Please add AMD Radeon PRO W7900 to the supported GPU list
FineKatz
Post by FineKatz »
Info from GPUz:
1002 7448 1002 0E0D
*********************** Log Started 2023-11-13T22:30:15Z ***********************
22:30:15:******************************* libFAH ********************************
22:30:15:           Date: Oct 20 2020
22:30:15:           Time: 13:36:55
22:30:15:       Revision: 5ca109d295a6245e2a2f590b3d0085ad5e567aeb
22:30:15:         Branch: master
22:30:15:       Compiler: Visual C++ 2015
22:30:15:        Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
22:30:15:       Platform: win32 10
22:30:15:           Bits: 32
22:30:15:           Mode: Release
22:30:15:****************************** FAHClient ******************************
22:30:15:        Version: 7.6.21
22:30:15:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
22:30:15:      Copyright: 2020 foldingathome.org
22:30:15:       Homepage: https://foldingathome.org/
22:30:15:           Time: 13:41:04
22:30:15:       Revision: 6efbf0e138e22d3963e6a291f78dcb9c6422a278
22:30:15:           Bits: 32
22:30:15:         Config: C:\ProgramData\FAHClient\config.xml
22:30:15:******************************** CBang ********************************
22:30:15:           Time: 11:36:18
22:30:15:       Revision: 7e4ce85225d7eaeb775e87c31740181ca603de60
22:30:15:           Bits: 32
22:30:15:******************************* System ********************************
22:30:15:            CPU: AMD Ryzen Threadripper PRO 5995WX 64-Cores
22:30:15:         CPU ID: AuthenticAMD Family 25 Model 8 Stepping 2
22:30:15:           CPUs: 32
22:30:15:         Memory: 255.84GiB
22:30:15:    Free Memory: 249.24GiB
22:30:15:        Threads: WINDOWS_THREADS
22:30:15:     OS Version: 6.2
22:30:15:    Has Battery: false
22:30:15:     On Battery: false
22:30:15:     UTC Offset: -5
22:30:15:            PID: 11088
22:30:15:            CWD: C:\ProgramData\FAHClient
22:30:15:  Win32 Service: false
22:30:15:             OS: Windows 10 Enterprise
22:30:15:        OS Arch: AMD64
22:30:15:           GPUs: 1
22:30:15:          GPU 0: Bus:67 Slot:0 Func:0 AMD:1
22:30:15:           CUDA: Not detected: Failed to open dynamic library 'nvcuda.dll': The
22:30:15:                 specified module could not be found.
22:30:15:
22:30:15:OpenCL Device 0: Platform:0 Device:0 Bus:67 Slot:0 Compute:1.2 Driver:3570.0
22:30:15:***********************************************************************
22:30:15:<config>
22:30:15:  <!-- Network -->
22:30:15:  <proxy v=':8080'/>
22:30:15:
22:30:15:  <!-- User Information -->
22:30:15:  <passkey v='*****'/>
22:30:15:  <team v='254500'/>
22:30:15:  <user v='FineKatz'/>
22:30:15:
22:30:15:  <!-- Folding Slots -->
22:30:15:  <slot id='0' type='CPU'/>
22:30:15:  <slot id='1' type='GPU'>
22:30:15:    <pci-bus v='67'/>
22:30:15:    <pci-slot v='0'/>
22:30:15:  </slot>
22:30:15:</config>
22:30:15:Trying to access database...
22:30:15:Successfully acquired database lock
22:30:15:FS00:Initialized folding slot 00: cpu:30
22:30:15:WARNING:FS01:Disabling beta GPU slot 01: gpu:67:0.  Beta GPUs can be tested for no points by setting ``gpu-beta=true`` in the configuration.
22:30:15:WU00:FS00:Starting
22:30:15:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/gromacs-core-a9/windows-10-64bit/cpu-avx2_256-release/0xa9-0.0.12/Core_a9.fah/FahCore_a9.exe -dir 00 -suffix 01 -version 706 -lifeline 11088 -checkpoint 15 -np 30
22:30:15:WU00:FS00:Started FahCore on PID 15196
22:30:15:WU00:FS00:Core PID:15128
22:30:15:WU00:FS00:FahCore 0xa9 started
22:30:15:WU00:FS00:0xa9:*********************** Log Started 2023-11-13T22:30:15Z ***********************
22:30:15:WU00:FS00:0xa9:************************** Gromacs Folding@home Core ***************************
22:30:15:WU00:FS00:0xa9:       Core: Gromacs
22:30:15:WU00:FS00:0xa9:       Type: 0xa9
22:30:15:WU00:FS00:0xa9:    Version: 0.0.12
22:30:15:WU00:FS00:0xa9:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
22:30:15:WU00:FS00:0xa9:  Copyright: 2022 foldingathome.org
22:30:15:WU00:FS00:0xa9:   Homepage: https://foldingathome.org/
22:30:15:WU00:FS00:0xa9:       Date: Nov 15 2022
22:30:15:WU00:FS00:0xa9:       Time: 13:31:08
22:30:15:WU00:FS00:0xa9:   Compiler: Visual C++
22:30:15:WU00:FS00:0xa9:    Options: /TP /std:c++17 /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
22:30:15:WU00:FS00:0xa9:   Platform: win32 10
22:30:15:WU00:FS00:0xa9:       Bits: 64
22:30:15:WU00:FS00:0xa9:       Mode: Release
22:30:15:WU00:FS00:0xa9:       SIMD: avx2_256
22:30:15:WU00:FS00:0xa9:     OpenMP: ON
22:30:15:WU00:FS00:0xa9:       CUDA: OFF
22:30:15:WU00:FS00:0xa9:     OpenCL: OFF
22:30:15:WU00:FS00:0xa9:       Args: -dir 00 -suffix 01 -version 706 -lifeline 15196 -checkpoint 15 -np
22:30:15:WU00:FS00:0xa9:             30
22:30:15:WU00:FS00:0xa9:************************************ libFAH ************************************
22:30:15:WU00:FS00:0xa9:       Time: 13:30:33
22:30:15:WU00:FS00:0xa9:    Options: /TP /std:c++14 /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
22:30:15:WU00:FS00:0xa9:************************************ CBang *************************************
22:30:15:WU00:FS00:0xa9:       Time: 13:29:57
22:30:15:WU00:FS00:0xa9:************************************ System ************************************
22:30:15:WU00:FS00:0xa9:        CPU: AMD Ryzen Threadripper PRO 5995WX 64-Cores
22:30:15:WU00:FS00:0xa9:     CPU ID: AuthenticAMD Family 25 Model 8 Stepping 2
22:30:15:WU00:FS00:0xa9:       CPUs: 64
22:30:15:WU00:FS00:0xa9:     Memory: 255.84GiB
22:30:15:WU00:FS00:0xa9:Free Memory: 249.19GiB
22:30:15:WU00:FS00:0xa9:    Threads: WINDOWS_THREADS
22:30:15:WU00:FS00:0xa9: OS Version: 6.2
22:30:15:WU00:FS00:0xa9:Has Battery: false
22:30:15:WU00:FS00:0xa9: On Battery: false
22:30:15:WU00:FS00:0xa9: UTC Offset: -5
22:30:15:WU00:FS00:0xa9:        PID: 15128
22:30:15:WU00:FS00:0xa9:        CWD: C:\ProgramData\FAHClient\work
22:30:15:WU00:FS00:0xa9:       Exec: C:\ProgramData\FAHClient\cores\cores.foldingathome.org\gromacs-core-a9\windows-10-64bit\cpu-avx2_256-release\0xa9-0.0.12\Core_a9.fah\FahCore_a9.exe
22:30:15:WU00:FS00:0xa9:********************************************************************************
22:30:15:WU00:FS00:0xa9:Project: 18806 (Run 11, Clone 26, Gen 63)
22:30:15:WU00:FS00:0xa9:Digital signatures verified
22:30:15:WU00:FS00:0xa9:Calling: mdrun -c frame63.gro -s frame63.tpr -x frame63.xtc -cpi state.cpt -cpt 15 -nt 30 -ntmpi 1 -update cpu -nb cpu -bonded cpu -pme cpu -pmefft cpu
22:30:17:WU00:FS00:0xa9:Steps: first=15750000 total=16000000
22:30:22:WU00:FS00:0xa9:Completed 1 out of 250000 steps (0%)
22:31:37:WU00:FS00:0xa9:Completed 2500 out of 250000 steps (1%)
22:32:53:WU00:FS00:0xa9:Completed 5000 out of 250000 steps (2%)
22:34:08:WU00:FS00:0xa9:Completed 7500 out of 250000 steps (3%)
22:35:24:WU00:FS00:0xa9:Completed 10000 out of 250000 steps (4%)
22:36:39:WU00:FS00:0xa9:Completed 12500 out of 250000 steps (5%)
22:37:55:WU00:FS00:0xa9:Completed 15000 out of 250000 steps (6%)
22:39:09:WU00:FS00:0xa9:Completed 17500 out of 250000 steps (7%)
22:40:25:WU00:FS00:0xa9:Completed 20000 out of 250000 steps (8%)
22:41:40:WU00:FS00:0xa9:Completed 22500 out of 250000 steps (9%)
22:42:55:WU00:FS00:0xa9:Completed 25000 out of 250000 steps (10%)
22:44:09:WU00:FS00:0xa9:Completed 27500 out of 250000 steps (11%)
Reason: added code tags to log
Re: Please add AMD Radeon PRO W7900 to the supported GPU list
Post by muziqaz »
Added.
Please restart your PC. And let us know if it works
Regards
FAH Omega tester
FineKatz
Post by FineKatz »
Thank you for the quick response! I deleted the existing GPUs.txt file and restarted and now the Radeon PRO W7900 is cranking up to an estimated 4.5M PPD. I work for AMD, so I will see if I can get the IDs for the rest of the Radeon PRO lineup as well (W7800, W7700, W7600, W7500).
Note that I am running on a Threadripper PRO 5995WX with 64 cores and 128 threads, but only 32 processes are active in Task Manager. Is there a way to leverage 64 physical cores and 128 threads? Or with the new Threadripper PRO 7995WX, using all 96 cores and 192 threads?
Thanks again,
Michael
Post by muziqaz »
yes, create more slots for a cpu with 32threads assigned to each, except the last one, which should be 30 threads, leaving 2 threads for your gpu
FAH Omega tester
