Server did not like results, dumping w/ new GPU
SmoothDrRod
Post by SmoothDrRod »
I've been a folder under this user name (and others including anonymous) for a long time and I am sorry to be here with my first post being a support req.
Windows GUI client is bone head simple always working well for me but after upgrading my GPU I have a problem with work units not being successfully completed/received. Per the subject, well over 3/4 of the WU that have been processed by my new GPU result in "Server did not like results, dumping". Not really sure what to make of it. I have seen WUs fail over the years from overzealous and/or not quite properly dialed in overclocks but in this instance every time the WU completes sans error in client and logs, seems to take longer than I would expect to upload, and ends with the forum thread subject quoted in the log.
Typically w/ enough errors in the past the client would disable the troubled CPU or GPU slot but in this case the servers continue giving me WUs to crunch and keep rejecting them. I haven't attempted to run WUs on this particular GPU in a few weeks so I am currently generating log data. I will have several WUs worth of results to supply tomorrow but I do want to sort out if this is a problem w/ the GPU or some sort of configurable issue on my end. From memory there is no one particular server that is swatting my results away so I do not believe this to be a problem on f@h's end.
Troubleshooting performed so far:
  • I have reinstalled Windows 10 Pro from drive wipe twice since this has cropped up.
    I am currently running the latest AMD chipset drivers
    Currently on a DDU'd install of nVidia driver 536.23, several prior versions behaved the same
    Have tried forcing slower PCIe connection spec to GPU in BIOS
    Have tried two different PCIe WiFi adapters + motherboard in-built, and wired to router. Have also tried using mobile Hotspot connection to transfer data. with all three WiFi adapters
    Have tested the GPU w. Aida64, OCCT, and FurMark (all > 24 hour continous runs), and the various 3dMark stability tests with no problem found or artifacting as applicable
    Have enabled GPU memory ECC
    Have swapped powersupplies
    Have downclocked system memory to JEDEC DDR4 baseline 2133
    Have tried 4 different pairs of known good, reputable manufacture system memory
    Have used MSI Afterburner to set negative GPU core and memory offsets down to -500 core, -500 memory with voltage and power limits set to both default and maxed out
System specs:
Watercooled CPU, GPU, motherboard VRM w/ (2) 560mmx140mmx60mm radiators, excellent flow rate
Asus x570 Crosshair VIII Formula
Ryzen 5800x3d (note, I do not run fah CPU WUs on this system)
Gigabyte 4090 Gaming OC
(2) different Seasonic Prime 1300w Platinum PSUs and a Seasonic Prime Prime 1000W Gold. The daily driver is one of the 1300w Platinums
I think that's everything to say w/o some logs. I will add that this machine games very well with fluid frame times and tight consistency within the capabilities of the CPU. It has yet to render a single visible error in my numerous home video edits which always call for a little bit of GPU work. Save for f@h servers not liking the results and dumping them, I can't tell there is a single thing wrong in the slightest.
I appreciate you and your time in advance.
Re: Server did not like results, dumping w/ new GPU
Logs always tell more than anything else ...
SmoothDrRod
Just the Errors:
*********************** Log Started 2023-08-01T01:59:28Z ***********************
01:59:54:WU00:FS00:0xa8:WARNING:Console control signal 1 on PID 11532
01:59:55:WARNING:WU00:Slot ID 0 no longer exists and there are no other matching slots, dumping
04:45:23:WARNING:WU00:FS01:Server did not like results, dumping
05:28:14:WARNING:WU01:FS01:Server did not like results, dumping
05:49:07:WARNING:WU00:FS01:Server did not like results, dumping
07:36:13:WARNING:WU01:FS01:Server did not like results, dumping
******************************* Date: 2023-08-01 *******************************
08:15:33:WARNING:WU00:FS01:Server did not like results, dumping
08:59:29:WARNING:WU01:FS01:Server did not like results, dumping
09:30:30:WARNING:WU00:FS01:Exception: Failed to send results to work server: 10002: Received short response, expected 512 bytes, got 0
09:30:32:WARNING:WU00:FS01:Server did not like results, dumping
10:11:42:WARNING:WU01:FS01:Server did not like results, dumping
10:35:16:WARNING:WU00:FS01:Server did not like results, dumping
11:06:07:WARNING:WU01:FS01:Server did not like results, dumping
11:24:03:WARNING:WU00:FS01:Server did not like results, dumping
Now, just the log of the last WU per section 6 of "How to provide enough info to get helpful support"
11:01:58:WU00:FS01:0x22:*********************** Log Started 2023-08-01T11:01:57Z ***********************
11:01:58:WU00:FS01:0x22:*************************** Core22 Folding@home Core ***************************
11:01:58:WU00:FS01:0x22:       Core: Core22
11:01:58:WU00:FS01:0x22:       Type: 0x22
11:01:58:WU00:FS01:0x22:    Version: 0.0.20
11:01:58:WU00:FS01:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
11:01:58:WU00:FS01:0x22:  Copyright: 2020 foldingathome.org
11:01:58:WU00:FS01:0x22:   Homepage: https://foldingathome.org/
11:01:58:WU00:FS01:0x22:       Date: Jan 20 2022
11:01:58:WU00:FS01:0x22:       Time: 01:15:36
11:01:58:WU00:FS01:0x22:   Revision: 3f211b8a4346514edbff34e3cb1c0e0ec951373c
11:01:58:WU00:FS01:0x22:     Branch: HEAD
11:01:58:WU00:FS01:0x22:   Compiler: Visual C++
11:01:58:WU00:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
11:01:58:WU00:FS01:0x22:             -DOPENMM_VERSION="\"7.7.0\""
11:01:58:WU00:FS01:0x22:   Platform: win32 10
11:01:58:WU00:FS01:0x22:       Bits: 64
11:01:58:WU00:FS01:0x22:       Mode: Release
11:01:58:WU00:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
11:01:58:WU00:FS01:0x22:             <peastman@stanford.edu>
11:01:58:WU00:FS01:0x22:       Args: -dir 00 -suffix 01 -version 706 -lifeline 5988 -checkpoint 30
11:01:58:WU00:FS01:0x22:             -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor
11:01:58:WU00:FS01:0x22:             nvidia -gpu 0 -gpu-usage 100
11:01:58:WU00:FS01:0x22:************************************ libFAH ************************************
11:01:58:WU00:FS01:0x22:       Time: 01:14:17
11:01:58:WU00:FS01:0x22:   Revision: 9f4ad694e75c2350d4bb6b8b5b769ba27e483a2f
11:01:58:WU00:FS01:0x22:************************************ CBang *************************************
11:01:58:WU00:FS01:0x22:       Time: 01:13:20
11:01:58:WU00:FS01:0x22:   Revision: ab023d155b446906d55b0f6c9a1eedeea04f7a1a
11:01:58:WU00:FS01:0x22:************************************ System ************************************
11:01:58:WU00:FS01:0x22:        CPU: AMD Ryzen 7 5800X3D 8-Core Processor
11:01:58:WU00:FS01:0x22:     CPU ID: AuthenticAMD Family 25 Model 33 Stepping 2
11:01:58:WU00:FS01:0x22:       CPUs: 16
11:01:58:WU00:FS01:0x22:     Memory: 31.91GiB
11:01:58:WU00:FS01:0x22:Free Memory: 26.99GiB
11:01:58:WU00:FS01:0x22:    Threads: WINDOWS_THREADS
11:01:58:WU00:FS01:0x22: OS Version: 6.2
11:01:58:WU00:FS01:0x22:Has Battery: false
11:01:58:WU00:FS01:0x22: On Battery: false
11:01:58:WU00:FS01:0x22: UTC Offset: -7
11:01:58:WU00:FS01:0x22:        PID: 12920
11:01:58:WU00:FS01:0x22:        CWD: C:\ProgramData\FAHClient\work
11:01:58:WU00:FS01:0x22:************************************ OpenMM ************************************
11:01:58:WU00:FS01:0x22:    Version: 7.7.0
11:01:58:WU00:FS01:0x22:********************************************************************************
11:01:58:WU00:FS01:0x22:Project: 12424 (Run 2, Clone 24, Gen 283)
11:01:58:WU00:FS01:0x22:Reading tar file core.xml
11:01:58:WU00:FS01:0x22:Reading tar file integrator.xml
11:01:58:WU00:FS01:0x22:Reading tar file state.xml
11:01:58:WU00:FS01:0x22:Reading tar file system.xml
11:01:59:WU00:FS01:0x22:Digital signatures verified
11:01:59:WU00:FS01:0x22:Folding@home GPU Core22 Folding@home Core
11:01:59:WU00:FS01:0x22:Version 0.0.20
11:01:59:WU00:FS01:0x22:  Checkpoint write interval: 10000 steps (2%) [50 total]
11:01:59:WU00:FS01:0x22:  JSON viewer frame write interval: 5000 steps (1%) [100 total]
11:01:59:WU00:FS01:0x22:  XTC frame write interval: 250000 steps (50%) [2 total]
11:01:59:WU00:FS01:0x22:  Global context and integrator variables write interval: disabled
11:01:59:WU00:FS01:0x22:There are 4 platforms available.
11:01:59:WU00:FS01:0x22:Platform 0: Reference
11:01:59:WU00:FS01:0x22:Platform 1: CPU
11:01:59:WU00:FS01:0x22:Platform 2: OpenCL
11:01:59:WU00:FS01:0x22:  opencl-device 0 specified
11:01:59:WU00:FS01:0x22:Platform 3: CUDA
11:01:59:WU00:FS01:0x22:  cuda-device 0 specified
11:02:06:WU01:FS01:Upload 19.77%
11:02:19:WU01:FS01:Upload 19.93%
11:02:22:WU00:FS01:0x22:Attempting to create CUDA context:
11:02:22:WU00:FS01:0x22:  Configuring platform CUDA
11:02:26:WU00:FS01:0x22:  Using CUDA and gpu 0
11:02:26:WU00:FS01:0x22:Completed 0 out of 500000 steps (0%)
11:02:27:WU00:FS01:0x22:Checkpoint completed at step 0
11:02:30:WU01:FS01:Upload 20.09%
11:02:36:WU01:FS01:Upload 21.89%
11:02:39:WU00:FS01:0x22:Completed 5000 out of 500000 steps (1%)
11:02:47:WU01:FS01:Upload 22.05%
11:02:51:WU00:FS01:0x22:Completed 10000 out of 500000 steps (2%)
11:02:52:WU00:FS01:0x22:Checkpoint completed at step 10000
11:02:59:WU01:FS01:Upload 22.22%
11:03:11:WU01:FS01:Upload 22.38%
11:03:17:WU00:FS01:0x22:Checkpoint completed at step 20000
11:03:18:WU01:FS01:Upload 22.54%
11:03:32:WU01:FS01:Upload 24.50%
11:03:42:WU00:FS01:0x22:Checkpoint completed at step 30000
11:03:45:WU01:FS01:Upload 24.67%
11:03:57:WU01:FS01:Upload 24.83%
11:04:03:WU01:FS01:Upload 26.79%
11:04:07:WU00:FS01:0x22:Checkpoint completed at step 40000
11:04:15:WU01:FS01:Upload 26.95%
11:04:28:WU01:FS01:Upload 27.12%
11:04:32:WU00:FS01:0x22:Checkpoint completed at step 50000
11:04:35:WU01:FS01:Upload 27.28%
11:04:43:WU01:FS01:Upload 29.08%
11:04:55:WU01:FS01:Upload 29.24%
11:04:57:WU00:FS01:0x22:Checkpoint completed at step 60000
11:05:07:WU01:FS01:Upload 29.40%
11:05:15:WU01:FS01:Upload 29.57%)
11:05:22:WU00:FS01:0x22:Checkpoint completed at step 70000
11:05:32:WU01:FS01:Upload 31.53%
11:05:45:WU01:FS01:Upload 31.69%
11:05:47:WU00:FS01:0x22:Checkpoint completed at step 80000
11:05:55:WU01:FS01:Upload 31.86%
11:06:01:WU01:FS01:Upload 73.35%
11:06:07:WU01:FS01:Upload complete
11:06:07:WU01:FS01:Server responded WORK_QUIT (404)
11:06:07:WU01:FS01:Cleaning up
11:06:12:WU00:FS01:0x22:Checkpoint completed at step 90000
11:06:38:WU00:FS01:0x22:Checkpoint completed at step 100000
11:07:04:WU00:FS01:0x22:Checkpoint completed at step 110000
11:07:29:WU00:FS01:0x22:Checkpoint completed at step 120000
11:07:54:WU00:FS01:0x22:Checkpoint completed at step 130000
11:08:19:WU00:FS01:0x22:Checkpoint completed at step 140000
11:08:45:WU00:FS01:0x22:Checkpoint completed at step 150000
11:09:10:WU00:FS01:0x22:Checkpoint completed at step 160000
11:09:36:WU00:FS01:0x22:Checkpoint completed at step 170000
11:10:02:WU00:FS01:0x22:Checkpoint completed at step 180000
11:10:27:WU00:FS01:0x22:Checkpoint completed at step 190000
11:10:52:WU00:FS01:0x22:Checkpoint completed at step 200000
11:11:17:WU00:FS01:0x22:Checkpoint completed at step 210000
11:11:27:FS01:Finishing
11:11:42:WU00:FS01:0x22:Checkpoint completed at step 220000
11:12:07:WU00:FS01:0x22:Checkpoint completed at step 230000
11:12:32:WU00:FS01:0x22:Checkpoint completed at step 240000
11:12:58:WU00:FS01:0x22:Checkpoint completed at step 250000
11:13:24:WU00:FS01:0x22:Checkpoint completed at step 260000
11:13:49:WU00:FS01:0x22:Checkpoint completed at step 270000
11:14:15:WU00:FS01:0x22:Checkpoint completed at step 280000
11:14:40:WU00:FS01:0x22:Checkpoint completed at step 290000
11:15:05:WU00:FS01:0x22:Checkpoint completed at step 300000
11:15:31:WU00:FS01:0x22:Checkpoint completed at step 310000
11:15:56:WU00:FS01:0x22:Checkpoint completed at step 320000
11:16:21:WU00:FS01:0x22:Checkpoint completed at step 330000
11:16:47:WU00:FS01:0x22:Checkpoint completed at step 340000
11:17:11:WU00:FS01:0x22:Checkpoint completed at step 350000
11:17:36:WU00:FS01:0x22:Checkpoint completed at step 360000
11:18:01:WU00:FS01:0x22:Checkpoint completed at step 370000
11:18:26:WU00:FS01:0x22:Checkpoint completed at step 380000
11:18:51:WU00:FS01:0x22:Checkpoint completed at step 390000
11:19:16:WU00:FS01:0x22:Checkpoint completed at step 400000
11:19:41:WU00:FS01:0x22:Checkpoint completed at step 410000
11:20:06:WU00:FS01:0x22:Checkpoint completed at step 420000
11:20:31:WU00:FS01:0x22:Checkpoint completed at step 430000
11:20:56:WU00:FS01:0x22:Checkpoint completed at step 440000
11:21:21:WU00:FS01:0x22:Checkpoint completed at step 450000
11:21:46:WU00:FS01:0x22:Checkpoint completed at step 460000
11:22:11:WU00:FS01:0x22:Checkpoint completed at step 470000
11:22:37:WU00:FS01:0x22:Checkpoint completed at step 480000
11:23:02:WU00:FS01:0x22:Checkpoint completed at step 490000
11:23:13:WU00:FS01:0x22:Completed 495000 out of 500000 steps (99%)
11:23:25:WU00:FS01:0x22:Completed 500000 out of 500000 steps (100%)
11:23:25:WU00:FS01:0x22:Average performance: 72 ns/day
11:23:27:WU00:FS01:0x22:Checkpoint completed at step 500000
11:23:33:WU00:FS01:0x22:Saving result file ..\logfile_01.txt
11:23:33:WU00:FS01:0x22:Saving result file checkpointIntegrator.xml
11:23:33:WU00:FS01:0x22:Saving result file checkpointState.xml
11:23:38:WU00:FS01:0x22:Saving result file positions.xtc
11:23:38:WU00:FS01:0x22:Saving result file science.log
11:23:38:WU00:FS01:0x22:Saving result file xtcAtoms.csv.bz2
11:23:38:WU00:FS01:0x22:Folding@home Core Shutdown: FINISHED_UNIT
11:23:39:WU00:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
11:23:39:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:12424 run:2 clone:24 gen:283 core:0x22 unit:0x000000180000011b0000308800000002
11:23:39:WU00:FS01:Uploading 38.24MiB to 129.32.209.200
11:23:39:WU00:FS01:Connecting to 129.32.209.200:8080
11:23:45:WU00:FS01:Upload 35.63%
11:23:51:WU00:FS01:Upload 55.74%
11:23:57:WU00:FS01:Upload 72.41%
11:24:03:WU00:FS01:Upload complete
11:24:03:WU00:FS01:Server responded WORK_QUIT (404)
11:24:03:WU00:FS01:Cleaning up]/code]
Reason: added code tags to log
Did you edit that log before posting it ?
SmoothDrRod
I took out the lines between 2% and 99% that read along the lines of "11:22:35:WU00:FS01:0x22:Completed 480000 out of 500000 steps (96%)". Other than that, no. I can copy and paste that entire section unabridged or further redact. I interpreted your helpful link "How to..." section 6 as needing to remove just the percentage progress. In the moments of editing I did not think it applied to checkpoints.
SmoothDrRod
Well, not sure what to do here other than give two revised copies:
With checkpoint completed log data removed:
SmoothDrRod
unabridged copy of the original selection:
11:03:04:WU00:FS01:0x22:Completed 15000 out of 500000 steps (3%)
11:03:16:WU00:FS01:0x22:Completed 20000 out of 500000 steps (4%)
11:03:29:WU00:FS01:0x22:Completed 25000 out of 500000 steps (5%)
11:03:40:WU00:FS01:0x22:Completed 30000 out of 500000 steps (6%)
11:03:54:WU00:FS01:0x22:Completed 35000 out of 500000 steps (7%)
11:04:06:WU00:FS01:0x22:Completed 40000 out of 500000 steps (8%)
11:04:19:WU00:FS01:0x22:Completed 45000 out of 500000 steps (9%)
11:04:31:WU00:FS01:0x22:Completed 50000 out of 500000 steps (10%)
11:04:44:WU00:FS01:0x22:Completed 55000 out of 500000 steps (11%)
11:04:56:WU00:FS01:0x22:Completed 60000 out of 500000 steps (12%)
11:05:09:WU00:FS01:0x22:Completed 65000 out of 500000 steps (13%)
11:05:21:WU00:FS01:0x22:Completed 70000 out of 500000 steps (14%)
11:05:34:WU00:FS01:0x22:Completed 75000 out of 500000 steps (15%)
11:05:46:WU00:FS01:0x22:Completed 80000 out of 500000 steps (16%)
11:05:59:WU00:FS01:0x22:Completed 85000 out of 500000 steps (17%)
11:06:11:WU00:FS01:0x22:Completed 90000 out of 500000 steps (18%)
11:06:25:WU00:FS01:0x22:Completed 95000 out of 500000 steps (19%)
11:06:37:WU00:FS01:0x22:Completed 100000 out of 500000 steps (20%)
11:06:50:WU00:FS01:0x22:Completed 105000 out of 500000 steps (21%)
11:07:02:WU00:FS01:0x22:Completed 110000 out of 500000 steps (22%)
11:07:16:WU00:FS01:0x22:Completed 115000 out of 500000 steps (23%)
11:07:28:WU00:FS01:0x22:Completed 120000 out of 500000 steps (24%)
11:07:41:WU00:FS01:0x22:Completed 125000 out of 500000 steps (25%)
11:07:53:WU00:FS01:0x22:Completed 130000 out of 500000 steps (26%)
11:08:06:WU00:FS01:0x22:Completed 135000 out of 500000 steps (27%)
11:08:18:WU00:FS01:0x22:Completed 140000 out of 500000 steps (28%)
11:08:32:WU00:FS01:0x22:Completed 145000 out of 500000 steps (29%)
11:08:43:WU00:FS01:0x22:Completed 150000 out of 500000 steps (30%)
11:08:57:WU00:FS01:0x22:Completed 155000 out of 500000 steps (31%)
11:09:09:WU00:FS01:0x22:Completed 160000 out of 500000 steps (32%)
11:09:22:WU00:FS01:0x22:Completed 165000 out of 500000 steps (33%)
11:09:35:WU00:FS01:0x22:Completed 170000 out of 500000 steps (34%)
11:09:48:WU00:FS01:0x22:Completed 175000 out of 500000 steps (35%)
11:10:00:WU00:FS01:0x22:Completed 180000 out of 500000 steps (36%)
11:10:14:WU00:FS01:0x22:Completed 185000 out of 500000 steps (37%)
11:10:25:WU00:FS01:0x22:Completed 190000 out of 500000 steps (38%)
11:10:39:WU00:FS01:0x22:Completed 195000 out of 500000 steps (39%)
11:10:50:WU00:FS01:0x22:Completed 200000 out of 500000 steps (40%)
11:11:04:WU00:FS01:0x22:Completed 205000 out of 500000 steps (41%)
11:11:16:WU00:FS01:0x22:Completed 210000 out of 500000 steps (42%)
11:11:29:WU00:FS01:0x22:Completed 215000 out of 500000 steps (43%)
11:11:41:WU00:FS01:0x22:Completed 220000 out of 500000 steps (44%)
11:11:54:WU00:FS01:0x22:Completed 225000 out of 500000 steps (45%)
11:12:06:WU00:FS01:0x22:Completed 230000 out of 500000 steps (46%)
11:12:19:WU00:FS01:0x22:Completed 235000 out of 500000 steps (47%)
11:12:31:WU00:FS01:0x22:Completed 240000 out of 500000 steps (48%)
11:12:45:WU00:FS01:0x22:Completed 245000 out of 500000 steps (49%)
11:12:57:WU00:FS01:0x22:Completed 250000 out of 500000 steps (50%)
11:13:10:WU00:FS01:0x22:Completed 255000 out of 500000 steps (51%)
11:13:22:WU00:FS01:0x22:Completed 260000 out of 500000 steps (52%)
11:13:36:WU00:FS01:0x22:Completed 265000 out of 500000 steps (53%)
11:13:48:WU00:FS01:0x22:Completed 270000 out of 500000 steps (54%)
11:14:02:WU00:FS01:0x22:Completed 275000 out of 500000 steps (55%)
11:14:13:WU00:FS01:0x22:Completed 280000 out of 500000 steps (56%)
11:14:27:WU00:FS01:0x22:Completed 285000 out of 500000 steps (57%)
11:14:39:WU00:FS01:0x22:Completed 290000 out of 500000 steps (58%)
11:14:52:WU00:FS01:0x22:Completed 295000 out of 500000 steps (59%)
11:15:04:WU00:FS01:0x22:Completed 300000 out of 500000 steps (60%)
11:15:17:WU00:FS01:0x22:Completed 305000 out of 500000 steps (61%)
11:15:30:WU00:FS01:0x22:Completed 310000 out of 500000 steps (62%)
11:15:43:WU00:FS01:0x22:Completed 315000 out of 500000 steps (63%)
11:15:55:WU00:FS01:0x22:Completed 320000 out of 500000 steps (64%)
11:16:08:WU00:FS01:0x22:Completed 325000 out of 500000 steps (65%)
11:16:20:WU00:FS01:0x22:Completed 330000 out of 500000 steps (66%)
11:16:33:WU00:FS01:0x22:Completed 335000 out of 500000 steps (67%)
11:16:45:WU00:FS01:0x22:Completed 340000 out of 500000 steps (68%)
11:16:58:WU00:FS01:0x22:Completed 345000 out of 500000 steps (69%)
11:17:10:WU00:FS01:0x22:Completed 350000 out of 500000 steps (70%)
11:17:23:WU00:FS01:0x22:Completed 355000 out of 500000 steps (71%)
11:17:35:WU00:FS01:0x22:Completed 360000 out of 500000 steps (72%)
11:17:48:WU00:FS01:0x22:Completed 365000 out of 500000 steps (73%)
11:18:00:WU00:FS01:0x22:Completed 370000 out of 500000 steps (74%)
11:18:13:WU00:FS01:0x22:Completed 375000 out of 500000 steps (75%)
11:18:25:WU00:FS01:0x22:Completed 380000 out of 500000 steps (76%)
11:18:38:WU00:FS01:0x22:Completed 385000 out of 500000 steps (77%)
11:18:50:WU00:FS01:0x22:Completed 390000 out of 500000 steps (78%)
11:19:03:WU00:FS01:0x22:Completed 395000 out of 500000 steps (79%)
11:19:15:WU00:FS01:0x22:Completed 400000 out of 500000 steps (80%)
11:19:28:WU00:FS01:0x22:Completed 405000 out of 500000 steps (81%)
11:19:40:WU00:FS01:0x22:Completed 410000 out of 500000 steps (82%)
11:19:53:WU00:FS01:0x22:Completed 415000 out of 500000 steps (83%)
11:20:05:WU00:FS01:0x22:Completed 420000 out of 500000 steps (84%)
11:20:18:WU00:FS01:0x22:Completed 425000 out of 500000 steps (85%)
11:20:30:WU00:FS01:0x22:Completed 430000 out of 500000 steps (86%)
11:20:43:WU00:FS01:0x22:Completed 435000 out of 500000 steps (87%)
11:20:55:WU00:FS01:0x22:Completed 440000 out of 500000 steps (88%)
11:21:08:WU00:FS01:0x22:Completed 445000 out of 500000 steps (89%)
11:21:20:WU00:FS01:0x22:Completed 450000 out of 500000 steps (90%)
11:21:33:WU00:FS01:0x22:Completed 455000 out of 500000 steps (91%)
11:21:45:WU00:FS01:0x22:Completed 460000 out of 500000 steps (92%)
11:21:58:WU00:FS01:0x22:Completed 465000 out of 500000 steps (93%)
11:22:10:WU00:FS01:0x22:Completed 470000 out of 500000 steps (94%)
11:22:23:WU00:FS01:0x22:Completed 475000 out of 500000 steps (95%)
11:22:48:WU00:FS01:0x22:Completed 485000 out of 500000 steps (97%)
11:23:00:WU00:FS01:0x22:Completed 490000 out of 500000 steps (98%)
Does it always fail, or only on some specific projects/servers ?
How does this machine connect to the Internet ?
SmoothDrRod
toTOW wrote: Sat Aug 05, 2023 7:07 pm Does it always fail, or only on some specific projects/servers ?
Machine in question was connected to the internet via an intel AX200 WiFi adapted to a XFi WiFi 6e Gateway through one drywall wall FWIW. I never really saw any rhyme or reason, just seemed to fail the majority of W/Us I ran on it so I stopped running F@h for a while.
Well between then and now I have migrated all of my machines at home to a Linux distro of some variety including my 4090 equipped rig. The other day, after pretty much exclusively using Ubuntu for this particular rig 99.9% of the time for a few months, I thought of trying to run f@h... and so far it has kicked out exactly 60 W/Us nary an error and with some nice points to go along with.
Given that I had reinstalled windows from an OS drive formatted state a few times chasing down the issue among the many other things listed in the OP I am kind of at a loss as to what the problem is. Other than OS now being Ubuntu, no other changes have been made... hell, it's even the same coolant. IDK WTH is the effective difference besides obvious and glaring things fundamental between a Windows 10 install and a Linux but I'll end things by saying I am using the nVidia proprietary drivers optioned to me by the Ubuntu installer and I am happy to be back in the fold.
