8.x.x can't retrieving work properly
nilptr0
Post by nilptr0 »
Hi all, I installed latest beta version n start folding when exist wu completed I can't retrieving the new one. log shows
00:13:20:I1:OUT124:> POST https://assign(any exist available wu assignment server index).foldingathome.org/api/assign HTTP/1.1
00:13:21:I1:OUT124:< HTTP/1.1 503 HTTP_SERVICE_UNAVAILABLE
00:13:21:E :OUT124:HTTP_SERVICE_UNAVAILABLE: {"error":"No appropriate assignment"}
I must manually dump the waiting task that can get new one wu. anyone same?
tried latest alpha ver. same.
Re: 8.x.x can't retrieving work properly
Post by calxalot »
You probably don't have a WU to dump.
I also just noticed I wasn't getting an assignment, but log had lines like
07:22:30:W :Connection:CON101:DNS lookup failed for assign5.foldingathome.org:443
I toggled my wifi off and on, then stopped and relaunched the client to fix. (possibly overkill)
My problem is different than yours.
macOS 13.6.3 intel, fah v8.2.4
Post by calxalot »
There may be a server issue affecting you.
I emailed someone.
nilptr0
Post by nilptr0 »
calxalot wrote: Thu Dec 21, 2023 7:41 am You probably don't have a WU to dump.
may not dns resolve problem dude.
11:06:51:I3:Connecting to assign1.foldingathome.org:443
11:06:51:I1:OUT231:> POST https://assign1.foldingathome.org/api/assign HTTP/1.1
11:06:52:I1:OUT231:< HTTP/1.1 503 HTTP_SERVICE_UNAVAILABLE
11:06:52:E :OUT231:HTTP_SERVICE_UNAVAILABLE: {"error":"No appropriate assignment"}
11:06:52:I1:WU32:Retry #33 in 8 mins 32 secs
11:15:24:I1:WU32:Requesting WU assignment
11:15:25:I3:Connecting to assign2.foldingathome.org:443
11:15:25:I1:OUT232:> POST https://assign2.foldingathome.org/api/assign HTTP/1.1
11:15:26:I1:OUT232:< HTTP/1.1 503 HTTP_SERVICE_UNAVAILABLE
11:15:26:E :OUT232:HTTP_SERVICE_UNAVAILABLE: {"error":"No appropriate assignment"}
11:15:26:I1:WU32:Retry #34 in 8 mins 32 secs
11:23:58:I1:WU32:Requesting WU assignment
11:23:59:I3:Connecting to assign3.foldingathome.org:443
11:23:59:I1:OUT233:> POST https://assign3.foldingathome.org/api/assign HTTP/1.1
11:24:00:I1:OUT233:< HTTP/1.1 503 HTTP_SERVICE_UNAVAILABLE
11:24:00:E :OUT233:HTTP_SERVICE_UNAVAILABLE: {"error":"No appropriate assignment"}
11:24:00:I1:WU32:Retry #35 in 8 mins 32 secs
11:32:32:I1:WU32:Requesting WU assignment
11:32:32:I3:Connecting to assign4.foldingathome.org:443
11:32:32:I1:OUT234:> POST https://assign4.foldingathome.org/api/assign HTTP/1.1
11:32:33:I1:OUT234:< HTTP/1.1 503 HTTP_SERVICE_UNAVAILABLE
11:32:33:E :OUT234:HTTP_SERVICE_UNAVAILABLE: {"error":"No appropriate assignment"}
11:32:33:I1:WU32:Retry #36 in 8 mins 32 secs
11:34:24:I1:WU26:Completed 2050000 out of 5000000 steps (41%)
11:41:05:I1:WU32:Requesting WU assignment
11:41:05:I3:Connecting to assign5.foldingathome.org:443
11:41:05:I1:OUT236:> POST https://assign5.foldingathome.org/api/assign HTTP/1.1
11:41:06:I1:OUT236:< HTTP/1.1 503 HTTP_SERVICE_UNAVAILABLE
11:41:06:E :OUT236:HTTP_SERVICE_UNAVAILABLE: {"error":"No appropriate assignment"}
11:41:06:I1:WU32:Retry #37 in 8 mins 32 secs
calxalot wrote: Thu Dec 21, 2023 7:52 am There may be a server issue affecting you.
I emailed someone.
thx for help
Post by calxalot »
What resources have you assigned to the client? How many CPUs? What GPUs?
nilptr0
Post by nilptr0 »
calxalot wrote: Thu Dec 21, 2023 11:57 am What resources have you assigned to the client? How many CPUs? What GPUs?
almost full res of computer.
Post by calxalot »
I don’t think there is currently any work for intel iGPUs. Is that the only thing getting the server error?
Post by calxalot »
You might want to try the debug build. If you do, don’t use verbosity greater than 3.
nilptr0
Post by nilptr0 »
calxalot wrote: Thu Dec 21, 2023 9:06 pm I don’t think there is currently any work for intel iGPUs. Is that the only thing getting the server error?
actually, I can't retrieving dGPU wu at the same time. not only iGPU wu.
and, i tried disable iGPU on folding setting, can retrieving work properly right now after pervious wu completed. I think wu assignment server may have sth. issue when iGPU n dGPU request new wu simultaneously.
calxalot wrote: Thu Dec 21, 2023 9:08 pm You might want to try the debug build. If you do, don’t use verbosity greater than 3.
how and where can I get the debug build? I only found alpha ver.
Post by calxalot »
The v8 download page has debug packages listed below the release packages.
nilptr0
Post by nilptr0 »
calxalot wrote: Fri Dec 22, 2023 3:13 am The v8 download page has debug packages listed below the release packages.
08:35:42:I1:WU58:Requesting WU assignment for user
08:35:42:D3:WU58:{
08:35:42:D3:WU58: "time": "2023-12-23T08:35:42Z",
08:35:42:D3:WU58: "wu": 58,
08:35:42:D3:WU58: "version": "8.2.4",
08:35:42:D3:WU58: "id": "",
08:35:42:D3:WU58: "user": "",
08:35:42:D3:WU58: "team": ,
08:35:42:D3:WU58: "passkey": "",
08:35:42:D3:WU58: "os": {"version": "6.2", "type": "win32", "memory": 9432567808},
08:35:42:D3:WU58: "project": {"cause": "any", "beta": true},
08:35:42:D3:WU58: "resources": {
08:35:42:D3:WU58: "cpu": {"cpu": "amd64", "cpus": 0, "vendor": "GenuineIntel", "signature": 656981, "family": 6, "model": 165, "stepping": 5, "features": 18445323022575074303, "extended": 10250153, "80000001": 1241984796672},
08:35:42:D3:WU58: "gpu:00:02:00": {
08:35:42:D3:WU58: "gpu": "intel",
08:35:42:D3:WU58: "vendor": 32902,
08:35:42:D3:WU58: "device": 39877,
08:35:42:D3:WU58: "opencl": {"platform": 1, "device": 0, "compute": "3.0", "driver": "31.0"}
08:35:42:D3:WU58: }
08:35:42:D3:WU58: }
08:35:42:D3:WU58:}
log shows fah only request iGPU wu even dGPU available after dGPU wu completed...
workaround: manually disabled iGPU on fah setting
i think this bug may cause all platform that user owned multi gpu , not only iGPU cause.
How do you connect to the Internet ? Is there a proxy or something like this ?
Can you access http://assign1.foldingathome.org/ in a web browser on the same machine ?
nilptr0
Post by nilptr0 »
toTOW wrote: Sat Dec 23, 2023 6:22 pm How do you connect to the Internet ? Is there a proxy or something like this ?
like VPN, use OpenVPN tap handle whole network connection can't directly connect to internet. n fah client won't connect though http proxy i tested before. assign*.foldingathome.org can display properly on the same machine.
I think not network cause in this issue, may caused by client logic. when disable iGPU everything works.
WesPerry
Hardware configuration: M1 Max 16" MacBook Pro
Post by WesPerry »
I haven't been able to connect to the F@H servers for a few days now while using the V8 client. I assume the team is just on break for the holidays and hopefully this will be fixed in the new year?
Please post some logs showing the errors : viewtopic.php?f=24&t=26036
