Using RAM, storage, and network to fold, or similar software
kasdashdfjsah
Post by kasdashdfjsah »
Will it ever be possible to use your RAM, SSD, and/or network connection with the folding home software, and does anybody know of any other software that's capable of utilizing these other components to contribute to similar "good" causes?
Re: Using RAM, storage, and network to fold, or similar software
FAH only uses what's needed ... don't forget that FAH main objective is to not interfere with your normal activities.
Note that large GPU projects (>1 million atoms) might use a significant amount of system RAM.
