 steps (21%)
14:14:56:WU01:FS01:0x22:Completed 1100000 out of 5000000 steps (22%)
14:15:07:WU00:FS00:0xa8:Completed 650000 out of 5000000 steps (13%)
14:16:19:WU01:FS01:0x22:Completed 1150000 out of 5000000 steps (23%)
14:17:36:WU00:FS00:0xa8:Completed 700000 out of 5000000 steps (14%)
14:17:42:WU01:FS01:0x22:Completed 1200000 out of 5000000 steps (24%)
14:19:05:WU01:FS01:0x22:Completed 1250000 out of 5000000 steps (25%)
14:19:06:WU01:FS01:0x22:Checkpoint completed at step 1250000
14:20:05:WU00:FS00:0xa8:Completed 750000 out of 5000000 steps (15%)
14:20:29:WU01:FS01:0x22:Completed 1300000 out of 5000000 steps (26%)
14:21:52:WU01:FS01:0x22:Completed 1350000 out of 5000000 steps (27%)
14:22:33:WU00:FS00:0xa8:Completed 800000 out of 5000000 steps (16%)
14:23:14:WU01:FS01:0x22:Completed 1400000 out of 5000000 steps (28%)
14:24:20:ERROR:Receive error: 10054: An existing connection was forcibly closed by the remote host.
14:24:36:WU01:FS01:0x22:Completed 1450000 out of 5000000 steps (29%)
14:24:59:WU00:FS00:0xa8:Completed 850000 out of 5000000 steps (17%)
14:25:57:WU01:FS01:0x22:Completed 1500000 out of 5000000 steps (30%)
14:25:57:WU01:FS01:0x22:Checkpoint completed at step 1500000
14:27:18:WU01:FS01:0x22:Completed 1550000 out of 5000000 steps (31%)
14:27:25:WU00:FS00:0xa8:Completed 900000 out of 5000000 steps (18%)
14:28:40:WU01:FS01:0x22:Completed 1600000 out of 5000000 steps (32%)
14:29:51:WU00:FS00:0xa8:Completed 950000 out of 5000000 steps (19%)
14:30:00:WU01:FS01:0x22:Completed 1650000 out of 5000000 steps (33%)
14:31:21:WU01:FS01:0x22:Completed 1700000 out of 5000000 steps (34%)
14:32:17:WU00:FS00:0xa8:Completed 1000000 out of 5000000 steps (20%)
14:32:42:WU01:FS01:0x22:Completed 1750000 out of 5000000 steps (35%)
14:32:42:WU01:FS01:0x22:Checkpoint completed at step 1750000
14:34:03:WU01:FS01:0x22:Completed 1800000 out of 5000000 steps (36%)
14:34:43:WU00:FS00:0xa8:Completed 1050000 out of 5000000 steps (21%)
14:35:24:WU01:FS01:0x22:Completed 1850000 out of 5000000 steps (37%)
14:36:45:WU01:FS01:0x22:Completed 1900000 out of 5000000 steps (38%)
14:37:10:WU00:FS00:0xa8:Completed 1100000 out of 5000000 steps (22%)
14:38:06:WU01:FS01:0x22:Completed 1950000 out of 5000000 steps (39%)
14:39:27:WU01:FS01:0x22:Completed 2000000 out of 5000000 steps (40%)
14:39:27:WU01:FS01:0x22:Checkpoint completed at step 2000000
14:39:36:WU00:FS00:0xa8:Completed 1150000 out of 5000000 steps (23%)
14:40:48:WU01:FS01:0x22:Completed 2050000 out of 5000000 steps (41%)
14:42:02:WU00:FS00:0xa8:Completed 1200000 out of 5000000 steps (24%)
14:42:09:WU01:FS01:0x22:Completed 2100000 out of 5000000 steps (42%)
14:43:30:WU01:FS01:0x22:Completed 2150000 out of 5000000 steps (43%)
14:44:29:WU00:FS00:0xa8:Completed 1250000 out of 5000000 steps (25%)
14:44:50:WU01:FS01:0x22:Completed 2200000 out of 5000000 steps (44%)
14:46:11:WU01:FS01:0x22:Completed 2250000 out of 5000000 steps (45%)
14:46:12:WU01:FS01:0x22:Checkpoint completed at step 2250000
14:46:56:WU00:FS00:0xa8:Completed 1300000 out of 5000000 steps (26%)
14:47:33:WU01:FS01:0x22:Completed 2300000 out of 5000000 steps (46%)
14:48:54:WU01:FS01:0x22:Completed 2350000 out of 5000000 steps (47%)
14:49:22:WU00:FS00:0xa8:Completed 1350000 out of 5000000 steps (27%)
14:50:15:WU01:FS01:0x22:Completed 2400000 out of 5000000 steps (48%)
14:51:05:42:127.0.0.1:New Web session
14:51:22:ERROR:Receive error: 10054: An existing connection was forcibly closed by the remote host.
14:51:37:WU01:FS01:0x22:Completed 2450000 out of 5000000 steps (49%)
14:51:50:WU00:FS00:0xa8:Completed 1400000 out of 5000000 steps (28%)
14:53:00:WU01:FS01:0x22:Completed 2500000 out of 5000000 steps (50%)
14:53:00:WU01:FS01:0x22:Checkpoint completed at step 2500000
14:54:13:WU00:FS00:0xa8:Completed 1450000 out of 5000000 steps (29%)
14:54:27:WU01:FS01:0x22:Completed 2550000 out of 5000000 steps (51%)
14:55:51:WU01:FS01:0x22:Completed 2600000 out of 5000000 steps (52%)
14:56:40:WU00:FS00:0xa8:Completed 1500000 out of 5000000 steps (30%)
14:57:15:WU01:FS01:0x22:Completed 2650000 out of 5000000 steps (53%)
14:58:39:WU01:FS01:0x22:Completed 2700000 out of 5000000 steps (54%)
14:59:09:WU00:FS00:0xa8:Completed 1550000 out of 5000000 steps (31%)
15:00:03:WU01:FS01:0x22:Completed 2750000 out of 5000000 steps (55%)
15:00:03:WU01:FS01:0x22:Checkpoint completed at step 2750000
15:01:28:WU01:FS01:0x22:Completed 2800000 out of 5000000 steps (56%)
15:01:37:WU00:FS00:0xa8:Completed 1600000 out of 5000000 steps (32%)
15:02:52:WU01:FS01:0x22:Completed 2850000 out of 5000000 steps (57%)
15:04:05:WU00:FS00:0xa8:Completed 1650000 out of 5000000 steps (33%)
15:04:16:WU01:FS01:0x22:Completed 2900000 out of 5000000 steps (58%)
15:05:40:WU01:FS01:0x22:Completed 2950000 out of 5000000 steps (59%)
15:06:34:WU00:FS00:0xa8:Completed 1700000 out of 5000000 steps (34%)
15:07:05:WU01:FS01:0x22:Completed 3000000 out of 5000000 steps (60%)
15:07:05:WU01:FS01:0x22:Checkpoint completed at step 3000000
15:08:29:WU01:FS01:0x22:Completed 3050000 out of 5000000 steps (61%)
15:09:04:WU00:FS00:0xa8:Completed 1750000 out of 5000000 steps (35%)
15:09:54:WU01:FS01:0x22:Completed 3100000 out of 5000000 steps (62%)
15:11:18:WU01:FS01:0x22:Completed 3150000 out of 5000000 steps (63%)
15:11:32:WU00:FS00:0xa8:Completed 1800000 out of 5000000 steps (36%)
15:12:42:WU01:FS01:0x22:Completed 3200000 out of 5000000 steps (64%)
15:14:00:WU00:FS00:0xa8:Completed 1850000 out of 5000000 steps (37%)
15:14:06:WU01:FS01:0x22:Completed 3250000 out of 5000000 steps (65%)
15:14:06:WU01:FS01:0x22:Checkpoint completed at step 3250000
15:15:30:WU01:FS01:0x22:Completed 3300000 out of 5000000 steps (66%)
15:16:28:WU00:FS00:0xa8:Completed 1900000 out of 5000000 steps (38%)
15:16:54:WU01:FS01:0x22:Completed 3350000 out of 5000000 steps (67%)
15:18:17:WU01:FS01:0x22:Completed 3400000 out of 5000000 steps (68%)
15:18:56:WU00:FS00:0xa8:Completed 1950000 out of 5000000 steps (39%)
15:19:41:WU01:FS01:0x22:Completed 3450000 out of 5000000 steps (69%)
15:21:05:WU01:FS01:0x22:Completed 3500000 out of 5000000 steps (70%)
15:21:06:WU01:FS01:0x22:Checkpoint completed at step 3500000
15:21:23:WU00:FS00:0xa8:Completed 2000000 out of 5000000 steps (40%)
15:22:29:WU01:FS01:0x22:Completed 3550000 out of 5000000 steps (71%)
15:23:51:WU00:FS00:0xa8:Completed 2050000 out of 5000000 steps (41%)
15:23:53:WU01:FS01:0x22:Completed 3600000 out of 5000000 steps (72%)
15:25:17:WU01:FS01:0x22:Completed 3650000 out of 5000000 steps (73%)
15:26:18:WU00:FS00:0xa8:Completed 2100000 out of 5000000 steps (42%)
15:26:41:WU01:FS01:0x22:Completed 3700000 out of 5000000 steps (74%)
15:28:05:WU01:FS01:0x22:Completed 3750000 out of 5000000 steps (75%)
15:28:05:WU01:FS01:0x22:Checkpoint completed at step 3750000
15:28:45:WU00:FS00:0xa8:Completed 2150000 out of 5000000 steps (43%)
15:29:25:WU01:FS01:0x22:Completed 3800000 out of 5000000 steps (76%)
15:30:46:WU01:FS01:0x22:Completed 3850000 out of 5000000 steps (77%)
15:31:04:WU00:FS00:0xa8:Completed 2200000 out of 5000000 steps (44%)
15:32:06:WU01:FS01:0x22:Completed 3900000 out of 5000000 steps (78%)
15:33:24:WU00:FS00:0xa8:Completed 2250000 out of 5000000 steps (45%)
15:33:26:WU01:FS01:0x22:Completed 3950000 out of 5000000 steps (79%)
15:34:46:WU01:FS01:0x22:Completed 4000000 out of 5000000 steps (80%)
15:34:46:WU01:FS01:0x22:Checkpoint completed at step 4000000
15:35:43:WU00:FS00:0xa8:Completed 2300000 out of 5000000 steps (46%)
15:36:06:WU01:FS01:0x22:Completed 4050000 out of 5000000 steps (81%)
15:37:26:WU01:FS01:0x22:Completed 4100000 out of 5000000 steps (82%)
15:38:02:WU00:FS00:0xa8:Completed 2350000 out of 5000000 steps (47%)
15:38:46:WU01:FS01:0x22:Completed 4150000 out of 5000000 steps (83%)
15:40:07:WU01:FS01:0x22:Completed 4200000 out of 5000000 steps (84%)
15:40:21:WU00:FS00:0xa8:Completed 2400000 out of 5000000 steps (48%)
15:41:27:WU01:FS01:0x22:Completed 4250000 out of 5000000 steps (85%)
15:41:27:WU01:FS01:0x22:Checkpoint completed at step 4250000
15:42:39:WU00:FS00:0xa8:Completed 2450000 out of 5000000 steps (49%)
15:42:47:WU01:FS01:0x22:Completed 4300000 out of 5000000 steps (86%)
15:44:07:WU01:FS01:0x22:Completed 4350000 out of 5000000 steps (87%)
15:44:59:WU00:FS00:0xa8:Completed 2500000 out of 5000000 steps (50%)
15:45:28:WU01:FS01:0x22:Completed 4400000 out of 5000000 steps (88%)
15:46:48:WU01:FS01:0x22:Completed 4450000 out of 5000000 steps (89%)
15:47:19:WU00:FS00:0xa8:Completed 2550000 out of 5000000 steps (51%)
15:48:08:WU01:FS01:0x22:Completed 4500000 out of 5000000 steps (90%)
15:48:08:WU01:FS01:0x22:Checkpoint completed at step 4500000
15:49:28:WU01:FS01:0x22:Completed 4550000 out of 5000000 steps (91%)
15:49:39:WU00:FS00:0xa8:Completed 2600000 out of 5000000 steps (52%)
15:50:49:WU01:FS01:0x22:Completed 4600000 out of 5000000 steps (92%)
15:51:59:WU00:FS00:0xa8:Completed 2650000 out of 5000000 steps (53%)
15:52:09:WU01:FS01:0x22:Completed 4650000 out of 5000000 steps (93%)
15:53:29:WU01:FS01:0x22:Completed 4700000 out of 5000000 steps (94%)
15:54:19:WU00:FS00:0xa8:Completed 2700000 out of 5000000 steps (54%)
15:54:49:WU01:FS01:0x22:Completed 4750000 out of 5000000 steps (95%)
15:54:50:WU01:FS01:0x22:Checkpoint completed at step 4750000
15:56:10:WU01:FS01:0x22:Completed 4800000 out of 5000000 steps (96%)
15:56:38:WU00:FS00:0xa8:Completed 2750000 out of 5000000 steps (55%)
15:57:30:WU01:FS01:0x22:Completed 4850000 out of 5000000 steps (97%)
15:58:51:WU01:FS01:0x22:Completed 4900000 out of 5000000 steps (98%)
15:58:56:WU00:FS00:0xa8:Completed 2800000 out of 5000000 steps (56%)
16:00:11:WU01:FS01:0x22:Completed 4950000 out of 5000000 steps (99%)
16:00:11:WU02:FS01:Connecting to assign1.foldingathome.org:80
16:00:12:WU02:FS01:Assigned to work server 158.130.118.25
16:00:12:WU02:FS01:Requesting new work unit for slot 01: gpu:1:0 AD104 [GeForce RTX 4070] from 158.130.118.25
16:00:12:WU02:FS01:Connecting to 158.130.118.25:8080
16:00:12:WU02:FS01:Downloading 23.42MiB
16:00:13:WU02:FS01:Download complete
16:00:13:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:18218 run:4790 clone:0 gen:9 core:0x23 unit:0x00000000000000090000472a000012b6
16:00:14:WU02:FS01:Downloading core from http://cores.foldingathome.org/openmm-core-23/windows-10-64bit/release/0x23-8.0.3/Core_23.fah
16:00:14:WU02:FS01:Connecting to cores.foldingathome.org:80
16:00:15:WU02:FS01:FahCore 23: Downloading 156.01MiB
16:00:21:WU02:FS01:FahCore 23: 32.85%
16:00:26:WU02:FS01:FahCore 23: Download complete
16:00:26:WU02:FS01:Valid core signature
16:00:26:WU02:FS01:Unpacked 2.24MiB to cores/cores.foldingathome.org/openmm-core-23/windows-10-64bit/release/0x23-8.0.3/Core_23.fah/FahCore_23.exe
16:00:26:WU02:FS01:Unpacked 30.90KiB to cores/cores.foldingathome.org/openmm-core-23/windows-10-64bit/release/0x23-8.0.3/Core_23.fah/msvcp140_codecvt_ids.dll
16:00:26:WU02:FS01:Unpacked 1.63MiB to cores/cores.foldingathome.org/openmm-core-23/windows-10-64bit/release/0x23-8.0.3/Core_23.fah/OpenMMCUDA.dll
16:00:26:WU02:FS01:Unpacked 48.40KiB to cores/cores.foldingathome.org/openmm-core-23/windows-10-64bit/release/0x23-8.0.3/Core_23.fah/vcruntime140_1.dll
16:00:26:WU02:FS01:Unpacked 5.29MiB to cores/cores.foldingathome.org/openmm-core-23/windows-10-64bit/release/0x23-8.0.3/Core_23.fah/nvrtc-builtins64_112.dll
16:00:26:WU02:FS01:Unpacked 2.67MiB to cores/cores.foldingathome.org/openmm-core-23/windows-10-64bit/release/0x23-8.0.3/Core_23.fah/OpenMM.dll
16:00:26:WU02:FS01:Unpacked 48.90KiB to cores/cores.foldingathome.org/openmm-core-23/windows-10-64bit/release/0x23-8.0.3/Core_23.fah/msvcp140_atomic_wait.dll
16:00:26:WU02:FS01:Unpacked 176.50KiB to cores/cores.foldingathome.org/openmm-core-23/windows-10-64bit/release/0x23-8.0.3/Core_23.fah/OpenMMRPMDReference.dll
16:00:26:WU02:FS01:Unpacked 50.00KiB to cores/cores.foldingathome.org/openmm-core-23/windows-10-64bit/release/0x23-8.0.3/Core_23.fah/OpenMMRPMD.dll
16:00:26:WU02:FS01:Unpacked 220.00KiB to cores/cores.foldingathome.org/openmm-core-23/windows-10-64bit/release/0x23-8.0.3/Core_23.fah/OpenMMPME.dll
16:00:26:WU02:FS01:Unpacked 40.00KiB to cores/cores.foldingathome.org/openmm-core-23/windows-10-64bit/release/0x23-8.0.3/Core_23.fah/OpenMMCudaCompiler.dll
16:00:26:WU02:FS01:Unpacked 106.88KiB to cores/cores.foldingathome.org/openmm-core-23/windows-10-64bit/release/0x23-8.0.3/Core_23.fah/vcruntime140.dll
16:00:26:WU02:FS01:Unpacked 30.51MiB to cores/cores.foldingathome.org/openmm-core-23/windows-10-64bit/release/0x23-8.0.3/Core_23.fah/nvrtc64_112_0.dll
16:00:26:WU02:FS01:Unpacked 105.50KiB to cores/cores.foldingathome.org/openmm-core-23/windows-10-64bit/release/0x23-8.0.3/Core_23.fah/OpenMMDrudeOpenCL.dll
16:00:26:WU02:FS01:Unpacked 279.50KiB to cores/cores.foldingathome.org/openmm-core-23/windows-10-64bit/release/0x23-8.0.3/Core_23.fah/OpenMMAmoeba.dll
16:00:26:WU02:FS01:Unpacked 539.50KiB to cores/cores.foldingathome.org/openmm-core-23/windows-10-64bit/release/0x23-8.0.3/Core_23.fah/OpenMMAmoebaReference.dll
16:00:26:WU02:FS01:Unpacked 474.50KiB to cores/cores.foldingathome.org/openmm-core-23/windows-10-64bit/release/0x23-8.0.3/Core_23.fah/OpenMMCPU.dll
16:00:26:WU02:FS01:Unpacked 673.50KiB to cores/cores.foldingathome.org/openmm-core-23/windows-10-64bit/release/0x23-8.0.3/Core_23.fah/libssl-1_1-x64.dll
16:00:26:WU02:FS01:Unpacked 121.50KiB to cores/cores.foldingathome.org/openmm-core-23/windows-10-64bit/release/0x23-8.0.3/Core_23.fah/OpenMMRPMDOpenCL.dll
16:00:27:WU02:FS01:Unpacked 179.58MiB to cores/cores.foldingathome.org/openmm-core-23/windows-10-64bit/release/0x23-8.0.3/Core_23.fah/cufft64_10.dll
16:00:27:WU02:FS01:Unpacked 105.50KiB to cores/cores.foldingathome.org/openmm-core-23/windows-10-64bit/release/0x23-8.0.3/Core_23.fah/OpenMMDrudeCUDA.dll
16:00:27:WU02:FS01:Unpacked 121.50KiB to cores/cores.foldingathome.org/openmm-core-23/windows-10-64bit/release/0x23-8.0.3/Core_23.fah/OpenMMRPMDCUDA.dll
16:00:27:WU02:FS01:Unpacked 1.02MiB to cores/cores.foldingathome.org/openmm-core-23/windows-10-64bit/release/0x23-8.0.3/Core_23.fah/OpenMMAmoebaCUDA.dll
16:00:27:WU02:FS01:Unpacked 96.50KiB to cores/cores.foldingathome.org/openmm-core-23/windows-10-64bit/release/0x23-8.0.3/Core_23.fah/OpenMMDrude.dll
16:00:27:WU02:FS01:Unpacked 1.66MiB to cores/cores.foldingathome.org/openmm-core-23/windows-10-64bit/release/0x23-8.0.3/Core_23.fah/OpenMMOpenCL.dll
16:00:27:WU02:FS01:Unpacked 3.28MiB to cores/cores.foldingathome.org/openmm-core-23/windows-10-64bit/release/0x23-8.0.3/Core_23.fah/libcrypto-1_1-x64.dll
16:00:27:WU02:FS01:Unpacked 929.50KiB to cores/cores.foldingathome.org/openmm-core-23/windows-10-64bit/release/0x23-8.0.3/Core_23.fah/OpenMMAmoebaOpenCL.dll
16:00:27:WU02:FS01:Unpacked 564.83KiB to cores/cores.foldingathome.org/openmm-core-23/windows-10-64bit/release/0x23-8.0.3/Core_23.fah/msvcp140.dll
16:00:27:WU02:FS01:Unpacked 79.50KiB to cores/cores.foldingathome.org/openmm-core-23/windows-10-64bit/release/0x23-8.0.3/Core_23.fah/OpenMMDrudeReference.dll
sweldon001
16:00:27:WU02:FS01:Unpacked 260.90KiB to cores/cores.foldingathome.org/openmm-core-23/windows-10-64bit/release/0x23-8.0.3/Core_23.fah/msvcp140_2.dll
16:00:27:WU02:FS01:Unpacked 34.87KiB to cores/cores.foldingathome.org/openmm-core-23/windows-10-64bit/release/0x23-8.0.3/Core_23.fah/msvcp140_1.dll
16:01:17:WU00:FS00:0xa8:Completed 2850000 out of 5000000 steps (57%)
16:01:31:WU01:FS01:0x22:Completed 5000000 out of 5000000 steps (100%)
16:01:31:WU01:FS01:0x22:Average performance: 215.461 ns/day
16:01:31:WU01:FS01:0x22:Checkpoint completed at step 5000000
16:01:37:WU01:FS01:0x22:Saving result file ..\logfile_01.txt
16:01:37:WU01:FS01:0x22:Saving result file checkpointIntegrator.xml.bz2
16:01:37:WU01:FS01:0x22:Saving result file checkpointState.xml.bz2
16:01:38:WU01:FS01:0x22:Saving result file positions.xtc
16:01:38:WU01:FS01:0x22:Saving result file science.log
16:01:38:WU01:FS01:0x22:Folding@home Core Shutdown: FINISHED_UNIT
16:01:39:WU01:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
16:01:39:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:18725 run:0 clone:2341 gen:733 core:0x22 unit:0xdd020000250900000000000025490000
16:01:39:WU01:FS01:Uploading 34.55MiB to 131.239.113.97
16:01:39:WU01:FS01:Connecting to 131.239.113.97:8080
16:01:39:WU02:FS01:Starting
16:01:39:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/openmm-core-23/windows-10-64bit/release/0x23-8.0.3/Core_23.fah/FahCore_23.exe -dir 02 -suffix 01 -version 706 -lifeline 4544 -checkpoint 15 -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100
16:01:39:WU02:FS01:Started FahCore on PID 15816
16:01:39:WU02:FS01:Core PID:27856
16:01:39:WU02:FS01:FahCore 0x23 started
16:01:40:WU02:FS01:0x23:*********************** Log Started 2024-02-06T16:01:40Z ***********************
16:01:40:WU02:FS01:0x23:*************************** Core23 Folding@home Core ***************************
16:01:40:WU02:FS01:0x23:       Core: Core23
16:01:40:WU02:FS01:0x23:       Type: 0x23
16:01:40:WU02:FS01:0x23:    Version: 8.0.3
16:01:40:WU02:FS01:0x23:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
16:01:40:WU02:FS01:0x23:  Copyright: 2022 foldingathome.org
16:01:40:WU02:FS01:0x23:   Homepage: https://foldingathome.org/
16:01:40:WU02:FS01:0x23:       Date: Aug 3 2023
16:01:40:WU02:FS01:0x23:       Time: 08:39:06
16:01:40:WU02:FS01:0x23:   Compiler: Visual C++
16:01:40:WU02:FS01:0x23:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
16:01:40:WU02:FS01:0x23:             -DOPENMM_VERSION="\"8.0.0\""
16:01:40:WU02:FS01:0x23:   Platform: win32 10
16:01:40:WU02:FS01:0x23:       Bits: 64
16:01:40:WU02:FS01:0x23:       Mode: Release
16:01:40:WU02:FS01:0x23:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
16:01:40:WU02:FS01:0x23:             <peastman@stanford.edu>
16:01:40:WU02:FS01:0x23:       Args: -dir 02 -suffix 01 -version 706 -lifeline 15816 -checkpoint 15
16:01:40:WU02:FS01:0x23:             -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor
16:01:40:WU02:FS01:0x23:             nvidia -gpu 0 -gpu-usage 100
16:01:40:WU02:FS01:0x23:************************************ libFAH ************************************
16:01:40:WU02:FS01:0x23:       Time: 08:37:55
16:01:40:WU02:FS01:0x23:************************************ CBang *************************************
16:01:40:WU02:FS01:0x23:    Version: 1.7.2
16:01:40:WU02:FS01:0x23:        Org: Cauldron Development LLC
16:01:40:WU02:FS01:0x23:  Copyright: Cauldron Development LLC, 2003-2023
16:01:40:WU02:FS01:0x23:   Homepage: https://cauldrondevelopment.com/
16:01:40:WU02:FS01:0x23:    License: GPL 2+
16:01:40:WU02:FS01:0x23:       Time: 08:37:14
16:01:40:WU02:FS01:0x23:************************************ System ************************************
16:01:40:WU02:FS01:0x23:        CPU: AMD Ryzen 9 7900X 12-Core Processor
16:01:40:WU02:FS01:0x23:     CPU ID: AuthenticAMD Family 25 Model 97 Stepping 2
16:01:40:WU02:FS01:0x23:       CPUs: 24
16:01:40:WU02:FS01:0x23:     Memory: 31.71GiB
16:01:40:WU02:FS01:0x23:Free Memory: 18.37GiB
16:01:40:WU02:FS01:0x23:    Threads: WINDOWS_THREADS
16:01:40:WU02:FS01:0x23: OS Version: 6.2
16:01:40:WU02:FS01:0x23:Has Battery: true
16:01:40:WU02:FS01:0x23: On Battery: false
16:01:40:WU02:FS01:0x23: UTC Offset: -5
16:01:40:WU02:FS01:0x23:        PID: 27856
16:01:40:WU02:FS01:0x23:        CWD: C:\ProgramData\FAHClient\work
16:01:40:WU02:FS01:0x23:       Exec: C:\ProgramData\FAHClient\cores\cores.foldingathome.org\openmm-core-23\windows-10-64bit\release\0x23-8.0.3\Core_23.fah\FahCore_23.exe
16:01:40:WU02:FS01:0x23:************************************ OpenMM ************************************
16:01:40:WU02:FS01:0x23:    Version: 8.0.0
16:01:40:WU02:FS01:0x23:********************************************************************************
16:01:40:WU02:FS01:0x23:Project: 18218 (Run 4790, Clone 0, Gen 9)
16:01:40:WU02:FS01:0x23:Reading tar file core.xml
16:01:40:WU02:FS01:0x23:Reading tar file integrator.xml
16:01:40:WU02:FS01:0x23:Reading tar file state.xml.bz2
16:01:40:WU02:FS01:0x23:Reading tar file system.xml.bz2
16:01:40:WU02:FS01:0x23:Digital signatures verified
16:01:40:WU02:FS01:0x23:Folding@home GPU Core23 Folding@home Core
16:01:40:WU02:FS01:0x23:Version 8.0.3
16:01:40:WU02:FS01:0x23:  Checkpoint write interval: 25000 steps (2%) [50 total]
16:01:40:WU02:FS01:0x23:  JSON viewer frame write interval: 12500 steps (1%) [100 total]
16:01:40:WU02:FS01:0x23:  XTC frame write interval: 10000 steps (0.8%) [125 total]
16:01:40:WU02:FS01:0x23:  Global context and integrator variables write interval: disabled
16:01:41:WU02:FS01:0x23:There are 4 platforms available.
16:01:41:WU02:FS01:0x23:Platform 0: Reference
16:01:41:WU02:FS01:0x23:Platform 1: CPU
16:01:41:WU02:FS01:0x23:Platform 2: OpenCL
16:01:41:WU02:FS01:0x23:  opencl-device 0 specified
16:01:41:WU02:FS01:0x23:Platform 3: CUDA
16:01:41:WU02:FS01:0x23:  cuda-device 0 specified
16:01:44:WU01:FS01:Upload complete
16:01:44:WU01:FS01:Server responded WORK_ACK (400)
16:01:44:WU01:FS01:Final credit estimate, 792597.00 points
16:01:44:WU01:FS01:Cleaning up
16:02:04:WU02:FS01:0x23:Attempting to create CUDA context:
16:02:04:WU02:FS01:0x23:  Configuring platform CUDA
16:02:11:WU02:FS01:0x23:  Using CUDA on CUDA Platform and gpu 0
16:02:11:WU02:FS01:0x23:  GPU info: Platform: CUDA
16:02:11:WU02:FS01:0x23:  GPU info: PlatformIndex: 0
16:02:11:WU02:FS01:0x23:  GPU info: Device: NVIDIA GeForce RTX 4070
16:02:11:WU02:FS01:0x23:  GPU info: DeviceIndex: 0
16:02:11:WU02:FS01:0x23:  GPU info: Vendor: 0x10de
16:02:11:WU02:FS01:0x23:  GPU info: PCI: 01:00:00
16:02:11:WU02:FS01:0x23:  GPU info: Compute: 8.9
16:02:11:WU02:FS01:0x23:  GPU info: Driver: 12.3
16:02:11:WU02:FS01:0x23:  GPU info: GPU: true
16:02:11:WU02:FS01:0x23:Completed 0 out of 1250000 steps (0%)
16:02:12:WU02:FS01:0x23:Checkpoint completed at step 0
16:02:55:WU00:FS00:0xa8:Completed 2900000 out of 5000000 steps (58%)
16:03:01:WU02:FS01:0x23:Completed 12500 out of 1250000 steps (1%)
16:03:49:WU02:FS01:0x23:Completed 25000 out of 1250000 steps (2%)
16:03:50:WU02:FS01:0x23:Checkpoint completed at step 25000
16:04:35:WU00:FS00:0xa8:Completed 2950000 out of 5000000 steps (59%)
16:04:38:WU02:FS01:0x23:Completed 37500 out of 1250000 steps (3%)
16:05:26:WU02:FS01:0x23:Completed 50000 out of 1250000 steps (4%)
16:05:27:WU02:FS01:0x23:Checkpoint completed at step 50000
16:06:15:WU02:FS01:0x23:Completed 62500 out of 1250000 steps (5%)
16:06:15:WU00:FS00:0xa8:Completed 3000000 out of 5000000 steps (60%)
16:07:03:WU02:FS01:0x23:Completed 75000 out of 1250000 steps (6%)
16:07:04:WU02:FS01:0x23:Checkpoint completed at step 75000
16:07:52:WU02:FS01:0x23:Completed 87500 out of 1250000 steps (7%)
16:07:55:WU00:FS00:0xa8:Completed 3050000 out of 5000000 steps (61%)
16:08:40:WU02:FS01:0x23:Completed 100000 out of 1250000 steps (8%)
16:08:42:WU02:FS01:0x23:Checkpoint completed at step 100000
16:09:29:WU02:FS01:0x23:Completed 112500 out of 1250000 steps (9%)
16:09:34:WU00:FS00:0xa8:Completed 3100000 out of 5000000 steps (62%)
16:10:18:WU02:FS01:0x23:Completed 125000 out of 1250000 steps (10%)
16:10:19:WU02:FS01:0x23:Checkpoint completed at step 125000
16:11:07:WU02:FS01:0x23:Completed 137500 out of 1250000 steps (11%)
16:11:14:WU00:FS00:0xa8:Completed 3150000 out of 5000000 steps (63%)
16:11:55:WU02:FS01:0x23:Completed 150000 out of 1250000 steps (12%)
16:11:56:WU02:FS01:0x23:Checkpoint completed at step 150000
16:12:44:WU02:FS01:0x23:Completed 162500 out of 1250000 steps (13%)
16:12:54:WU00:FS00:0xa8:Completed 3200000 out of 5000000 steps (64%)
16:13:32:WU02:FS01:0x23:Completed 175000 out of 1250000 steps (14%)
16:13:33:WU02:FS01:0x23:Checkpoint completed at step 175000
16:14:21:WU02:FS01:0x23:Completed 187500 out of 1250000 steps (15%)
16:14:34:WU00:FS00:0xa8:Completed 3250000 out of 5000000 steps (65%)
16:15:09:WU02:FS01:0x23:Completed 200000 out of 1250000 steps (16%)
16:15:11:WU02:FS01:0x23:Checkpoint completed at step 200000
16:15:58:WU02:FS01:0x23:Completed 212500 out of 1250000 steps (17%)
16:16:14:WU00:FS00:0xa8:Completed 3300000 out of 5000000 steps (66%)
16:16:47:WU02:FS01:0x23:Completed 225000 out of 1250000 steps (18%)
16:16:48:WU02:FS01:0x23:Checkpoint completed at step 225000
16:17:37:WU02:FS01:0x23:Completed 237500 out of 1250000 steps (19%)
16:17:57:WU00:FS00:0xa8:Completed 3350000 out of 5000000 steps (67%)
16:18:27:WU02:FS01:0x23:Completed 250000 out of 1250000 steps (20%)
16:18:28:WU02:FS01:0x23:Checkpoint completed at step 250000
16:19:17:WU02:FS01:0x23:Completed 262500 out of 1250000 steps (21%)
16:19:27:ERROR:Receive error: 10054: An existing connection was forcibly closed by the remote host.
16:19:42:WU00:FS00:0xa8:Completed 3400000 out of 5000000 steps (68%)
16:20:05:WU02:FS01:0x23:Completed 275000 out of 1250000 steps (22%)
16:20:07:WU02:FS01:0x23:Checkpoint completed at step 275000
16:20:55:WU02:FS01:0x23:Completed 287500 out of 1250000 steps (23%)
16:21:25:WU00:FS00:0xa8:Completed 3450000 out of 5000000 steps (69%)
16:21:46:WU02:FS01:0x23:Completed 300000 out of 1250000 steps (24%)
16:21:47:WU02:FS01:0x23:Checkpoint completed at step 300000
16:22:38:WU02:FS01:0x23:Completed 312500 out of 1250000 steps (25%)
16:23:09:WU00:FS00:0xa8:Completed 3500000 out of 5000000 steps (70%)
16:23:29:WU02:FS01:0x23:Completed 325000 out of 1250000 steps (26%)
16:23:30:WU02:FS01:0x23:Checkpoint completed at step 325000
16:24:20:WU02:FS01:0x23:Completed 337500 out of 1250000 steps (27%)
16:25:00:WU00:FS00:0xa8:Completed 3550000 out of 5000000 steps (71%)
16:25:11:WU02:FS01:0x23:Completed 350000 out of 1250000 steps (28%)
16:25:12:WU02:FS01:0x23:Checkpoint completed at step 350000
16:26:04:WU02:FS01:0x23:Completed 362500 out of 1250000 steps (29%)
16:26:45:WU00:FS00:0xa8:Completed 3600000 out of 5000000 steps (72%)
16:26:55:WU02:FS01:0x23:Completed 375000 out of 1250000 steps (30%)
16:26:56:WU02:FS01:0x23:Checkpoint completed at step 375000
16:27:48:WU02:FS01:0x23:Completed 387500 out of 1250000 steps (31%)
16:28:31:WU00:FS00:0xa8:Completed 3650000 out of 5000000 steps (73%)
16:28:39:WU02:FS01:0x23:Completed 400000 out of 1250000 steps (32%)
16:28:40:WU02:FS01:0x23:Checkpoint completed at step 400000
16:29:32:WU02:FS01:0x23:Completed 412500 out of 1250000 steps (33%)
16:30:18:WU00:FS00:0xa8:Completed 3700000 out of 5000000 steps (74%)
16:30:23:WU02:FS01:0x23:Completed 425000 out of 1250000 steps (34%)
16:30:24:WU02:FS01:0x23:Checkpoint completed at step 425000
16:31:16:WU02:FS01:0x23:Completed 437500 out of 1250000 steps (35%)
16:32:03:WU00:FS00:0xa8:Completed 3750000 out of 5000000 steps (75%)
16:32:06:WU02:FS01:0x23:Completed 450000 out of 1250000 steps (36%)
16:32:07:WU02:FS01:0x23:Checkpoint completed at step 450000
16:32:57:WU02:FS01:0x23:Completed 462500 out of 1250000 steps (37%)
16:33:45:WU02:FS01:0x23:Completed 475000 out of 1250000 steps (38%)
16:33:46:WU02:FS01:0x23:Checkpoint completed at step 475000
16:33:46:WU00:FS00:0xa8:Completed 3800000 out of 5000000 steps (76%)
16:34:34:WU02:FS01:0x23:Completed 487500 out of 1250000 steps (39%)
16:35:22:WU02:FS01:0x23:Completed 500000 out of 1250000 steps (40%)
16:35:23:WU02:FS01:0x23:Checkpoint completed at step 500000
16:35:25:WU00:FS00:0xa8:Completed 3850000 out of 5000000 steps (77%)
16:36:11:WU02:FS01:0x23:Completed 512500 out of 1250000 steps (41%)
16:36:59:WU02:FS01:0x23:Completed 525000 out of 1250000 steps (42%)
16:37:00:WU02:FS01:0x23:Checkpoint completed at step 525000
16:37:04:WU00:FS00:0xa8:Completed 3900000 out of 5000000 steps (78%)
16:37:48:WU02:FS01:0x23:Completed 537500 out of 1250000 steps (43%)
16:38:37:WU02:FS01:0x23:Completed 550000 out of 1250000 steps (44%)
16:38:38:WU02:FS01:0x23:Checkpoint completed at step 550000
16:38:44:WU00:FS00:0xa8:Completed 3950000 out of 5000000 steps (79%)
16:39:26:WU02:FS01:0x23:Completed 562500 out of 1250000 steps (45%)
16:40:14:WU02:FS01:0x23:Completed 575000 out of 1250000 steps (46%)
16:40:15:WU02:FS01:0x23:Checkpoint completed at step 575000
16:40:23:WU00:FS00:0xa8:Completed 4000000 out of 5000000 steps (80%)
16:41:03:WU02:FS01:0x23:Completed 587500 out of 1250000 steps (47%)
16:41:51:WU02:FS01:0x23:Completed 600000 out of 1250000 steps (48%)
16:41:52:WU02:FS01:0x23:Checkpoint completed at step 600000
16:42:03:WU00:FS00:0xa8:Completed 4050000 out of 5000000 steps (81%)
16:42:41:WU02:FS01:0x23:Completed 612500 out of 1250000 steps (49%)
16:43:29:WU02:FS01:0x23:Completed 625000 out of 1250000 steps (50%)
16:43:30:WU02:FS01:0x23:Checkpoint completed at step 625000
16:43:42:WU00:FS00:0xa8:Completed 4100000 out of 5000000 steps (82%)
16:44:18:WU02:FS01:0x23:Completed 637500 out of 1250000 steps (51%)
16:45:06:WU02:FS01:0x23:Completed 650000 out of 1250000 steps (52%)
16:45:07:WU02:FS01:0x23:Checkpoint completed at step 650000
16:45:21:WU00:FS00:0xa8:Completed 4150000 out of 5000000 steps (83%)
16:45:56:WU02:FS01:0x23:Completed 662500 out of 1250000 steps (53%)
16:46:43:WU02:FS01:0x23:Completed 675000 out of 1250000 steps (54%)
16:46:45:WU02:FS01:0x23:Checkpoint completed at step 675000
16:47:00:WU00:FS00:0xa8:Completed 4200000 out of 5000000 steps (84%)
16:47:33:WU02:FS01:0x23:Completed 687500 out of 1250000 steps (55%)
16:48:21:WU02:FS01:0x23:Completed 700000 out of 1250000 steps (56%)
16:48:22:WU02:FS01:0x23:Checkpoint completed at step 700000
16:48:39:WU00:FS00:0xa8:Completed 4250000 out of 5000000 steps (85%)
16:49:10:WU02:FS01:0x23:Completed 712500 out of 1250000 steps (57%)
16:49:58:WU02:FS01:0x23:Completed 725000 out of 1250000 steps (58%)
16:49:59:WU02:FS01:0x23:Checkpoint completed at step 725000
16:50:19:WU00:FS00:0xa8:Completed 4300000 out of 5000000 steps (86%)
16:50:47:WU02:FS01:0x23:Completed 737500 out of 1250000 steps (59%)
16:51:35:WU02:FS01:0x23:Completed 750000 out of 1250000 steps (60%)
16:51:36:WU02:FS01:0x23:Checkpoint completed at step 750000
16:51:58:WU00:FS00:0xa8:Completed 4350000 out of 5000000 steps (87%)
16:52:25:WU02:FS01:0x23:Completed 762500 out of 1250000 steps (61%)
16:53:13:WU02:FS01:0x23:Completed 775000 out of 1250000 steps (62%)
16:53:14:WU02:FS01:0x23:Checkpoint completed at step 775000
16:53:37:WU00:FS00:0xa8:Completed 4400000 out of 5000000 steps (88%)
16:54:02:WU02:FS01:0x23:Completed 787500 out of 1250000 steps (63%)
16:54:50:WU02:FS01:0x23:Completed 800000 out of 1250000 steps (64%)
16:54:51:WU02:FS01:0x23:Checkpoint completed at step 800000
16:55:17:WU00:FS00:0xa8:Completed 4450000 out of 5000000 steps (89%)
16:55:39:WU02:FS01:0x23:Completed 812500 out of 1250000 steps (65%)
16:56:27:WU02:FS01:0x23:Completed 825000 out of 1250000 steps (66%)
16:56:28:WU02:FS01:0x23:Checkpoint completed at step 825000
16:56:56:WU00:FS00:0xa8:Completed 4500000 out of 5000000 steps (90%)
16:57:16:WU02:FS01:0x23:Completed 837500 out of 1250000 steps (67%)
16:58:04:WU02:FS01:0x23:Completed 850000 out of 1250000 steps (68%)
16:58:06:WU02:FS01:0x23:Checkpoint completed at step 850000
16:58:35:WU00:FS00:0xa8:Completed 4550000 out of 5000000 steps (91%)
16:58:54:WU02:FS01:0x23:Completed 862500 out of 1250000 steps (69%)
16:59:42:WU02:FS01:0x23:Completed 875000 out of 1250000 steps (70%)
16:59:43:WU02:FS01:0x23:Checkpoint completed at step 875000
17:00:13:63:127.0.0.1:New Web session
17:00:17:WU00:FS00:0xa8:Completed 4600000 out of 5000000 steps (92%)
17:00:32:ERROR:Receive error: 10054: An existing connection was forcibly closed by the remote host.
17:00:32:WU02:FS01:0x23:Completed 887500 out of 1250000 steps (71%)
17:01:20:WU02:FS01:0x23:Completed 900000 out of 1250000 steps (72%)
17:01:21:WU02:FS01:0x23:Checkpoint completed at step 900000
17:01:57:WU00:FS00:0xa8:Completed 4650000 out of 5000000 steps (93%)
17:02:10:WU02:FS01:0x23:Completed 912500 out of 1250000 steps (73%)
17:02:58:WU02:FS01:0x23:Completed 925000 out of 1250000 steps (74%)
17:02:59:WU02:FS01:0x23:Checkpoint completed at step 925000
17:03:36:WU00:FS00:0xa8:Completed 4700000 out of 5000000 steps (94%)
17:03:47:WU02:FS01:0x23:Completed 937500 out of 1250000 steps (75%)
17:04:35:WU02:FS01:0x23:Completed 950000 out of 1250000 steps (76%)
17:04:36:WU02:FS01:0x23:Checkpoint completed at step 950000
17:05:15:WU00:FS00:0xa8:Completed 4750000 out of 5000000 steps (95%)
17:05:24:WU02:FS01:0x23:Completed 962500 out of 1250000 steps (77%)
17:06:13:WU02:FS01:0x23:Completed 975000 out of 1250000 steps (78%)
17:06:14:WU02:FS01:0x23:Checkpoint completed at step 975000
17:06:54:WU00:FS00:0xa8:Completed 4800000 out of 5000000 steps (96%)
17:07:02:WU02:FS01:0x23:Completed 987500 out of 1250000 steps (79%)
17:07:50:WU02:FS01:0x23:Completed 1000000 out of 1250000 steps (80%)
17:07:51:WU02:FS01:0x23:Checkpoint completed at step 1000000
17:08:33:WU00:FS00:0xa8:Completed 4850000 out of 5000000 steps (97%)
17:08:39:WU02:FS01:0x23:Completed 1012500 out of 1250000 steps (81%)
17:09:27:WU02:FS01:0x23:Completed 1025000 out of 1250000 steps (82%)
17:09:28:WU02:FS01:0x23:Checkpoint completed at step 1025000
17:10:12:WU00:FS00:0xa8:Completed 4900000 out of 5000000 steps (98%)
17:10:16:WU02:FS01:0x23:Completed 1037500 out of 1250000 steps (83%)
17:11:04:WU02:FS01:0x23:Completed 1050000 out of 1250000 steps (84%)
17:11:05:WU02:FS01:0x23:Checkpoint completed at step 1050000
17:11:51:WU00:FS00:0xa8:Completed 4950000 out of 5000000 steps (99%)
17:11:52:WU01:FS00:Connecting to assign1.foldingathome.org:80
17:11:53:WU01:FS00:Assigned to work server 129.32.209.202
17:11:53:WU01:FS00:Requesting new work unit for slot 00: cpu:22 from 129.32.209.202
17:11:53:WU01:FS00:Connecting to 129.32.209.202:8080
17:11:53:WU01:FS00:Downloading 1.35MiB
17:11:53:WU01:FS00:Download complete
17:11:53:WU02:FS01:0x23:Completed 1062500 out of 1250000 steps (85%)
17:11:53:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:12444 run:16 clone:0 gen:18 core:0xa8 unit:0x1200000000000000100000009c300000
17:12:42:WU02:FS01:0x23:Completed 1075000 out of 1250000 steps (86%)
17:12:43:WU02:FS01:0x23:Checkpoint completed at step 1075000
17:13:30:WU00:FS00:0xa8:Completed 5000000 out of 5000000 steps (100%)
17:13:31:WU00:FS00:0xa8:Saving result file ..\logfile_01.txt
17:13:31:WU00:FS00:0xa8:Saving result file dhdl.xvg
17:13:31:WU00:FS00:0xa8:Saving result file frame105.gro
17:13:31:WU00:FS00:0xa8:Saving result file frame105.xtc
17:13:31:WU00:FS00:0xa8:Saving result file md.log
17:13:31:WU00:FS00:0xa8:Saving result file science.log
17:13:31:WU00:FS00:0xa8:Saving result file state.cpt
17:13:31:WU00:FS00:0xa8:Folding@home Core Shutdown: FINISHED_UNIT
17:13:31:WU02:FS01:0x23:Completed 1087500 out of 1250000 steps (87%)
17:13:31:WU00:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
17:13:32:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:12408 run:36 clone:1 gen:105 core:0xa8 unit:0x69000000010000002400000078300000
17:13:32:WU00:FS00:Uploading 9.60MiB to 129.32.209.203
17:13:32:WU00:FS00:Connecting to 129.32.209.203:8080
17:13:32:WU01:FS00:Starting
17:13:32:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit-avx2-256/a8-0.0.12/Core_a8.fah/FahCore_a8.exe -dir 01 -suffix 01 -version 706 -lifeline 4544 -checkpoint 15 -np 22
17:13:32:WU01:FS00:Started FahCore on PID 21612
17:13:33:WU01:FS00:Core PID:20452
17:13:33:WU01:FS00:FahCore 0xa8 started
17:13:34:WU01:FS00:0xa8:*********************** Log Started 2024-02-06T17:13:34Z ***********************
17:13:34:WU01:FS00:0xa8:************************** Gromacs Folding@home Core ***************************
17:13:34:WU01:FS00:0xa8:       Core: Gromacs
17:13:34:WU01:FS00:0xa8:       Type: 0xa8
17:13:34:WU01:FS00:0xa8:    Version: 0.0.12
17:13:34:WU01:FS00:0xa8:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
17:13:34:WU01:FS00:0xa8:  Copyright: 2020 foldingathome.org
17:13:34:WU01:FS00:0xa8:   Homepage: https://foldingathome.org/
17:13:34:WU01:FS00:0xa8:       Date: Jan 16 2021
17:13:34:WU01:FS00:0xa8:       Time: 12:29:40
17:13:34:WU01:FS00:0xa8:   Revision: c5816759c404e4b65f9f364c3d1ef554a67c4225
17:13:34:WU01:FS00:0xa8:     Branch: master
17:13:34:WU01:FS00:0xa8:   Compiler: Visual C++ 2019 16.7
17:13:34:WU01:FS00:0xa8:    Options: /TP /std:c++14 /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
17:13:34:WU01:FS00:0xa8:   Platform: win32 10
17:13:34:WU01:FS00:0xa8:       Bits: 64
17:13:34:WU01:FS00:0xa8:       Mode: Release
17:13:34:WU01:FS00:0xa8:       SIMD: avx2_256
17:13:34:WU01:FS00:0xa8:     OpenMP: ON
17:13:34:WU01:FS00:0xa8:       CUDA: OFF
17:13:34:WU01:FS00:0xa8:       Args: -dir 01 -suffix 01 -version 706 -lifeline 21612 -checkpoint 15 -np
17:13:34:WU01:FS00:0xa8:             22
17:13:34:WU01:FS00:0xa8:************************************ libFAH ************************************
17:13:34:WU01:FS00:0xa8:       Time: 11:24:13
17:13:34:WU01:FS00:0xa8:************************************ CBang *************************************
17:13:34:WU01:FS00:0xa8:       Time: 11:23:53
17:13:34:WU01:FS00:0xa8:************************************ System ************************************
17:13:34:WU01:FS00:0xa8:        CPU: AMD Ryzen 9 7900X 12-Core Processor
17:13:34:WU01:FS00:0xa8:     CPU ID: AuthenticAMD Family 25 Model 97 Stepping 2
17:13:34:WU01:FS00:0xa8:       CPUs: 24
17:13:34:WU01:FS00:0xa8:     Memory: 31.71GiB
17:13:34:WU01:FS00:0xa8:Free Memory: 18.08GiB
17:13:34:WU01:FS00:0xa8:    Threads: WINDOWS_THREADS
17:13:34:WU01:FS00:0xa8: OS Version: 6.2
17:13:34:WU01:FS00:0xa8:Has Battery: true
17:13:34:WU01:FS00:0xa8: On Battery: false
17:13:34:WU01:FS00:0xa8: UTC Offset: -5
17:13:34:WU01:FS00:0xa8:        PID: 20452
17:13:34:WU01:FS00:0xa8:        CWD: C:\ProgramData\FAHClient\work
17:13:34:WU01:FS00:0xa8:********************************************************************************
17:13:34:WU01:FS00:0xa8:Project: 12444 (Run 16, Clone 0, Gen 18)
17:13:34:WU01:FS00:0xa8:Unit: 0x00000000000000000000000000000000
17:13:34:WU01:FS00:0xa8:Reading tar file core.xml
17:13:34:WU01:FS00:0xa8:Reading tar file frame18.tpr
17:13:34:WU01:FS00:0xa8:Digital signatures verified
17:13:34:WU01:FS00:0xa8:Calling: mdrun -c frame18.gro -s frame18.tpr -x frame18.xtc -cpt 15 -nt 22 -ntmpi 1
17:13:34:WU01:FS00:0xa8:Steps: first=45000000 total=47500000
17:13:35:WU01:FS00:0xa8:Completed 1 out of 2500000 steps (0%)
17:13:37:WU00:FS00:Upload complete
17:13:37:WU00:FS00:Server responded WORK_ACK (400)
17:13:37:WU00:FS00:Final credit estimate, 47022.00 points
17:13:37:WU00:FS00:Cleaning up
17:14:19:WU02:FS01:0x23:Completed 1100000 out of 1250000 steps (88%)
17:14:20:WU02:FS01:0x23:Checkpoint completed at step 1100000
17:14:23:WU01:FS00:0xa8:Completed 25000 out of 2500000 steps (1%)
17:15:08:WU02:FS01:0x23:Completed 1112500 out of 1250000 steps (89%)
17:15:11:WU01:FS00:0xa8:Completed 50000 out of 2500000 steps (2%)
17:15:56:WU02:FS01:0x23:Completed 1125000 out of 1250000 steps (90%)
17:15:57:WU02:FS01:0x23:Checkpoint completed at step 1125000
17:15:59:WU01:FS00:0xa8:Completed 75000 out of 2500000 steps (3%)
17:16:45:WU02:FS01:0x23:Completed 1137500 out of 1250000 steps (91%)
17:16:47:WU01:FS00:0xa8:Completed 100000 out of 2500000 steps (4%)
17:17:33:WU02:FS01:0x23:Completed 1150000 out of 1250000 steps (92%)
17:17:34:WU02:FS01:0x23:Checkpoint completed at step 1150000
17:17:35:WU01:FS00:0xa8:Completed 125000 out of 2500000 steps (5%)
17:18:22:WU01:FS00:0xa8:Completed 150000 out of 2500000 steps (6%)
17:18:23:WU02:FS01:0x23:Completed 1162500 out of 1250000 steps (93%)
17:19:10:WU01:FS00:0xa8:Completed 175000 out of 2500000 steps (7%)
17:19:11:WU02:FS01:0x23:Completed 1175000 out of 1250000 steps (94%)
17:19:12:WU02:FS01:0x23:Checkpoint completed at step 1175000
17:19:58:WU01:FS00:0xa8:Completed 200000 out of 2500000 steps (8%)
17:20:00:WU02:FS01:0x23:Completed 1187500 out of 1250000 steps (95%)
17:20:46:WU01:FS00:0xa8:Completed 225000 out of 2500000 steps (9%)
17:20:48:WU02:FS01:0x23:Completed 1200000 out of 1250000 steps (96%)
17:20:49:WU02:FS01:0x23:Checkpoint completed at step 1200000
17:21:34:WU01:FS00:0xa8:Completed 250000 out of 2500000 steps (10%)
17:21:37:WU02:FS01:0x23:Completed 1212500 out of 1250000 steps (97%)
17:22:22:WU01:FS00:0xa8:Completed 275000 out of 2500000 steps (11%)
17:22:25:WU02:FS01:0x23:Completed 1225000 out of 1250000 steps (98%)
17:22:26:WU02:FS01:0x23:Checkpoint completed at step 1225000
17:23:10:WU01:FS00:0xa8:Completed 300000 out of 2500000 steps (12%)
17:23:14:WU02:FS01:0x23:Completed 1237500 out of 1250000 steps (99%)
17:23:15:WU00:FS01:Connecting to assign1.foldingathome.org:80
17:23:16:WU00:FS01:Assigned to work server 158.130.118.24
17:23:16:WU00:FS01:Requesting new work unit for slot 01: gpu:1:0 AD104 [GeForce RTX 4070] from 158.130.118.24
17:23:16:WU00:FS01:Connecting to 158.130.118.24:8080
17:23:17:WU00:FS01:Downloading 23.43MiB
17:23:17:WU00:FS01:Download complete
17:23:17:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:18219 run:7318 clone:0 gen:5 core:0x23 unit:0x00000000000000050000472b00001c96
17:23:58:WU01:FS00:0xa8:Completed 325000 out of 2500000 steps (13%)
17:24:02:WU02:FS01:0x23:Completed 1250000 out of 1250000 steps (100%)
17:24:02:WU02:FS01:0x23:Average performance: 90 ns/day
17:24:03:WU02:FS01:0x23:Checkpoint completed at step 1250000
17:24:15:WU02:FS01:0x23:Saving result file ..\logfile_01.txt
17:24:15:WU02:FS01:0x23:Saving result file checkpointIntegrator.xml
17:24:15:WU02:FS01:0x23:Saving result file checkpointState.xml.bz2
17:24:15:WU02:FS01:0x23:Saving result file positions.xtc
17:24:15:WU02:FS01:0x23:Saving result file science.log
17:24:15:WU02:FS01:0x23:Saving result file xtcAtoms.csv.bz2
17:24:15:WU02:FS01:0x23:Folding@home Core Shutdown: FINISHED_UNIT
17:24:17:WU02:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
17:24:17:WU02:FS01:Sending unit results: id:02 state:SEND error:NO_ERROR project:18218 run:4790 clone:0 gen:9 core:0x23 unit:0x00000000000000090000472a000012b6
17:24:17:WU02:FS01:Uploading 23.80MiB to 158.130.118.25
17:24:17:WU00:FS01:Starting
17:24:17:WU02:FS01:Connecting to 158.130.118.25:8080
17:24:17:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/openmm-core-23/windows-10-64bit/release/0x23-8.0.3/Core_23.fah/FahCore_23.exe -dir 00 -suffix 01 -version 706 -lifeline 4544 -checkpoint 15 -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100
17:24:17:WU00:FS01:Started FahCore on PID 27828
17:24:18:WU00:FS01:Core PID:5256
17:24:18:WU00:FS01:FahCore 0x23 started
17:24:18:WU00:FS01:0x23:*********************** Log Started 2024-02-06T17:24:18Z ***********************
17:24:18:WU00:FS01:0x23:*************************** Core23 Folding@home Core ***************************
17:24:18:WU00:FS01:0x23:       Core: Core23
17:24:18:WU00:FS01:0x23:       Type: 0x23
17:24:18:WU00:FS01:0x23:    Version: 8.0.3
17:24:18:WU00:FS01:0x23:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
17:24:18:WU00:FS01:0x23:  Copyright: 2022 foldingathome.org
17:24:18:WU00:FS01:0x23:   Homepage: https://foldingathome.org/
17:24:18:WU00:FS01:0x23:       Date: Aug 3 2023
17:24:18:WU00:FS01:0x23:       Time: 08:39:06
17:24:18:WU00:FS01:0x23:   Compiler: Visual C++
17:24:18:WU00:FS01:0x23:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
17:24:18:WU00:FS01:0x23:             -DOPENMM_VERSION="\"8.0.0\""
17:24:18:WU00:FS01:0x23:   Platform: win32 10
17:24:18:WU00:FS01:0x23:       Bits: 64
17:24:18:WU00:FS01:0x23:       Mode: Release
17:24:18:WU00:FS01:0x23:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
17:24:18:WU00:FS01:0x23:             <peastman@stanford.edu>
17:24:18:WU00:FS01:0x23:       Args: -dir 00 -suffix 01 -version 706 -lifeline 27828 -checkpoint 15
17:24:18:WU00:FS01:0x23:             -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor
17:24:18:WU00:FS01:0x23:             nvidia -gpu 0 -gpu-usage 100
17:24:18:WU00:FS01:0x23:************************************ libFAH ************************************
17:24:18:WU00:FS01:0x23:       Time: 08:37:55
17:24:18:WU00:FS01:0x23:************************************ CBang *************************************
17:24:18:WU00:FS01:0x23:    Version: 1.7.2
17:24:18:WU00:FS01:0x23:        Org: Cauldron Development LLC
17:24:18:WU00:FS01:0x23:  Copyright: Cauldron Development LLC, 2003-2023
17:24:18:WU00:FS01:0x23:   Homepage: https://cauldrondevelopment.com/
17:24:18:WU00:FS01:0x23:    License: GPL 2+
17:24:18:WU00:FS01:0x23:       Time: 08:37:14
17:24:18:WU00:FS01:0x23:************************************ System ************************************
17:24:18:WU00:FS01:0x23:        CPU: AMD Ryzen 9 7900X 12-Core Processor
17:24:18:WU00:FS01:0x23:     CPU ID: AuthenticAMD Family 25 Model 97 Stepping 2
17:24:18:WU00:FS01:0x23:       CPUs: 24
17:24:18:WU00:FS01:0x23:     Memory: 31.71GiB
17:24:18:WU00:FS01:0x23:Free Memory: 19.56GiB
17:24:18:WU00:FS01:0x23:    Threads: WINDOWS_THREADS
17:24:18:WU00:FS01:0x23: OS Version: 6.2
17:24:18:WU00:FS01:0x23:Has Battery: true
17:24:18:WU00:FS01:0x23: On Battery: false
17:24:18:WU00:FS01:0x23: UTC Offset: -5
17:24:18:WU00:FS01:0x23:        PID: 5256
17:24:18:WU00:FS01:0x23:        CWD: C:\ProgramData\FAHClient\work
17:24:18:WU00:FS01:0x23:       Exec: C:\ProgramData\FAHClient\cores\cores.foldingathome.org\openmm-core-23\windows-10-64bit\release\0x23-8.0.3\Core_23.fah\FahCore_23.exe
17:24:18:WU00:FS01:0x23:************************************ OpenMM ************************************
17:24:18:WU00:FS01:0x23:    Version: 8.0.0
17:24:18:WU00:FS01:0x23:********************************************************************************
17:24:18:WU00:FS01:0x23:Project: 18219 (Run 7318, Clone 0, Gen 5)
17:24:18:WU00:FS01:0x23:Reading tar file core.xml
17:24:18:WU00:FS01:0x23:Reading tar file integrator.xml
17:24:18:WU00:FS01:0x23:Reading tar file state.xml.bz2
17:24:18:WU00:FS01:0x23:Reading tar file system.xml.bz2
17:24:18:WU00:FS01:0x23:Digital signatures verified
17:24:18:WU00:FS01:0x23:Folding@home GPU Core23 Folding@home Core
17:24:18:WU00:FS01:0x23:Version 8.0.3
17:24:18:WU00:FS01:0x23:  Checkpoint write interval: 25000 steps (2%) [50 total]
17:24:18:WU00:FS01:0x23:  JSON viewer frame write interval: 12500 steps (1%) [100 total]
17:24:18:WU00:FS01:0x23:  XTC frame write interval: 10000 steps (0.8%) [125 total]
17:24:18:WU00:FS01:0x23:  Global context and integrator variables write interval: disabled
17:24:18:WU00:FS01:0x23:There are 4 platforms available.
17:24:18:WU00:FS01:0x23:Platform 0: Reference
17:24:18:WU00:FS01:0x23:Platform 1: CPU
17:24:18:WU00:FS01:0x23:Platform 2: OpenCL
17:24:18:WU00:FS01:0x23:  opencl-device 0 specified
17:24:18:WU00:FS01:0x23:Platform 3: CUDA
17:24:18:WU00:FS01:0x23:  cuda-device 0 specified
17:24:20:WU02:FS01:Upload complete
17:24:21:WU02:FS01:Server responded WORK_ACK (400)
17:24:21:WU02:FS01:Final credit estimate, 538061.00 points
17:24:21:WU02:FS01:Cleaning up
17:24:41:WU00:FS01:0x23:Attempting to create CUDA context:
17:24:41:WU00:FS01:0x23:  Configuring platform CUDA
17:24:41:WU01:FS00:0xa8:Completed 350000 out of 2500000 steps (14%)
17:24:47:WU00:FS01:0x23:  Using CUDA on CUDA Platform and gpu 0
17:24:47:WU00:FS01:0x23:  GPU info: Platform: CUDA
17:24:47:WU00:FS01:0x23:  GPU info: PlatformIndex: 0
17:24:47:WU00:FS01:0x23:  GPU info: Device: NVIDIA GeForce RTX 4070
17:24:47:WU00:FS01:0x23:  GPU info: DeviceIndex: 0
17:24:47:WU00:FS01:0x23:  GPU info: Vendor: 0x10de
17:24:47:WU00:FS01:0x23:  GPU info: PCI: 01:00:00
17:24:47:WU00:FS01:0x23:  GPU info: Compute: 8.9
17:24:47:WU00:FS01:0x23:  GPU info: Driver: 12.3
17:24:47:WU00:FS01:0x23:  GPU info: GPU: true
17:24:47:WU00:FS01:0x23:Completed 0 out of 1250000 steps (0%)
17:24:48:WU00:FS01:0x23:Checkpoint completed at step 0
17:25:29:WU01:FS00:0xa8:Completed 375000 out of 2500000 steps (15%)
17:25:37:WU00:FS01:0x23:Completed 12500 out of 1250000 steps (1%)
17:26:16:WU01:FS00:0xa8:Completed 400000 out of 2500000 steps (16%)
17:26:25:WU00:FS01:0x23:Completed 25000 out of 1250000 steps (2%)
17:26:26:WU00:FS01:0x23:Checkpoint completed at step 25000
17:27:05:WU01:FS00:0xa8:Completed 425000 out of 2500000 steps (17%)
17:27:14:WU00:FS01:0x23:Completed 37500 out of 1250000 steps (3%)
17:27:53:WU01:FS00:0xa8:Completed 450000 out of 2500000 steps (18%)
17:28:02:WU00:FS01:0x23:Completed 50000 out of 1250000 steps (4%)
17:28:03:WU00:FS01:0x23:Checkpoint completed at step 50000
17:28:40:WU01:FS00:0xa8:Completed 475000 out of 2500000 steps (19%)
17:28:52:WU00:FS01:0x23:Completed 62500 out of 1250000 steps (5%)
17:29:28:WU01:FS00:0xa8:Completed 500000 out of 2500000 steps (20%)
17:29:40:WU00:FS01:0x23:Completed 75000 out of 1250000 steps (6%)
17:29:41:WU00:FS01:0x23:Checkpoint completed at step 75000
17:30:16:WU01:FS00:0xa8:Completed 525000 out of 2500000 steps (21%)
17:30:29:WU00:FS01:0x23:Completed 87500 out of 1250000 steps (7%)
17:31:03:WU01:FS00:0xa8:Completed 550000 out of 2500000 steps (22%)
17:31:17:WU00:FS01:0x23:Completed 100000 out of 1250000 steps (8%)
17:31:18:WU00:FS01:0x23:Checkpoint completed at step 100000
17:31:51:WU01:FS00:0xa8:Completed 575000 out of 2500000 steps (23%)
17:32:06:WU00:FS01:0x23:Completed 112500 out of 1250000 steps (9%)
17:32:38:WU01:FS00:0xa8:Completed 600000 out of 2500000 steps (24%)
17:32:54:WU00:FS01:0x23:Completed 125000 out of 1250000 steps (10%)
17:32:55:WU00:FS01:0x23:Checkpoint completed at step 125000
sweldon001
Re: log file posting.
Post by sweldon001 »
17:33:26:WU01:FS00:0xa8:Completed 625000 out of 2500000 steps (25%)
17:33:44:WU00:FS01:0x23:Completed 137500 out of 1250000 steps (11%)
17:34:14:WU01:FS00:0xa8:Completed 650000 out of 2500000 steps (26%)
17:34:32:WU00:FS01:0x23:Completed 150000 out of 1250000 steps (12%)
17:34:33:WU00:FS01:0x23:Checkpoint completed at step 150000
17:35:02:WU01:FS00:0xa8:Completed 675000 out of 2500000 steps (27%)
17:35:21:WU00:FS01:0x23:Completed 162500 out of 1250000 steps (13%)
17:35:49:WU01:FS00:0xa8:Completed 700000 out of 2500000 steps (28%)
17:36:09:WU00:FS01:0x23:Completed 175000 out of 1250000 steps (14%)
17:36:10:WU00:FS01:0x23:Checkpoint completed at step 175000
17:36:37:WU01:FS00:0xa8:Completed 725000 out of 2500000 steps (29%)
17:36:58:WU00:FS01:0x23:Completed 187500 out of 1250000 steps (15%)
17:37:24:WU01:FS00:0xa8:Completed 750000 out of 2500000 steps (30%)
17:37:46:WU00:FS01:0x23:Completed 200000 out of 1250000 steps (16%)
17:37:47:WU00:FS01:0x23:Checkpoint completed at step 200000
17:38:12:WU01:FS00:0xa8:Completed 775000 out of 2500000 steps (31%)
17:38:36:WU00:FS01:0x23:Completed 212500 out of 1250000 steps (17%)
17:38:59:WU01:FS00:0xa8:Completed 800000 out of 2500000 steps (32%)
17:39:24:WU00:FS01:0x23:Completed 225000 out of 1250000 steps (18%)
17:39:25:WU00:FS01:0x23:Checkpoint completed at step 225000
17:39:47:WU01:FS00:0xa8:Completed 825000 out of 2500000 steps (33%)
17:40:13:WU00:FS01:0x23:Completed 237500 out of 1250000 steps (19%)
17:40:35:WU01:FS00:0xa8:Completed 850000 out of 2500000 steps (34%)
17:41:01:WU00:FS01:0x23:Completed 250000 out of 1250000 steps (20%)
17:41:02:WU00:FS01:0x23:Checkpoint completed at step 250000
17:41:23:WU01:FS00:0xa8:Completed 875000 out of 2500000 steps (35%)
17:41:50:WU00:FS01:0x23:Completed 262500 out of 1250000 steps (21%)
17:42:11:WU01:FS00:0xa8:Completed 900000 out of 2500000 steps (36%)
17:42:38:WU00:FS01:0x23:Completed 275000 out of 1250000 steps (22%)
17:42:39:WU00:FS01:0x23:Checkpoint completed at step 275000
17:42:58:WU01:FS00:0xa8:Completed 925000 out of 2500000 steps (37%)
17:43:27:WU00:FS01:0x23:Completed 287500 out of 1250000 steps (23%)
17:43:46:WU01:FS00:0xa8:Completed 950000 out of 2500000 steps (38%)
17:44:15:WU00:FS01:0x23:Completed 300000 out of 1250000 steps (24%)
17:44:17:WU00:FS01:0x23:Checkpoint completed at step 300000
17:44:34:WU01:FS00:0xa8:Completed 975000 out of 2500000 steps (39%)
17:45:04:WU00:FS01:0x23:Completed 312500 out of 1250000 steps (25%)
17:45:21:WU01:FS00:0xa8:Completed 1000000 out of 2500000 steps (40%)
17:45:53:WU00:FS01:0x23:Completed 325000 out of 1250000 steps (26%)
17:45:54:WU00:FS01:0x23:Checkpoint completed at step 325000
17:46:09:WU01:FS00:0xa8:Completed 1025000 out of 2500000 steps (41%)
17:46:42:WU00:FS01:0x23:Completed 337500 out of 1250000 steps (27%)
17:46:57:WU01:FS00:0xa8:Completed 1050000 out of 2500000 steps (42%)
17:47:30:WU00:FS01:0x23:Completed 350000 out of 1250000 steps (28%)
17:47:31:WU00:FS01:0x23:Checkpoint completed at step 350000
17:47:44:WU01:FS00:0xa8:Completed 1075000 out of 2500000 steps (43%)
17:48:19:WU00:FS01:0x23:Completed 362500 out of 1250000 steps (29%)
17:48:32:WU01:FS00:0xa8:Completed 1100000 out of 2500000 steps (44%)
17:49:08:WU00:FS01:0x23:Completed 375000 out of 1250000 steps (30%)
17:49:09:WU00:FS01:0x23:Checkpoint completed at step 375000
17:49:20:WU01:FS00:0xa8:Completed 1125000 out of 2500000 steps (45%)
17:49:57:WU00:FS01:0x23:Completed 387500 out of 1250000 steps (31%)
17:50:07:WU01:FS00:0xa8:Completed 1150000 out of 2500000 steps (46%)
17:50:45:WU00:FS01:0x23:Completed 400000 out of 1250000 steps (32%)
17:50:46:WU00:FS01:0x23:Checkpoint completed at step 400000
17:50:55:WU01:FS00:0xa8:Completed 1175000 out of 2500000 steps (47%)
17:51:34:WU00:FS01:0x23:Completed 412500 out of 1250000 steps (33%)
17:51:42:WU01:FS00:0xa8:Completed 1200000 out of 2500000 steps (48%)
17:52:22:WU00:FS01:0x23:Completed 425000 out of 1250000 steps (34%)
17:52:23:WU00:FS01:0x23:Checkpoint completed at step 425000
17:52:30:WU01:FS00:0xa8:Completed 1225000 out of 2500000 steps (49%)
17:53:11:WU00:FS01:0x23:Completed 437500 out of 1250000 steps (35%)
17:53:17:WU01:FS00:0xa8:Completed 1250000 out of 2500000 steps (50%)
17:54:00:WU00:FS01:0x23:Completed 450000 out of 1250000 steps (36%)
17:54:01:WU00:FS01:0x23:Checkpoint completed at step 450000
17:54:05:WU01:FS00:0xa8:Completed 1275000 out of 2500000 steps (51%)
17:54:49:WU00:FS01:0x23:Completed 462500 out of 1250000 steps (37%)
17:54:52:WU01:FS00:0xa8:Completed 1300000 out of 2500000 steps (52%)
17:55:37:WU00:FS01:0x23:Completed 475000 out of 1250000 steps (38%)
17:55:38:WU00:FS01:0x23:Checkpoint completed at step 475000
17:55:40:WU01:FS00:0xa8:Completed 1325000 out of 2500000 steps (53%)
17:56:26:WU00:FS01:0x23:Completed 487500 out of 1250000 steps (39%)
17:56:27:WU01:FS00:0xa8:Completed 1350000 out of 2500000 steps (54%)
17:57:14:WU00:FS01:0x23:Completed 500000 out of 1250000 steps (40%)
17:57:15:WU01:FS00:0xa8:Completed 1375000 out of 2500000 steps (55%)
17:57:15:WU00:FS01:0x23:Checkpoint completed at step 500000
17:58:03:WU01:FS00:0xa8:Completed 1400000 out of 2500000 steps (56%)
17:58:03:WU00:FS01:0x23:Completed 512500 out of 1250000 steps (41%)
17:58:50:WU01:FS00:0xa8:Completed 1425000 out of 2500000 steps (57%)
17:58:51:WU00:FS01:0x23:Completed 525000 out of 1250000 steps (42%)
17:58:52:WU00:FS01:0x23:Checkpoint completed at step 525000
17:59:38:WU01:FS00:0xa8:Completed 1450000 out of 2500000 steps (58%)
17:59:40:WU00:FS01:0x23:Completed 537500 out of 1250000 steps (43%)
18:00:26:WU01:FS00:0xa8:Completed 1475000 out of 2500000 steps (59%)
18:00:28:WU00:FS01:0x23:Completed 550000 out of 1250000 steps (44%)
18:00:29:WU00:FS01:0x23:Checkpoint completed at step 550000
18:01:14:WU01:FS00:0xa8:Completed 1500000 out of 2500000 steps (60%)
18:01:17:WU00:FS01:0x23:Completed 562500 out of 1250000 steps (45%)
18:02:01:WU01:FS00:0xa8:Completed 1525000 out of 2500000 steps (61%)
18:02:05:WU00:FS01:0x23:Completed 575000 out of 1250000 steps (46%)
18:02:06:WU00:FS01:0x23:Checkpoint completed at step 575000
18:02:49:WU01:FS00:0xa8:Completed 1550000 out of 2500000 steps (62%)
18:02:54:WU00:FS01:0x23:Completed 587500 out of 1250000 steps (47%)
18:03:37:WU01:FS00:0xa8:Completed 1575000 out of 2500000 steps (63%)
18:03:42:WU00:FS01:0x23:Completed 600000 out of 1250000 steps (48%)
18:03:43:WU00:FS01:0x23:Checkpoint completed at step 600000
18:04:24:WU01:FS00:0xa8:Completed 1600000 out of 2500000 steps (64%)
18:04:31:WU00:FS01:0x23:Completed 612500 out of 1250000 steps (49%)
18:05:13:WU01:FS00:0xa8:Completed 1625000 out of 2500000 steps (65%)
18:05:19:WU00:FS01:0x23:Completed 625000 out of 1250000 steps (50%)
18:05:20:WU00:FS01:0x23:Checkpoint completed at step 625000
18:06:01:WU01:FS00:0xa8:Completed 1650000 out of 2500000 steps (66%)
18:06:08:WU00:FS01:0x23:Completed 637500 out of 1250000 steps (51%)
18:06:48:WU01:FS00:0xa8:Completed 1675000 out of 2500000 steps (67%)
18:06:56:WU00:FS01:0x23:Completed 650000 out of 1250000 steps (52%)
18:06:57:WU00:FS01:0x23:Checkpoint completed at step 650000
18:07:36:WU01:FS00:0xa8:Completed 1700000 out of 2500000 steps (68%)
18:07:45:WU00:FS01:0x23:Completed 662500 out of 1250000 steps (53%)
18:08:23:WU01:FS00:0xa8:Completed 1725000 out of 2500000 steps (69%)
18:08:33:WU00:FS01:0x23:Completed 675000 out of 1250000 steps (54%)
18:08:34:WU00:FS01:0x23:Checkpoint completed at step 675000
18:09:11:WU01:FS00:0xa8:Completed 1750000 out of 2500000 steps (70%)
18:09:23:WU00:FS01:0x23:Completed 687500 out of 1250000 steps (55%)
18:09:59:WU01:FS00:0xa8:Completed 1775000 out of 2500000 steps (71%)
18:10:10:WU00:FS01:0x23:Completed 700000 out of 1250000 steps (56%)
18:10:11:WU00:FS01:0x23:Checkpoint completed at step 700000
18:10:46:WU01:FS00:0xa8:Completed 1800000 out of 2500000 steps (72%)
18:11:00:WU00:FS01:0x23:Completed 712500 out of 1250000 steps (57%)
18:11:34:WU01:FS00:0xa8:Completed 1825000 out of 2500000 steps (73%)
18:11:48:WU00:FS01:0x23:Completed 725000 out of 1250000 steps (58%)
18:11:49:WU00:FS01:0x23:Checkpoint completed at step 725000
18:12:21:WU01:FS00:0xa8:Completed 1850000 out of 2500000 steps (74%)
18:12:37:WU00:FS01:0x23:Completed 737500 out of 1250000 steps (59%)
18:13:09:WU01:FS00:0xa8:Completed 1875000 out of 2500000 steps (75%)
18:13:25:WU00:FS01:0x23:Completed 750000 out of 1250000 steps (60%)
18:13:26:WU00:FS01:0x23:Checkpoint completed at step 750000
18:13:57:WU01:FS00:0xa8:Completed 1900000 out of 2500000 steps (76%)
18:14:14:WU00:FS01:0x23:Completed 762500 out of 1250000 steps (61%)
18:14:44:WU01:FS00:0xa8:Completed 1925000 out of 2500000 steps (77%)
18:15:02:WU00:FS01:0x23:Completed 775000 out of 1250000 steps (62%)
18:15:03:WU00:FS01:0x23:Checkpoint completed at step 775000
18:15:32:WU01:FS00:0xa8:Completed 1950000 out of 2500000 steps (78%)
18:15:51:WU00:FS01:0x23:Completed 787500 out of 1250000 steps (63%)
18:16:19:WU01:FS00:0xa8:Completed 1975000 out of 2500000 steps (79%)
18:16:39:WU00:FS01:0x23:Completed 800000 out of 1250000 steps (64%)
18:16:40:WU00:FS01:0x23:Checkpoint completed at step 800000
18:17:07:WU01:FS00:0xa8:Completed 2000000 out of 2500000 steps (80%)
18:17:28:WU00:FS01:0x23:Completed 812500 out of 1250000 steps (65%)
18:17:54:WU01:FS00:0xa8:Completed 2025000 out of 2500000 steps (81%)
18:18:16:WU00:FS01:0x23:Completed 825000 out of 1250000 steps (66%)
18:18:17:WU00:FS01:0x23:Checkpoint completed at step 825000
18:18:42:WU01:FS00:0xa8:Completed 2050000 out of 2500000 steps (82%)
18:19:05:WU00:FS01:0x23:Completed 837500 out of 1250000 steps (67%)
18:19:29:WU01:FS00:0xa8:Completed 2075000 out of 2500000 steps (83%)
18:19:53:WU00:FS01:0x23:Completed 850000 out of 1250000 steps (68%)
18:19:54:WU00:FS01:0x23:Checkpoint completed at step 850000
18:20:17:WU01:FS00:0xa8:Completed 2100000 out of 2500000 steps (84%)
18:20:42:WU00:FS01:0x23:Completed 862500 out of 1250000 steps (69%)
18:21:05:WU01:FS00:0xa8:Completed 2125000 out of 2500000 steps (85%)
18:21:30:WU00:FS01:0x23:Completed 875000 out of 1250000 steps (70%)
18:21:31:WU00:FS01:0x23:Checkpoint completed at step 875000
18:21:52:WU01:FS00:0xa8:Completed 2150000 out of 2500000 steps (86%)
18:22:19:WU00:FS01:0x23:Completed 887500 out of 1250000 steps (71%)
18:22:40:WU01:FS00:0xa8:Completed 2175000 out of 2500000 steps (87%)
18:23:07:WU00:FS01:0x23:Completed 900000 out of 1250000 steps (72%)
18:23:08:WU00:FS01:0x23:Checkpoint completed at step 900000
18:23:27:WU01:FS00:0xa8:Completed 2200000 out of 2500000 steps (88%)
18:23:56:WU00:FS01:0x23:Completed 912500 out of 1250000 steps (73%)
18:24:15:WU01:FS00:0xa8:Completed 2225000 out of 2500000 steps (89%)
18:24:44:WU00:FS01:0x23:Completed 925000 out of 1250000 steps (74%)
18:24:45:WU00:FS01:0x23:Checkpoint completed at step 925000
18:25:03:WU01:FS00:0xa8:Completed 2250000 out of 2500000 steps (90%)
18:25:33:WU00:FS01:0x23:Completed 937500 out of 1250000 steps (75%)
18:25:50:WU01:FS00:0xa8:Completed 2275000 out of 2500000 steps (91%)
18:26:21:WU00:FS01:0x23:Completed 950000 out of 1250000 steps (76%)
18:26:22:WU00:FS01:0x23:Checkpoint completed at step 950000
18:26:39:WU01:FS00:0xa8:Completed 2300000 out of 2500000 steps (92%)
18:27:10:WU00:FS01:0x23:Completed 962500 out of 1250000 steps (77%)
18:27:27:WU01:FS00:0xa8:Completed 2325000 out of 2500000 steps (93%)
18:27:58:WU00:FS01:0x23:Completed 975000 out of 1250000 steps (78%)
18:27:59:WU00:FS01:0x23:Checkpoint completed at step 975000
18:28:14:WU01:FS00:0xa8:Completed 2350000 out of 2500000 steps (94%)
18:28:47:WU00:FS01:0x23:Completed 987500 out of 1250000 steps (79%)
18:29:02:WU01:FS00:0xa8:Completed 2375000 out of 2500000 steps (95%)
18:29:35:WU00:FS01:0x23:Completed 1000000 out of 1250000 steps (80%)
18:29:36:WU00:FS01:0x23:Checkpoint completed at step 1000000
18:29:50:WU01:FS00:0xa8:Completed 2400000 out of 2500000 steps (96%)
18:30:24:WU00:FS01:0x23:Completed 1012500 out of 1250000 steps (81%)
18:30:38:WU01:FS00:0xa8:Completed 2425000 out of 2500000 steps (97%)
18:31:12:WU00:FS01:0x23:Completed 1025000 out of 1250000 steps (82%)
18:31:13:WU00:FS01:0x23:Checkpoint completed at step 1025000
18:31:25:WU01:FS00:0xa8:Completed 2450000 out of 2500000 steps (98%)
18:32:01:WU00:FS01:0x23:Completed 1037500 out of 1250000 steps (83%)
18:32:13:WU01:FS00:0xa8:Completed 2475000 out of 2500000 steps (99%)
18:32:13:WU02:FS00:Connecting to assign1.foldingathome.org:80
18:32:14:WU02:FS00:Assigned to work server 129.32.209.205
18:32:14:WU02:FS00:Requesting new work unit for slot 00: cpu:22 from 129.32.209.205
18:32:14:WU02:FS00:Connecting to 129.32.209.205:8080
18:32:14:WU02:FS00:Downloading 480.00KiB
18:32:14:WU02:FS00:Download complete
18:32:14:WU02:FS00:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:18492 run:34 clone:91 gen:54 core:0xa8 unit:0x360000005b000000220000003c480000
18:32:49:WU00:FS01:0x23:Completed 1050000 out of 1250000 steps (84%)
18:32:50:WU00:FS01:0x23:Checkpoint completed at step 1050000
18:33:00:WU01:FS00:0xa8:Completed 2500000 out of 2500000 steps (100%)
18:33:01:WU01:FS00:0xa8:Saving result file ..\logfile_01.txt
18:33:01:WU01:FS00:0xa8:Saving result file frame18.gro
18:33:01:WU01:FS00:0xa8:Saving result file frame18.xtc
18:33:01:WU01:FS00:0xa8:Saving result file md.log
18:33:01:WU01:FS00:0xa8:Saving result file science.log
18:33:01:WU01:FS00:0xa8:Saving result file state.cpt
18:33:01:WU01:FS00:0xa8:Folding@home Core Shutdown: FINISHED_UNIT
18:33:02:WU01:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
18:33:02:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:12444 run:16 clone:0 gen:18 core:0xa8 unit:0x1200000000000000100000009c300000
18:33:02:WU01:FS00:Uploading 3.48MiB to 129.32.209.202
18:33:02:WU02:FS00:Starting
18:33:02:WU01:FS00:Connecting to 129.32.209.202:8080
18:33:02:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit-avx2-256/a8-0.0.12/Core_a8.fah/FahCore_a8.exe -dir 02 -suffix 01 -version 706 -lifeline 4544 -checkpoint 15 -np 22
18:33:02:WU02:FS00:Started FahCore on PID 28156
18:33:03:WU02:FS00:Core PID:2852
18:33:03:WU02:FS00:FahCore 0xa8 started
18:33:03:WU02:FS00:0xa8:*********************** Log Started 2024-02-06T18:33:03Z ***********************
18:33:03:WU02:FS00:0xa8:************************** Gromacs Folding@home Core ***************************
18:33:03:WU02:FS00:0xa8:       Core: Gromacs
18:33:03:WU02:FS00:0xa8:       Type: 0xa8
18:33:03:WU02:FS00:0xa8:    Version: 0.0.12
18:33:03:WU02:FS00:0xa8:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
18:33:03:WU02:FS00:0xa8:  Copyright: 2020 foldingathome.org
18:33:03:WU02:FS00:0xa8:   Homepage: https://foldingathome.org/
18:33:03:WU02:FS00:0xa8:       Date: Jan 16 2021
18:33:03:WU02:FS00:0xa8:       Time: 12:29:40
18:33:03:WU02:FS00:0xa8:   Revision: c5816759c404e4b65f9f364c3d1ef554a67c4225
18:33:03:WU02:FS00:0xa8:     Branch: master
18:33:03:WU02:FS00:0xa8:   Compiler: Visual C++ 2019 16.7
18:33:03:WU02:FS00:0xa8:    Options: /TP /std:c++14 /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
18:33:03:WU02:FS00:0xa8:   Platform: win32 10
18:33:03:WU02:FS00:0xa8:       Bits: 64
18:33:03:WU02:FS00:0xa8:       Mode: Release
18:33:03:WU02:FS00:0xa8:       SIMD: avx2_256
18:33:03:WU02:FS00:0xa8:     OpenMP: ON
18:33:03:WU02:FS00:0xa8:       CUDA: OFF
18:33:03:WU02:FS00:0xa8:       Args: -dir 02 -suffix 01 -version 706 -lifeline 28156 -checkpoint 15 -np
18:33:03:WU02:FS00:0xa8:             22
18:33:03:WU02:FS00:0xa8:************************************ libFAH ************************************
18:33:03:WU02:FS00:0xa8:       Time: 11:24:13
18:33:03:WU02:FS00:0xa8:************************************ CBang *************************************
18:33:03:WU02:FS00:0xa8:       Time: 11:23:53
18:33:03:WU02:FS00:0xa8:************************************ System ************************************
18:33:03:WU02:FS00:0xa8:        CPU: AMD Ryzen 9 7900X 12-Core Processor
18:33:03:WU02:FS00:0xa8:     CPU ID: AuthenticAMD Family 25 Model 97 Stepping 2
18:33:03:WU02:FS00:0xa8:       CPUs: 24
18:33:03:WU02:FS00:0xa8:     Memory: 31.71GiB
18:33:03:WU02:FS00:0xa8:Free Memory: 17.99GiB
18:33:03:WU02:FS00:0xa8:    Threads: WINDOWS_THREADS
18:33:03:WU02:FS00:0xa8: OS Version: 6.2
18:33:03:WU02:FS00:0xa8:Has Battery: true
18:33:03:WU02:FS00:0xa8: On Battery: false
18:33:03:WU02:FS00:0xa8: UTC Offset: -5
18:33:03:WU02:FS00:0xa8:        PID: 2852
18:33:03:WU02:FS00:0xa8:        CWD: C:\ProgramData\FAHClient\work
18:33:03:WU02:FS00:0xa8:********************************************************************************
18:33:03:WU02:FS00:0xa8:Project: 18492 (Run 34, Clone 91, Gen 54)
18:33:03:WU02:FS00:0xa8:Unit: 0x00000000000000000000000000000000
18:33:03:WU02:FS00:0xa8:Reading tar file core.xml
18:33:03:WU02:FS00:0xa8:Reading tar file frame54.tpr
18:33:03:WU02:FS00:0xa8:Digital signatures verified
18:33:03:WU02:FS00:0xa8:Calling: mdrun -c frame54.gro -s frame54.tpr -x frame54.xtc -cpt 15 -nt 22 -ntmpi 1
18:33:03:WU02:FS00:0xa8:Steps: first=270000000 total=275000000
18:33:03:WU01:FS00:Upload complete
18:33:04:WU02:FS00:0xa8:Completed 1 out of 5000000 steps (0%)
18:33:04:WU01:FS00:Server responded WORK_ACK (400)
18:33:04:WU01:FS00:Final credit estimate, 33931.00 points
18:33:04:WU01:FS00:Cleaning up
18:33:38:WU00:FS01:0x23:Completed 1062500 out of 1250000 steps (85%)
18:34:26:WU00:FS01:0x23:Completed 1075000 out of 1250000 steps (86%)
18:34:27:WU00:FS01:0x23:Checkpoint completed at step 1075000
18:35:15:WU00:FS01:0x23:Completed 1087500 out of 1250000 steps (87%)
18:35:59:WU02:FS00:0xa8:Completed 50000 out of 5000000 steps (1%)
18:36:03:WU00:FS01:0x23:Completed 1100000 out of 1250000 steps (88%)
18:36:04:WU00:FS01:0x23:Checkpoint completed at step 1100000
18:36:52:WU00:FS01:0x23:Completed 1112500 out of 1250000 steps (89%)
18:37:40:WU00:FS01:0x23:Completed 1125000 out of 1250000 steps (90%)
18:37:42:WU00:FS01:0x23:Checkpoint completed at step 1125000
18:38:29:WU00:FS01:0x23:Completed 1137500 out of 1250000 steps (91%)
18:38:53:WU02:FS00:0xa8:Completed 100000 out of 5000000 steps (2%)
18:39:17:WU00:FS01:0x23:Completed 1150000 out of 1250000 steps (92%)
18:39:18:WU00:FS01:0x23:Checkpoint completed at step 1150000
18:40:06:WU00:FS01:0x23:Completed 1162500 out of 1250000 steps (93%)
18:40:55:WU00:FS01:0x23:Completed 1175000 out of 1250000 steps (94%)
18:40:56:WU00:FS01:0x23:Checkpoint completed at step 1175000
18:41:44:WU00:FS01:0x23:Completed 1187500 out of 1250000 steps (95%)
18:41:48:WU02:FS00:0xa8:Completed 150000 out of 5000000 steps (3%)
18:42:32:WU00:FS01:0x23:Completed 1200000 out of 1250000 steps (96%)
18:42:33:WU00:FS01:0x23:Checkpoint completed at step 1200000
18:43:21:WU00:FS01:0x23:Completed 1212500 out of 1250000 steps (97%)
18:44:09:WU00:FS01:0x23:Completed 1225000 out of 1250000 steps (98%)
18:44:11:WU00:FS01:0x23:Checkpoint completed at step 1225000
18:44:51:WU02:FS00:0xa8:Completed 200000 out of 5000000 steps (4%)
18:44:58:WU00:FS01:0x23:Completed 1237500 out of 1250000 steps (99%)
18:45:00:WU01:FS01:Connecting to assign1.foldingathome.org:80
18:45:01:WU01:FS01:Assigned to work server 206.223.170.146
18:45:01:WU01:FS01:Requesting new work unit for slot 01: gpu:1:0 AD104 [GeForce RTX 4070] from 206.223.170.146
18:45:01:WU01:FS01:Connecting to 206.223.170.146:8080
18:45:02:WU01:FS01:Downloading 19.43MiB
18:45:08:WU01:FS01:Download 48.57%
18:45:09:WU01:FS01:Download complete
18:45:09:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:12266 run:0 clone:779 gen:428 core:0x23 unit:0x0000030b000001ac00002fea00000000
18:45:46:WU00:FS01:0x23:Completed 1250000 out of 1250000 steps (100%)
18:45:46:WU00:FS01:0x23:Average performance: 90 ns/day
18:45:48:WU00:FS01:0x23:Checkpoint completed at step 1250000
18:46:00:WU00:FS01:0x23:Saving result file ..\logfile_01.txt
18:46:00:WU00:FS01:0x23:Saving result file checkpointIntegrator.xml
18:46:00:WU00:FS01:0x23:Saving result file checkpointState.xml.bz2
18:46:00:WU00:FS01:0x23:Saving result file positions.xtc
18:46:00:WU00:FS01:0x23:Saving result file science.log
18:46:00:WU00:FS01:0x23:Saving result file xtcAtoms.csv.bz2
18:46:00:WU00:FS01:0x23:Folding@home Core Shutdown: FINISHED_UNIT
18:46:01:WU00:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
18:46:01:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:18219 run:7318 clone:0 gen:5 core:0x23 unit:0x00000000000000050000472b00001c96
18:46:01:WU00:FS01:Uploading 23.80MiB to 158.130.118.24
18:46:01:WU01:FS01:Starting
18:46:01:WU00:FS01:Connecting to 158.130.118.24:8080
18:46:01:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/openmm-core-23/windows-10-64bit/release/0x23-8.0.3/Core_23.fah/FahCore_23.exe -dir 01 -suffix 01 -version 706 -lifeline 4544 -checkpoint 15 -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100
18:46:02:WU01:FS01:Started FahCore on PID 29188
18:46:02:WU01:FS01:Core PID:27124
18:46:02:WU01:FS01:FahCore 0x23 started
18:46:03:WU01:FS01:0x23:*********************** Log Started 2024-02-06T18:46:02Z ***********************
18:46:03:WU01:FS01:0x23:*************************** Core23 Folding@home Core ***************************
18:46:03:WU01:FS01:0x23:       Core: Core23
18:46:03:WU01:FS01:0x23:       Type: 0x23
18:46:03:WU01:FS01:0x23:    Version: 8.0.3
18:46:03:WU01:FS01:0x23:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
18:46:03:WU01:FS01:0x23:  Copyright: 2022 foldingathome.org
18:46:03:WU01:FS01:0x23:   Homepage: https://foldingathome.org/
18:46:03:WU01:FS01:0x23:       Date: Aug 3 2023
18:46:03:WU01:FS01:0x23:       Time: 08:39:06
18:46:03:WU01:FS01:0x23:   Compiler: Visual C++
18:46:03:WU01:FS01:0x23:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
18:46:03:WU01:FS01:0x23:             -DOPENMM_VERSION="\"8.0.0\""
18:46:03:WU01:FS01:0x23:   Platform: win32 10
18:46:03:WU01:FS01:0x23:       Bits: 64
18:46:03:WU01:FS01:0x23:       Mode: Release
18:46:03:WU01:FS01:0x23:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
18:46:03:WU01:FS01:0x23:             <peastman@stanford.edu>
18:46:03:WU01:FS01:0x23:       Args: -dir 01 -suffix 01 -version 706 -lifeline 29188 -checkpoint 15
18:46:03:WU01:FS01:0x23:             -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor
18:46:03:WU01:FS01:0x23:             nvidia -gpu 0 -gpu-usage 100
18:46:03:WU01:FS01:0x23:************************************ libFAH ************************************
18:46:03:WU01:FS01:0x23:       Time: 08:37:55
18:46:03:WU01:FS01:0x23:************************************ CBang *************************************
18:46:03:WU01:FS01:0x23:    Version: 1.7.2
18:46:03:WU01:FS01:0x23:        Org: Cauldron Development LLC
18:46:03:WU01:FS01:0x23:  Copyright: Cauldron Development LLC, 2003-2023
18:46:03:WU01:FS01:0x23:   Homepage: https://cauldrondevelopment.com/
18:46:03:WU01:FS01:0x23:    License: GPL 2+
18:46:03:WU01:FS01:0x23:       Time: 08:37:14
18:46:03:WU01:FS01:0x23:************************************ System ************************************
18:46:03:WU01:FS01:0x23:        CPU: AMD Ryzen 9 7900X 12-Core Processor
18:46:03:WU01:FS01:0x23:     CPU ID: AuthenticAMD Family 25 Model 97 Stepping 2
18:46:03:WU01:FS01:0x23:       CPUs: 24
18:46:03:WU01:FS01:0x23:     Memory: 31.71GiB
18:46:03:WU01:FS01:0x23:Free Memory: 19.40GiB
18:46:03:WU01:FS01:0x23:    Threads: WINDOWS_THREADS
18:46:03:WU01:FS01:0x23: OS Version: 6.2
18:46:03:WU01:FS01:0x23:Has Battery: true
18:46:03:WU01:FS01:0x23: On Battery: false
18:46:03:WU01:FS01:0x23: UTC Offset: -5
18:46:03:WU01:FS01:0x23:        PID: 27124
18:46:03:WU01:FS01:0x23:        CWD: C:\ProgramData\FAHClient\work
18:46:03:WU01:FS01:0x23:       Exec: C:\ProgramData\FAHClient\cores\cores.foldingathome.org\openmm-core-23\windows-10-64bit\release\0x23-8.0.3\Core_23.fah\FahCore_23.exe
18:46:03:WU01:FS01:0x23:************************************ OpenMM ************************************
18:46:03:WU01:FS01:0x23:    Version: 8.0.0
18:46:03:WU01:FS01:0x23:********************************************************************************
18:46:03:WU01:FS01:0x23:Project: 12266 (Run 0, Clone 779, Gen 428)
18:46:03:WU01:FS01:0x23:Reading tar file core.xml
18:46:03:WU01:FS01:0x23:Reading tar file integrator.xml
18:46:03:WU01:FS01:0x23:Reading tar file state.xml.bz2
18:46:03:WU01:FS01:0x23:Reading tar file system.xml.bz2
18:46:03:WU01:FS01:0x23:Digital signatures verified
18:46:03:WU01:FS01:0x23:Folding@home GPU Core23 Folding@home Core
18:46:03:WU01:FS01:0x23:Version 8.0.3
18:46:03:WU01:FS01:0x23:  Checkpoint write interval: 50000 steps (2%) [50 total]
18:46:03:WU01:FS01:0x23:  JSON viewer frame write interval: 25000 steps (1%) [100 total]
18:46:03:WU01:FS01:0x23:  XTC frame write interval: 25000 steps (1%) [100 total]
18:46:03:WU01:FS01:0x23:  Global context and integrator variables write interval: disabled
18:46:04:WU01:FS01:0x23:There are 4 platforms available.
18:46:04:WU01:FS01:0x23:Platform 0: Reference
18:46:04:WU01:FS01:0x23:Platform 1: CPU
18:46:04:WU01:FS01:0x23:Platform 2: OpenCL
18:46:04:WU01:FS01:0x23:  opencl-device 0 specified
18:46:04:WU01:FS01:0x23:Platform 3: CUDA
18:46:04:WU01:FS01:0x23:  cuda-device 0 specified
18:46:07:WU00:FS01:Upload 55.68%
18:46:09:WU00:FS01:Upload complete
18:46:09:WU00:FS01:Server responded WORK_ACK (400)
18:46:09:WU00:FS01:Final credit estimate, 542157.00 points
18:46:09:WU00:FS01:Cleaning up
18:46:29:WU01:FS01:0x23:Attempting to create CUDA context:
18:46:29:WU01:FS01:0x23:  Configuring platform CUDA
18:46:35:WU01:FS01:0x23:  Using CUDA on CUDA Platform and gpu 0
18:46:35:WU01:FS01:0x23:  GPU info: Platform: CUDA
18:46:35:WU01:FS01:0x23:  GPU info: PlatformIndex: 0
18:46:35:WU01:FS01:0x23:  GPU info: Device: NVIDIA GeForce RTX 4070
18:46:35:WU01:FS01:0x23:  GPU info: DeviceIndex: 0
18:46:35:WU01:FS01:0x23:  GPU info: Vendor: 0x10de
18:46:35:WU01:FS01:0x23:  GPU info: PCI: 01:00:00
18:46:35:WU01:FS01:0x23:  GPU info: Compute: 8.9
18:46:35:WU01:FS01:0x23:  GPU info: Driver: 12.3
18:46:35:WU01:FS01:0x23:  GPU info: GPU: true
18:46:35:WU01:FS01:0x23:Completed 0 out of 2500000 steps (0%)
18:46:36:WU01:FS01:0x23:Checkpoint completed at step 0
18:47:49:WU02:FS00:0xa8:Completed 250000 out of 5000000 steps (5%)
18:48:01:WU01:FS01:0x23:Completed 25000 out of 2500000 steps (1%)
18:49:25:WU01:FS01:0x23:Completed 50000 out of 2500000 steps (2%)
18:49:26:WU01:FS01:0x23:Checkpoint completed at step 50000
18:50:50:WU01:FS01:0x23:Completed 75000 out of 2500000 steps (3%)
18:50:53:WU02:FS00:0xa8:Completed 300000 out of 5000000 steps (6%)
18:52:13:WU01:FS01:0x23:Completed 100000 out of 2500000 steps (4%)
18:52:14:WU01:FS01:0x23:Checkpoint completed at step 100000
18:53:38:WU01:FS01:0x23:Completed 125000 out of 2500000 steps (5%)
18:53:53:WU02:FS00:0xa8:Completed 350000 out of 5000000 steps (7%)
18:55:02:WU01:FS01:0x23:Completed 150000 out of 2500000 steps (6%)
18:55:03:WU01:FS01:0x23:Checkpoint completed at step 150000
18:56:27:WU01:FS01:0x23:Completed 175000 out of 2500000 steps (7%)
18:56:53:WU02:FS00:0xa8:Completed 400000 out of 5000000 steps (8%)
18:57:51:WU01:FS01:0x23:Completed 200000 out of 2500000 steps (8%)
18:57:52:WU01:FS01:0x23:Checkpoint completed at step 200000
18:59:16:WU01:FS01:0x23:Completed 225000 out of 2500000 steps (9%)
18:59:53:WU02:FS00:0xa8:Completed 450000 out of 5000000 steps (9%)
19:00:40:WU01:FS01:0x23:Completed 250000 out of 2500000 steps (10%)
19:00:41:WU01:FS01:0x23:Checkpoint completed at step 250000
19:02:05:WU01:FS01:0x23:Completed 275000 out of 2500000 steps (11%)
19:02:54:WU02:FS00:0xa8:Completed 500000 out of 5000000 steps (10%)
19:03:29:WU01:FS01:0x23:Completed 300000 out of 2500000 steps (12%)
19:03:30:WU01:FS01:0x23:Checkpoint completed at step 300000
19:04:54:WU01:FS01:0x23:Completed 325000 out of 2500000 steps (13%)
19:05:56:WU02:FS00:0xa8:Completed 550000 out of 5000000 steps (11%)
19:06:18:WU01:FS01:0x23:Completed 350000 out of 2500000 steps (14%)
19:06:19:WU01:FS01:0x23:Checkpoint completed at step 350000
19:07:43:WU01:FS01:0x23:Completed 375000 out of 2500000 steps (15%)
19:08:56:WU02:FS00:0xa8:Completed 600000 out of 5000000 steps (12%)
19:09:07:WU01:FS01:0x23:Completed 400000 out of 2500000 steps (16%)
19:09:08:WU01:FS01:0x23:Checkpoint completed at step 400000
19:10:32:WU01:FS01:0x23:Completed 425000 out of 2500000 steps (17%)
19:11:55:WU01:FS01:0x23:Completed 450000 out of 2500000 steps (18%)
19:11:56:WU01:FS01:0x23:Checkpoint completed at step 450000
19:11:58:WU02:FS00:0xa8:Completed 650000 out of 5000000 steps (13%)
19:13:20:WU01:FS01:0x23:Completed 475000 out of 2500000 steps (19%)
19:14:44:WU01:FS01:0x23:Completed 500000 out of 2500000 steps (20%)
19:14:45:WU01:FS01:0x23:Checkpoint completed at step 500000
19:14:57:WU02:FS00:0xa8:Completed 700000 out of 5000000 steps (14%)
19:16:09:WU01:FS01:0x23:Completed 525000 out of 2500000 steps (21%)
19:17:33:WU01:FS01:0x23:Completed 550000 out of 2500000 steps (22%)
19:17:34:WU01:FS01:0x23:Checkpoint completed at step 550000
19:17:56:WU02:FS00:0xa8:Completed 750000 out of 5000000 steps (15%)
19:18:58:WU01:FS01:0x23:Completed 575000 out of 2500000 steps (23%)
19:20:21:WU01:FS01:0x23:Completed 600000 out of 2500000 steps (24%)
19:20:22:WU01:FS01:0x23:Checkpoint completed at step 600000
19:20:55:WU02:FS00:0xa8:Completed 800000 out of 5000000 steps (16%)
19:21:46:WU01:FS01:0x23:Completed 625000 out of 2500000 steps (25%)
19:23:10:WU01:FS01:0x23:Completed 650000 out of 2500000 steps (26%)
19:23:11:WU01:FS01:0x23:Checkpoint completed at step 650000
19:23:54:WU02:FS00:0xa8:Completed 850000 out of 5000000 steps (17%)
19:24:36:WU01:FS01:0x23:Completed 675000 out of 2500000 steps (27%)
19:26:01:WU01:FS01:0x23:Completed 700000 out of 2500000 steps (28%)
19:26:02:WU01:FS01:0x23:Checkpoint completed at step 700000
19:26:57:WU02:FS00:0xa8:Completed 900000 out of 5000000 steps (18%)
19:27:26:WU01:FS01:0x23:Completed 725000 out of 2500000 steps (29%)
19:28:50:WU01:FS01:0x23:Completed 750000 out of 2500000 steps (30%)
19:28:51:WU01:FS01:0x23:Checkpoint completed at step 750000
19:29:57:WU02:FS00:0xa8:Completed 950000 out of 5000000 steps (19%)
19:30:15:WU01:FS01:0x23:Completed 775000 out of 2500000 steps (31%)
19:31:39:WU01:FS01:0x23:Completed 800000 out of 2500000 steps (32%)
19:31:40:WU01:FS01:0x23:Checkpoint completed at step 800000
19:32:57:WU02:FS00:0xa8:Completed 1000000 out of 5000000 steps (20%)
19:33:04:WU01:FS01:0x23:Completed 825000 out of 2500000 steps (33%)
19:34:27:WU01:FS01:0x23:Completed 850000 out of 2500000 steps (34%)
19:34:28:WU01:FS01:0x23:Checkpoint completed at step 850000
19:35:53:WU01:FS01:0x23:Completed 875000 out of 2500000 steps (35%)
19:35:57:WU02:FS00:0xa8:Completed 1050000 out of 5000000 steps (21%)
19:37:16:WU01:FS01:0x23:Completed 900000 out of 2500000 steps (36%)
19:37:18:WU01:FS01:0x23:Checkpoint completed at step 900000
19:38:41:WU01:FS01:0x23:Completed 925000 out of 2500000 steps (37%)
19:39:00:WU02:FS00:0xa8:Completed 1100000 out of 5000000 steps (22%)
19:40:06:WU01:FS01:0x23:Completed 950000 out of 2500000 steps (38%)
19:40:07:WU01:FS01:0x23:Checkpoint completed at step 950000
19:41:31:WU01:FS01:0x23:Completed 975000 out of 2500000 steps (39%)
19:42:05:WU02:FS00:0xa8:Completed 1150000 out of 5000000 steps (23%)
19:42:54:WU01:FS01:0x23:Completed 1000000 out of 2500000 steps (40%)
19:42:55:WU01:FS01:0x23:Checkpoint completed at step 1000000
******************************* Date: 2024-02-06 *******************************
19:44:19:WU01:FS01:0x23:Completed 1025000 out of 2500000 steps (41%)
19:45:06:WU02:FS00:0xa8:Completed 1200000 out of 5000000 steps (24%)
19:45:44:WU01:FS01:0x23:Completed 1050000 out of 2500000 steps (42%)
19:45:45:WU01:FS01:0x23:Checkpoint completed at step 1050000
19:47:08:WU01:FS01:0x23:Completed 1075000 out of 2500000 steps (43%)
19:48:09:WU02:FS00:0xa8:Completed 1250000 out of 5000000 steps (25%)
19:48:32:WU01:FS01:0x23:Completed 1100000 out of 2500000 steps (44%)
19:48:33:WU01:FS01:0x23:Checkpoint completed at step 1100000
19:49:58:WU01:FS01:0x23:Completed 1125000 out of 2500000 steps (45%)
19:51:13:WU02:FS00:0xa8:Completed 1300000 out of 5000000 steps (26%)
19:51:21:WU01:FS01:0x23:Completed 1150000 out of 2500000 steps (46%)
19:51:22:WU01:FS01:0x23:Checkpoint completed at step 1150000
19:52:46:WU01:FS01:0x23:Completed 1175000 out of 2500000 steps (47%)
19:54:10:WU01:FS01:0x23:Completed 1200000 out of 2500000 steps (48%)
19:54:11:WU01:FS01:0x23:Checkpoint completed at step 1200000
19:54:16:WU02:FS00:0xa8:Completed 1350000 out of 5000000 steps (27%)
19:55:35:WU01:FS01:0x23:Completed 1225000 out of 2500000 steps (49%)
19:56:59:WU01:FS01:0x23:Completed 1250000 out of 2500000 steps (50%)
19:57:00:WU01:FS01:0x23:Checkpoint completed at step 1250000
19:57:20:WU02:FS00:0xa8:Completed 1400000 out of 5000000 steps (28%)
19:58:24:WU01:FS01:0x23:Completed 1275000 out of 2500000 steps (51%)
19:59:48:WU01:FS01:0x23:Completed 1300000 out of 2500000 steps (52%)
19:59:49:WU01:FS01:0x23:Checkpoint completed at step 1300000
20:00:24:WU02:FS00:0xa8:Completed 1450000 out of 5000000 steps (29%)
20:01:13:WU01:FS01:0x23:Completed 1325000 out of 2500000 steps (53%)
20:02:37:WU01:FS01:0x23:Completed 1350000 out of 2500000 steps (54%)
20:02:38:WU01:FS01:0x23:Checkpoint completed at step 1350000
20:03:26:WU02:FS00:0xa8:Completed 1500000 out of 5000000 steps (30%)
20:04:02:WU01:FS01:0x23:Completed 1375000 out of 2500000 steps (55%)
20:05:26:WU01:FS01:0x23:Completed 1400000 out of 2500000 steps (56%)
20:05:27:WU01:FS01:0x23:Checkpoint completed at step 1400000
20:06:29:WU02:FS00:0xa8:Completed 1550000 out of 5000000 steps (31%)
20:06:51:WU01:FS01:0x23:Completed 1425000 out of 2500000 steps (57%)
20:08:15:WU01:FS01:0x23:Completed 1450000 out of 2500000 steps (58%)
20:08:16:WU01:FS01:0x23:Checkpoint completed at step 1450000
20:09:31:WU02:FS00:0xa8:Completed 1600000 out of 5000000 steps (32%)
20:09:40:WU01:FS01:0x23:Completed 1475000 out of 2500000 steps (59%)
20:11:04:WU01:FS01:0x23:Completed 1500000 out of 2500000 steps (60%)
20:11:05:WU01:FS01:0x23:Checkpoint completed at step 1500000
20:12:29:WU01:FS01:0x23:Completed 1525000 out of 2500000 steps (61%)
20:12:35:WU02:FS00:0xa8:Completed 1650000 out of 5000000 steps (33%)
20:13:53:WU01:FS01:0x23:Completed 1550000 out of 2500000 steps (62%)
20:13:54:WU01:FS01:0x23:Checkpoint completed at step 1550000
20:15:17:WU01:FS01:0x23:Completed 1575000 out of 2500000 steps (63%)
20:15:39:WU02:FS00:0xa8:Completed 1700000 out of 5000000 steps (34%)
20:16:41:WU01:FS01:0x23:Completed 1600000 out of 2500000 steps (64%)
20:16:42:WU01:FS01:0x23:Checkpoint completed at step 1600000
20:18:06:WU01:FS01:0x23:Completed 1625000 out of 2500000 steps (65%)
20:18:42:WU02:FS00:0xa8:Completed 1750000 out of 5000000 steps (35%)
20:19:30:WU01:FS01:0x23:Completed 1650000 out of 2500000 steps (66%)
20:19:31:WU01:FS01:0x23:Checkpoint completed at step 1650000
20:20:55:WU01:FS01:0x23:Completed 1675000 out of 2500000 steps (67%)
20:21:45:WU02:FS00:0xa8:Completed 1800000 out of 5000000 steps (36%)
20:22:19:WU01:FS01:0x23:Completed 1700000 out of 2500000 steps (68%)
20:22:20:WU01:FS01:0x23:Checkpoint completed at step 1700000
20:23:44:WU01:FS01:0x23:Completed 1725000 out of 2500000 steps (69%)
20:24:47:WU02:FS00:0xa8:Completed 1850000 out of 5000000 steps (37%)
20:25:08:WU01:FS01:0x23:Completed 1750000 out of 2500000 steps (70%)
20:25:09:WU01:FS01:0x23:Checkpoint completed at step 1750000
20:26:33:WU01:FS01:0x23:Completed 1775000 out of 2500000 steps (71%)
20:27:51:WU02:FS00:0xa8:Completed 1900000 out of 5000000 steps (38%)
20:27:57:WU01:FS01:0x23:Completed 1800000 out of 2500000 steps (72%)
20:27:58:WU01:FS01:0x23:Checkpoint completed at step 1800000
20:29:22:WU01:FS01:0x23:Completed 1825000 out of 2500000 steps (73%)
20:30:46:WU01:FS01:0x23:Completed 1850000 out of 2500000 steps (74%)
20:30:47:WU01:FS01:0x23:Checkpoint completed at step 1850000
20:30:54:WU02:FS00:0xa8:Completed 1950000 out of 5000000 steps (39%)
20:32:11:WU01:FS01:0x23:Completed 1875000 out of 2500000 steps (75%)
20:33:35:WU01:FS01:0x23:Completed 1900000 out of 2500000 steps (76%)
20:33:36:WU01:FS01:0x23:Checkpoint completed at step 1900000
20:33:58:WU02:FS00:0xa8:Completed 2000000 out of 5000000 steps (40%)
20:35:00:WU01:FS01:0x23:Completed 1925000 out of 2500000 steps (77%)
20:36:24:WU01:FS01:0x23:Completed 1950000 out of 2500000 steps (78%)
20:36:25:WU01:FS01:0x23:Checkpoint completed at step 1950000
20:36:59:WU02:FS00:0xa8:Completed 2050000 out of 5000000 steps (41%)
20:37:49:WU01:FS01:0x23:Completed 1975000 out of 2500000 steps (79%)
20:39:13:WU01:FS01:0x23:Completed 2000000 out of 2500000 steps (80%)
20:39:14:WU01:FS01:0x23:Checkpoint completed at step 2000000
20:39:59:WU02:FS00:0xa8:Completed 2100000 out of 5000000 steps (42%)
20:40:38:WU01:FS01:0x23:Completed 2025000 out of 2500000 steps (81%)
20:42:02:WU01:FS01:0x23:Completed 2050000 out of 2500000 steps (82%)
20:42:03:WU01:FS01:0x23:Checkpoint completed at step 2050000
20:42:59:WU02:FS00:0xa8:Completed 2150000 out of 5000000 steps (43%)
20:43:27:WU01:FS01:0x23:Completed 2075000 out of 2500000 steps (83%)
20:44:51:WU01:FS01:0x23:Completed 2100000 out of 2500000 steps (84%)
20:44:52:WU01:FS01:0x23:Checkpoint completed at step 2100000
20:45:58:WU02:FS00:0xa8:Completed 2200000 out of 5000000 steps (44%)
20:46:15:WU01:FS01:0x23:Completed 2125000 out of 2500000 steps (85%)
20:47:40:WU01:FS01:0x23:Completed 2150000 out of 2500000 steps (86%)
20:47:41:WU01:FS01:0x23:Checkpoint completed at step 2150000
20:48:58:WU02:FS00:0xa8:Completed 2250000 out of 5000000 steps (45%)
20:49:04:WU01:FS01:0x23:Completed 2175000 out of 2500000 steps (87%)
20:50:28:WU01:FS01:0x23:Completed 2200000 out of 2500000 steps (88%)
20:50:29:WU01:FS01:0x23:Checkpoint completed at step 2200000
20:51:53:WU01:FS01:0x23:Completed 2225000 out of 2500000 steps (89%)
20:51:59:WU02:FS00:0xa8:Completed 2300000 out of 5000000 steps (46%)
20:53:17:WU01:FS01:0x23:Completed 2250000 out of 2500000 steps (90%)
20:53:18:WU01:FS01:0x23:Checkpoint completed at step 2250000
20:54:42:WU01:FS01:0x23:Completed 2275000 out of 2500000 steps (91%)
20:55:00:WU02:FS00:0xa8:Completed 2350000 out of 5000000 steps (47%)
20:56:06:WU01:FS01:0x23:Completed 2300000 out of 2500000 steps (92%)
20:56:07:WU01:FS01:0x23:Checkpoint completed at step 2300000
20:57:31:WU01:FS01:0x23:Completed 2325000 out of 2500000 steps (93%)
20:58:00:WU02:FS00:0xa8:Completed 2400000 out of 5000000 steps (48%)
20:58:55:WU01:FS01:0x23:Completed 2350000 out of 2500000 steps (94%)
20:58:56:WU01:FS01:0x23:Checkpoint completed at step 2350000
21:00:20:WU01:FS01:0x23:Completed 2375000 out of 2500000 steps (95%)
21:01:01:WU02:FS00:0xa8:Completed 2450000 out of 5000000 steps (49%)
21:01:44:WU01:FS01:0x23:Completed 2400000 out of 2500000 steps (96%)
21:01:45:WU01:FS01:0x23:Checkpoint completed at step 2400000
21:03:09:WU01:FS01:0x23:Completed 2425000 out of 2500000 steps (97%)
21:04:04:WU02:FS00:0xa8:Completed 2500000 out of 5000000 steps (50%)
21:04:33:WU01:FS01:0x23:Completed 2450000 out of 2500000 steps (98%)
21:04:34:WU01:FS01:0x23:Checkpoint completed at step 2450000
21:05:57:WU01:FS01:0x23:Completed 2475000 out of 2500000 steps (99%)
21:05:58:WU00:FS01:Connecting to assign1.foldingathome.org:80
21:05:59:WU00:FS01:Assigned to work server 206.223.170.146
21:05:59:WU00:FS01:Requesting new work unit for slot 01: gpu:1:0 AD104 [GeForce RTX 4070] from 206.223.170.146
21:05:59:WU00:FS01:Connecting to 206.223.170.146:8080
21:05:59:WU00:FS01:Downloading 21.71MiB
21:06:00:WU00:FS01:Download complete
21:06:00:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:12266 run:0 clone:757 gen:340 core:0x23 unit:0x000002f50000015400002fea00000000
21:07:04:WU02:FS00:0xa8:Completed 2550000 out of 5000000 steps (51%)
21:07:21:WU01:FS01:0x23:Completed 2500000 out of 2500000 steps (100%)
21:07:21:WU01:FS01:0x23:Average performance: 102.857 ns/day
21:07:22:WU01:FS01:0x23:Checkpoint completed at step 2500000
21:07:33:WU01:FS01:0x23:Saving result file ..\logfile_01.txt
21:07:33:WU01:FS01:0x23:Saving result file checkpointIntegrator.xml
21:07:33:WU01:FS01:0x23:Saving result file checkpointState.xml.bz2
21:07:33:WU01:FS01:0x23:Saving result file positions.xtc
21:07:33:WU01:FS01:0x23:Saving result file science.log
21:07:33:WU01:FS01:0x23:Saving result file xtcAtoms.csv.bz2
21:07:33:WU01:FS01:0x23:Folding@home Core Shutdown: FINISHED_UNIT
21:07:34:WU01:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
21:07:34:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:12266 run:0 clone:779 gen:428 core:0x23 unit:0x0000030b000001ac00002fea00000000
21:07:34:WU01:FS01:Uploading 22.97MiB to 206.223.170.146
21:07:34:WU00:FS01:Starting
21:07:34:WU01:FS01:Connecting to 206.223.170.146:8080
21:07:34:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/openmm-core-23/windows-10-64bit/release/0x23-8.0.3/Core_23.fah/FahCore_23.exe -dir 00 -suffix 01 -version 706 -lifeline 4544 -checkpoint 15 -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100
21:07:35:WU00:FS01:Started FahCore on PID 26760
21:07:35:WU00:FS01:Core PID:29912
21:07:35:WU00:FS01:FahCore 0x23 started
21:07:36:WU00:FS01:0x23:*********************** Log Started 2024-02-06T21:07:35Z ***********************
21:07:36:WU00:FS01:0x23:*************************** Core23 Folding@home Core ***************************
21:07:36:WU00:FS01:0x23:       Core: Core23
21:07:36:WU00:FS01:0x23:       Type: 0x23
21:07:36:WU00:FS01:0x23:    Version: 8.0.3
21:07:36:WU00:FS01:0x23:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
21:07:36:WU00:FS01:0x23:  Copyright: 2022 foldingathome.org
21:07:36:WU00:FS01:0x23:   Homepage: https://foldingathome.org/
21:07:36:WU00:FS01:0x23:       Date: Aug 3 2023
21:07:36:WU00:FS01:0x23:       Time: 08:39:06
21:07:36:WU00:FS01:0x23:   Compiler: Visual C++
21:07:36:WU00:FS01:0x23:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
21:07:36:WU00:FS01:0x23:             -DOPENMM_VERSION="\"8.0.0\""
21:07:36:WU00:FS01:0x23:   Platform: win32 10
21:07:36:WU00:FS01:0x23:       Bits: 64
21:07:36:WU00:FS01:0x23:       Mode: Release
21:07:36:WU00:FS01:0x23:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
21:07:36:WU00:FS01:0x23:             <peastman@stanford.edu>
21:07:36:WU00:FS01:0x23:       Args: -dir 00 -suffix 01 -version 706 -lifeline 26760 -checkpoint 15
21:07:36:WU00:FS01:0x23:             -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor
21:07:36:WU00:FS01:0x23:             nvidia -gpu 0 -gpu-usage 100
21:07:36:WU00:FS01:0x23:************************************ libFAH ************************************
21:07:36:WU00:FS01:0x23:       Time: 08:37:55
21:07:36:WU00:FS01:0x23:************************************ CBang *************************************
21:07:36:WU00:FS01:0x23:    Version: 1.7.2
21:07:36:WU00:FS01:0x23:        Org: Cauldron Development LLC
21:07:36:WU00:FS01:0x23:  Copyright: Cauldron Development LLC, 2003-2023
21:07:36:WU00:FS01:0x23:   Homepage: https://cauldrondevelopment.com/
21:07:36:WU00:FS01:0x23:    License: GPL 2+
21:07:36:WU00:FS01:0x23:       Time: 08:37:14
21:07:36:WU00:FS01:0x23:************************************ System ************************************
21:07:36:WU00:FS01:0x23:        CPU: AMD Ryzen 9 7900X 12-Core Processor
21:07:36:WU00:FS01:0x23:     CPU ID: AuthenticAMD Family 25 Model 97 Stepping 2
21:07:36:WU00:FS01:0x23:       CPUs: 24
21:07:36:WU00:FS01:0x23:     Memory: 31.71GiB
21:07:36:WU00:FS01:0x23:Free Memory: 19.53GiB
21:07:36:WU00:FS01:0x23:    Threads: WINDOWS_THREADS
21:07:36:WU00:FS01:0x23: OS Version: 6.2
21:07:36:WU00:FS01:0x23:Has Battery: true
21:07:36:WU00:FS01:0x23: On Battery: false
21:07:36:WU00:FS01:0x23: UTC Offset: -5
21:07:36:WU00:FS01:0x23:        PID: 29912
21:07:36:WU00:FS01:0x23:        CWD: C:\ProgramData\FAHClient\work
21:07:36:WU00:FS01:0x23:       Exec: C:\ProgramData\FAHClient\cores\cores.foldingathome.org\openmm-core-23\windows-10-64bit\release\0x23-8.0.3\Core_23.fah\FahCore_23.exe
21:07:36:WU00:FS01:0x23:************************************ OpenMM ************************************
21:07:36:WU00:FS01:0x23:    Version: 8.0.0
21:07:36:WU00:FS01:0x23:********************************************************************************
21:07:36:WU00:FS01:0x23:Project: 12266 (Run 0, Clone 757, Gen 340)
21:07:36:WU00:FS01:0x23:Reading tar file core.xml
21:07:36:WU00:FS01:0x23:Reading tar file integrator.xml
21:07:36:WU00:FS01:0x23:Reading tar file state.xml.bz2
21:07:36:WU00:FS01:0x23:Reading tar file system.xml.bz2
21:07:36:WU00:FS01:0x23:Digital signatures verified
21:07:36:WU00:FS01:0x23:Folding@home GPU Core23 Folding@home Core
21:07:36:WU00:FS01:0x23:Version 8.0.3
21:07:36:WU00:FS01:0x23:  Checkpoint write interval: 50000 steps (2%) [50 total]
21:07:36:WU00:FS01:0x23:  JSON viewer frame write interval: 25000 steps (1%) [100 total]
21:07:36:WU00:FS01:0x23:  XTC frame write interval: 25000 steps (1%) [100 total]
21:07:36:WU00:FS01:0x23:  Global context and integrator variables write interval: disabled
21:07:37:WU01:FS01:Upload complete
21:07:37:WU00:FS01:0x23:There are 4 platforms available.
21:07:37:WU00:FS01:0x23:Platform 0: Reference
21:07:37:WU00:FS01:0x23:Platform 1: CPU
21:07:37:WU00:FS01:0x23:Platform 2: OpenCL
21:07:37:WU00:FS01:0x23:  opencl-device 0 specified
21:07:37:WU00:FS01:0x23:Platform 3: CUDA
21:07:37:WU00:FS01:0x23:  cuda-device 0 specified
21:07:37:WU01:FS01:Server responded WORK_ACK (400)
21:07:37:WU01:FS01:Final credit estimate, 952262.00 points
21:07:37:WU01:FS01:Cleaning up
21:08:01:WU00:FS01:0x23:Attempting to create CUDA context:
21:08:01:WU00:FS01:0x23:  Configuring platform CUDA
21:08:06:WU00:FS01:0x23:  Using CUDA on CUDA Platform and gpu 0
21:08:06:WU00:FS01:0x23:  GPU info: Platform: CUDA
21:08:06:WU00:FS01:0x23:  GPU info: PlatformIndex: 0
21:08:06:WU00:FS01:0x23:  GPU info: Device: NVIDIA GeForce RTX 4070
21:08:06:WU00:FS01:0x23:  GPU info: DeviceIndex: 0
21:08:06:WU00:FS01:0x23:  GPU info: Vendor: 0x10de
21:08:06:WU00:FS01:0x23:  GPU info: PCI: 01:00:00
21:08:06:WU00:FS01:0x23:  GPU info: Compute: 8.9
21:08:06:WU00:FS01:0x23:  GPU info: Driver: 12.3
21:08:06:WU00:FS01:0x23:  GPU info: GPU: true
21:08:06:WU00:FS01:0x23:Completed 0 out of 2500000 steps (0%)
21:08:06:WU00:FS01:0x23:Checkpoint completed at step 0
21:09:30:WU00:FS01:0x23:Completed 25000 out of 2500000 steps (1%)
21:10:01:WU02:FS00:0xa8:Completed 2600000 out of 5000000 steps (52%)
21:10:54:WU00:FS01:0x23:Completed 50000 out of 2500000 steps (2%)
21:10:55:WU00:FS01:0x23:Checkpoint completed at step 50000
21:12:18:WU00:FS01:0x23:Completed 75000 out of 2500000 steps (3%)
21:13:02:WU02:FS00:0xa8:Completed 2650000 out of 5000000 steps (53%)
21:13:42:WU00:FS01:0x23:Completed 100000 out of 2500000 steps (4%)
21:13:43:WU00:FS01:0x23:Checkpoint completed at step 100000
21:15:07:WU00:FS01:0x23:Completed 125000 out of 2500000 steps (5%)
21:16:01:WU02:FS00:0xa8:Completed 2700000 out of 5000000 steps (54%)
21:16:31:WU00:FS01:0x23:Completed 150000 out of 2500000 steps (6%)
21:16:32:WU00:FS01:0x23:Checkpoint completed at step 150000
21:17:55:WU00:FS01:0x23:Completed 175000 out of 2500000 steps (7%)
21:19:02:WU02:FS00:0xa8:Completed 2750000 out of 5000000 steps (55%)
21:19:19:WU00:FS01:0x23:Completed 200000 out of 2500000 steps (8%)
21:19:20:WU00:FS01:0x23:Checkpoint completed at step 200000
21:20:44:WU00:FS01:0x23:Completed 225000 out of 2500000 steps (9%)
21:22:04:WU02:FS00:0xa8:Completed 2800000 out of 5000000 steps (56%)
21:22:08:WU00:FS01:0x23:Completed 250000 out of 2500000 steps (10%)
21:22:09:WU00:FS01:0x23:Checkpoint completed at step 250000
21:23:32:WU00:FS01:0x23:Completed 275000 out of 2500000 steps (11%)
21:24:56:WU00:FS01:0x23:Completed 300000 out of 2500000 steps (12%)
21:24:57:WU00:FS01:0x23:Checkpoint completed at step 300000
21:25:05:WU02:FS00:0xa8:Completed 2850000 out of 5000000 steps (57%)
21:26:21:WU00:FS01:0x23:Completed 325000 out of 2500000 steps (13%)
21:27:44:WU00:FS01:0x23:Completed 350000 out of 2500000 steps (14%)
21:27:45:WU00:FS01:0x23:Checkpoint completed at step 350000
21:28:06:WU02:FS00:0xa8:Completed 2900000 out of 5000000 steps (58%)
21:29:09:WU00:FS01:0x23:Completed 375000 out of 2500000 steps (15%)
21:30:33:WU00:FS01:0x23:Completed 400000 out of 2500000 steps (16%)
21:30:34:WU00:FS01:0x23:Checkpoint completed at step 400000
21:31:11:WU02:FS00:0xa8:Completed 2950000 out of 5000000 steps (59%)
21:31:57:WU00:FS01:0x23:Completed 425000 out of 2500000 steps (17%)
21:33:21:WU00:FS01:0x23:Completed 450000 out of 2500000 steps (18%)
21:33:22:WU00:FS01:0x23:Checkpoint completed at step 450000
21:34:18:WU02:FS00:0xa8:Completed 3000000 out of 5000000 steps (60%)
21:34:46:WU00:FS01:0x23:Completed 475000 out of 2500000 steps (19%)
21:36:10:WU00:FS01:0x23:Completed 500000 out of 2500000 steps (20%)
21:36:11:WU00:FS01:0x23:Checkpoint completed at step 500000
21:37:23:WU02:FS00:0xa8:Completed 3050000 out of 5000000 steps (61%)
sweldon001
21:37:34:WU00:FS01:0x23:Completed 525000 out of 2500000 steps (21%)
21:38:58:WU00:FS01:0x23:Completed 550000 out of 2500000 steps (22%)
21:38:59:WU00:FS01:0x23:Checkpoint completed at step 550000
21:40:23:WU00:FS01:0x23:Completed 575000 out of 2500000 steps (23%)
21:40:29:WU02:FS00:0xa8:Completed 3100000 out of 5000000 steps (62%)
21:41:46:WU00:FS01:0x23:Completed 600000 out of 2500000 steps (24%)
21:41:48:WU00:FS01:0x23:Checkpoint completed at step 600000
21:43:11:WU00:FS01:0x23:Completed 625000 out of 2500000 steps (25%)
21:43:35:WU02:FS00:0xa8:Completed 3150000 out of 5000000 steps (63%)
21:44:35:WU00:FS01:0x23:Completed 650000 out of 2500000 steps (26%)
21:44:36:WU00:FS01:0x23:Checkpoint completed at step 650000
21:45:59:WU00:FS01:0x23:Completed 675000 out of 2500000 steps (27%)
21:46:39:WU02:FS00:0xa8:Completed 3200000 out of 5000000 steps (64%)
21:47:23:WU00:FS01:0x23:Completed 700000 out of 2500000 steps (28%)
21:47:24:WU00:FS01:0x23:Checkpoint completed at step 700000
21:48:48:WU00:FS01:0x23:Completed 725000 out of 2500000 steps (29%)
21:49:45:WU02:FS00:0xa8:Completed 3250000 out of 5000000 steps (65%)
21:50:12:WU00:FS01:0x23:Completed 750000 out of 2500000 steps (30%)
21:50:13:WU00:FS01:0x23:Checkpoint completed at step 750000
21:51:36:WU00:FS01:0x23:Completed 775000 out of 2500000 steps (31%)
21:52:51:WU02:FS00:0xa8:Completed 3300000 out of 5000000 steps (66%)
21:53:00:WU00:FS01:0x23:Completed 800000 out of 2500000 steps (32%)
21:53:01:WU00:FS01:0x23:Checkpoint completed at step 800000
21:54:25:WU00:FS01:0x23:Completed 825000 out of 2500000 steps (33%)
21:55:48:WU00:FS01:0x23:Completed 850000 out of 2500000 steps (34%)
21:55:49:WU00:FS01:0x23:Checkpoint completed at step 850000
21:55:56:WU02:FS00:0xa8:Completed 3350000 out of 5000000 steps (67%)
21:57:13:WU00:FS01:0x23:Completed 875000 out of 2500000 steps (35%)
21:58:37:WU00:FS01:0x23:Completed 900000 out of 2500000 steps (36%)
21:58:38:WU00:FS01:0x23:Checkpoint completed at step 900000
21:59:01:WU02:FS00:0xa8:Completed 3400000 out of 5000000 steps (68%)
22:00:02:WU00:FS01:0x23:Completed 925000 out of 2500000 steps (37%)
22:01:26:WU00:FS01:0x23:Completed 950000 out of 2500000 steps (38%)
22:01:27:WU00:FS01:0x23:Checkpoint completed at step 950000
22:02:06:WU02:FS00:0xa8:Completed 3450000 out of 5000000 steps (69%)
22:02:50:WU00:FS01:0x23:Completed 975000 out of 2500000 steps (39%)
22:04:14:WU00:FS01:0x23:Completed 1000000 out of 2500000 steps (40%)
22:04:15:WU00:FS01:0x23:Checkpoint completed at step 1000000
22:05:10:WU02:FS00:0xa8:Completed 3500000 out of 5000000 steps (70%)
22:05:39:WU00:FS01:0x23:Completed 1025000 out of 2500000 steps (41%)
22:07:02:WU00:FS01:0x23:Completed 1050000 out of 2500000 steps (42%)
22:07:03:WU00:FS01:0x23:Checkpoint completed at step 1050000
22:08:16:WU02:FS00:0xa8:Completed 3550000 out of 5000000 steps (71%)
22:08:27:WU00:FS01:0x23:Completed 1075000 out of 2500000 steps (43%)
22:09:51:WU00:FS01:0x23:Completed 1100000 out of 2500000 steps (44%)
22:09:52:WU00:FS01:0x23:Checkpoint completed at step 1100000
22:11:16:WU00:FS01:0x23:Completed 1125000 out of 2500000 steps (45%)
22:11:21:WU02:FS00:0xa8:Completed 3600000 out of 5000000 steps (72%)
22:12:39:WU00:FS01:0x23:Completed 1150000 out of 2500000 steps (46%)
22:12:40:WU00:FS01:0x23:Checkpoint completed at step 1150000
22:14:04:WU00:FS01:0x23:Completed 1175000 out of 2500000 steps (47%)
22:14:27:WU02:FS00:0xa8:Completed 3650000 out of 5000000 steps (73%)
22:15:28:WU00:FS01:0x23:Completed 1200000 out of 2500000 steps (48%)
22:15:29:WU00:FS01:0x23:Checkpoint completed at step 1200000
22:16:52:WU00:FS01:0x23:Completed 1225000 out of 2500000 steps (49%)
22:17:32:WU02:FS00:0xa8:Completed 3700000 out of 5000000 steps (74%)
22:18:16:WU00:FS01:0x23:Completed 1250000 out of 2500000 steps (50%)
22:18:17:WU00:FS01:0x23:Checkpoint completed at step 1250000
22:19:41:WU00:FS01:0x23:Completed 1275000 out of 2500000 steps (51%)
22:20:38:WU02:FS00:0xa8:Completed 3750000 out of 5000000 steps (75%)
22:21:05:WU00:FS01:0x23:Completed 1300000 out of 2500000 steps (52%)
22:21:06:WU00:FS01:0x23:Checkpoint completed at step 1300000
22:22:29:WU00:FS01:0x23:Completed 1325000 out of 2500000 steps (53%)
22:23:43:WU02:FS00:0xa8:Completed 3800000 out of 5000000 steps (76%)
22:23:53:WU00:FS01:0x23:Completed 1350000 out of 2500000 steps (54%)
22:23:54:WU00:FS01:0x23:Checkpoint completed at step 1350000
22:25:18:WU00:FS01:0x23:Completed 1375000 out of 2500000 steps (55%)
22:26:42:WU00:FS01:0x23:Completed 1400000 out of 2500000 steps (56%)
22:26:43:WU00:FS01:0x23:Checkpoint completed at step 1400000
22:26:49:WU02:FS00:0xa8:Completed 3850000 out of 5000000 steps (77%)
22:28:07:WU00:FS01:0x23:Completed 1425000 out of 2500000 steps (57%)
22:29:31:WU00:FS01:0x23:Completed 1450000 out of 2500000 steps (58%)
22:29:32:WU00:FS01:0x23:Checkpoint completed at step 1450000
22:29:54:WU02:FS00:0xa8:Completed 3900000 out of 5000000 steps (78%)
22:30:55:WU00:FS01:0x23:Completed 1475000 out of 2500000 steps (59%)
22:32:19:WU00:FS01:0x23:Completed 1500000 out of 2500000 steps (60%)
22:32:20:WU00:FS01:0x23:Checkpoint completed at step 1500000
22:32:59:WU02:FS00:0xa8:Completed 3950000 out of 5000000 steps (79%)
22:33:44:WU00:FS01:0x23:Completed 1525000 out of 2500000 steps (61%)
22:35:08:WU00:FS01:0x23:Completed 1550000 out of 2500000 steps (62%)
22:35:09:WU00:FS01:0x23:Checkpoint completed at step 1550000
22:36:04:WU02:FS00:0xa8:Completed 4000000 out of 5000000 steps (80%)
22:36:32:WU00:FS01:0x23:Completed 1575000 out of 2500000 steps (63%)
22:37:56:WU00:FS01:0x23:Completed 1600000 out of 2500000 steps (64%)
22:37:57:WU00:FS01:0x23:Checkpoint completed at step 1600000
22:39:09:WU02:FS00:0xa8:Completed 4050000 out of 5000000 steps (81%)
22:39:21:WU00:FS01:0x23:Completed 1625000 out of 2500000 steps (65%)
22:40:45:WU00:FS01:0x23:Completed 1650000 out of 2500000 steps (66%)
22:40:46:WU00:FS01:0x23:Checkpoint completed at step 1650000
22:42:10:WU00:FS01:0x23:Completed 1675000 out of 2500000 steps (67%)
22:42:14:WU02:FS00:0xa8:Completed 4100000 out of 5000000 steps (82%)
22:43:34:WU00:FS01:0x23:Completed 1700000 out of 2500000 steps (68%)
22:43:35:WU00:FS01:0x23:Checkpoint completed at step 1700000
22:44:58:WU00:FS01:0x23:Completed 1725000 out of 2500000 steps (69%)
22:45:19:WU02:FS00:0xa8:Completed 4150000 out of 5000000 steps (83%)
22:46:22:WU00:FS01:0x23:Completed 1750000 out of 2500000 steps (70%)
22:46:23:WU00:FS01:0x23:Checkpoint completed at step 1750000
22:47:47:WU00:FS01:0x23:Completed 1775000 out of 2500000 steps (71%)
22:48:24:WU02:FS00:0xa8:Completed 4200000 out of 5000000 steps (84%)
22:49:11:WU00:FS01:0x23:Completed 1800000 out of 2500000 steps (72%)
22:49:12:WU00:FS01:0x23:Checkpoint completed at step 1800000
22:50:36:WU00:FS01:0x23:Completed 1825000 out of 2500000 steps (73%)
22:51:29:WU02:FS00:0xa8:Completed 4250000 out of 5000000 steps (85%)
22:51:59:WU00:FS01:0x23:Completed 1850000 out of 2500000 steps (74%)
22:52:00:WU00:FS01:0x23:Checkpoint completed at step 1850000
22:53:24:WU00:FS01:0x23:Completed 1875000 out of 2500000 steps (75%)
22:54:33:WU02:FS00:0xa8:Completed 4300000 out of 5000000 steps (86%)
22:54:48:WU00:FS01:0x23:Completed 1900000 out of 2500000 steps (76%)
22:54:49:WU00:FS01:0x23:Checkpoint completed at step 1900000
22:56:12:WU00:FS01:0x23:Completed 1925000 out of 2500000 steps (77%)
22:57:36:WU00:FS01:0x23:Completed 1950000 out of 2500000 steps (78%)
22:57:37:WU02:FS00:0xa8:Completed 4350000 out of 5000000 steps (87%)
22:57:37:WU00:FS01:0x23:Checkpoint completed at step 1950000
22:59:01:WU00:FS01:0x23:Completed 1975000 out of 2500000 steps (79%)
23:00:25:WU00:FS01:0x23:Completed 2000000 out of 2500000 steps (80%)
23:00:26:WU00:FS01:0x23:Checkpoint completed at step 2000000
23:00:41:WU02:FS00:0xa8:Completed 4400000 out of 5000000 steps (88%)
23:01:50:WU00:FS01:0x23:Completed 2025000 out of 2500000 steps (81%)
23:03:14:WU00:FS01:0x23:Completed 2050000 out of 2500000 steps (82%)
23:03:15:WU00:FS01:0x23:Checkpoint completed at step 2050000
23:03:46:WU02:FS00:0xa8:Completed 4450000 out of 5000000 steps (89%)
23:04:38:WU00:FS01:0x23:Completed 2075000 out of 2500000 steps (83%)
23:06:02:WU00:FS01:0x23:Completed 2100000 out of 2500000 steps (84%)
23:06:03:WU00:FS01:0x23:Checkpoint completed at step 2100000
23:06:51:WU02:FS00:0xa8:Completed 4500000 out of 5000000 steps (90%)
23:07:27:WU00:FS01:0x23:Completed 2125000 out of 2500000 steps (85%)
23:08:51:WU00:FS01:0x23:Completed 2150000 out of 2500000 steps (86%)
23:08:52:WU00:FS01:0x23:Checkpoint completed at step 2150000
23:09:56:WU02:FS00:0xa8:Completed 4550000 out of 5000000 steps (91%)
23:10:16:WU00:FS01:0x23:Completed 2175000 out of 2500000 steps (87%)
23:11:40:WU00:FS01:0x23:Completed 2200000 out of 2500000 steps (88%)
23:11:41:WU00:FS01:0x23:Checkpoint completed at step 2200000
23:13:00:WU02:FS00:0xa8:Completed 4600000 out of 5000000 steps (92%)
23:13:04:WU00:FS01:0x23:Completed 2225000 out of 2500000 steps (89%)
23:14:28:WU00:FS01:0x23:Completed 2250000 out of 2500000 steps (90%)
23:14:29:WU00:FS01:0x23:Checkpoint completed at step 2250000
23:15:53:WU00:FS01:0x23:Completed 2275000 out of 2500000 steps (91%)
23:16:05:WU02:FS00:0xa8:Completed 4650000 out of 5000000 steps (93%)
23:17:17:WU00:FS01:0x23:Completed 2300000 out of 2500000 steps (92%)
23:17:18:WU00:FS01:0x23:Checkpoint completed at step 2300000
23:18:42:WU00:FS01:0x23:Completed 2325000 out of 2500000 steps (93%)
23:19:09:WU02:FS00:0xa8:Completed 4700000 out of 5000000 steps (94%)
23:20:06:WU00:FS01:0x23:Completed 2350000 out of 2500000 steps (94%)
23:20:07:WU00:FS01:0x23:Checkpoint completed at step 2350000
23:21:31:WU00:FS01:0x23:Completed 2375000 out of 2500000 steps (95%)
23:22:11:WU02:FS00:0xa8:Completed 4750000 out of 5000000 steps (95%)
23:22:55:WU00:FS01:0x23:Completed 2400000 out of 2500000 steps (96%)
23:22:56:WU00:FS01:0x23:Checkpoint completed at step 2400000
23:24:20:WU00:FS01:0x23:Completed 2425000 out of 2500000 steps (97%)
23:25:15:WU02:FS00:0xa8:Completed 4800000 out of 5000000 steps (96%)
23:25:44:WU00:FS01:0x23:Completed 2450000 out of 2500000 steps (98%)
23:25:45:WU00:FS01:0x23:Checkpoint completed at step 2450000
23:27:09:WU00:FS01:0x23:Completed 2475000 out of 2500000 steps (99%)
23:27:10:WU01:FS01:Connecting to assign1.foldingathome.org:80
23:27:11:WU01:FS01:Assigned to work server 128.174.73.78
23:27:11:WU01:FS01:Requesting new work unit for slot 01: gpu:1:0 AD104 [GeForce RTX 4070] from 128.174.73.78
23:27:11:WU01:FS01:Connecting to 128.174.73.78:8080
23:27:14:WU01:FS01:Downloading 10.70MiB
23:27:14:WU01:FS01:Download complete
23:27:14:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:19218 run:1138 clone:2 gen:17 core:0x22 unit:0x110000000200000072040000124b0000
23:28:19:WU02:FS00:0xa8:Completed 4850000 out of 5000000 steps (97%)
23:28:33:WU00:FS01:0x23:Completed 2500000 out of 2500000 steps (100%)
23:28:33:WU00:FS01:0x23:Average performance: 102.857 ns/day
23:28:34:WU00:FS01:0x23:Checkpoint completed at step 2500000
23:28:44:WU00:FS01:0x23:Saving result file ..\logfile_01.txt
23:28:44:WU00:FS01:0x23:Saving result file checkpointIntegrator.xml
23:28:44:WU00:FS01:0x23:Saving result file checkpointState.xml.bz2
23:28:44:WU00:FS01:0x23:Saving result file positions.xtc
23:28:44:WU00:FS01:0x23:Saving result file science.log
23:28:44:WU00:FS01:0x23:Saving result file xtcAtoms.csv.bz2
23:28:44:WU00:FS01:0x23:Folding@home Core Shutdown: FINISHED_UNIT
23:28:46:WU00:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
23:28:46:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:12266 run:0 clone:757 gen:340 core:0x23 unit:0x000002f50000015400002fea00000000
23:28:46:WU00:FS01:Uploading 22.95MiB to 206.223.170.146
23:28:46:WU01:FS01:Starting
23:28:46:WU00:FS01:Connecting to 206.223.170.146:8080
23:28:46:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.20/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 706 -lifeline 4544 -checkpoint 15 -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100
23:28:46:WU01:FS01:Started FahCore on PID 27124
23:28:47:WU01:FS01:Core PID:29868
23:28:47:WU01:FS01:FahCore 0x22 started
23:28:47:WU01:FS01:0x22:*********************** Log Started 2024-02-06T23:28:47Z ***********************
23:28:47:WU01:FS01:0x22:*************************** Core22 Folding@home Core ***************************
23:28:47:WU01:FS01:0x22:       Core: Core22
23:28:47:WU01:FS01:0x22:       Type: 0x22
23:28:47:WU01:FS01:0x22:    Version: 0.0.20
23:28:47:WU01:FS01:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
23:28:47:WU01:FS01:0x22:  Copyright: 2020 foldingathome.org
23:28:47:WU01:FS01:0x22:   Homepage: https://foldingathome.org/
23:28:47:WU01:FS01:0x22:       Date: Jan 20 2022
23:28:47:WU01:FS01:0x22:       Time: 01:15:36
23:28:47:WU01:FS01:0x22:   Revision: 3f211b8a4346514edbff34e3cb1c0e0ec951373c
23:28:47:WU01:FS01:0x22:     Branch: HEAD
23:28:47:WU01:FS01:0x22:   Compiler: Visual C++
23:28:47:WU01:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
23:28:47:WU01:FS01:0x22:             -DOPENMM_VERSION="\"7.7.0\""
23:28:47:WU01:FS01:0x22:   Platform: win32 10
23:28:47:WU01:FS01:0x22:       Bits: 64
23:28:47:WU01:FS01:0x22:       Mode: Release
23:28:47:WU01:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
23:28:47:WU01:FS01:0x22:             <peastman@stanford.edu>
23:28:47:WU01:FS01:0x22:       Args: -dir 01 -suffix 01 -version 706 -lifeline 27124 -checkpoint 15
23:28:47:WU01:FS01:0x22:             -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor
23:28:47:WU01:FS01:0x22:             nvidia -gpu 0 -gpu-usage 100
23:28:47:WU01:FS01:0x22:************************************ libFAH ************************************
23:28:47:WU01:FS01:0x22:       Time: 01:14:17
23:28:47:WU01:FS01:0x22:   Revision: 9f4ad694e75c2350d4bb6b8b5b769ba27e483a2f
23:28:47:WU01:FS01:0x22:************************************ CBang *************************************
23:28:47:WU01:FS01:0x22:       Time: 01:13:20
23:28:47:WU01:FS01:0x22:   Revision: ab023d155b446906d55b0f6c9a1eedeea04f7a1a
23:28:47:WU01:FS01:0x22:************************************ System ************************************
23:28:47:WU01:FS01:0x22:        CPU: AMD Ryzen 9 7900X 12-Core Processor
23:28:47:WU01:FS01:0x22:     CPU ID: AuthenticAMD Family 25 Model 97 Stepping 2
23:28:47:WU01:FS01:0x22:       CPUs: 24
23:28:47:WU01:FS01:0x22:     Memory: 31.71GiB
23:28:47:WU01:FS01:0x22:Free Memory: 19.54GiB
23:28:47:WU01:FS01:0x22:    Threads: WINDOWS_THREADS
23:28:47:WU01:FS01:0x22: OS Version: 6.2
23:28:47:WU01:FS01:0x22:Has Battery: true
23:28:47:WU01:FS01:0x22: On Battery: false
23:28:47:WU01:FS01:0x22: UTC Offset: -5
23:28:47:WU01:FS01:0x22:        PID: 29868
23:28:47:WU01:FS01:0x22:        CWD: C:\ProgramData\FAHClient\work
23:28:47:WU01:FS01:0x22:************************************ OpenMM ************************************
23:28:47:WU01:FS01:0x22:    Version: 7.7.0
23:28:47:WU01:FS01:0x22:********************************************************************************
23:28:47:WU01:FS01:0x22:Project: 19218 (Run 1138, Clone 2, Gen 17)
23:28:47:WU01:FS01:0x22:Reading tar file core.xml
23:28:47:WU01:FS01:0x22:Reading tar file integrator.xml
23:28:47:WU01:FS01:0x22:Reading tar file state.xml
23:28:47:WU01:FS01:0x22:Reading tar file system.xml
23:28:48:WU01:FS01:0x22:Digital signatures verified
23:28:48:WU01:FS01:0x22:Folding@home GPU Core22 Folding@home Core
23:28:48:WU01:FS01:0x22:Version 0.0.20
23:28:48:WU01:FS01:0x22:  Checkpoint write interval: 62500 steps (5%) [20 total]
23:28:48:WU01:FS01:0x22:  JSON viewer frame write interval: 12500 steps (1%) [100 total]
23:28:48:WU01:FS01:0x22:  XTC frame write interval: 25000 steps (2%) [50 total]
23:28:48:WU01:FS01:0x22:  Global context and integrator variables write interval: disabled
23:28:48:WU01:FS01:0x22:There are 4 platforms available.
23:28:48:WU01:FS01:0x22:Platform 0: Reference
23:28:48:WU01:FS01:0x22:Platform 1: CPU
23:28:48:WU01:FS01:0x22:Platform 2: OpenCL
23:28:48:WU01:FS01:0x22:  opencl-device 0 specified
23:28:48:WU01:FS01:0x22:Platform 3: CUDA
23:28:48:WU01:FS01:0x22:  cuda-device 0 specified
23:28:48:WU00:FS01:Upload complete
23:28:49:WU00:FS01:Server responded WORK_ACK (400)
23:28:49:WU00:FS01:Final credit estimate, 951539.00 points
23:28:49:WU00:FS01:Cleaning up
23:29:01:WU01:FS01:0x22:Attempting to create CUDA context:
23:29:01:WU01:FS01:0x22:  Configuring platform CUDA
23:29:07:WU01:FS01:0x22:  Using CUDA and gpu 0
23:29:07:WU01:FS01:0x22:Completed 0 out of 1250000 steps (0%)
23:29:07:WU01:FS01:0x22:Checkpoint completed at step 0
23:29:24:WU01:FS01:0x22:Completed 12500 out of 1250000 steps (1%)
23:29:40:WU01:FS01:0x22:Completed 25000 out of 1250000 steps (2%)
23:29:56:WU01:FS01:0x22:Completed 37500 out of 1250000 steps (3%)
23:30:12:WU01:FS01:0x22:Completed 50000 out of 1250000 steps (4%)
23:30:28:WU01:FS01:0x22:Completed 62500 out of 1250000 steps (5%)
23:30:29:WU01:FS01:0x22:Checkpoint completed at step 62500
23:30:45:WU01:FS01:0x22:Completed 75000 out of 1250000 steps (6%)
23:31:01:WU01:FS01:0x22:Completed 87500 out of 1250000 steps (7%)
23:31:17:WU01:FS01:0x22:Completed 100000 out of 1250000 steps (8%)
23:31:33:WU01:FS01:0x22:Completed 112500 out of 1250000 steps (9%)
23:31:35:WU02:FS00:0xa8:Completed 4900000 out of 5000000 steps (98%)
23:31:49:WU01:FS01:0x22:Completed 125000 out of 1250000 steps (10%)
23:31:50:WU01:FS01:0x22:Checkpoint completed at step 125000
23:32:06:WU01:FS01:0x22:Completed 137500 out of 1250000 steps (11%)
23:32:22:WU01:FS01:0x22:Completed 150000 out of 1250000 steps (12%)
23:32:38:WU01:FS01:0x22:Completed 162500 out of 1250000 steps (13%)
23:32:54:WU01:FS01:0x22:Completed 175000 out of 1250000 steps (14%)
23:33:10:WU01:FS01:0x22:Completed 187500 out of 1250000 steps (15%)
23:33:11:WU01:FS01:0x22:Checkpoint completed at step 187500
23:33:27:WU01:FS01:0x22:Completed 200000 out of 1250000 steps (16%)
23:33:43:WU01:FS01:0x22:Completed 212500 out of 1250000 steps (17%)
23:33:59:WU01:FS01:0x22:Completed 225000 out of 1250000 steps (18%)
23:34:15:WU01:FS01:0x22:Completed 237500 out of 1250000 steps (19%)
23:34:31:WU01:FS01:0x22:Completed 250000 out of 1250000 steps (20%)
23:34:32:WU01:FS01:0x22:Checkpoint completed at step 250000
23:34:48:WU01:FS01:0x22:Completed 262500 out of 1250000 steps (21%)
23:34:59:WU02:FS00:0xa8:Completed 4950000 out of 5000000 steps (99%)
23:35:00:WU00:FS00:Connecting to assign1.foldingathome.org:80
23:35:01:WU00:FS00:Assigned to work server 129.32.209.202
23:35:01:WU00:FS00:Requesting new work unit for slot 00: cpu:22 from 129.32.209.202
23:35:01:WU00:FS00:Connecting to 129.32.209.202:8080
23:35:01:WU00:FS00:Downloading 832.00KiB
23:35:01:WU00:FS00:Download complete
23:35:01:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:16998 run:18 clone:23 gen:526 core:0xa8 unit:0x0e020000170000001200000066420000
23:35:04:WU01:FS01:0x22:Completed 275000 out of 1250000 steps (22%)
23:35:20:WU01:FS01:0x22:Completed 287500 out of 1250000 steps (23%)
23:35:36:WU01:FS01:0x22:Completed 300000 out of 1250000 steps (24%)
23:35:52:WU01:FS01:0x22:Completed 312500 out of 1250000 steps (25%)
23:35:53:WU01:FS01:0x22:Checkpoint completed at step 312500
23:36:09:WU01:FS01:0x22:Completed 325000 out of 1250000 steps (26%)
23:36:25:WU01:FS01:0x22:Completed 337500 out of 1250000 steps (27%)
23:36:41:WU01:FS01:0x22:Completed 350000 out of 1250000 steps (28%)
23:36:57:WU01:FS01:0x22:Completed 362500 out of 1250000 steps (29%)
23:37:14:WU01:FS01:0x22:Completed 375000 out of 1250000 steps (30%)
23:37:14:WU01:FS01:0x22:Checkpoint completed at step 375000
23:37:30:WU01:FS01:0x22:Completed 387500 out of 1250000 steps (31%)
23:37:46:WU01:FS01:0x22:Completed 400000 out of 1250000 steps (32%)
23:38:02:WU01:FS01:0x22:Completed 412500 out of 1250000 steps (33%)
23:38:19:WU01:FS01:0x22:Completed 425000 out of 1250000 steps (34%)
23:38:23:WU02:FS00:0xa8:Completed 5000000 out of 5000000 steps (100%)
23:38:23:WU02:FS00:0xa8:Saving result file ..\logfile_01.txt
23:38:23:WU02:FS00:0xa8:Saving result file dhdl.xvg
23:38:23:WU02:FS00:0xa8:Saving result file frame54.gro
23:38:23:WU02:FS00:0xa8:Saving result file frame54.xtc
23:38:23:WU02:FS00:0xa8:Saving result file md.log
23:38:24:WU02:FS00:0xa8:Saving result file science.log
23:38:24:WU02:FS00:0xa8:Saving result file state.cpt
23:38:24:WU02:FS00:0xa8:Folding@home Core Shutdown: FINISHED_UNIT
23:38:24:WU02:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
23:38:24:WU02:FS00:Sending unit results: id:02 state:SEND error:NO_ERROR project:18492 run:34 clone:91 gen:54 core:0xa8 unit:0x360000005b000000220000003c480000
23:38:24:WU02:FS00:Uploading 41.37MiB to 129.32.209.205
23:38:24:WU00:FS00:Starting
23:38:24:WU02:FS00:Connecting to 129.32.209.205:8080
23:38:24:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit-avx2-256/a8-0.0.12/Core_a8.fah/FahCore_a8.exe -dir 00 -suffix 01 -version 706 -lifeline 4544 -checkpoint 15 -np 22
23:38:24:WU00:FS00:Started FahCore on PID 28048
23:38:28:WU00:FS00:Core PID:27372
23:38:28:WU00:FS00:FahCore 0xa8 started
23:38:28:WU00:FS00:0xa8:*********************** Log Started 2024-02-06T23:38:28Z ***********************
23:38:28:WU00:FS00:0xa8:************************** Gromacs Folding@home Core ***************************
23:38:28:WU00:FS00:0xa8:       Core: Gromacs
23:38:28:WU00:FS00:0xa8:       Type: 0xa8
23:38:28:WU00:FS00:0xa8:    Version: 0.0.12
23:38:28:WU00:FS00:0xa8:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
23:38:28:WU00:FS00:0xa8:  Copyright: 2020 foldingathome.org
23:38:28:WU00:FS00:0xa8:   Homepage: https://foldingathome.org/
23:38:28:WU00:FS00:0xa8:       Date: Jan 16 2021
23:38:28:WU00:FS00:0xa8:       Time: 12:29:40
23:38:28:WU00:FS00:0xa8:   Revision: c5816759c404e4b65f9f364c3d1ef554a67c4225
23:38:28:WU00:FS00:0xa8:     Branch: master
23:38:28:WU00:FS00:0xa8:   Compiler: Visual C++ 2019 16.7
23:38:28:WU00:FS00:0xa8:    Options: /TP /std:c++14 /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
23:38:28:WU00:FS00:0xa8:   Platform: win32 10
23:38:28:WU00:FS00:0xa8:       Bits: 64
23:38:28:WU00:FS00:0xa8:       Mode: Release
23:38:28:WU00:FS00:0xa8:       SIMD: avx2_256
23:38:28:WU00:FS00:0xa8:     OpenMP: ON
23:38:28:WU00:FS00:0xa8:       CUDA: OFF
23:38:28:WU00:FS00:0xa8:       Args: -dir 00 -suffix 01 -version 706 -lifeline 28048 -checkpoint 15 -np
23:38:28:WU00:FS00:0xa8:             22
23:38:28:WU00:FS00:0xa8:************************************ libFAH ************************************
23:38:28:WU00:FS00:0xa8:       Time: 11:24:13
23:38:28:WU00:FS00:0xa8:************************************ CBang *************************************
23:38:28:WU00:FS00:0xa8:       Time: 11:23:53
23:38:28:WU00:FS00:0xa8:************************************ System ************************************
23:38:28:WU00:FS00:0xa8:        CPU: AMD Ryzen 9 7900X 12-Core Processor
23:38:28:WU00:FS00:0xa8:     CPU ID: AuthenticAMD Family 25 Model 97 Stepping 2
23:38:28:WU00:FS00:0xa8:       CPUs: 24
23:38:28:WU00:FS00:0xa8:     Memory: 31.71GiB
23:38:28:WU00:FS00:0xa8:Free Memory: 18.80GiB
23:38:28:WU00:FS00:0xa8:    Threads: WINDOWS_THREADS
23:38:28:WU00:FS00:0xa8: OS Version: 6.2
23:38:28:WU00:FS00:0xa8:Has Battery: true
23:38:28:WU00:FS00:0xa8: On Battery: false
23:38:28:WU00:FS00:0xa8: UTC Offset: -5
23:38:28:WU00:FS00:0xa8:        PID: 27372
23:38:28:WU00:FS00:0xa8:        CWD: C:\ProgramData\FAHClient\work
23:38:28:WU00:FS00:0xa8:********************************************************************************
23:38:28:WU00:FS00:0xa8:Project: 16998 (Run 18, Clone 23, Gen 526)
23:38:28:WU00:FS00:0xa8:Unit: 0x00000000000000000000000000000000
23:38:28:WU00:FS00:0xa8:Reading tar file core.xml
23:38:28:WU00:FS00:0xa8:Reading tar file frame526.tpr
23:38:28:WU00:FS00:0xa8:Digital signatures verified
23:38:28:WU00:FS00:0xa8:Calling: mdrun -c frame526.gro -s frame526.tpr -x frame526.xtc -cpt 15 -nt 22 -ntmpi 1
23:38:28:WU00:FS00:0xa8:Steps: first=1315000000 total=1317500000
23:38:29:WU00:FS00:0xa8:Completed 1 out of 2500000 steps (0%)
23:38:35:WU01:FS01:0x22:Completed 437500 out of 1250000 steps (35%)
23:38:35:WU01:FS01:0x22:Checkpoint completed at step 437500
23:38:46:WU02:FS00:Upload 0.30%
23:38:46:WARNING:WU02:FS00:Exception: Failed to send results to work server: Transfer failed
23:38:46:WU02:FS00:Trying to send results to collection server
23:38:46:WU02:FS00:Uploading 41.37MiB to 129.32.209.206
23:38:46:WU02:FS00:Connecting to 129.32.209.206:8080
23:38:51:WU01:FS01:0x22:Completed 450000 out of 1250000 steps (36%)
23:39:07:WU01:FS01:0x22:Completed 462500 out of 1250000 steps (37%)
23:39:08:WU02:FS00:Upload 0.30%
23:39:09:ERROR:WU02:FS00:Exception: Transfer failed
23:39:09:WU02:FS00:Sending unit results: id:02 state:SEND error:NO_ERROR project:18492 run:34 clone:91 gen:54 core:0xa8 unit:0x360000005b000000220000003c480000
23:39:09:WU02:FS00:Uploading 41.37MiB to 129.32.209.205
23:39:09:WU02:FS00:Connecting to 129.32.209.205:8080
23:39:17:WU00:FS00:0xa8:Completed 25000 out of 2500000 steps (1%)
23:39:23:WU01:FS01:0x22:Completed 475000 out of 1250000 steps (38%)
23:39:28:WU02:FS00:Upload 0.30%
23:39:28:WARNING:WU02:FS00:Exception: Failed to send results to work server: Transfer failed
23:39:28:WU02:FS00:Trying to send results to collection server
23:39:28:WU02:FS00:Uploading 41.37MiB to 129.32.209.206
23:39:28:WU02:FS00:Connecting to 129.32.209.206:8080
23:39:39:WU01:FS01:0x22:Completed 487500 out of 1250000 steps (39%)
23:39:48:WU02:FS00:Upload 0.30%
23:39:48:ERROR:WU02:FS00:Exception: Transfer failed
23:39:55:WU01:FS01:0x22:Completed 500000 out of 1250000 steps (40%)
23:39:56:WU01:FS01:0x22:Checkpoint completed at step 500000
23:40:06:WU00:FS00:0xa8:Completed 50000 out of 2500000 steps (2%)
23:40:09:WU02:FS00:Sending unit results: id:02 state:SEND error:NO_ERROR project:18492 run:34 clone:91 gen:54 core:0xa8 unit:0x360000005b000000220000003c480000
23:40:09:WU02:FS00:Uploading 41.37MiB to 129.32.209.205
23:40:09:WU02:FS00:Connecting to 129.32.209.205:8080
23:40:12:WU01:FS01:0x22:Completed 512500 out of 1250000 steps (41%)
23:40:15:WU02:FS00:Upload 73.72%
23:40:16:WU02:FS00:Upload complete
23:40:16:WU02:FS00:Server responded WORK_ACK (400)
23:40:16:WU02:FS00:Final credit estimate, 117089.00 points
23:40:16:WU02:FS00:Cleaning up
23:40:28:WU01:FS01:0x22:Completed 525000 out of 1250000 steps (42%)
23:40:44:WU01:FS01:0x22:Completed 537500 out of 1250000 steps (43%)
23:40:55:WU00:FS00:0xa8:Completed 75000 out of 2500000 steps (3%)
23:41:00:WU01:FS01:0x22:Completed 550000 out of 1250000 steps (44%)
23:41:17:WU01:FS01:0x22:Completed 562500 out of 1250000 steps (45%)
23:41:17:WU01:FS01:0x22:Checkpoint completed at step 562500
23:41:33:WU01:FS01:0x22:Completed 575000 out of 1250000 steps (46%)
23:41:44:WU00:FS00:0xa8:Completed 100000 out of 2500000 steps (4%)
23:41:49:WU01:FS01:0x22:Completed 587500 out of 1250000 steps (47%)
23:42:06:WU01:FS01:0x22:Completed 600000 out of 1250000 steps (48%)
23:42:22:WU01:FS01:0x22:Completed 612500 out of 1250000 steps (49%)
23:42:32:WU00:FS00:0xa8:Completed 125000 out of 2500000 steps (5%)
23:42:38:WU01:FS01:0x22:Completed 625000 out of 1250000 steps (50%)
23:42:39:WU01:FS01:0x22:Checkpoint completed at step 625000
23:42:55:WU01:FS01:0x22:Completed 637500 out of 1250000 steps (51%)
23:43:11:WU01:FS01:0x22:Completed 650000 out of 1250000 steps (52%)
23:43:21:WU00:FS00:0xa8:Completed 150000 out of 2500000 steps (6%)
23:43:27:WU01:FS01:0x22:Completed 662500 out of 1250000 steps (53%)
23:43:43:WU01:FS01:0x22:Completed 675000 out of 1250000 steps (54%)
23:43:59:WU01:FS01:0x22:Completed 687500 out of 1250000 steps (55%)
23:44:00:WU01:FS01:0x22:Checkpoint completed at step 687500
23:44:10:WU00:FS00:0xa8:Completed 175000 out of 2500000 steps (7%)
23:44:16:WU01:FS01:0x22:Completed 700000 out of 1250000 steps (56%)
23:44:32:WU01:FS01:0x22:Completed 712500 out of 1250000 steps (57%)
23:44:48:WU01:FS01:0x22:Completed 725000 out of 1250000 steps (58%)
23:44:59:WU00:FS00:0xa8:Completed 200000 out of 2500000 steps (8%)
23:45:04:WU01:FS01:0x22:Completed 737500 out of 1250000 steps (59%)
23:45:20:WU01:FS01:0x22:Completed 750000 out of 1250000 steps (60%)
23:45:21:WU01:FS01:0x22:Checkpoint completed at step 750000
23:45:37:WU01:FS01:0x22:Completed 762500 out of 1250000 steps (61%)
23:45:48:WU00:FS00:0xa8:Completed 225000 out of 2500000 steps (9%)
23:45:53:WU01:FS01:0x22:Completed 775000 out of 1250000 steps (62%)
23:46:09:WU01:FS01:0x22:Completed 787500 out of 1250000 steps (63%)
23:46:25:WU01:FS01:0x22:Completed 800000 out of 1250000 steps (64%)
23:46:36:WU00:FS00:0xa8:Completed 250000 out of 2500000 steps (10%)
23:46:41:WU01:FS01:0x22:Completed 812500 out of 1250000 steps (65%)
23:46:42:WU01:FS01:0x22:Checkpoint completed at step 812500
23:46:58:WU01:FS01:0x22:Completed 825000 out of 1250000 steps (66%)
23:47:14:WU01:FS01:0x22:Completed 837500 out of 1250000 steps (67%)
23:47:25:WU00:FS00:0xa8:Completed 275000 out of 2500000 steps (11%)
23:47:30:WU01:FS01:0x22:Completed 850000 out of 1250000 steps (68%)
23:47:46:WU01:FS01:0x22:Completed 862500 out of 1250000 steps (69%)
23:48:02:WU01:FS01:0x22:Completed 875000 out of 1250000 steps (70%)
23:48:03:WU01:FS01:0x22:Checkpoint completed at step 875000
23:48:14:WU00:FS00:0xa8:Completed 300000 out of 2500000 steps (12%)
23:48:19:WU01:FS01:0x22:Completed 887500 out of 1250000 steps (71%)
23:48:35:WU01:FS01:0x22:Completed 900000 out of 1250000 steps (72%)
23:48:51:WU01:FS01:0x22:Completed 912500 out of 1250000 steps (73%)
23:49:03:WU00:FS00:0xa8:Completed 325000 out of 2500000 steps (13%)
23:49:07:WU01:FS01:0x22:Completed 925000 out of 1250000 steps (74%)
23:49:23:WU01:FS01:0x22:Completed 937500 out of 1250000 steps (75%)
23:49:24:WU01:FS01:0x22:Checkpoint completed at step 937500
23:49:40:WU01:FS01:0x22:Completed 950000 out of 1250000 steps (76%)
23:49:52:WU00:FS00:0xa8:Completed 350000 out of 2500000 steps (14%)
23:49:56:WU01:FS01:0x22:Completed 962500 out of 1250000 steps (77%)
23:50:13:WU01:FS01:0x22:Completed 975000 out of 1250000 steps (78%)
23:50:29:WU01:FS01:0x22:Completed 987500 out of 1250000 steps (79%)
23:50:44:WU00:FS00:0xa8:Completed 375000 out of 2500000 steps (15%)
23:50:47:WU01:FS01:0x22:Completed 1000000 out of 1250000 steps (80%)
23:50:47:WU01:FS01:0x22:Checkpoint completed at step 1000000
23:51:04:WU01:FS01:0x22:Completed 1012500 out of 1250000 steps (81%)
23:51:20:WU01:FS01:0x22:Completed 1025000 out of 1250000 steps (82%)
23:51:36:WU00:FS00:0xa8:Completed 400000 out of 2500000 steps (16%)
23:51:37:WU01:FS01:0x22:Completed 1037500 out of 1250000 steps (83%)
23:51:54:WU01:FS01:0x22:Completed 1050000 out of 1250000 steps (84%)
23:52:10:WU01:FS01:0x22:Completed 1062500 out of 1250000 steps (85%)
23:52:11:WU01:FS01:0x22:Checkpoint completed at step 1062500
23:52:27:WU01:FS01:0x22:Completed 1075000 out of 1250000 steps (86%)
23:52:29:WU00:FS00:0xa8:Completed 425000 out of 2500000 steps (17%)
23:52:44:WU01:FS01:0x22:Completed 1087500 out of 1250000 steps (87%)
23:53:00:WU01:FS01:0x22:Completed 1100000 out of 1250000 steps (88%)
23:53:17:WU01:FS01:0x22:Completed 1112500 out of 1250000 steps (89%)
23:53:19:WU00:FS00:0xa8:Completed 450000 out of 2500000 steps (18%)
23:53:28:72:127.0.0.1:New Web session
23:53:33:WU01:FS01:0x22:Completed 1125000 out of 1250000 steps (90%)
23:53:34:WU01:FS01:0x22:Checkpoint completed at step 1125000
23:53:50:WU01:FS01:0x22:Completed 1137500 out of 1250000 steps (91%)
23:53:50:83:127.0.0.1:New Web session
23:53:53:ERROR:Receive error: 10054: An existing connection was forcibly closed by the remote host.
23:54:06:WU01:FS01:0x22:Completed 1150000 out of 1250000 steps (92%)
23:54:09:WU00:FS00:0xa8:Completed 475000 out of 2500000 steps (19%)
23:54:23:WU01:FS01:0x22:Completed 1162500 out of 1250000 steps (93%)
23:54:39:WU01:FS01:0x22:Completed 1175000 out of 1250000 steps (94%)
23:54:56:WU01:FS01:0x22:Completed 1187500 out of 1250000 steps (95%)
23:54:57:WU01:FS01:0x22:Checkpoint completed at step 1187500
23:54:59:WU00:FS00:0xa8:Completed 500000 out of 2500000 steps (20%)
23:55:13:WU01:FS01:0x22:Completed 1200000 out of 1250000 steps (96%)
23:55:30:WU01:FS01:0x22:Completed 1212500 out of 1250000 steps (97%)
23:55:46:WU01:FS01:0x22:Completed 1225000 out of 1250000 steps (98%)
23:55:49:WU00:FS00:0xa8:Completed 525000 out of 2500000 steps (21%)
23:56:03:WU01:FS01:0x22:Completed 1237500 out of 1250000 steps (99%)
23:56:03:WU02:FS01:Connecting to assign1.foldingathome.org:80
23:56:04:WU02:FS01:Assigned to work server 206.223.170.146
23:56:04:WU02:FS01:Requesting new work unit for slot 01: gpu:1:0 AD104 [GeForce RTX 4070] from 206.223.170.146
23:56:04:WU02:FS01:Connecting to 206.223.170.146:8080
23:56:04:WU02:FS01:Downloading 21.71MiB
23:56:05:WU02:FS01:Download complete
23:56:05:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:12266 run:0 clone:290 gen:511 core:0x23 unit:0x00000122000001ff00002fea00000000
23:56:19:WU01:FS01:0x22:Completed 1250000 out of 1250000 steps (100%)
23:56:19:WU01:FS01:0x22:Average performance: 260.241 ns/day
23:56:20:WU01:FS01:0x22:Checkpoint completed at step 1250000
23:56:22:WU01:FS01:0x22:Saving result file ..\logfile_01.txt
23:56:22:WU01:FS01:0x22:Saving result file checkpointIntegrator.xml
23:56:22:WU01:FS01:0x22:Saving result file checkpointState.xml
23:56:23:WU01:FS01:0x22:Saving result file positions.xtc
23:56:23:WU01:FS01:0x22:Saving result file science.log
23:56:23:WU01:FS01:0x22:Folding@home Core Shutdown: FINISHED_UNIT
23:56:24:WU01:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
23:56:25:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:19218 run:1138 clone:2 gen:17 core:0x22 unit:0x110000000200000072040000124b0000
23:56:25:WU01:FS01:Uploading 22.21MiB to 128.174.73.78
23:56:25:WU02:FS01:Starting
23:56:25:WU01:FS01:Connecting to 128.174.73.78:8080
23:56:25:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/openmm-core-23/windows-10-64bit/release/0x23-8.0.3/Core_23.fah/FahCore_23.exe -dir 02 -suffix 01 -version 706 -lifeline 4544 -checkpoint 15 -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100
23:56:25:WU02:FS01:Started FahCore on PID 5236
23:56:26:WU02:FS01:Core PID:20784
23:56:26:WU02:FS01:FahCore 0x23 started
23:56:26:WU02:FS01:0x23:*********************** Log Started 2024-02-06T23:56:26Z ***********************
23:56:26:WU02:FS01:0x23:*************************** Core23 Folding@home Core ***************************
23:56:26:WU02:FS01:0x23:       Core: Core23
23:56:26:WU02:FS01:0x23:       Type: 0x23
23:56:26:WU02:FS01:0x23:    Version: 8.0.3
23:56:26:WU02:FS01:0x23:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
23:56:26:WU02:FS01:0x23:  Copyright: 2022 foldingathome.org
23:56:26:WU02:FS01:0x23:   Homepage: https://foldingathome.org/
23:56:26:WU02:FS01:0x23:       Date: Aug 3 2023
23:56:26:WU02:FS01:0x23:       Time: 08:39:06
23:56:26:WU02:FS01:0x23:   Compiler: Visual C++
23:56:26:WU02:FS01:0x23:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
23:56:26:WU02:FS01:0x23:             -DOPENMM_VERSION="\"8.0.0\""
23:56:26:WU02:FS01:0x23:   Platform: win32 10
23:56:26:WU02:FS01:0x23:       Bits: 64
23:56:26:WU02:FS01:0x23:       Mode: Release
23:56:26:WU02:FS01:0x23:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
23:56:26:WU02:FS01:0x23:             <peastman@stanford.edu>
23:56:26:WU02:FS01:0x23:       Args: -dir 02 -suffix 01 -version 706 -lifeline 5236 -checkpoint 15
23:56:26:WU02:FS01:0x23:             -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor
23:56:26:WU02:FS01:0x23:             nvidia -gpu 0 -gpu-usage 100
23:56:26:WU02:FS01:0x23:************************************ libFAH ************************************
23:56:26:WU02:FS01:0x23:       Time: 08:37:55
23:56:26:WU02:FS01:0x23:************************************ CBang *************************************
23:56:26:WU02:FS01:0x23:    Version: 1.7.2
23:56:26:WU02:FS01:0x23:        Org: Cauldron Development LLC
23:56:26:WU02:FS01:0x23:  Copyright: Cauldron Development LLC, 2003-2023
23:56:26:WU02:FS01:0x23:   Homepage: https://cauldrondevelopment.com/
23:56:26:WU02:FS01:0x23:    License: GPL 2+
23:56:26:WU02:FS01:0x23:       Time: 08:37:14
23:56:26:WU02:FS01:0x23:************************************ System ************************************
23:56:26:WU02:FS01:0x23:        CPU: AMD Ryzen 9 7900X 12-Core Processor
23:56:26:WU02:FS01:0x23:     CPU ID: AuthenticAMD Family 25 Model 97 Stepping 2
23:56:26:WU02:FS01:0x23:       CPUs: 24
23:56:26:WU02:FS01:0x23:     Memory: 31.71GiB
23:56:26:WU02:FS01:0x23:Free Memory: 19.44GiB
23:56:26:WU02:FS01:0x23:    Threads: WINDOWS_THREADS
23:56:26:WU02:FS01:0x23: OS Version: 6.2
23:56:26:WU02:FS01:0x23:Has Battery: true
23:56:26:WU02:FS01:0x23: On Battery: false
23:56:26:WU02:FS01:0x23: UTC Offset: -5
23:56:26:WU02:FS01:0x23:        PID: 20784
23:56:26:WU02:FS01:0x23:        CWD: C:\ProgramData\FAHClient\work
23:56:26:WU02:FS01:0x23:       Exec: C:\ProgramData\FAHClient\cores\cores.foldingathome.org\openmm-core-23\windows-10-64bit\release\0x23-8.0.3\Core_23.fah\FahCore_23.exe
23:56:26:WU02:FS01:0x23:************************************ OpenMM ************************************
23:56:26:WU02:FS01:0x23:    Version: 8.0.0
23:56:26:WU02:FS01:0x23:********************************************************************************
23:56:26:WU02:FS01:0x23:Project: 12266 (Run 0, Clone 290, Gen 511)
23:56:26:WU02:FS01:0x23:Reading tar file core.xml
23:56:26:WU02:FS01:0x23:Reading tar file integrator.xml
23:56:26:WU02:FS01:0x23:Reading tar file state.xml.bz2
23:56:26:WU02:FS01:0x23:Reading tar file system.xml.bz2
23:56:26:WU02:FS01:0x23:Digital signatures verified
23:56:26:WU02:FS01:0x23:Folding@home GPU Core23 Folding@home Core
23:56:26:WU02:FS01:0x23:Version 8.0.3
23:56:26:WU02:FS01:0x23:  Checkpoint write interval: 50000 steps (2%) [50 total]
23:56:26:WU02:FS01:0x23:  JSON viewer frame write interval: 25000 steps (1%) [100 total]
23:56:26:WU02:FS01:0x23:  XTC frame write interval: 25000 steps (1%) [100 total]
23:56:26:WU02:FS01:0x23:  Global context and integrator variables write interval: disabled
23:56:26:WU02:FS01:0x23:There are 4 platforms available.
23:56:26:WU02:FS01:0x23:Platform 0: Reference
23:56:26:WU02:FS01:0x23:Platform 1: CPU
23:56:26:WU02:FS01:0x23:Platform 2: OpenCL
23:56:26:WU02:FS01:0x23:  opencl-device 0 specified
23:56:26:WU02:FS01:0x23:Platform 3: CUDA
23:56:26:WU02:FS01:0x23:  cuda-device 0 specified
23:56:27:WU01:FS01:Upload complete
23:56:28:WU01:FS01:Server responded WORK_ACK (400)
23:56:28:WU01:FS01:Final credit estimate, 124250.00 points
23:56:28:WU01:FS01:Cleaning up
23:56:34:WU00:FS00:0xa8:Completed 550000 out of 2500000 steps (22%)
23:56:51:WU02:FS01:0x23:Attempting to create CUDA context:
23:56:51:WU02:FS01:0x23:  Configuring platform CUDA
23:56:56:WU02:FS01:0x23:  Using CUDA on CUDA Platform and gpu 0
23:56:56:WU02:FS01:0x23:  GPU info: Platform: CUDA
23:56:56:WU02:FS01:0x23:  GPU info: PlatformIndex: 0
23:56:56:WU02:FS01:0x23:  GPU info: Device: NVIDIA GeForce RTX 4070
23:56:56:WU02:FS01:0x23:  GPU info: DeviceIndex: 0
23:56:56:WU02:FS01:0x23:  GPU info: Vendor: 0x10de
23:56:56:WU02:FS01:0x23:  GPU info: PCI: 01:00:00
23:56:56:WU02:FS01:0x23:  GPU info: Compute: 8.9
23:56:56:WU02:FS01:0x23:  GPU info: Driver: 12.3
23:56:56:WU02:FS01:0x23:  GPU info: GPU: true
23:56:56:WU02:FS01:0x23:Completed 0 out of 2500000 steps (0%)
23:56:57:WU02:FS01:0x23:Checkpoint completed at step 0
23:57:15:WU00:FS00:0xa8:Completed 575000 out of 2500000 steps (23%)
23:57:58:WU00:FS00:0xa8:Completed 600000 out of 2500000 steps (24%)
23:58:20:WU02:FS01:0x23:Completed 25000 out of 2500000 steps (1%)
23:58:41:WU00:FS00:0xa8:Completed 625000 out of 2500000 steps (25%)
23:59:24:WU00:FS00:0xa8:Completed 650000 out of 2500000 steps (26%)
23:59:44:WU02:FS01:0x23:Completed 50000 out of 2500000 steps (2%)
23:59:45:WU02:FS01:0x23:Checkpoint completed at step 50000
00:00:07:WU00:FS00:0xa8:Completed 675000 out of 2500000 steps (27%)
00:00:50:WU00:FS00:0xa8:Completed 700000 out of 2500000 steps (28%)
00:01:09:WU02:FS01:0x23:Completed 75000 out of 2500000 steps (3%)
00:01:33:WU00:FS00:0xa8:Completed 725000 out of 2500000 steps (29%)
00:02:17:WU00:FS00:0xa8:Completed 750000 out of 2500000 steps (30%)
00:02:33:WU02:FS01:0x23:Completed 100000 out of 2500000 steps (4%)
00:02:34:WU02:FS01:0x23:Checkpoint completed at step 100000
00:03:02:WU00:FS00:0xa8:Completed 775000 out of 2500000 steps (31%)
00:03:45:WU00:FS00:0xa8:Completed 800000 out of 2500000 steps (32%)
00:03:59:WU02:FS01:0x23:Completed 125000 out of 2500000 steps (5%)
00:04:27:WU00:FS00:0xa8:Completed 825000 out of 2500000 steps (33%)
00:05:10:WU00:FS00:0xa8:Completed 850000 out of 2500000 steps (34%)
00:05:23:WU02:FS01:0x23:Completed 150000 out of 2500000 steps (6%)
00:05:24:WU02:FS01:0x23:Checkpoint completed at step 150000
00:05:53:WU00:FS00:0xa8:Completed 875000 out of 2500000 steps (35%)
00:06:36:WU00:FS00:0xa8:Completed 900000 out of 2500000 steps (36%)
00:06:48:WU02:FS01:0x23:Completed 175000 out of 2500000 steps (7%)
00:07:19:WU00:FS00:0xa8:Completed 925000 out of 2500000 steps (37%)
00:08:02:WU00:FS00:0xa8:Completed 950000 out of 2500000 steps (38%)
00:08:13:WU02:FS01:0x23:Completed 200000 out of 2500000 steps (8%)
00:08:14:WU02:FS01:0x23:Checkpoint completed at step 200000
00:08:45:WU00:FS00:0xa8:Completed 975000 out of 2500000 steps (39%)
00:09:28:WU00:FS00:0xa8:Completed 1000000 out of 2500000 steps (40%)
00:09:38:WU02:FS01:0x23:Completed 225000 out of 2500000 steps (9%)
00:10:11:WU00:FS00:0xa8:Completed 1025000 out of 2500000 steps (41%)
00:10:54:WU00:FS00:0xa8:Completed 1050000 out of 2500000 steps (42%)
00:11:03:WU02:FS01:0x23:Completed 250000 out of 2500000 steps (10%)
00:11:04:WU02:FS01:0x23:Checkpoint completed at step 250000
00:11:37:WU00:FS00:0xa8:Completed 1075000 out of 2500000 steps (43%)
00:12:19:WU00:FS00:0xa8:Completed 1100000 out of 2500000 steps (44%)
00:12:28:WU02:FS01:0x23:Completed 275000 out of 2500000 steps (11%)
00:13:02:WU00:FS00:0xa8:Completed 1125000 out of 2500000 steps (45%)
00:13:45:WU00:FS00:0xa8:Completed 1150000 out of 2500000 steps (46%)
00:13:52:WU02:FS01:0x23:Completed 300000 out of 2500000 steps (12%)
00:13:53:WU02:FS01:0x23:Checkpoint completed at step 300000
00:14:28:WU00:FS00:0xa8:Completed 1175000 out of 2500000 steps (47%)
00:15:11:WU00:FS00:0xa8:Completed 1200000 out of 2500000 steps (48%)
00:15:17:WU02:FS01:0x23:Completed 325000 out of 2500000 steps (13%)
00:15:54:WU00:FS00:0xa8:Completed 1225000 out of 2500000 steps (49%)
00:16:37:WU00:FS00:0xa8:Completed 1250000 out of 2500000 steps (50%)
00:16:41:WU02:FS01:0x23:Completed 350000 out of 2500000 steps (14%)
00:16:42:WU02:FS01:0x23:Checkpoint completed at step 350000
00:17:20:WU00:FS00:0xa8:Completed 1275000 out of 2500000 steps (51%)
00:18:03:WU00:FS00:0xa8:Completed 1300000 out of 2500000 steps (52%)
00:18:06:WU02:FS01:0x23:Completed 375000 out of 2500000 steps (15%)
00:18:46:WU00:FS00:0xa8:Completed 1325000 out of 2500000 steps (53%)
00:19:29:WU00:FS00:0xa8:Completed 1350000 out of 2500000 steps (54%)
00:19:30:WU02:FS01:0x23:Completed 400000 out of 2500000 steps (16%)
00:19:31:WU02:FS01:0x23:Checkpoint completed at step 400000
00:20:11:WU00:FS00:0xa8:Completed 1375000 out of 2500000 steps (55%)
00:20:54:WU00:FS00:0xa8:Completed 1400000 out of 2500000 steps (56%)
00:20:56:WU02:FS01:0x23:Completed 425000 out of 2500000 steps (17%)
00:21:37:WU00:FS00:0xa8:Completed 1425000 out of 2500000 steps (57%)
00:22:20:WU02:FS01:0x23:Completed 450000 out of 2500000 steps (18%)
00:22:20:WU00:FS00:0xa8:Completed 1450000 out of 2500000 steps (58%)
00:22:21:WU02:FS01:0x23:Checkpoint completed at step 450000
00:23:02:WU00:FS00:0xa8:Completed 1475000 out of 2500000 steps (59%)
00:23:45:WU02:FS01:0x23:Completed 475000 out of 2500000 steps (19%)
00:23:46:WU00:FS00:0xa8:Completed 1500000 out of 2500000 steps (60%)
00:24:29:WU00:FS00:0xa8:Completed 1525000 out of 2500000 steps (61%)
00:25:09:WU02:FS01:0x23:Completed 500000 out of 2500000 steps (20%)
00:25:10:WU02:FS01:0x23:Checkpoint completed at step 500000
00:25:11:WU00:FS00:0xa8:Completed 1550000 out of 2500000 steps (62%)
00:25:54:WU00:FS00:0xa8:Completed 1575000 out of 2500000 steps (63%)
00:26:34:WU02:FS01:0x23:Completed 525000 out of 2500000 steps (21%)
00:26:38:WU00:FS00:0xa8:Completed 1600000 out of 2500000 steps (64%)
00:27:21:WU00:FS00:0xa8:Completed 1625000 out of 2500000 steps (65%)
00:27:58:WU02:FS01:0x23:Completed 550000 out of 2500000 steps (22%)
00:27:59:WU02:FS01:0x23:Checkpoint completed at step 550000
00:28:04:WU00:FS00:0xa8:Completed 1650000 out of 2500000 steps (66%)
00:28:46:WU00:FS00:0xa8:Completed 1675000 out of 2500000 steps (67%)
00:29:23:WU02:FS01:0x23:Completed 575000 out of 2500000 steps (23%)
00:29:29:WU00:FS00:0xa8:Completed 1700000 out of 2500000 steps (68%)
00:30:12:WU00:FS00:0xa8:Completed 1725000 out of 2500000 steps (69%)
00:30:47:WU02:FS01:0x23:Completed 600000 out of 2500000 steps (24%)
00:30:48:WU02:FS01:0x23:Checkpoint completed at step 600000
00:30:55:WU00:FS00:0xa8:Completed 1750000 out of 2500000 steps (70%)
00:31:38:WU00:FS00:0xa8:Completed 1775000 out of 2500000 steps (71%)
00:32:13:WU02:FS01:0x23:Completed 625000 out of 2500000 steps (25%)
00:32:21:WU00:FS00:0xa8:Completed 1800000 out of 2500000 steps (72%)
00:33:05:WU00:FS00:0xa8:Completed 1825000 out of 2500000 steps (73%)
00:33:38:WU02:FS01:0x23:Completed 650000 out of 2500000 steps (26%)
00:33:39:WU02:FS01:0x23:Checkpoint completed at step 650000
00:33:48:WU00:FS00:0xa8:Completed 1850000 out of 2500000 steps (74%)
00:34:32:WU00:FS00:0xa8:Completed 1875000 out of 2500000 steps (75%)
00:35:05:WU02:FS01:0x23:Completed 675000 out of 2500000 steps (27%)
00:35:21:WU00:FS00:0xa8:Completed 1900000 out of 2500000 steps (76%)
00:36:10:WU00:FS00:0xa8:Completed 1925000 out of 2500000 steps (77%)
00:36:36:WU02:FS01:0x23:Completed 700000 out of 2500000 steps (28%)
00:36:37:WU02:FS01:0x23:Checkpoint completed at step 700000
00:37:00:WU00:FS00:0xa8:Completed 1950000 out of 2500000 steps (78%)
00:37:47:WU00:FS00:0xa8:Completed 1975000 out of 2500000 steps (79%)
00:38:06:WU02:FS01:0x23:Completed 725000 out of 2500000 steps (29%)
00:38:34:WU00:FS00:0xa8:Completed 2000000 out of 2500000 steps (80%)
00:39:21:WU00:FS00:0xa8:Completed 2025000 out of 2500000 steps (81%)
00:39:35:WU02:FS01:0x23:Completed 750000 out of 2500000 steps (30%)
00:39:36:WU02:FS01:0x23:Checkpoint completed at step 750000
00:40:09:WU00:FS00:0xa8:Completed 2050000 out of 2500000 steps (82%)
00:40:55:WU00:FS00:0xa8:Completed 2075000 out of 2500000 steps (83%)
00:41:05:WU02:FS01:0x23:Completed 775000 out of 2500000 steps (31%)
00:41:50:WU00:FS00:0xa8:Completed 2100000 out of 2500000 steps (84%)
00:42:32:WU02:FS01:0x23:Completed 800000 out of 2500000 steps (32%)
00:42:34:WU02:FS01:0x23:Checkpoint completed at step 800000
00:42:47:WU00:FS00:0xa8:Completed 2125000 out of 2500000 steps (85%)
00:43:32:WU00:FS00:0xa8:Completed 2150000 out of 2500000 steps (86%)
00:44:00:WU02:FS01:0x23:Completed 825000 out of 2500000 steps (33%)
00:44:23:WU00:FS00:0xa8:Completed 2175000 out of 2500000 steps (87%)
00:45:16:WU00:FS00:0xa8:Completed 2200000 out of 2500000 steps (88%)
00:45:26:WU02:FS01:0x23:Completed 850000 out of 2500000 steps (34%)
00:45:28:WU02:FS01:0x23:Checkpoint completed at step 850000
00:46:07:WU00:FS00:0xa8:Completed 2225000 out of 2500000 steps (89%)
00:46:54:WU02:FS01:0x23:Completed 875000 out of 2500000 steps (35%)
00:46:59:WU00:FS00:0xa8:Completed 2250000 out of 2500000 steps (90%)
End of log file :)
Re: Re: log file posting.
Is there a problem that you are wanting to ask about? Otherwise I see no problems reported in the log sections.
bikeaddict
Post by bikeaddict »
Looks like you don't have a passkey set up. None of the recent WUs earned the bonus, but you've completed 156 WUs. See:
https://foldingathome.org/support/faq/p ... ey/?lng=en
https://apps.foldingathome.org/getpasskey
sweldon001
Post by sweldon001 »
am I connecting properly ? Because mine say inactive ?
sweldon001
I got passkey, but it still say inactive.....
BobWilliams757
Ryzen 2400G APU
32 GB DDR4-3200
MSI GTX 1660 Super Gaming X
Post by BobWilliams757 »
Sometimes the client hangs up when updating, usually restarting it will solve the issue. In some cases a full system reboot is needed.
Fold them if you get them!
sweldon001
it shows as incactive is this normal I useing ip and port ????
sweldon001
what ip do i use to connect for activity to get bonuses ?
sweldon001
Never mind I'm a f###king idiot... thank all for your help....
