No work assigments...
SandyG
Hardware configuration: 2 Shuttle i9's with RTX3060, Old server mobo, Mint Linux with 2 RTX3090's and 2 RTX 4090. Dell 7920 RTX3060, RTX4070
[img]https://folding.extremeoverclocking.com/sigs/sigimage.php?u=1172112[/img]
Post by SandyG »
Saw this in the logs today -
21:22:53:WU03:FS03:Connecting to assign1.foldingathome.org:80
21:22:54:WARNING:WU03:FS03:Failed to get assignment from 'assign1.foldingathome.or                       g:80': No WUs available for this configuration
21:22:54:WU03:FS03:Connecting to assign2.foldingathome.org:80
21:22:54:WARNING:WU03:FS03:Failed to get assignment from 'assign2.foldingathome.or                       g:80': No WUs available for this configuration
21:22:54:WU03:FS03:Connecting to assign3.foldingathome.org:80
21:22:55:WARNING:WU03:FS03:Failed to get assignment from 'assign3.foldingathome.or                       g:80': No WUs available for this configuration
21:22:55:WU03:FS03:Connecting to assign4.foldingathome.org:80
21:22:55:WARNING:WU03:FS03:Failed to get assignment from 'assign4.foldingathome.or                       g:80': No WUs available for this configuration
21:22:55:ERROR:WU03:FS03:Exception: Could not get an assignment
Not sure what this is as it looks like an alias for a server now not a specific server IP like before, or it's totally a different thing :D
This is running on my Linux box on a 4090 card. If you need any more info please holler!
Sandy
SandyG
Re: No work assigments...
Post by SandyG »
Just dug into the log a bit deeper and saw this -
20:55:27:ERROR:WU03:FS03:Exception: Transfer failed
20:55:28:WU03:FS03:Connecting to assign1.foldingathome.org:80
20:55:28:WU03:FS03:Assigned to work server 129.32.209.202
20:55:28:WU03:FS03:Requesting new work unit for slot 03: gpu:182:0 AD102 [GeForce RTX 4090] f            rom 129.32.209.202
20:55:28:WU03:FS03:Connecting to 129.32.209.202:8080
20:55:28:WARNING:WU03:FS03:WorkServer connection failed on port 8080 trying 80
20:55:29:ERROR:WU03:FS03:Exception: Failed to connect to 129.32.209.202:80: Connection refuse            d
20:55:36:WU01:FS02:0x22:Completed 2425000 out of 2500000 steps (97%)
20:55:44:WU02:FS01:0x22:Completed 575000 out of 2500000 steps (23%)
20:55:49:WU04:FS04:0x22:Completed 1600000 out of 2500000 steps (64%)
20:55:50:WU04:FS04:0x22:Checkpoint completed at step 1600000
20:56:12:WU04:FS04:0x22:Completed 1625000 out of 2500000 steps (65%)
20:56:16:WU01:FS02:0x22:Completed 2450000 out of 2500000 steps (98%)
20:56:16:WU01:FS02:0x22:Checkpoint completed at step 2450000
20:56:28:WU03:FS03:Connecting to assign1.foldingathome.org:80
20:56:28:WU03:FS03:Assigned to work server 129.32.209.202
20:56:28:WU03:FS03:Requesting new work unit for slot 03: gpu:182:0 AD102 [GeForce RTX 4090] f            rom 129.32.209.202
20:56:28:WU03:FS03:Connecting to 129.32.209.202:8080
20:56:29:WARNING:WU03:FS03:WorkServer connection failed on port 8080 trying 80
20:56:29:WU03:FS03:Connecting to 129.32.209.202:80
20:56:29:ERROR:WU03:FS03:Exception: Failed to connect to 129.32.209.202:80: Connection refuse
Not sure if this is helpful, but here ya' go.
Sandy
The client has been using names for the Assignment Servers for many years, they need to be resolved by your DNS to IP numbers. Work Servers get connected to by IP numbers instead of names, at least for the v7 client. The v8 Public Beta uses names instead of IP numbers to connect to both AS and WS.
Without your client configuration info, not sure why you are not getting an assignment here. Possibly the server(s) with projects large enough to assign to a 4090 were either down or out of WUs at that time.
SandyG
Post by SandyG »
Joe_H wrote: Tue Aug 29, 2023 9:41 pm The client has been using names for the Assignment Servers for many years, they need to be resolved by your DNS to IP numbers. Work Servers get connected to by IP numbers instead of names, at least for the v7 client. The v8 Public Beta uses names instead of IP numbers to connect to both AS and WS.
OK, never saw the DNS ones fail, it's always been one to a specific server. I hit assign1.foldingathome.org:80 and could resolve it from the browser so not sure if possibly a temporary thing. I did catch the error again just now (about 20min later). My systems are all up and have good access but who knows.
Normally I would complain that I have an idle GPU but it's been so hot where they are at, it's a nice break to take one out of rotation. Still don't understand why ever their is no back fill work for the larger CPU's if it's a problem (had been a few times in the past for me and others). I can only see more an more of the higher end CPU's coming online as time goes on. Hopefully addressed in the next version.
Thanks for you super quick response
Sandy
SandyG
Post by SandyG »
Just verified from linx on that box that I can hit the assign4.foldingathome.org:80 from the machine in question! All good, responded, so likely just no work units.
My client configuration has not changed for a couple of months, nothing new of done to the machine as it normally just hums along.
While typing this I just saw an error for the second 4090 as well. The 3090 just picked up another WU, so they seem to have heat to generate!
Sandy
n1np
Hardware configuration: HP DL380g8 x12
Post by n1np »
I just upgraded a machine with two RTX A4000 gpus and was surprised to see no work assignment. Glad it's not just me or my new configuration.
*********************** Log Started 2023-08-29T23:13:03Z ***********************
23:13:03:******************************* libFAH ********************************
23:13:03:           Date: Oct 20 2020
23:13:03:           Time: 13:36:55
23:13:03:       Revision: 5ca109d295a6245e2a2f590b3d0085ad5e567aeb
23:13:03:         Branch: master
23:13:03:       Compiler: Visual C++ 2015
23:13:03:        Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
23:13:03:       Platform: win32 10
23:13:03:           Bits: 32
23:13:03:           Mode: Release
23:13:03:****************************** FAHClient ******************************
23:13:03:        Version: 7.6.21
23:13:03:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
23:13:03:      Copyright: 2020 foldingathome.org
23:13:03:       Homepage: https://foldingathome.org/
23:13:03:           Time: 13:41:04
23:13:03:       Revision: 6efbf0e138e22d3963e6a291f78dcb9c6422a278
23:13:03:           Bits: 32
23:13:03:         Config: C:\ProgramData\FAHClient\config.xml
23:13:03:******************************** CBang ********************************
23:13:03:           Time: 11:36:18
23:13:03:       Revision: 7e4ce85225d7eaeb775e87c31740181ca603de60
23:13:03:           Bits: 32
23:13:03:******************************* System ********************************
23:13:03:            CPU: Intel(R) Xeon(R) CPU E5-2690 0 @ 2.90GHz
23:13:03:         CPU ID: GenuineIntel Family 6 Model 45 Stepping 7
23:13:03:           CPUs: 32
23:13:03:         Memory: 63.95GiB
23:13:03:    Free Memory: 61.04GiB
23:13:03:        Threads: WINDOWS_THREADS
23:13:03:     OS Version: 6.2
23:13:03:    Has Battery: false
23:13:03:     On Battery: false
23:13:03:     UTC Offset: -4
23:13:03:            PID: 11296
23:13:03:            CWD: C:\ProgramData\FAHClient
23:13:03:  Win32 Service: false
23:13:03:             OS: Windows 10 Enterprise
23:13:03:        OS Arch: AMD64
23:13:03:           GPUs: 2
23:13:03:          GPU 0: Bus:3 Slot:0 Func:0 NVIDIA:8 GA104GL [RTX A4000]
23:13:03:          GPU 1: Bus:2 Slot:0 Func:0 NVIDIA:8 GA104GL [RTX A4000]
23:13:03:  CUDA Device 0: Platform:0 Device:0 Bus:2 Slot:0 Compute:8.6 Driver:12.2
23:13:03:  CUDA Device 1: Platform:0 Device:1 Bus:3 Slot:0 Compute:8.6 Driver:12.2
23:13:03:OpenCL Device 0: Platform:0 Device:0 Bus:2 Slot:0 Compute:3.0 Driver:537.13
23:13:03:OpenCL Device 1: Platform:0 Device:1 Bus:3 Slot:0 Compute:3.0 Driver:537.13
23:13:03:***********************************************************************
23:13:04:<config>
23:13:04:  <!-- Folding Slot Configuration -->
23:13:04:  <extra-core-args v='-np 16'/>
23:13:04:
23:13:04:  <!-- HTTP Server -->
23:13:04:  <allow v='192.168.0.0/24'/>
23:13:04:
23:13:04:  <!-- Network -->
23:13:04:  <proxy v=':8080'/>
23:13:04:
23:13:04:  <!-- Remote Command Server -->
23:13:04:  <password v='*****'/>
23:13:04:
23:13:04:  <!-- User Information -->
23:13:04:  <passkey v='*****'/>
23:13:04:  <team v='12912'/>
23:13:04:  <user v='n1np'/>
23:13:04:
23:13:04:  <!-- Folding Slots -->
23:13:04:  <slot id='0' type='CPU'>
23:13:04:    <cpus v='16'/>
23:13:04:    <pause-on-start v='true'/>
23:13:04:  </slot>
23:13:04:  <slot id='1' type='GPU'>
23:13:04:    <pci-bus v='2'/>
23:13:04:    <pci-slot v='0'/>
23:13:04:  </slot>
23:13:04:  <slot id='2' type='GPU'>
23:13:04:    <paused v='true'/>
23:13:04:    <pci-bus v='3'/>
23:13:04:  </slot>
23:13:04:</config>
23:13:04:Trying to access database...
23:13:04:Successfully acquired database lock
23:13:04:FS00:Initialized folding slot 00: cpu:16
23:13:04:FS01:Initialized folding slot 01: gpu:2:0 GA104GL [RTX A4000]
23:13:04:FS02:Initialized folding slot 02: gpu:3:0 GA104GL [RTX A4000]
23:19:14:FS01:Unpaused
23:19:14:WU00:FS01:Connecting to assign1.foldingathome.org:80
23:19:15:WU00:FS01:Assigned to work server 129.32.209.200
23:19:15:WU00:FS01:Requesting new work unit for slot 01: gpu:2:0 GA104GL [RTX A4000] from 129.32.209.200
23:19:15:WU00:FS01:Connecting to 129.32.209.200:8080
23:19:15:ERROR:WU00:FS01:Exception: Server did not assign work unit
23:19:15:WU00:FS01:Connecting to assign1.foldingathome.org:80
23:19:16:WARNING:WU00:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
23:19:16:WU00:FS01:Connecting to assign2.foldingathome.org:80
23:19:16:WARNING:WU00:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
23:19:16:WU00:FS01:Connecting to assign3.foldingathome.org:80
23:19:16:WARNING:WU00:FS01:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
23:19:16:WU00:FS01:Connecting to assign4.foldingathome.org:80
23:19:16:WU00:FS01:Assigned to work server 129.32.209.200
23:19:16:WU00:FS01:Requesting new work unit for slot 01: gpu:2:0 GA104GL [RTX A4000] from 129.32.209.200
23:19:16:WU00:FS01:Connecting to 129.32.209.200:8080
23:19:17:ERROR:WU00:FS01:Exception: Server did not assign work unit
23:20:15:WU00:FS01:Connecting to assign1.foldingathome.org:80
23:20:16:WARNING:WU00:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
23:20:16:WU00:FS01:Connecting to assign2.foldingathome.org:80
23:20:16:WARNING:WU00:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
23:20:17:WU00:FS01:Connecting to assign3.foldingathome.org:80
23:20:17:WARNING:WU00:FS01:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
23:20:17:WU00:FS01:Connecting to assign4.foldingathome.org:80
23:20:17:WARNING:WU00:FS01:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
23:20:17:ERROR:WU00:FS01:Exception: Could not get an assignment
23:21:52:WU00:FS01:Connecting to assign1.foldingathome.org:80
23:21:53:WARNING:WU00:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
23:21:53:WU00:FS01:Connecting to assign2.foldingathome.org:80
23:21:53:WARNING:WU00:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
23:21:53:WU00:FS01:Connecting to assign3.foldingathome.org:80
23:21:54:WARNING:WU00:FS01:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
23:21:54:WU00:FS01:Connecting to assign4.foldingathome.org:80
23:21:55:WARNING:WU00:FS01:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
23:21:55:ERROR:WU00:FS01:Exception: Could not get an assignment
23:24:30:WU00:FS01:Connecting to assign1.foldingathome.org:80
23:24:30:WU00:FS01:Assigned to work server 128.174.73.78
23:24:30:WU00:FS01:Requesting new work unit for slot 01: gpu:2:0 GA104GL [RTX A4000] from 128.174.73.78
23:24:30:WU00:FS01:Connecting to 128.174.73.78:8080
23:24:30:ERROR:WU00:FS01:Exception: Server did not assign work unit
23:28:44:WU00:FS01:Connecting to assign1.foldingathome.org:80
23:28:45:WARNING:WU00:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
23:28:45:WU00:FS01:Connecting to assign2.foldingathome.org:80
23:28:45:WARNING:WU00:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
23:28:45:WU00:FS01:Connecting to assign3.foldingathome.org:80
23:28:45:WARNING:WU00:FS01:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
23:28:45:WU00:FS01:Connecting to assign4.foldingathome.org:80
23:28:46:WARNING:WU00:FS01:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
23:28:46:ERROR:WU00:FS01:Exception: Could not get an assignment
I will continue to monitor.
Ben N1NP
Antonomasia Productions
New Release 2022: Re-Entrant
SandyG
Post by SandyG »
I just bounced my server to see if I could restart the connections possibly to a new server that could dispense WU's.
Both of my 4090's were at idle for a while, this seemed to at least cause the check for WU's to go again, both cards are generating heat again!
I'll say this again, my machine should never have to wait for work units or it's a waste of me buying high end hardware. This is something that has come up a few times for me and others, if their are open machines not working on processing it's seems like sorta a waste. I know someone mentioned that their are specific reasons for sending WU's tailored for more capable processors but smaller stuff should run as well if nothing is running.
Lot's of 2 pennies here, but I make a lot of commitment to FAH and hope some of these issues can be fixed.
Sandy
SandyG
Post by SandyG »
Short lived success, any possible solutions?
FS03 and FS04 are RTX4090's for this and previous post logs.
01:37:52:WU04:FS03:Connecting to assign1.foldingathome.org:80
01:37:53:WARNING:WU04:FS03:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
01:37:53:WU04:FS03:Connecting to assign2.foldingathome.org:80
01:37:53:WARNING:WU04:FS03:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
01:37:53:WU04:FS03:Connecting to assign3.foldingathome.org:80
01:37:54:WARNING:WU04:FS03:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
01:37:54:WU04:FS03:Connecting to assign4.foldingathome.org:80
01:37:54:WARNING:WU04:FS03:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
01:37:54:ERROR:WU04:FS03:Exception: Could not get an assignment
Lazvon
Hardware configuration: 4080 / 12700F, 3090Ti/12900KS, 3090/12900K, 3090/10940X, 3080Ti/12700K, 3080Ti/9900X, 3080Ti/9900X
Post by Lazvon »
3 out 7 systems “Ready” right now. I can’t check directly… hmm, wonder if HFM puts the logs on the web server… ahhhh, yep.
This is on a 3080Ti, 4090, and 4080.
21:18:32:WU00:FS01:0x22:Completed 2450000 out of 2500000 steps (98%)
21:18:32:WU00:FS01:0x22:Checkpoint completed at step 2450000
21:19:04:WU00:FS01:0x22:Completed 2475000 out of 2500000 steps (99%)
21:19:04:WU01:FS01:Connecting to assign1.foldingathome.org:80
21:19:04:WARNING:WU01:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
21:19:04:WU01:FS01:Connecting to assign2.foldingathome.org:80
21:19:05:WARNING:WU01:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
21:19:05:WU01:FS01:Connecting to assign3.foldingathome.org:80
21:19:05:WARNING:WU01:FS01:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
21:19:05:WU01:FS01:Connecting to assign4.foldingathome.org:80
21:19:06:WARNING:WU01:FS01:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
21:19:06:ERROR:WU01:FS01:Exception: Could not get an assignment
21:19:06:WU01:FS01:Connecting to assign1.foldingathome.org:80
21:19:06:WARNING:WU01:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
21:19:06:WU01:FS01:Connecting to assign2.foldingathome.org:80
21:19:06:WARNING:WU01:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
21:19:06:WU01:FS01:Connecting to assign3.foldingathome.org:80
21:19:07:WARNING:WU01:FS01:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
21:19:07:WU01:FS01:Connecting to assign4.foldingathome.org:80
21:19:07:WARNING:WU01:FS01:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
21:19:07:ERROR:WU01:FS01:Exception: Could not get an assignment
21:19:35:WU00:FS01:0x22:Completed 2500000 out of 2500000 steps (100%)
21:19:35:WU00:FS01:0x22:Average performance: 137.143 ns/day
21:19:36:WU00:FS01:0x22:Checkpoint completed at step 2500000
21:19:38:WU00:FS01:0x22:Saving result file ..\\logfile_01.txt
21:19:38:WU00:FS01:0x22:Saving result file checkpointIntegrator.xml
21:19:38:WU00:FS01:0x22:Saving result file checkpointState.xml
21:19:38:WU00:FS01:0x22:Saving result file positions.xtc
21:19:38:WU00:FS01:0x22:Saving result file science.log
21:19:38:WU00:FS01:0x22:Saving result file xtcAtoms.csv.bz2
21:19:38:WU00:FS01:0x22:Folding@home Core Shutdown: FINISHED_UNIT
21:19:39:WU00:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
21:19:39:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:18449 run:3 clone:130 gen:633 core:0x22 unit:0x00000082000002790000481100000003
21:19:39:WU00:FS01:Uploading 32.09MiB to 129.32.209.202
21:19:39:WU00:FS01:Connecting to 129.32.209.202:8080
21:19:42:WU00:FS01:Upload complete
21:19:42:WU00:FS01:Server responded WORK_ACK (400)
21:19:42:WU00:FS01:Final credit estimate, 396317.00 points
21:19:42:WU00:FS01:Cleaning up
21:20:06:WU01:FS01:Connecting to assign1.foldingathome.org:80
21:20:06:WARNING:WU01:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
21:20:06:WU01:FS01:Connecting to assign2.foldingathome.org:80
21:20:07:WARNING:WU01:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
21:20:07:WU01:FS01:Connecting to assign3.foldingathome.org:80
21:20:07:WARNING:WU01:FS01:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
21:20:07:WU01:FS01:Connecting to assign4.foldingathome.org:80
21:20:07:WARNING:WU01:FS01:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
21:20:07:ERROR:WU01:FS01:Exception: Could not get an assignment
21:21:43:WU01:FS01:Connecting to assign1.foldingathome.org:80
21:21:44:WARNING:WU01:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
21:21:44:WU01:FS01:Connecting to assign2.foldingathome.org:80
21:21:44:WARNING:WU01:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
21:21:44:WU01:FS01:Connecting to assign3.foldingathome.org:80
21:21:45:WARNING:WU01:FS01:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
21:21:45:WU01:FS01:Connecting to assign4.foldingathome.org:80
21:21:45:WARNING:WU01:FS01:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
21:21:45:ERROR:WU01:FS01:Exception: Could not get an assignment
21:24:20:WU01:FS01:Connecting to assign1.foldingathome.org:80
21:24:21:WARNING:WU01:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
21:24:21:WU01:FS01:Connecting to assign2.foldingathome.org:80
21:24:21:WARNING:WU01:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
21:24:21:WU01:FS01:Connecting to assign3.foldingathome.org:80
21:24:22:WARNING:WU01:FS01:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
21:24:22:WU01:FS01:Connecting to assign4.foldingathome.org:80
21:24:23:WARNING:WU01:FS01:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
21:24:23:ERROR:WU01:FS01:Exception: Could not get an assignment
21:28:35:WU01:FS01:Connecting to assign1.foldingathome.org:80
21:28:35:WARNING:WU01:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
21:28:35:WU01:FS01:Connecting to assign2.foldingathome.org:80
21:28:36:WARNING:WU01:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
21:28:36:WU01:FS01:Connecting to assign3.foldingathome.org:80
21:28:36:WARNING:WU01:FS01:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
21:28:36:WU01:FS01:Connecting to assign4.foldingathome.org:80
21:28:36:WARNING:WU01:FS01:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
21:28:36:ERROR:WU01:FS01:Exception: Could not get an assignment
21:35:26:WU01:FS01:Connecting to assign1.foldingathome.org:80
21:35:26:WARNING:WU01:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
21:35:26:WU01:FS01:Connecting to assign2.foldingathome.org:80
21:35:27:WARNING:WU01:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
21:35:27:WU01:FS01:Connecting to assign3.foldingathome.org:80
21:35:28:WARNING:WU01:FS01:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
21:35:28:WU01:FS01:Connecting to assign4.foldingathome.org:80
21:35:28:WARNING:WU01:FS01:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
21:35:28:ERROR:WU01:FS01:Exception: Could not get an assignment
21:46:32:WU01:FS01:Connecting to assign1.foldingathome.org:80
21:46:32:WARNING:WU01:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
21:46:32:WU01:FS01:Connecting to assign2.foldingathome.org:80
21:46:33:WARNING:WU01:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
21:46:33:WU01:FS01:Connecting to assign3.foldingathome.org:80
21:46:33:WARNING:WU01:FS01:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
21:46:33:WU01:FS01:Connecting to assign4.foldingathome.org:80
21:46:34:WARNING:WU01:FS01:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
21:46:34:ERROR:WU01:FS01:Exception: Could not get an assignment
22:04:28:WU01:FS01:Connecting to assign1.foldingathome.org:80
22:04:29:WARNING:WU01:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
22:04:29:WU01:FS01:Connecting to assign2.foldingathome.org:80
22:04:29:WARNING:WU01:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
22:04:29:WU01:FS01:Connecting to assign3.foldingathome.org:80
22:04:30:WARNING:WU01:FS01:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
22:04:30:WU01:FS01:Connecting to assign4.foldingathome.org:80
22:04:30:WARNING:WU01:FS01:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
22:04:30:ERROR:WU01:FS01:Exception: Could not get an assignment
22:33:31:WU01:FS01:Connecting to assign1.foldingathome.org:80
22:33:31:WARNING:WU01:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
22:33:31:WU01:FS01:Connecting to assign2.foldingathome.org:80
22:33:32:WU01:FS01:Assigned to work server 128.174.73.78
22:33:32:WU01:FS01:Requesting new work unit for slot 01: gpu:1:0 AD102 [GeForce RTX 4090] from 128.174.73.78
22:33:32:WU01:FS01:Connecting to 128.174.73.78:8080
22:33:32:ERROR:WU01:FS01:Exception: Server did not assign work unit
23:20:29:WU01:FS01:Connecting to assign1.foldingathome.org:80
23:20:29:WARNING:WU01:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
23:20:29:WU01:FS01:Connecting to assign2.foldingathome.org:80
23:20:30:WARNING:WU01:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
23:20:30:WU01:FS01:Connecting to assign3.foldingathome.org:80
23:20:30:WARNING:WU01:FS01:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
23:20:30:WU01:FS01:Connecting to assign4.foldingathome.org:80
23:20:31:WARNING:WU01:FS01:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
23:20:31:ERROR:WU01:FS01:Exception: Could not get an assignment
00:20:30:WU01:FS01:Connecting to assign1.foldingathome.org:80
00:20:30:WARNING:WU01:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
00:20:30:WU01:FS01:Connecting to assign2.foldingathome.org:80
00:20:30:WARNING:WU01:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
00:20:30:WU01:FS01:Connecting to assign3.foldingathome.org:80
00:20:31:WARNING:WU01:FS01:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
00:20:31:WU01:FS01:Connecting to assign4.foldingathome.org:80
00:20:31:WARNING:WU01:FS01:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
00:20:31:ERROR:WU01:FS01:Exception: Could not get an assignment
01:20:30:WU01:FS01:Connecting to assign1.foldingathome.org:80
01:20:30:WARNING:WU01:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
01:20:30:WU01:FS01:Connecting to assign2.foldingathome.org:80
01:20:31:WARNING:WU01:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
01:20:31:WU01:FS01:Connecting to assign3.foldingathome.org:80
01:20:31:WARNING:WU01:FS01:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
01:20:31:WU01:FS01:Connecting to assign4.foldingathome.org:80
01:20:31:WARNING:WU01:FS01:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
01:20:31:ERROR:WU01:FS01:Exception: Could not get an assignment
Folding since Feb 2021. 1) 4090/12900KS, 2) 4080/12700F, 3) 4070Ti/9900X, 4) 3090/12900K, 5) 3090/10940X, 6) 3080Ti/12700K, 7) 3080Ti/9900X
SandyG
Post by SandyG »
Well might be a bigger problem, my Windows RTX3060 is now 10 minutes without a work unit -
01:54:53:1277:127.0.0.1:New Web session
01:55:04:WU00:FS02:Connecting to assign1.foldingathome.org:80
01:55:05:WARNING:WU00:FS02:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
01:55:05:WU00:FS02:Connecting to assign2.foldingathome.org:80
01:55:05:WARNING:WU00:FS02:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
01:55:05:WU00:FS02:Connecting to assign3.foldingathome.org:80
01:55:06:WARNING:WU00:FS02:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
01:55:06:WU00:FS02:Connecting to assign4.foldingathome.org:80
01:55:06:WARNING:WU00:FS02:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
01:55:06:ERROR:WU00:FS02:Exception: Could not get an assignment
My internet is good, it's not picking up 4090's and now 3060's for work. Might be something odd going on.
Sandy
SandyG
Post by SandyG »
Linux machine is idle on 3090's (the 3090 may have cycled to a different server and picked up something after an error) and 4090's with an odd quick work unit now and again.
Windows machine with RTX4070 Now in the same boat, no work units for the windows machine that houses the 4070 and 3060. Both now sitting idle.
All assignX.foldingathome.org:80 servers are returning a page when tested in the browser.
Something not working somewhere???
Lazvon
Post by Lazvon »
Yep, have a second 3080Ti down now. Bed time for me. Hopefully resolved.
My DNS servers are PiHole boxes with Ad Blocking. Also using UniFi Networks UDM SE Pro… 5Gbs down/up symmetrical Fiber and 1.2Gbs/45Mbs Cable asymmetrical as a failover. UDM SE Pro is blocking all Malware and a few countries like China, Iran, and Russia.
Everything else working great.
Lazvon
Post by Lazvon »
Now 5 down, a 4070. Just a couple 3090s still folding. One I assume goes down in 9-minutes, the other has an hour.
SandyG
Post by SandyG »
Interesting every once in a while I see a WU come in looks slow to download but that may be just my imagination, then same thing all over again. Something in the infra is not right, likely something looks OK but really is just not working right.
I would love to see a big picture of all the infrastructure and monitoring if it exists if anyone knows where it might be?
Sandy
I alerted the researchers. The WU shortage motly hits high end GPUs (nvidia species 9 and 8) as far as I know.
edit : the server status page is here : https://apps.foldingathome.org/serverstats
