Project: 2665 (Run 0, Clone 548, Gen 29) - ERROR 0x7b
DocJonz
Post by DocJonz »
I've read the error codes regarding this one - but I don't recall having three in a row before .....
[08:00:32] Completed 250000 out of 250000 steps  (100 percent)
[08:00:32] Writing final coordinates.
[08:00:34] Past main M.D. loop
[08:00:34] Will end MPI now
[08:01:34]
[08:01:34] Finished Work Unit:
[08:01:34] - Reading up to 21310704 from "work/wudata_08.arc": Read 21310704
[08:01:34] - Reading up to 561496 from "work/wudata_08.xtc": Read 561496
[08:01:34] goefile size: 0
[08:01:34] logfile size: 212436
[08:01:34] Leaving Run
[08:01:35] - Writing 22091008 bytes of core data to disk...
[08:01:36]   ... Done.
[08:01:36] - Failed to delete work/wudata_08.sas
[08:01:36] - Failed to delete work/wudata_08.goe
[08:01:36] Warning:  check for stray files
[08:01:36] - Shutting down core
[08:03:36]
[08:03:36] Folding@home Core Shutdown: FINISHED_UNIT
[08:03:36]
[08:03:42] CoreStatus = 64 (100)
[08:03:42] Sending work to server
[08:03:42] + Attempting to send results
[08:15:28] + Results successfully sent
[08:15:28] Thank you for your contribution to Folding@Home.
[08:15:28] + Number of Units Completed: 402
[08:17:48] - Preparing to get new work unit...
[08:17:48] + Attempting to get work packet
[08:17:48] - Connecting to assignment server
[08:17:49] - Successful: assigned to (171.64.65.64).
[08:17:49] + News From Folding@Home: Welcome to Folding@Home
[08:17:49] Loaded queue successfully.
[08:24:03] + Closed connections
[08:24:03]
[08:24:03] + Processing work unit
[08:24:03] Core required: FahCore_a1.exe
[08:24:03] Core found.
[08:24:03] Working on Unit 09 [July 20 08:24:03]
[08:24:03] + Working ...
[08:24:03]
[08:24:03] *------------------------------*
[08:24:03] Folding@Home Gromacs SMP Core
[08:24:03] Version 1.74 (March 10, 2007)
[08:24:03]
[08:24:03] Preparing to commence simulation
[08:24:03] - Ensuring status. Please wait.
[08:24:20] - Assembly optimizations manually forced on.
[08:24:20] - Not checking prior termination.
[08:24:34] - Expanded 4741405 -> 24426905 (decompressed 515.1 percent)
[08:24:35] - Starting from initial work packet
[08:24:37]
[08:24:37] Project: 2665 (Run 0, Clone 548, Gen 29)
[08:24:37]
[08:24:38] Assembly optimizations on if available.
[08:24:39] Entering M.D.
[08:24:45] Rejecting checkpoint
[08:24:47] Protein: HGG in water
[08:24:47] Writing local files
[08:24:57] Extra SSE boost OK.
[08:24:58] Writing local files
[08:24:58] Completed 0 out of 250000 steps  (0 percent)
[08:45:19] Writing local files
[08:45:19] Completed 2500 out of 250000 steps  (1 percent)
[09:05:36] Writing local files
[09:05:36] Completed 5000 out of 250000 steps  (2 percent)
[09:25:58] Writing local files
[09:25:58] Completed 7500 out of 250000 steps  (3 percent)
[09:36:24] Warning:  long 1-4 interactions
[09:36:24] Gromacs cannot continue further.
[09:36:24] Going to send back what have done.
[09:36:24] logfile size: 15856
[09:36:24] - Writing 16392 bytes of core data to disk...
[09:36:24]   ... Done.
[09:36:24] - Failed to delete work/wudata_09.sas
[09:36:24] - Failed to delete work/wudata_09.goe
[09:36:24] Warning:  check for stray files
[09:36:24]
[09:36:24] Folding@home Core Shutdown: EARLY_UNIT_END
[09:36:24]
[09:36:27] CoreStatus = 7B (123)
[09:36:27] Client-core communications error: ERROR 0x7b
[09:36:27] Deleting current work unit & continuing...
[09:38:47] - Preparing to get new work unit...
[09:38:47] + Attempting to get work packet
[09:38:47] - Connecting to assignment server
[09:38:48] - Successful: assigned to (171.64.65.64).
[09:38:48] + News From Folding@Home: Welcome to Folding@Home
[09:38:48] Loaded queue successfully.
[09:42:42] + Closed connections
[09:42:47]
[09:42:47] + Processing work unit
[09:42:47] Core required: FahCore_a1.exe
[09:42:47] Core found.
[09:42:47] Working on Unit 00 [July 20 09:42:47]
[09:42:47] + Working ...
[09:42:47]
[09:42:47] *------------------------------*
[09:42:47] Folding@Home Gromacs SMP Core
[09:42:47] Version 1.74 (March 10, 2007)
[09:42:47]
[09:42:47] Preparing to commence simulation
[09:42:47] - Ensuring status. Please wait.
[09:43:04] - Assembly optimizations manually forced on.
[09:43:04] - Not checking prior termination.
[09:43:19] - Expanded 4741405 -> 24426905 (decompressed 515.1 percent)
[09:43:19] - Starting from initial work packet
[09:43:21]
[09:43:21] Project: 2665 (Run 0, Clone 548, Gen 29)
[09:43:21]
[09:43:22] Assembly optimizations on if available.
[09:43:22] Entering M.D.
[09:43:29] Rejecting checkpoint
[09:43:31] Protein: HGG in water
[09:43:31] Writing local files
[09:43:41] Extra SSE boost OK.
[09:43:41] Writing local files
[09:43:41] Completed 0 out of 250000 steps  (0 percent)
[10:04:03] Writing local files
[10:04:03] Completed 2500 out of 250000 steps  (1 percent)
[10:24:26] Writing local files
[10:24:26] Completed 5000 out of 250000 steps  (2 percent)
[10:44:49] Writing local files
[10:44:49] Completed 7500 out of 250000 steps  (3 percent)
[10:55:16] Warning:  long 1-4 interactions
[10:55:16] Gromacs cannot continue further.
[10:55:16] Going to send back what have done.
[10:55:16] logfile size: 15856
[10:55:16] - Writing 16392 bytes of core data to disk...
[10:55:16]   ... Done.
[10:55:16] - Failed to delete work/wudata_00.sas
[10:55:16] - Failed to delete work/wudata_00.goe
[10:55:16] Warning:  check for stray files
[10:55:16]
[10:55:16] Folding@home Core Shutdown: EARLY_UNIT_END
[10:55:16]
[10:55:19] CoreStatus = 7B (123)
[10:55:19] Client-core communications error: ERROR 0x7b
[10:55:19] Deleting current work unit & continuing...
[10:57:39] - Preparing to get new work unit...
[10:57:39] + Attempting to get work packet
[10:57:39] - Connecting to assignment server
[10:57:40] - Successful: assigned to (171.64.65.64).
[10:57:40] + News From Folding@Home: Welcome to Folding@Home
[10:57:41] Loaded queue successfully.
[11:02:25] + Closed connections
[11:02:30]
[11:02:30] + Processing work unit
[11:02:30] Core required: FahCore_a1.exe
[11:02:30] Core found.
[11:02:30] Working on Unit 01 [July 20 11:02:30]
[11:02:30] + Working ...
[11:02:30]
[11:02:30] *------------------------------*
[11:02:30] Folding@Home Gromacs SMP Core
[11:02:30] Version 1.74 (March 10, 2007)
[11:02:30]
[11:02:30] Preparing to commence simulation
[11:02:30] - Ensuring status. Please wait.
[11:02:47] - Assembly optimizations manually forced on.
[11:02:47] - Not checking prior termination.
[11:03:02] - Expanded 4741405 -> 24426905 (decompressed 515.1 percent)
[11:03:02] - Starting from initial work packet
[11:03:04]
[11:03:04] Project: 2665 (Run 0, Clone 548, Gen 29)
[11:03:04]
[11:03:05] ailed to delete work/wudata_01.pdo
[11:03:05] Warning:  check for stray files
[11:03:05] - Starting from initial work packet
[11:03:05]
[11:03:05] Project: 2665 (Run 0, Clone 548, Gen 29)
[11:03:05]
[11:03:05] lone 548, Gen 29)
[11:03:05]
[11:03:06] Assembly oavailable.
[11:03:06] Entering M.D.
[11:03:06] ble.
[11:03:14] er
[11:03:14] Writing local files
[11:03:14] riting local files
[11:03:15]
[11:03:16] xtra SSE boost OK.
[11:41:10] al files
[11:41:10] Completed 5000 out of 250000 steps  (2 percent)
[12:00:01] Writing local files
[12:00:01] Completed 7500 out of 250000 steps  (3 percent)
[12:09:49] Warning:  long 1-4 interactions
[12:09:49] Gromacs cannot continue further.
[12:09:49] Going to send back what have done.
[12:09:49] logfile size: 15856
[12:09:49] - Writing 16392 bytes of core data to disk...
[12:09:49]   ... Done.
[12:09:49] - Failed to delete work/wudata_01.sas
[12:09:49] - Failed to delete work/wudata_01.goe
[12:09:49] Warning:  check for stray files
[12:09:49]
[12:09:49] Folding@home Core Shutdown: EARLY_UNIT_END
[12:09:49]
[12:09:54] CoreStatus = 7B (123)
[12:09:54] Client-core communications error: ERROR 0x7b
[12:09:54] - Attempting to download new core...
[12:09:54] + Downloading new core: FahCore_a1.exe
[12:09:56] + 10240 bytes downloaded
[12:09:56] + 20480 bytes downloaded
[12:09:56] + 30720 bytes downloaded
[12:09:57] + 40960 bytes downloaded
[12:09:57] + 51200 bytes downloaded
[12:09:58] + 61440 bytes downloaded
[12:09:58] + 71680 bytes downloaded
[12:09:59] + 81920 bytes downloaded
[12:09:59] + 92160 bytes downloaded
[12:10:00] + 102400 bytes downloaded
anko1
(3.2GHz) HT;Windows XP
Re: Project: 2665 (Run 0, Clone 548, Gen 29) - ERROR 0x7b
Post by anko1 »
Maybe there was something wrong with the core? I notice that it downloads a new a1.exe at the end of your log section.
0x7b is an unknown WIndows error.
One of the things that the client does when it doesn't know what else to do is refresh the FahCore.
anko1
Post by anko1 »
Thanks for letting me know. Sort of like a reboot, eh?
