Project: 4595 (Run 7, Clone 13, Gen 22)
anko1
(3.2GHz) HT;Windows XP
Post by anko1 »
FYI - I got an EUE on this WU. I posted the log below. Not sure why this happened. I've done lots of other 4595s successfully on this computer, and it's not overclocked.
[01:21:54] + Processing work unit
[01:21:54] Core required: FahCore_82.exe
[01:21:54] Core found.
[01:21:54] Working on Unit 01 [July 19 01:21:54]
[01:21:54] + Working ...
[01:21:54] - Calling 'FahCore_82.exe -dir work/ -suffix 01 -checkpoint 15 -verbose -lifeline 720 -version 503'
[01:21:54]
[01:21:54] *------------------------------*
[01:21:54] Folding@Home PMD Core
[01:21:54] Version 1.03 (September 7, 2005)
[01:21:54]
[01:21:54] Preparing to commence simulation
[01:21:54] - Looking at optimizations...
[01:21:54] - Created dyn
[01:21:54] - Files status OK
[01:21:54] - Expanded 11847 -> 74864 (decompressed 631.9 percent)
[01:21:54]
[01:21:54] Project: 4595 (Run 7, Clone 13, Gen 22)
[01:21:54]
[01:21:54] Assembly optimizations on if available.
[01:21:54] Entering M.D.
[01:21:56] + New frame time estimate; Working...
[01:22:00] Going to send back what have done.
[01:22:00] logfile size: 5649
[01:22:00] - Writing 6169 bytes of core data to disk...
[01:22:00]   ... Done.
[01:22:00]
[01:22:00] Folding@home Core Shutdown: EARLY_UNIT_END
[01:22:01] + New frame time estimate; Working...
[01:22:04] CoreStatus = 72 (114)
[01:22:04] Sending work to server
[01:22:04] + Attempting to send results
[01:22:04] - Reading file work/wuresults_01.dat from core
[01:22:04]   (Read 6169 bytes from disk)
[01:22:04] Connecting to http://169.230.26.30:8080/
[01:22:04] Posted data.
[01:22:04] Initial: 0000; Conversation time very short, giving reduced weight in bandwidth avg
[01:22:04] - Uploaded at ~14 kB/s
[01:22:04] - Averaged speed for that direction ~46 kB/s
[01:22:04] + Results successfully sent
[01:22:04] Thank you for your contribution to Folding@Home.
[01:22:08] Trying to send all finished work units
Re: Project: 4595 (Run 7, Clone 13, Gen 22)
This is probably a bad WU ... I see 6 reports of EUE for 0 points for it :(
anko1
Post by anko1 »
Thanks for letting me know I'm not alone. ;-)
ppetrone
Pande Group Member
Post by ppetrone »
Hi anko1,
You are definitely not alone, and yes, it looks like a bad WU from the reports. Thanks for the post. I will make a note to Vince Voelz. The report will be useful to him.
paula
anko1
Post by anko1 »
Thank you, also, Paula.
Angela
vvoelz
Pande Group Member
Post by vvoelz »
I'll shut down this WU (p4595) and check it out. Thanks for letting me know. --Vince
