Hi, I haven't been able to find an answer to this.
When installing FAH on my laptop, two GPUs showed up: my normal Nvidia one and an "UHD GRAPHICS 630." I deleted the latter from FAHControl, and it's no longer listed there. But on the Web Control client it's still being displayed under a "Deleting" status.
Did I go about this the wrong way? Is there a way to delete it completely so it doesn't show up there?
Sorry, I'm still new to this, so I'm not sure why the desktop app and web client wouldn't match.
Deleting slot on Web Control
Re: Deleting slot on Web Control
By default, the GPU slots are automatically recreated when you restart the client.
To prevent this, add this to your config.xml file :
<gpu v='false'/> <!-- If true, attempt to autoconfigure GPUs -->
