please add the AMD 7800XT to the list.
I guess not too many people purchased this new card to be making a request to add to the white list....lol Please add the 7800XT to the list when you can.
Re: please add the AMD 7800XT to the list.
Can you provide the PCI ID for this GPU per the instructions in this stickied post for this section of the forum - viewtopic.php?p=262894#p262894
Name AMD Radeon RX 7800 XT Device ID 1002 747E-1849 5324
*********************** Log Started 2023-09-14T17:16:25Z ***********************
17:16:25:******************************* libFAH ********************************
17:16:25: Date: Oct 20 2020
17:16:25: Time: 13:36:55
17:16:25: Revision: 5ca109d295a6245e2a2f590b3d0085ad5e567aeb
17:16:25: Branch: master
17:16:25: Compiler: Visual C++ 2015
17:16:25: Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
17:16:25: Platform: win32 10
17:16:25: Bits: 32
17:16:25: Mode: Release
17:16:25:****************************** FAHClient ******************************
17:16:25: Version: 7.6.21
17:16:25: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
17:16:25: Copyright: 2020 foldingathome.org
17:16:25: Homepage: https://foldingathome.org/
17:16:25: Time: 13:41:04
17:16:25: Revision: 6efbf0e138e22d3963e6a291f78dcb9c6422a278
17:16:25: Bits: 32
17:16:25: Args: --open-web-control
17:16:25: Config: C:\ProgramData\FAHClient\config.xml
17:16:25:******************************** CBang ********************************
17:16:25: Time: 11:36:18
17:16:25: Revision: 7e4ce85225d7eaeb775e87c31740181ca603de60
17:16:25: Bits: 32
17:16:25:******************************* System ********************************
17:16:25: CPU: AMD Ryzen 9 5900X 12-Core Processor
17:16:25: CPU ID: AuthenticAMD Family 25 Model 33 Stepping 2
17:16:25: CPUs: 24
17:16:25: Memory: 31.92GiB
17:16:25: Free Memory: 27.04GiB
17:16:25: Threads: WINDOWS_THREADS
17:16:25: OS Version: 6.2
17:16:25: Has Battery: false
17:16:25: On Battery: false
17:16:25: UTC Offset: -4
17:16:25: PID: 9732
17:16:25: CWD: C:\ProgramData\FAHClient
17:16:25: Win32 Service: false
17:16:25: OS: Windows 10 Home
17:16:25: OS Arch: AMD64
17:16:25: GPUs: 1
17:16:25: GPU 0: Bus:12 Slot:0 Func:0 AMD:1
17:16:25: CUDA: Not detected: Failed to open dynamic library 'nvcuda.dll': The
17:16:25: specified module could not be found.
17:16:25:
17:16:25:OpenCL Device 0: Platform:0 Device:0 Bus:12 Slot:0 Compute:1.2 Driver:3584.0
17:16:25:***********************************************************************
17:16:25:<config>
17:16:25: <!-- Slot Control -->
17:16:25: <power v='full'/>
17:16:25:
17:16:25: <!-- User Information -->
17:16:25: <passkey v='*****'/>
17:16:25: <team v='11108'/>
17:16:25: <user v='armax1980'/>
17:16:25:
17:16:25: <!-- Folding Slots -->
17:16:25: <slot id='0' type='CPU'>
17:16:25: <paused v='true'/>
17:16:25: </slot>
17:16:25: <slot id='1' type='GPU'>
17:16:25: <pci-bus v='12'/>
17:16:25: <pci-slot v='0'/>
17:16:25: </slot>
17:16:25:</config>
17:16:25:Trying to access database...
17:16:25:Successfully acquired database lock
17:16:25:FS00:Initialized folding slot 00: cpu:23
17:16:25:WARNING:FS01:Disabling beta GPU slot 01: gpu:12:0. Beta GPUs can be tested for no points by setting ``gpu-beta=true`` in the configuration.
17:16:26:9:127.0.0.1:New Web session
17:16:40:FS00:Unpaused
17:16:40:WU01:FS00:Starting
17:16:40:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit-avx2-256/a8-0.0.12/Core_a8.fah/FahCore_a8.exe -dir 01 -suffix 01 -version 706 -lifeline 9732 -checkpoint 15 -np 23
17:16:40:WU01:FS00:Started FahCore on PID 10228
17:16:40:WU01:FS00:Core PID:812
17:16:40:WU01:FS00:FahCore 0xa8 started
17:16:41:WU01:FS00:0xa8:*********************** Log Started 2023-09-14T17:16:40Z ***********************
17:16:41:WU01:FS00:0xa8:************************** Gromacs Folding@home Core ***************************
17:16:41:WU01:FS00:0xa8: Core: Gromacs
17:16:41:WU01:FS00:0xa8: Type: 0xa8
17:16:41:WU01:FS00:0xa8: Version: 0.0.12
17:16:41:WU01:FS00:0xa8: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
17:16:41:WU01:FS00:0xa8: Copyright: 2020 foldingathome.org
17:16:41:WU01:FS00:0xa8: Homepage: https://foldingathome.org/
17:16:41:WU01:FS00:0xa8: Date: Jan 16 2021
17:16:41:WU01:FS00:0xa8: Time: 12:29:40
17:16:41:WU01:FS00:0xa8: Revision: c5816759c404e4b65f9f364c3d1ef554a67c4225
17:16:41:WU01:FS00:0xa8: Branch: master
17:16:41:WU01:FS00:0xa8: Compiler: Visual C++ 2019 16.7
17:16:41:WU01:FS00:0xa8: Options: /TP /std:c++14 /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
17:16:41:WU01:FS00:0xa8: Platform: win32 10
17:16:41:WU01:FS00:0xa8: Bits: 64
17:16:41:WU01:FS00:0xa8: Mode: Release
17:16:41:WU01:FS00:0xa8: SIMD: avx2_256
17:16:41:WU01:FS00:0xa8: OpenMP: ON
17:16:41:WU01:FS00:0xa8: CUDA: OFF
17:16:41:WU01:FS00:0xa8: Args: -dir 01 -suffix 01 -version 706 -lifeline 10228 -checkpoint 15 -np
17:16:41:WU01:FS00:0xa8: 23
17:16:41:WU01:FS00:0xa8:************************************ libFAH ************************************
17:16:41:WU01:FS00:0xa8: Time: 11:24:13
17:16:41:WU01:FS00:0xa8:************************************ CBang *************************************
17:16:41:WU01:FS00:0xa8: Time: 11:23:53
17:16:41:WU01:FS00:0xa8:************************************ System ************************************
17:16:41:WU01:FS00:0xa8: CPU: AMD Ryzen 9 5900X 12-Core Processor
17:16:41:WU01:FS00:0xa8: CPU ID: AuthenticAMD Family 25 Model 33 Stepping 2
17:16:41:WU01:FS00:0xa8: CPUs: 24
17:16:41:WU01:FS00:0xa8: Memory: 31.92GiB
17:16:41:WU01:FS00:0xa8:Free Memory: 26.99GiB
17:16:41:WU01:FS00:0xa8: Threads: WINDOWS_THREADS
17:16:41:WU01:FS00:0xa8: OS Version: 6.2
17:16:41:WU01:FS00:0xa8:Has Battery: false
17:16:41:WU01:FS00:0xa8: On Battery: false
17:16:41:WU01:FS00:0xa8: UTC Offset: -4
17:16:41:WU01:FS00:0xa8: PID: 812
17:16:41:WU01:FS00:0xa8: CWD: C:\ProgramData\FAHClient\work
17:16:41:WU01:FS00:0xa8:********************************************************************************
17:16:41:WU01:FS00:0xa8:Project: 12412 (Run 142, Clone 2, Gen 10)
17:16:41:WU01:FS00:0xa8:Unit: 0x00000000000000000000000000000000
17:16:41:WU01:FS00:0xa8:Digital signatures verified
17:16:41:WU01:FS00:0xa8:Calling: mdrun -c frame10.gro -s frame10.tpr -x frame10.xtc -cpi state.cpt -cpt 15 -nt 23 -ntmpi 1
17:16:41:WU01:FS00:0xa8:Steps: first=50000000 total=55000000
17:16:43:WU01:FS00:0xa8:Completed 449667 out of 5000000 steps (8%)
17:16:48:WU01:FS00:0xa8:Completed 450000 out of 5000000 steps (9%)
17:17:26:Saving configuration to config.xml
17:17:26:<config>
17:17:26: <!-- Slot Control -->
17:17:26: <power v='full'/>
17:17:26:
17:17:26: <!-- User Information -->
17:17:26: <passkey v='*****'/>
17:17:26: <team v='11108'/>
17:17:26: <user v='armax1980'/>
17:17:26:
17:17:26: <!-- Folding Slots -->
17:17:26: <slot id='0' type='CPU'/>
17:17:26: <slot id='1' type='GPU'>
17:17:26: <paused v='true'/>
17:17:26: <pci-bus v='12'/>
17:17:26: <pci-slot v='0'/>
17:17:26: </slot>
17:17:26:</config>
Sorry, slept on this. However for a moment we have issues with page which we use to add new GPUs, give us some time. This will be added eventually.
This GPU should be added now. Please restart your computer for changes to take effect
