!!PSA: Major AMD Species reshuffle Part 2 underway!!
Hardware configuration: 9950x, 7950x3D, 5950x, 5800x3D
7900xtx, RX9070, Radeon 7, 5700xt, 6900xt, RX 550 640SP
Post by muziqaz »
HI,
certain things have forced our hand to reshuffle AMD performance bracket (aka Species) yet again. This time we are not only splitting GPUs per performance, but also per GPU arch (GCN, RDNA 1, 2, 3, CDNA). This should allow us higher flexibility when assigning work or disabling certain architectures from certain projects either due to catastrophic performance or instability bugs.
While HIP is coming (hopefully), all the issues which plagued OpenCL, might be gone, but seeing how AMD is EOL'ing their support for older GPUs left and right, I think species reshuffle will still be extremely relevant.
Also, starting from RDNA3, there will no longer be performance brackets, as everything with RDNA3 arch on desktop and dGPU mobile is stupidly fast. iGPUs will still be pushed to lower tiers per their theoretical performance (hopefully HIP will makes those far more relevant than they are now).
Please, be mindful of this change in next week or so, until we get all the researchers informed and acting on changing their constraints. During this period your AMD GPUs might fail receiving any work, or might receive work which either performs very badly, or outright crashes. Hopefully this will be kept to the minimum, and everyone will come out happier :)
FAH Omega tester
DarkFoss
Hardware configuration: AMD 5800X3D Asus ROG Strix X570-E Gaming WiFi II bios 5031 G-Skill TridentZ Neo 3600mhz Asrock Tachi RX 7900XTX Corsair rm850x psu Asus PG32UQXR EK Elite 360 D-rgb aio Win 11pro/Kubuntu 2404.2 LTS Kernel 6.11.x HWE LowLatency UPS BX1500G
Re: !!PSA: Major AMD Species reshuffle Part 2 underway!!
Post by DarkFoss »
Thank you for the update.
I had not checked the board in the last week and noticed some erratic performance. I wasn't sure if the 11.23.1 driver was somehow at fault even though everything looked normal under the performance tab settings.
HIP before the New Year would be a welcome surprise. :wink:
