GPU Disabled - Showing face with X's for eyes
Dylon
Post by Dylon »
I just downloaded the application, and when I opened Web Viewer, it is telling me the GPU is Disabled and to head to the Folding@Home forum. I just got the Laptop. The specs are a Ryzen 7000 series CPU with integrated Radeon Graphics. There is a portion dedicated for the GPU, and a shared portion. The application is using the CPU just fine, But there is nothing running on the GPU. How do I get the application to recognise the GPU, Enable it, and start using it please?
Thank You all in advance :D
Re: GPU Disabled - Showing face with X's for eyes
The first 200 lines of the log have configuration details.
viewtopic.php?t=26036
Shows how to post a log
Dylon
Post by Dylon »
*********************** Log Started 2023-11-22T22:55:11Z ***********************
22:55:11:******************************* libFAH ********************************
22:55:11:           Date: Oct 20 2020
22:55:11:           Time: 13:36:55
22:55:11:       Revision: 5ca109d295a6245e2a2f590b3d0085ad5e567aeb
22:55:11:         Branch: master
22:55:11:       Compiler: Visual C++ 2015
22:55:11:        Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
22:55:11:       Platform: win32 10
22:55:11:           Bits: 32
22:55:11:           Mode: Release
22:55:11:****************************** FAHClient ******************************
22:55:11:        Version: 7.6.21
22:55:11:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
22:55:11:      Copyright: 2020 foldingathome.org
22:55:11:       Homepage: https://foldingathome.org/
22:55:11:           Time: 13:41:04
22:55:11:       Revision: 6efbf0e138e22d3963e6a291f78dcb9c6422a278
22:55:11:           Bits: 32
22:55:11:         Config: C:\ProgramData\FAHClient\config.xml
22:55:11:******************************** CBang ********************************
22:55:11:           Time: 11:36:18
22:55:11:       Revision: 7e4ce85225d7eaeb775e87c31740181ca603de60
22:55:11:           Bits: 32
22:55:11:******************************* System ********************************
22:55:11:            CPU: AMD Ryzen 5 7520U with Radeon Graphics
22:55:11:         CPU ID: AuthenticAMD Family 23 Model 160 Stepping 0
22:55:11:           CPUs: 8
22:55:11:         Memory: 7.24GiB
22:55:11:    Free Memory: 2.14GiB
22:55:11:        Threads: WINDOWS_THREADS
22:55:11:     OS Version: 6.2
22:55:11:    Has Battery: true
22:55:11:     On Battery: false
22:55:11:     UTC Offset: -5
22:55:11:            PID: 17260
22:55:11:            CWD: C:\ProgramData\FAHClient
22:55:11:  Win32 Service: false
22:55:11:             OS: Windows 10 Home
22:55:11:        OS Arch: AMD64
22:55:11:           GPUs: 1
22:55:11:          GPU 0: Bus:3 Slot:0 Func:0 AMD:1
22:55:11:           CUDA: Not detected: Failed to open dynamic library 'nvcuda.dll': The
22:55:11:                 specified module could not be found.
22:55:11:
22:55:11:OpenCL Device 0: Platform:0 Device:0 Bus:3 Slot:0 Compute:1.2 Driver:3584.0
22:55:11:***********************************************************************
22:55:12:<config>
22:55:12:  <!-- Slot Control -->
22:55:12:  <power v='FULL'/>
22:55:12:
22:55:12:  <!-- User Information -->
22:55:12:  <user v='Dylon007'/>
22:55:12:
22:55:12:  <!-- Folding Slots -->
22:55:12:  <slot id='0' type='CPU'/>
22:55:12:  <slot id='1' type='GPU'>
22:55:12:    <pci-bus v='3'/>
22:55:12:    <pci-slot v='0'/>
22:55:12:  </slot>
22:55:12:</config>
22:55:12:Trying to access database...
22:55:12:Successfully acquired database lock
22:55:12:FS00:Initialized folding slot 00: cpu:7
22:55:12:WARNING:FS01:Disabling beta GPU slot 01: gpu:3:0.  Beta GPUs can be tested for no points by setting ``gpu-beta=true`` in the configuration.
22:55:12:WU00:FS00:Starting
22:55:12:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit-avx2-256/a8-0.0.12/Core_a8.fah/FahCore_a8.exe -dir 00 -suffix 01 -version 706 -lifeline 17260 -checkpoint 15 -np 7
22:55:12:WU00:FS00:Started FahCore on PID 17620
22:55:13:WU00:FS00:Core PID:17648
22:55:13:WU00:FS00:FahCore 0xa8 started
22:55:13:WU00:FS00:0xa8:*********************** Log Started 2023-11-22T22:55:13Z ***********************
22:55:13:WU00:FS00:0xa8:************************** Gromacs Folding@home Core ***************************
22:55:13:WU00:FS00:0xa8:       Core: Gromacs
22:55:13:WU00:FS00:0xa8:       Type: 0xa8
22:55:13:WU00:FS00:0xa8:    Version: 0.0.12
22:55:13:WU00:FS00:0xa8:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
22:55:13:WU00:FS00:0xa8:  Copyright: 2020 foldingathome.org
22:55:13:WU00:FS00:0xa8:   Homepage: https://foldingathome.org/
22:55:13:WU00:FS00:0xa8:       Date: Jan 16 2021
22:55:13:WU00:FS00:0xa8:       Time: 12:29:40
22:55:13:WU00:FS00:0xa8:   Revision: c5816759c404e4b65f9f364c3d1ef554a67c4225
22:55:13:WU00:FS00:0xa8:     Branch: master
22:55:13:WU00:FS00:0xa8:   Compiler: Visual C++ 2019 16.7
22:55:13:WU00:FS00:0xa8:    Options: /TP /std:c++14 /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
22:55:13:WU00:FS00:0xa8:   Platform: win32 10
22:55:13:WU00:FS00:0xa8:       Bits: 64
22:55:13:WU00:FS00:0xa8:       Mode: Release
22:55:13:WU00:FS00:0xa8:       SIMD: avx2_256
22:55:13:WU00:FS00:0xa8:     OpenMP: ON
22:55:13:WU00:FS00:0xa8:       CUDA: OFF
22:55:13:WU00:FS00:0xa8:       Args: -dir 00 -suffix 01 -version 706 -lifeline 17620 -checkpoint 15 -np
22:55:13:WU00:FS00:0xa8:             7
22:55:13:WU00:FS00:0xa8:************************************ libFAH ************************************
22:55:13:WU00:FS00:0xa8:       Time: 11:24:13
22:55:13:WU00:FS00:0xa8:************************************ CBang *************************************
22:55:13:WU00:FS00:0xa8:       Time: 11:23:53
22:55:13:WU00:FS00:0xa8:************************************ System ************************************
22:55:13:WU00:FS00:0xa8:        CPU: AMD Ryzen 5 7520U with Radeon Graphics
22:55:13:WU00:FS00:0xa8:     CPU ID: AuthenticAMD Family 23 Model 160 Stepping 0
22:55:13:WU00:FS00:0xa8:       CPUs: 8
22:55:13:WU00:FS00:0xa8:     Memory: 7.24GiB
22:55:13:WU00:FS00:0xa8:Free Memory: 1.80GiB
22:55:13:WU00:FS00:0xa8:    Threads: WINDOWS_THREADS
22:55:13:WU00:FS00:0xa8: OS Version: 6.2
22:55:13:WU00:FS00:0xa8:Has Battery: true
22:55:13:WU00:FS00:0xa8: On Battery: false
22:55:13:WU00:FS00:0xa8: UTC Offset: -5
22:55:13:WU00:FS00:0xa8:        PID: 17648
22:55:13:WU00:FS00:0xa8:        CWD: C:\ProgramData\FAHClient\work
22:55:13:WU00:FS00:0xa8:********************************************************************************
22:55:13:WU00:FS00:0xa8:Project: 12408 (Run 37, Clone 2, Gen 81)
22:55:13:WU00:FS00:0xa8:Unit: 0x00000000000000000000000000000000
22:55:13:WU00:FS00:0xa8:Digital signatures verified
22:55:13:WU00:FS00:0xa8:Calling: mdrun -c frame81.gro -s frame81.tpr -x frame81.xtc -cpi state.cpt -cpt 15 -nt 7 -ntmpi 1
22:55:13:WU00:FS00:0xa8:Steps: first=405000000 total=410000000
22:55:15:WU00:FS00:0xa8:Completed 36824 out of 5000000 steps (0%)
22:55:27:4:127.0.0.1:New Web session
22:57:18:WU00:FS00:0xa8:Completed 50000 out of 5000000 steps (1%)
23:00:17:Saving configuration to config.xml
23:00:17:<config>
23:00:17:  <!-- Network -->
23:00:17:  <proxy v=':8080'/>
23:00:17:
23:00:17:  <!-- Slot Control -->
23:00:17:  <pause-on-battery v='false'/>
23:00:17:  <power v='FULL'/>
23:00:17:
23:00:17:  <!-- User Information -->
23:00:17:  <user v='Dylon007'/>
23:00:17:
23:00:17:  <!-- Folding Slots -->
23:00:17:  <slot id='0' type='CPU'/>
23:00:17:  <slot id='1' type='GPU'>
23:00:17:    <pci-bus v='3'/>
23:00:17:    <pci-slot v='0'/>
23:00:17:  </slot>
23:00:17:</config>
23:04:24:WU00:FS00:0xa8:Completed 100000 out of 5000000 steps (2%)
23:11:57:WU00:FS00:0xa8:Completed 150000 out of 5000000 steps (3%)
23:20:12:WU00:FS00:0xa8:Completed 200000 out of 5000000 steps (4%)
23:27:20:WU00:FS00:0xa8:Completed 250000 out of 5000000 steps (5%)
23:34:46:WU00:FS00:0xa8:Completed 300000 out of 5000000 steps (6%)
23:42:00:WU00:FS00:0xa8:Completed 350000 out of 5000000 steps (7%)
23:48:29:WU00:FS00:0xa8:Completed 400000 out of 5000000 steps (8%)
23:54:55:WU00:FS00:0xa8:Completed 450000 out of 5000000 steps (9%)
00:01:44:WU00:FS00:0xa8:Completed 500000 out of 5000000 steps (10%)
00:08:40:WU00:FS00:0xa8:Completed 550000 out of 5000000 steps (11%)
00:15:45:WU00:FS00:0xa8:Completed 600000 out of 5000000 steps (12%)
00:22:23:WU00:FS00:0xa8:Completed 650000 out of 5000000 steps (13%)
00:28:42:WU00:FS00:0xa8:Completed 700000 out of 5000000 steps (14%)
00:34:57:WU00:FS00:0xa8:Completed 750000 out of 5000000 steps (15%)
00:41:12:WU00:FS00:0xa8:Completed 800000 out of 5000000 steps (16%)
00:47:27:WU00:FS00:0xa8:Completed 850000 out of 5000000 steps (17%)
00:53:41:WU00:FS00:0xa8:Completed 900000 out of 5000000 steps (18%)
01:00:16:WU00:FS00:0xa8:Completed 950000 out of 5000000 steps (19%)
01:06:32:WU00:FS00:0xa8:Completed 1000000 out of 5000000 steps (20%)
01:12:48:WU00:FS00:0xa8:Completed 1050000 out of 5000000 steps (21%)
01:19:01:WU00:FS00:0xa8:Completed 1100000 out of 5000000 steps (22%)
01:25:14:WU00:FS00:0xa8:Completed 1150000 out of 5000000 steps (23%)
01:31:32:WU00:FS00:0xa8:Completed 1200000 out of 5000000 steps (24%)
01:37:55:WU00:FS00:0xa8:Completed 1250000 out of 5000000 steps (25%)
01:44:22:WU00:FS00:0xa8:Completed 1300000 out of 5000000 steps (26%)
01:50:50:WU00:FS00:0xa8:Completed 1350000 out of 5000000 steps (27%)
01:57:16:WU00:FS00:0xa8:Completed 1400000 out of 5000000 steps (28%)
02:03:43:WU00:FS00:0xa8:Completed 1450000 out of 5000000 steps (29%)
02:10:09:WU00:FS00:0xa8:Completed 1500000 out of 5000000 steps (30%)
02:16:37:WU00:FS00:0xa8:Completed 1550000 out of 5000000 steps (31%)
02:23:04:35:127.0.0.1:New Web session
02:23:08:WU00:FS00:0xa8:Completed 1600000 out of 5000000 steps (32%)
02:29:37:WU00:FS00:0xa8:Completed 1650000 out of 5000000 steps (33%)
02:35:52:WU00:FS00:0xa8:Completed 1700000 out of 5000000 steps (34%)
02:42:09:WU00:FS00:0xa8:Completed 1750000 out of 5000000 steps (35%)
02:48:25:WU00:FS00:0xa8:Completed 1800000 out of 5000000 steps (36%)
02:54:41:WU00:FS00:0xa8:Completed 1850000 out of 5000000 steps (37%)
03:00:57:WU00:FS00:0xa8:Completed 1900000 out of 5000000 steps (38%)
Https://www.techpowerup.com/gpuz/
Ok you have a year old AMD 7520U cpu.
It appears no one has entered the integrated gpu in the server database.
You can help by running gpuz and posting your device id, usually formatted as four 4 digit numbers.
Post by muziqaz »
Please restart your PC.
Still GPU Z screenshot would help a ton.
Do not expect this iGPU to receive much work, but at least it will be recognised, if we managed to guess the pci id correctly :D
FAH Omega tester
Dylon
Post by Dylon »
The device ID is: 1002-1506-103C-8B27
Hope this helps. Thank you all :)
I think this all you need to tell.
Now we wait for an expert
@toTOW
Dylon
Post by Dylon »
I hope so, I wanna try to use my computer to its full potential to help as soon as I can. If anymore info is needed, I'll be more than happy to provide it. Thank you all for your help with all of this :)
Post by muziqaz »
Has the PC been restarted? And appropriate driver installed?
That PCI ID string has been guessed by one of the members already and iGPU has been added yesterday
FAH Omega tester
Post by muziqaz »
And as I mentioned in my original post, do not expect iGPU to get any work too often, if at all.
We rarely de-restrict them
FAH Omega tester
Dylon
Post by Dylon »
Yeah, I restarted my PC 3 times, and it's still showing that the GPU is disabled. I don't get why if the update was made. I will wait for the current work unit in my CPU to finish, and then i'll delete the program and reinstall it, see if that fixes the issue. As for the Driver software, it's updated to the current available: 31.0.22023.1014 for the graphics, 10.0.22621.2506 for the processor, along with AMD Adrenalin Edition 23.11.1 for the software. Thank You muziqaz and JimboPalmer. :)
Dylon
Post by Dylon »
In the mean time, while i'm waiting for this task to finish, I figured i'd post an updated log. I see it mentions something about a beta mode for testing with no points, but i dunno. I hope this provides some additional insight. Thank you. :wink:
*********************** Log Started 2023-11-25T11:11:03Z ***********************
11:11:03:******************************* libFAH ********************************
11:11:03:           Date: Oct 20 2020
11:11:03:           Time: 13:36:55
11:11:03:       Revision: 5ca109d295a6245e2a2f590b3d0085ad5e567aeb
11:11:03:         Branch: master
11:11:03:       Compiler: Visual C++ 2015
11:11:03:        Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
11:11:03:       Platform: win32 10
11:11:03:           Bits: 32
11:11:03:           Mode: Release
11:11:03:****************************** FAHClient ******************************
11:11:03:        Version: 7.6.21
11:11:03:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
11:11:03:      Copyright: 2020 foldingathome.org
11:11:03:       Homepage: https://foldingathome.org/
11:11:03:           Time: 13:41:04
11:11:03:       Revision: 6efbf0e138e22d3963e6a291f78dcb9c6422a278
11:11:03:           Bits: 32
11:11:03:           Args: --open-web-control
11:11:03:         Config: C:\ProgramData\FAHClient\config.xml
11:11:03:******************************** CBang ********************************
11:11:03:           Time: 11:36:18
11:11:03:       Revision: 7e4ce85225d7eaeb775e87c31740181ca603de60
11:11:03:           Bits: 32
11:11:03:******************************* System ********************************
11:11:03:            CPU: AMD Ryzen 5 7520U with Radeon Graphics
11:11:03:         CPU ID: AuthenticAMD Family 23 Model 160 Stepping 0
11:11:03:           CPUs: 8
11:11:03:         Memory: 7.24GiB
11:11:03:    Free Memory: 3.32GiB
11:11:03:        Threads: WINDOWS_THREADS
11:11:03:     OS Version: 6.2
11:11:03:    Has Battery: true
11:11:03:     On Battery: true
11:11:03:     UTC Offset: -5
11:11:03:            PID: 12884
11:11:03:            CWD: C:\ProgramData\FAHClient
11:11:03:  Win32 Service: false
11:11:03:             OS: Windows 10 Home
11:11:03:        OS Arch: AMD64
11:11:03:           GPUs: 1
11:11:03:          GPU 0: Bus:3 Slot:0 Func:0 AMD:1
11:11:03:           CUDA: Not detected: Failed to open dynamic library 'nvcuda.dll': The
11:11:03:                 specified module could not be found.
11:11:03:
11:11:03:OpenCL Device 0: Platform:0 Device:0 Bus:3 Slot:0 Compute:1.2 Driver:3584.0
11:11:03:***********************************************************************
11:11:03:<config>
11:11:03:  <!-- Network -->
11:11:03:  <proxy v=':8080'/>
11:11:03:
11:11:03:  <!-- Slot Control -->
11:11:03:  <pause-on-battery v='false'/>
11:11:03:  <power v='FULL'/>
11:11:03:
11:11:03:  <!-- User Information -->
11:11:03:  <user v='Dylon007'/>
11:11:03:
11:11:03:  <!-- Folding Slots -->
11:11:03:  <slot id='0' type='CPU'/>
11:11:03:  <slot id='1' type='GPU'>
11:11:03:    <pci-bus v='3'/>
11:11:03:    <pci-slot v='0'/>
11:11:03:  </slot>
11:11:03:</config>
11:11:03:Trying to access database...
11:11:03:Successfully acquired database lock
11:11:03:FS00:Initialized folding slot 00: cpu:7
11:11:03:WARNING:FS01:Disabling beta GPU slot 01: gpu:3:0.  Beta GPUs can be tested for no points by setting ``gpu-beta=true`` in the configuration.
11:11:03:WU00:FS00:Starting
11:11:03:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit-avx2-256/a8-0.0.12/Core_a8.fah/FahCore_a8.exe -dir 00 -suffix 01 -version 706 -lifeline 12884 -checkpoint 15 -np 7
11:11:03:WU00:FS00:Started FahCore on PID 13204
11:11:03:WU00:FS00:Core PID:13264
11:11:04:WU00:FS00:FahCore 0xa8 started
11:11:04:WU00:FS00:0xa8:*********************** Log Started 2023-11-25T11:11:04Z ***********************
11:11:04:WU00:FS00:0xa8:************************** Gromacs Folding@home Core ***************************
11:11:05:WU00:FS00:0xa8:       Core: Gromacs
11:11:05:WU00:FS00:0xa8:       Type: 0xa8
11:11:05:WU00:FS00:0xa8:    Version: 0.0.12
11:11:05:WU00:FS00:0xa8:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
11:11:05:WU00:FS00:0xa8:  Copyright: 2020 foldingathome.org
11:11:05:WU00:FS00:0xa8:   Homepage: https://foldingathome.org/
11:11:05:WU00:FS00:0xa8:       Date: Jan 16 2021
11:11:05:WU00:FS00:0xa8:       Time: 12:29:40
11:11:05:WU00:FS00:0xa8:   Revision: c5816759c404e4b65f9f364c3d1ef554a67c4225
11:11:05:WU00:FS00:0xa8:     Branch: master
11:11:05:WU00:FS00:0xa8:   Compiler: Visual C++ 2019 16.7
11:11:05:WU00:FS00:0xa8:    Options: /TP /std:c++14 /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
11:11:05:WU00:FS00:0xa8:   Platform: win32 10
11:11:05:WU00:FS00:0xa8:       Bits: 64
11:11:05:WU00:FS00:0xa8:       Mode: Release
11:11:05:WU00:FS00:0xa8:       SIMD: avx2_256
11:11:05:WU00:FS00:0xa8:     OpenMP: ON
11:11:05:WU00:FS00:0xa8:       CUDA: OFF
11:11:05:WU00:FS00:0xa8:       Args: -dir 00 -suffix 01 -version 706 -lifeline 13204 -checkpoint 15 -np
11:11:05:WU00:FS00:0xa8:             7
11:11:05:WU00:FS00:0xa8:************************************ libFAH ************************************
11:11:05:WU00:FS00:0xa8:       Time: 11:24:13
11:11:05:WU00:FS00:0xa8:************************************ CBang *************************************
11:11:05:WU00:FS00:0xa8:       Time: 11:23:53
11:11:05:WU00:FS00:0xa8:************************************ System ************************************
11:11:05:WU00:FS00:0xa8:        CPU: AMD Ryzen 5 7520U with Radeon Graphics
11:11:05:WU00:FS00:0xa8:     CPU ID: AuthenticAMD Family 23 Model 160 Stepping 0
11:11:05:WU00:FS00:0xa8:       CPUs: 8
11:11:05:WU00:FS00:0xa8:     Memory: 7.24GiB
11:11:05:WU00:FS00:0xa8:Free Memory: 3.29GiB
11:11:05:WU00:FS00:0xa8:    Threads: WINDOWS_THREADS
11:11:05:WU00:FS00:0xa8: OS Version: 6.2
11:11:05:WU00:FS00:0xa8:Has Battery: true
11:11:05:WU00:FS00:0xa8: On Battery: true
11:11:05:WU00:FS00:0xa8: UTC Offset: -5
11:11:05:WU00:FS00:0xa8:        PID: 13264
11:11:05:WU00:FS00:0xa8:        CWD: C:\ProgramData\FAHClient\work
11:11:05:WU00:FS00:0xa8:********************************************************************************
11:11:05:WU00:FS00:0xa8:Project: 18492 (Run 25, Clone 20, Gen 56)
11:11:05:WU00:FS00:0xa8:Unit: 0x00000000000000000000000000000000
11:11:05:WU00:FS00:0xa8:Digital signatures verified
11:11:05:WU00:FS00:0xa8:Calling: mdrun -c frame56.gro -s frame56.tpr -x frame56.xtc -cpi state.cpt -cpt 15 -nt 7 -ntmpi 1
11:11:05:WU00:FS00:0xa8:Steps: first=280000000 total=285000000
11:11:06:4:127.0.0.1:New Web session
11:11:07:WU00:FS00:0xa8:Completed 1858920 out of 5000000 steps (37%)
11:20:43:WU00:FS00:0xa8:Completed 1900000 out of 5000000 steps (38%)
11:32:51:WU00:FS00:0xa8:Completed 1950000 out of 5000000 steps (39%)
11:44:58:WU00:FS00:0xa8:Completed 2000000 out of 5000000 steps (40%)
11:57:07:WU00:FS00:0xa8:Completed 2050000 out of 5000000 steps (41%)
12:09:25:WU00:FS00:0xa8:Completed 2100000 out of 5000000 steps (42%)
_r2w_ben
Post by _r2w_ben »
Before reinstalling, first try deleting GPUs.txt. There should be an entry in the Start menu for "Data Directory" that should launch File Explorer. Delete GPUs.txt from that folder and then restart your computer. Please re-post the log if it doesn't detect the GPU as supported.
Post by muziqaz »
Reinstallation shouldn't matter. And GPUs.txt would get updated every time fahclient finds new device which is not in current GPUs.txt file. But yeah, to make sure delete gpus.txt and restart the PC
FAH Omega tester
muziqaz wrote: Sat Nov 25, 2023 4:00 pm Reinstallation shouldn't matter. And GPUs.txt would get updated every time fahclient finds new device which is not in current GPUs.txt file. But yeah, to make sure delete gpus.txt and restart the PC
GPUs.txt gets downloaded at installation or any time FAHClient restarts and there is no copy of it in th directory. In between the file gets updated about once a month, but the last I checked it does not get downloaded very time a new device is found.
