cuda not found
- Hardware configuration: openSUSE Tumbleweed, x86_64,Asrock B760M-HDV/M.2 D4, Intel Core i3-12100, 16 GB, Intel UHD Graphics 730, NVIDIA GeForce GT 1030, Edup-Love EP-9651GS Wi-Fi Bluetooth, multicard reader USB 3.0 startech.com 35fcreadbu3, Epson XP 7100, Headset Bluetooth 3.0 Philips SHQ7300
cuda not found
Yesterday there were a big update (about 5000 packages) then i get this :
CUDA: Not detected: cuInit() returned 999
WARNING:FS01:No CUDA or OpenCL 1.2+ support detected for GPU slot 01: gpu:1:0 GP108 [GeForce GT 1030]. Disabling.
opencl info :
Number of platforms 1
Platform Name NVIDIA CUDA
Platform Vendor NVIDIA Corporation
Platform Version OpenCL 3.0 CUDA 12.3.99
Platform Profile FULL_PROFILE
Platform Extensions cl_khr_global_int32_base_atomics
Number of devices 1
Device Name NVIDIA GeForce GT 1030
Device Vendor NVIDIA Corporation
Device Vendor ID 0x10de
Device Version OpenCL 3.0 CUDA
Device UUID af5796b8-8307-1190-b16d-a80a088c45be
Driver UUID af5796b8-8307-1190-b16d-a80a088c45be
Valid Device LUID No
Device LUID 6d69-637300000000
Device Node Mask 0
Device Numeric Version 0xc00000 (3.0.0)
Driver Version 545.29.06
Device OpenCL C Version OpenCL C 1.2
Device OpenCL C all versions OpenCL C
opencl info :
Number of devices 1
Device Node Mask 0
Re: cuda not found
You did not mention which OS, but someone reported problems updating the Nvidia drivers on Ubuntu in mid January - viewtopic.php?t=40994. Apparently the driver package with the update was missing headers. Perhaps that will help you in getting your GT 1030 going again.
Re: cuda not found
I use FAH rpms from someone named "curiosity" who builds fah rpms for openSUSE.
FAHClient is launching with a systemd service.
Fah does only cpu computing. No more cuda computing.
I reinstalled the rpms from folding@home.
I launched FAHClient under my user id in konsole. There is no problem with the gpu nvidia. Cuda is found by FAHClient. GPU Computing works well !
But if I tried to launch FAHClient with a systemd service, thus as root, it does not find cuda ! Only cpu computing runs well. The exact same problem as with rpms from "curiosity".
Is it an ACL problem ?
Re: cuda not found
hypothesis :
fahclient does not find the icd files.
Do you know a little app which uses cuda according to do a test ?
Re: cuda not found
I made this experiment
in a root text console i run :
clinfo
then
systemctl start fahclient
This time, Fah detects nvidia cuda and nvidia opencl !!!!!
clinfo
then
Re: cuda not found
I found a solution
I add for gpu slot
cuda-index = 0
opencl-index = 0
gpu-index = 0
Now fah finds nvidia cuda and nvidia opencl !!! Victory.
I add for gpu slot
cuda-index = 0
opencl-index = 0
gpu-index = 0
Re: cuda not found
adding for gpu slot
cuda-index = 0
opencl-index = 0
gpu-index = 0
does not work.
We must run "clinfo" before fahclient at PC starting.
I put "clinfo" command in a custom service. this service happily (i don't know why) is started before fahclient.
It works.
cuda-index = 0
opencl-index = 0
gpu-index = 0
does not work.
It works.
