ChatGPT advice for Optimizing CUDA
zincan_images
Hardware configuration: HP Elitedesk 800 G3 TWR with 550W PU
Intel Core i3-6100T
DDR4-2400T 8GB (4GB x 2)
Windows 10
Fold with Nvidia Tesla K20C (GK110 Kepler GDDR5 5GB, 6pin x 2 pwr)
Post by zincan_images »
Hello everyone.
:!: Notice: Possibly this topic is kidding or mysteriously :?:
One thinking for F@H with ChatGPT.
“What can I do for F@H?”
(I have use 3 NVIDIA GPUs with run Ubuntu for F@H. What can I do without change hardwares)
ChatGPU reply “Optimize CUDA”
I will explain how to apply specific optimization techniques for CUDA.
1. Thread and Block Optimization: When launching a CUDA kernel, you specify the number of threads per block and the number of blocks. These values depend on the hardware and algorithm. Generally, the number of threads per block should be a multiple of 32 (warp size). The number of blocks depends on the number of multiprocessors on the GPU. By adjusting these values, you can maximize the computational power of the GPU.
dim3 threadsPerBlock(256); // Set the number of threads per block to 256
dim3 numBlocks((N + threadsPerBlock.x - 1) / threadsPerBlock.x); // Calculate the number of blocks
myKernel<<<numBlocks, threadsPerBlock>>>(args); // Launch the kernel
2. Memory Access Optimization: In CUDA, accessing global memory is slow, so minimizing it is crucial. To achieve this, you can utilize shared memory or optimize memory access patterns. For example, you can declare and use shared memory as shown below:
cpp
__global__ void myKernel(float* data) {
    __shared__ float sharedData[256]; // Declare shared memory
    int tid = threadIdx.x;
    sharedData[tid] = data[tid]; // Load data into shared memory
    __syncthreads(); // Wait for all threads to load data into shared memory
    // Perform calculations using shared memory here
Here is a questions:
  • True or false
  • Should I be run this code?
Thank you for your reading time.
Re: ChatGPT advice for Optimizing CUDA
It's ChatGPT. Any results from it are suspect at best, and can be entirely made up to give you a response that might be pure BS at worst. In any case it is something that would need to be implemented in the folding core.
zincan_images wrote: Sun Jul 23, 2023 12:10 pm Hello everyone.
cpp
  • True or false
What's the point of this topic ? What's the connection between FAH, ChatGPT and what your posted ?
