If this is not the right section let me know. I figured this might be the best sub but could be jsut the basic program sub.
I recently upgraded to a MSI 7900 XTX from a GTX 970. Never had this issue prior and its been through several CPUs and versions of F@H. However, since running an AMD GPU, no matter if I had the program set to light power + paused, if I reboot Win10, so does my pause status on the GPU only. The 5900x CPU has never ran into this issue. Only a mild issue as this will cook power bill on restarts IF I don't check F@H, which can be random. (yay stability issues).
Anyone else running into this issue, is this exclusive to me, amd, 7000 series.
GPU Folding auto runs after reboot - 7900XTX
appepi
- Hardware configuration: HP Z600 (5) HP Z800 (3) HP Z440 (3) HP Z4G4 (3) ASUS Turbo GTX 1060, 1070, 1080, RTX 2060 (3) Dell GTX 1080 NVIDIA P1000 (2) K1200
Re: GPU Folding auto runs after reboot - 7900XTX
Better late than never? ... But thanks for asking because it led me to re-find a reddit post from Joe_H 5 years ago explaining " ... just add the option "pause-on-start" set to "true" using FAHControl's Configure. The FAHClient process uses almost no resources when folding is not active."
I had forgotten this on one of my devices and your query led me to re-find the settinmg I had used on all the others." These are all W10 and Intel and NVIDIA, so ...
