Need muti GPU work for same work unit together
When V8 can made all GPUs work for same work unit at same time ?
PaulTV
- Hardware configuration: Fedora Linux w/ v8.5.6
Ryzen 9800X3D / RTX 4090
Ryzen 9800X3D / RTX 5070 Ti
Ryzen 5600 / RTX 3070 Ti - Location: Netherlands
Re: Need muti GPU work for same work unit together
That's very unlikely to happen. It'd require a *lot* of data transfer back and forth between the GPUs (threads need each other's data), which would slow everything down horribly.
They looked into it a number of years ago, testing showed too much PCI overhead transferring data between GPUs. It was determined that running one WU on one GPU was a better use of resources.
It's already hard to get WU that have enough atoms to fully use the biggest GPUs ... image the pain it would be with more than one at once ...
