Project: 2170 (Run 36, Clone 599, Gen 3)
Oriolus
Post by Oriolus »
On July 15th my computer started working on:
[08:16:05] + Processing work unit
[08:16:06] + Attempting to send results
[08:16:06] Core required: FahCore_82.exe
[08:16:07] Core found.
[08:16:24] Working on Unit 07 [July 15 08:16:24]
On July 17th work on unit 07 stopped and a new one was downloaded:
[00:24:08] Completed 270000 out of 500000 steps  (54)
[00:24:52] Writing checkpoint files
[00:27:54] Writing checkpoint files
[00:31:06] Writing checkpoint files
[00:34:17] Writing checkpoint files
[00:36:07] CoreStatus = 40010004 (1073807364)
[00:36:07] Client-core communications error: ERROR 0x40010004
[00:36:07] Deleting current work unit & continuing...
[00:36:11] - Preparing to get new work unit...
[00:36:11] + Attempting to get work packet
[00:36:11] - Connecting to assignment server
[00:36:12] - Successful: assigned to (171.64.122.72).
[00:36:12] + News From Folding@Home: Welcome to Folding@Home
[00:36:12] Loaded queue successfully.
[00:36:17] + Closed connections
[00:36:22]
[00:36:22] + Processing work unit
[00:36:22] Core required: FahCore_81.exe
[00:36:22] Core found.
[00:36:22] Working on Unit 08 [July 18 00:36:22]
[00:36:22] + Working ...
[00:36:26] CoreStatus = C0000142 (-1073741502)
[00:36:26] Client-core communications error: ERROR 0xc0000142
[00:36:26] Deleting current work unit & continuing...
[00:36:30] - Preparing to get new work unit...
[00:36:30] + Attempting to get work packet
[00:36:30] - Connecting to assignment server
[00:36:31] - Successful: assigned to (171.64.122.72).
[00:36:31] + News From Folding@Home: Welcome to Folding@Home
[00:36:31] Loaded queue successfully.
[00:36:35] + Closed connections
[00:36:40]
[00:36:40] + Processing work unit
[00:36:40] Core required: FahCore_81.exe
[00:36:40] Core found.
[00:36:40] Working on Unit 09 [July 18 00:36:40]
[00:36:40] + Working ...
[00:36:44] CoreStatus = C0000142 (-1073741502)
[00:36:44] Client-core communications error: ERROR 0xc0000142
[00:36:44] - Attempting to download new core...
[00:36:44] + Downloading new core: FahCore_81.exe
[00:36:45] + 10240 bytes downloaded
On July 18th work on unit 09 finished, seemingly to, me in an abnormal way:
Project: 4416 (Run 27, Clone 5, Gen 192)
[11:16:29] Completed 150000 out of 150000 steps  (100)
[11:16:29] Writing final coordinates.
[11:16:29] Past main M.D. loop
[11:17:29]
[11:17:29] Finished Work Unit:
[11:17:29] - Reading up to 377376 from "work/wudata_09.arc": Read 377376
[11:17:29] - Reading up to 169616 from "work/wudata_09.xtc": Read 169616
[11:17:29] goefile size: 0
[11:17:30] logfile size: 19227
[11:17:30] Leaving Run
[11:17:30] - Writing 1205652 bytes of core data to disk...
[11:17:30] Done: 1205140 -> 596261 (compressed to 49.4 percent)
[11:17:30]   ... Done.
[11:17:30] - Shutting down core
[11:17:30]
[11:17:30] Folding@home Core Shutdown: FINISHED_UNIT
[11:17:34] CoreStatus = 64 (100)
[11:17:34] Sending work to server
[11:17:34] + Attempting to send results
[11:17:43] + Results successfully sent
[11:17:43] Thank you for your contribution to Folding@Home.
[11:17:43] + Number of Units Completed: 179
My two questions are:
1. What happened to unit 08?
2. Was there something the matter with unit 09, as a consequence of trouble with the previous unit 08?
TIA, Oriolus
PS - OT: How can I insert parts of logs as a nice window that one can scroll up and down? I like that :)
Re: Project: 2170 (Run 36, Clone 599, Gen 3)
Use the tags ;)
Oriolus
Post by Oriolus »
Great, thanks, toTOW!
codysluder
Post by codysluder »
I think you've missed a bit of important information.
Unit 07 had an error and was deleted.
Units 08 and 09 had immediate errors and were deleted.
From what you've posted, it's not clear to me whether this is unit 09 or unit 00 or even 01, but that's not really important. It finished normally and you should have gotten credit for it.
[11:17:29]
[11:17:30]
Oriolus
Post by Oriolus »
Thank you, codysluder; I presume you are right, so I'm content :)
Nevertheless, after studying my logs I cannot understand what happened exactly; a pity, because I'm a nosy poker :)
Thanks again, Oriolus
uncle_fungus
Post by uncle_fungus »
The Stats Database wrote:Hi Oriolus (team 99),
Your WU (P4416 R27 C5 G192) was added to the stats database on 2008-07-18 06:21:36 for 15 points of credit.
TheSonOfMan
Post by TheSonOfMan »
The description of this project has a broken link to an image file. The extension should be lowercase (jpg , not JPG).
ppetrone
Pande Group Member
Post by ppetrone »
Ups! Thank you SonOfMan. I will make a note to Dan so that he knows about the image. It will be fixed soon.
DanEnsign
Pande Group Member
Post by DanEnsign »
Sorry, there was no description for this project, but rather a minor bug that sent all projects from 2075 through 2304 to the 2075 description -- which has a broken image. Probably that's a dead project (since Alex graduated) so it probably won't be fixed.
Of course you were probably looking for a description of 2170, but I won't be able to get to that today -- if you have any questions, you can ask them here. :)
Dan
Oriolus
Post by Oriolus »
Thanks uncle_fungus. I beleave all is well again, if it not were already!
