Projevt 17118 on 4090
Hola,
Last night I got a job for project 17118 on my 4090, which is probably by mistake. It was ready in only 6 minutes or so, and got me just 18k points. This project is probably meant for smaller GPUs.
https://apps.foldingathome.org/wu#proje ... =338&gen=0
Cheers,
Paul
Cheers,
Paul
pyrocyborg
- Hardware configuration: 3060 12GB, 3060 Ti, 3070, 3080, 3090, 6700 XT, 6800 XT, 6900 XT
Re: Projevt 17118 on 4090
This is a very fast benchmark, I think. Happens sometimes.
Exactly. There are a few benchmarking projects to check performance on various GPUs. In this case the description was copy / pasted from a previous project for Core_22, but is testing Core_23.pyrocyborg wrote: ↑Mon Oct 30, 2023 2:43 pm This is a very fast benchmark, I think. Happens sometimes.
Project description - https://stats.foldingathome.org/project/17118
Thanks! I should have realized it's a performance project, I guess I was still half asleep this morning when posting...
How do I get my machine to stop jamming up on this project?
This system keeps cycling
23:51:31:WU00:FS00:Starting
23:51:31:WU00:FS00:Removing old file 'work/00/logfile_01-20231031-231156.txt'
23:51:31:WU00:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/openmm-core-23/centos-7.9.2009-64bit/release/0x23-8.0.3/Core_23.fah/FahCore_23 -dir 00 -suffix 01 -version 706 -lifeline 1446 -checkpoint 30 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
23:51:31:WU00:FS00:Started FahCore on PID 4787
23:51:31:WU00:FS00:Core PID:4791
23:51:31:WU00:FS00:FahCore 0x23 started
23:51:32:WU00:FS00:0x23:*********************** Log Started 2023-10-31T23:51:31Z ***********************
23:51:32:WU00:FS00:0x23:*************************** Core23 Folding@home Core ***************************
23:51:32:WU00:FS00:0x23: Core: Core23
23:51:32:WU00:FS00:0x23: Type: 0x23
23:51:32:WU00:FS00:0x23: Version: 8.0.3
23:51:32:WU00:FS00:0x23: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
23:51:32:WU00:FS00:0x23: Copyright: 2022 foldingathome.org
23:51:32:WU00:FS00:0x23: Homepage: https://foldingathome.org/
23:51:32:WU00:FS00:0x23: Date: Aug 3 2023
23:51:32:WU00:FS00:0x23: Time: 08:28:22
23:51:32:WU00:FS00:0x23: Revision: 199cb870317d05441d0a301287d9ef61254fa32b
23:51:32:WU00:FS00:0x23: Branch: HEAD
23:51:32:WU00:FS00:0x23: Compiler: GNU 7.5.0
23:51:32:WU00:FS00:0x23: Options: -faligned-new -std=c++11 -fsigned-char -ffunction-sections
23:51:32:WU00:FS00:0x23: -fdata-sections -O3 -funroll-loops -fno-pie
23:51:32:WU00:FS00:0x23: -DOPENMM_VERSION="\"8.0.0\""
23:51:32:WU00:FS00:0x23: Platform: linux 5.15.0-1041-azure
23:51:32:WU00:FS00:0x23: Bits: 64
23:51:32:WU00:FS00:0x23: Mode: Release
23:51:32:WU00:FS00:0x23:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
23:51:32:WU00:FS00:0x23: <peastman@stanford.edu>
23:51:32:WU00:FS00:0x23: Args: -dir 00 -suffix 01 -version 706 -lifeline 4787 -checkpoint 30
23:51:32:WU00:FS00:0x23: -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
23:51:32:WU00:FS00:0x23: 0 -gpu 0
23:51:32:WU00:FS00:0x23:************************************ libFAH ************************************
23:51:32:WU00:FS00:0x23: Time: 08:27:48
23:51:32:WU00:FS00:0x23: Revision: 112c2234abe20611a05652defc3c7f854cbf927f
23:51:32:WU00:FS00:0x23:************************************ CBang *************************************
23:51:32:WU00:FS00:0x23: Version: 1.7.2
23:51:32:WU00:FS00:0x23: Org: Cauldron Development LLC
23:51:32:WU00:FS00:0x23: Copyright: Cauldron Development LLC, 2003-2023
23:51:32:WU00:FS00:0x23: Homepage: https://cauldrondevelopment.com/
23:51:32:WU00:FS00:0x23: License: GPL 2+
23:51:32:WU00:FS00:0x23: Time: 08:27:30
23:51:32:WU00:FS00:0x23: Revision: eae4b58965bdd4d54ea9eb77972674352b37a547
23:51:32:WU00:FS00:0x23: -fdata-sections -O3 -funroll-loops -fno-pie -fPIC
23:51:32:WU00:FS00:0x23:************************************ System ************************************
23:51:32:WU00:FS00:0x23: CPU: AMD Phenom(tm) II X2 545 Processor
23:51:32:WU00:FS00:0x23: CPU ID: AuthenticAMD Family 16 Model 4 Stepping 2
23:51:32:WU00:FS00:0x23: CPUs: 2
23:51:32:WU00:FS00:0x23: Memory: 3.81GiB
23:51:32:WU00:FS00:0x23:Free Memory: 824.84MiB
23:51:32:WU00:FS00:0x23: Threads: POSIX_THREADS
23:51:32:WU00:FS00:0x23: OS Version: 6.5
23:51:32:WU00:FS00:0x23:Has Battery: false
23:51:32:WU00:FS00:0x23: On Battery: false
23:51:32:WU00:FS00:0x23: UTC Offset: -5
23:51:32:WU00:FS00:0x23: PID: 4791
23:51:32:WU00:FS00:0x23: CWD: /var/lib/fahclient/work
23:51:32:WU00:FS00:0x23: Exec: /var/lib/fahclient/cores/cores.foldingathome.org/openmm-core-23/centos-7.9.2009-64bit/release/0x23-8.0.3/Core_23.fah/FahCore_23
23:51:32:WU00:FS00:0x23:************************************ OpenMM ************************************
23:51:32:WU00:FS00:0x23: Version: 8.0.0
23:51:32:WU00:FS00:0x23:********************************************************************************
23:51:32:WU00:FS00:0x23:Project: 17118 (Run 2, Clone 406, Gen 0)
23:51:32:WU00:FS00:0x23:Digital signatures verified
23:51:32:WU00:FS00:0x23:Folding@home GPU Core23 Folding@home Core
23:51:32:WU00:FS00:0x23:Version 8.0.3
23:51:32:WU00:FS00:0x23: Checkpoint write interval: 433117 steps (50%) [2 total]
23:51:32:WU00:FS00:0x23: JSON viewer frame write interval: 8662 steps (1%) [100 total]
23:51:32:WU00:FS00:0x23: XTC frame write interval: 866234 steps (1e+02%) [1 total]
23:51:32:WU00:FS00:0x23: Global context and integrator variables write interval: disabled
23:51:32:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
BobWilliams757
Ryzen 2400G APU
32 GB DDR4-3200
MSI GTX 1660 Super Gaming X
It might be worth showing more of your log. I can see the last line you posted, and assume it crashed after that, but the why and/or the specifics might be down further in the log. If it doesn't go beyond that point and just restarts at least we will know that.
Also....
Does it reboot the machine, or just kill the work unit?
What OS, and basic (at least) system configuration?
Is the machine usually stable for folding?
Has it been multiple work units, every unit from that project, etc?
And anything else that might be of importance. Some of these benchmark work units are experimental to some extent, and knowing what machines they cause issues on might help them straighten things out.
Fold them if you get them!
It got better (after a day or two). I'm runnung Fedora Linux 38 (Workstation Edition) on an AMD Phenom™ II X2 545 × 2 with a NVIDIA GeForce GTX 1660 SUPER GPU. It had been running ~ 1 million 'points' per day.
This is what the end of the problem looked like:
Now it is back to running jobs again. It would be useful to know how to short-circuit this problem (if it happens again) so I don't have to wait until the job times out.
... 05:53:01:WU00:FS00:0x23:************************************ OpenMM ************************************
05:53:01:WU00:FS00:0x23: Version: 8.0.0
05:53:01:WU00:FS00:0x23:********************************************************************************
05:53:01:WU00:FS00:0x23:Project: 17118 (Run 2, Clone 406, Gen 0)
05:53:01:WU00:FS00:0x23:Digital signatures verified
05:53:01:WU00:FS00:0x23:Folding@home GPU Core23 Folding@home Core
05:53:01:WU00:FS00:0x23:Version 8.0.3
05:53:01:WU00:FS00:0x23: Checkpoint write interval: 433117 steps (50%) [2 total]
05:53:01:WU00:FS00:0x23: JSON viewer frame write interval: 8662 steps (1%) [100 total]
05:53:01:WU00:FS00:0x23: XTC frame write interval: 866234 steps (1e+02%) [1 total]
05:53:01:WU00:FS00:0x23: Global context and integrator variables write interval: disabled
05:53:02:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
05:53:04:WARNING:WU00:FS00:Past final deadline 2023-11-01T05:53:03Z, dumping
05:53:04:WU00:FS00:Cleaning up
05:53:04:WU00:FS00:Connecting to assign1.foldingathome.org:80
05:53:04:WU00:FS00:Assigned to work server 129.32.209.200
05:53:04:WU00:FS00:Requesting new work unit for slot 00: READY gpu:0:TU116 [GeForce GTX 1660 SUPER] from 129.32.209.200
05:53:04:WU00:FS00:Connecting to 129.32.209.200:8080-
BobWilliams757
Ryzen 2400G APU
32 GB DDR4-3200
Interesting that it just hung like that until it timed out. In any case, if you get continued problems you should report them, since it's a benchmarking project and looking for any possible issues.
Try to run this command in a terminal, it will print the actual issue that is causing the INTERRUPTED errore :wdanwatts wrote: ↑Tue Oct 31, 2023 11:56 pm This system keeps cyclingCode: Select all
23:51:31:WU00:FS00:Starting 23:51:31:WU00:FS00:Removing old file 'work/00/logfile_01-20231031-231156.txt' 23:51:31:WU00:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/openmm-core-23/centos-7.9.2009-64bit/release/0x23-8.0.3/Core_23.fah/FahCore_23 -dir 00 -suffix 01 -version 706 -lifeline 1446 -checkpoint 30 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0 23:51:31:WU00:FS00:Started FahCore on PID 4787 23:51:31:WU00:FS00:Core PID:4791 23:51:31:WU00:FS00:FahCore 0x23 started 23:51:32:WU00:FS00:0x23:*********************** Log Started 2023-10-31T23:51:31Z *********************** 23:51:32:WU00:FS00:0x23:*************************** Core23 Folding@home Core *************************** 23:51:32:WU00:FS00:0x23: Core: Core23 23:51:32:WU00:FS00:0x23: Type: 0x23 23:51:32:WU00:FS00:0x23: Version: 8.0.3 23:51:32:WU00:FS00:0x23: Author: Joseph Coffland <joseph@cauldrondevelopment.com> 23:51:32:WU00:FS00:0x23: Copyright: 2022 foldingathome.org 23:51:32:WU00:FS00:0x23: Homepage: https://foldingathome.org/ 23:51:32:WU00:FS00:0x23: Date: Aug 3 2023 23:51:32:WU00:FS00:0x23: Time: 08:28:22 23:51:32:WU00:FS00:0x23: Revision: 199cb870317d05441d0a301287d9ef61254fa32b 23:51:32:WU00:FS00:0x23: Branch: HEAD 23:51:32:WU00:FS00:0x23: Compiler: GNU 7.5.0 23:51:32:WU00:FS00:0x23: Options: -faligned-new -std=c++11 -fsigned-char -ffunction-sections 23:51:32:WU00:FS00:0x23: -fdata-sections -O3 -funroll-loops -fno-pie 23:51:32:WU00:FS00:0x23: -DOPENMM_VERSION="\"8.0.0\"" 23:51:32:WU00:FS00:0x23: Platform: linux 5.15.0-1041-azure 23:51:32:WU00:FS00:0x23: Bits: 64 23:51:32:WU00:FS00:0x23: Mode: Release 23:51:32:WU00:FS00:0x23:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman 23:51:32:WU00:FS00:0x23: <peastman@stanford.edu> 23:51:32:WU00:FS00:0x23: Args: -dir 00 -suffix 01 -version 706 -lifeline 4787 -checkpoint 30 23:51:32:WU00:FS00:0x23: -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 23:51:32:WU00:FS00:0x23: 0 -gpu 0 23:51:32:WU00:FS00:0x23:************************************ libFAH ************************************ 23:51:32:WU00:FS00:0x23: Date: Aug 3 2023 23:51:32:WU00:FS00:0x23: Time: 08:27:48 23:51:32:WU00:FS00:0x23: Revision: 112c2234abe20611a05652defc3c7f854cbf927f 23:51:32:WU00:FS00:0x23: Branch: HEAD 23:51:32:WU00:FS00:0x23: Compiler: GNU 7.5.0 23:51:32:WU00:FS00:0x23: Options: -faligned-new -std=c++11 -fsigned-char -ffunction-sections 23:51:32:WU00:FS00:0x23: -fdata-sections -O3 -funroll-loops -fno-pie 23:51:32:WU00:FS00:0x23: Platform: linux 5.15.0-1041-azure 23:51:32:WU00:FS00:0x23: Bits: 64 23:51:32:WU00:FS00:0x23: Mode: Release 23:51:32:WU00:FS00:0x23:************************************ CBang ************************************* 23:51:32:WU00:FS00:0x23: Version: 1.7.2 23:51:32:WU00:FS00:0x23: Author: Joseph Coffland <joseph@cauldrondevelopment.com> 23:51:32:WU00:FS00:0x23: Org: Cauldron Development LLC 23:51:32:WU00:FS00:0x23: Copyright: Cauldron Development LLC, 2003-2023 23:51:32:WU00:FS00:0x23: Homepage: https://cauldrondevelopment.com/ 23:51:32:WU00:FS00:0x23: License: GPL 2+ 23:51:32:WU00:FS00:0x23: Date: Aug 3 2023 23:51:32:WU00:FS00:0x23: Time: 08:27:30 23:51:32:WU00:FS00:0x23: Revision: eae4b58965bdd4d54ea9eb77972674352b37a547 23:51:32:WU00:FS00:0x23: Branch: HEAD 23:51:32:WU00:FS00:0x23: Compiler: GNU 7.5.0 23:51:32:WU00:FS00:0x23: Options: -faligned-new -std=c++11 -fsigned-char -ffunction-sections 23:51:32:WU00:FS00:0x23: -fdata-sections -O3 -funroll-loops -fno-pie -fPIC 23:51:32:WU00:FS00:0x23: Platform: linux 5.15.0-1041-azure 23:51:32:WU00:FS00:0x23: Bits: 64 23:51:32:WU00:FS00:0x23: Mode: Release 23:51:32:WU00:FS00:0x23:************************************ System ************************************ 23:51:32:WU00:FS00:0x23: CPU: AMD Phenom(tm) II X2 545 Processor 23:51:32:WU00:FS00:0x23: CPU ID: AuthenticAMD Family 16 Model 4 Stepping 2 23:51:32:WU00:FS00:0x23: CPUs: 2 23:51:32:WU00:FS00:0x23: Memory: 3.81GiB 23:51:32:WU00:FS00:0x23:Free Memory: 824.84MiB 23:51:32:WU00:FS00:0x23: Threads: POSIX_THREADS 23:51:32:WU00:FS00:0x23: OS Version: 6.5 23:51:32:WU00:FS00:0x23:Has Battery: false 23:51:32:WU00:FS00:0x23: On Battery: false 23:51:32:WU00:FS00:0x23: UTC Offset: -5 23:51:32:WU00:FS00:0x23: PID: 4791 23:51:32:WU00:FS00:0x23: CWD: /var/lib/fahclient/work 23:51:32:WU00:FS00:0x23: Exec: /var/lib/fahclient/cores/cores.foldingathome.org/openmm-core-23/centos-7.9.2009-64bit/release/0x23-8.0.3/Core_23.fah/FahCore_23 23:51:32:WU00:FS00:0x23:************************************ OpenMM ************************************ 23:51:32:WU00:FS00:0x23: Version: 8.0.0 23:51:32:WU00:FS00:0x23:******************************************************************************** 23:51:32:WU00:FS00:0x23:Project: 17118 (Run 2, Clone 406, Gen 0) 23:51:32:WU00:FS00:0x23:Digital signatures verified 23:51:32:WU00:FS00:0x23:Folding@home GPU Core23 Folding@home Core 23:51:32:WU00:FS00:0x23:Version 8.0.3 23:51:32:WU00:FS00:0x23: Checkpoint write interval: 433117 steps (50%) [2 total] 23:51:32:WU00:FS00:0x23: JSON viewer frame write interval: 8662 steps (1%) [100 total] 23:51:32:WU00:FS00:0x23: XTC frame write interval: 866234 steps (1e+02%) [1 total] 23:51:32:WU00:FS00:0x23: Global context and integrator variables write interval: disabled 23:51:32:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
./var/lib/fahclient/cores/cores.foldingathome.org/openmm-core-23/centos-7.9.2009-64bit/release/0x23-8.0.3/Core_23.fah/FahCore_23 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0Re: Projevt 17118 on 4090
On my Fedora v 39 I get
How do I get libOpenMM.so.8.0 ?
./FahCore_23: error while loading shared libraries: libOpenMM.so.8.0: cannot open shared object file: No such file or directory-
bikeaddict
This library and many more libOpenMM files should be downloaded by the client as part of the core files. It's here on my Fedora system:
/var/lib/fahclient/cores/cores.foldingathome.org/openmm-core-23/centos-7.9.2009-64bit/release/0x23-8.0.3/Core_23.fah/libOpenMM.so.8.0Re: Projevt 17118 on 4090
A system reboot started a string of Core 22 jobs so my lack of a Core 23 library is not critical at this time.
