1574/500 WU Completion WTF !?
I had this weird thing happen where my computer was working on a WU that was 2500 frames.. but when i went back 30mins later it was working on a completely different WU that is only 500 frames, but it says I've completed 1574/500 and that number is rising as the frames complete.. whats going on?! anyone know?
uncle_fungus
Re: 1574/500 WU Completion WTF !?
Can you post the contents of your log please?
Be sure to paste it inside some [code]your log here[/code] tags.
Baowoulf
- Hardware configuration: Pentium 4 2.8 GHz, 512MB DDR Ram, 128MB Radeon 9800, Creative Soundblaster Audigy 4 Pro
I had this happen to be before as well. I had a 2500frame WU I believe. I can't remember if it ended up with an error/or if it completed. After that I had a 150frame 15point WU. But when I looked at it it was like 2408/150. I was like whoa I then restarted my computer and after I did everything was fine.
Maybe it was just something with the visulation or something due to OpenGL incompatibility. I don't know. But it didn't have any bad effects except the numbers being off.
