Re: Slow upload.
Slow upload.
The upload is really slow. https://photos.app.goo.gl/GENf727UeGKpGSF68
Re: Slow upload.
I noticed that it also gives errors. https://photos.app.goo.gl/rwFoe7YK2UQjQepL9
Re: Slow upload.
But I have a slow upload generally in the last few days. I don't know if it can be Deluge, but I used it before too. I try to keep Deluge off.
Uploading 38.19MiB to 129.32.209.200
Uploading 24.16MiB to 128.174.73.74
Uploading 23.83MiB to 128.174.73.74
Re: Re: Slow upload.
I'm doing some tests. I limited Deluge. I see with the next work unit. Approximately 37 minutes until the end of the work unit. However the problem is general so I think it's Deluge.
I even turned off Deluge while it was uploading but it's still very slow. But finally the upload was completed. What I don't understand is why if I turn off Deluge the upload doesn't speed up. Now I try to keep Deluge off. is that I've never used Deluge to upload so for me the problem is new. I'm checking the next work unit, I have about 9 minutes to go with Deluge off even though I limited it.
15:31:20:WU00:FS01:Trying to send results to collection server
15:31:20:WU00:FS01:Uploading 29.41MiB to 129.32.209.203
15:31:20:WU00:FS01:Connecting to 129.32.209.203:8080
15:31:22:WU01:FS01:Connecting to assign1.foldingathome.org:80
15:31:23:WU01:FS01:Assigned to work server 129.32.209.202
15:31:23:WU01:FS01:Requesting new work unit for slot 01: gpu:1:0 TU102 [GeForce RTX 2080 Ti Rev. A] M 13448 from 129.32.209.202
15:31:23:WU01:FS01:Connecting to 129.32.209.202:8080
15:31:26:WU00:FS01:Upload 3.19%
15:31:32:WU00:FS01:Upload 11.05%
15:31:38:WU00:FS01:Upload 19.55%
15:31:44:WU00:FS01:Upload 25.29%
15:31:50:WU00:FS01:Upload 33.79%
15:31:54:ERROR:WU01:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
15:32:43:WU00:FS01:Upload 37.41%
15:33:00:WU01:FS01:Connecting to assign1.foldingathome.org:80
15:33:01:WU01:FS01:Assigned to work server 128.174.73.74
15:33:01:WU01:FS01:Requesting new work unit for slot 01: gpu:1:0 TU102 [GeForce RTX 2080 Ti Rev. A] M 13448 from 128.174.73.74
15:33:01:WU01:FS01:Connecting to 128.174.73.74:8080
15:33:10:WU01:FS01:Downloading 13.49MiB
15:33:16:WU01:FS01:Download 38.45%
15:33:19:WU01:FS01:Download complete
15:33:20:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:14947 run:2 clone:270 gen:46 core:0x22 unit:0x0000010e0000002e00003a6300000002
15:33:20:WU01:FS01:Starting
15:33:20:WU01:FS01:Running FahCore: D:\Folding\FAHClient/FAHCoreWrapper.exe D:\Folding\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.20/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 706 -lifeline 10596 -checkpoint 3 -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100
15:33:20:WU01:FS01:Started FahCore on PID 8168
15:33:20:WU01:FS01:Core PID:20556
15:33:20:WU01:FS01:FahCore 0x22 started
15:33:20:WU01:FS01:0x22:*********************** Log Started 2023-06-16T15:33:20Z ***********************
15:33:20:WU01:FS01:0x22:*************************** Core22 Folding@home Core ***************************
15:33:20:WU01:FS01:0x22: Core: Core22
15:33:20:WU01:FS01:0x22: Type: 0x22
15:33:20:WU01:FS01:0x22: Version: 0.0.20
15:33:20:WU01:FS01:0x22: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
15:33:20:WU01:FS01:0x22: Copyright: 2020 foldingathome.org
15:33:20:WU01:FS01:0x22: Homepage: https://foldingathome.org/
15:33:20:WU01:FS01:0x22: Date: Jan 20 2022
15:33:20:WU01:FS01:0x22: Time: 01:15:36
15:33:20:WU01:FS01:0x22: Revision: 3f211b8a4346514edbff34e3cb1c0e0ec951373c
15:33:20:WU01:FS01:0x22: Branch: HEAD
15:33:20:WU01:FS01:0x22: Compiler: Visual C++
15:33:20:WU01:FS01:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
15:33:20:WU01:FS01:0x22: -DOPENMM_VERSION="\"7.7.0\""
15:33:20:WU01:FS01:0x22: Platform: win32 10
15:33:20:WU01:FS01:0x22: Bits: 64
15:33:20:WU01:FS01:0x22: Mode: Release
15:33:20:WU01:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
15:33:20:WU01:FS01:0x22: <peastman@stanford.edu>
15:33:20:WU01:FS01:0x22: Args: -dir 01 -suffix 01 -version 706 -lifeline 8168 -checkpoint 3
15:33:20:WU01:FS01:0x22: -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor
15:33:20:WU01:FS01:0x22: nvidia -gpu 0 -gpu-usage 100
15:33:20:WU01:FS01:0x22:************************************ libFAH ************************************
15:33:20:WU01:FS01:0x22: Time: 01:14:17
15:33:20:WU01:FS01:0x22: Revision: 9f4ad694e75c2350d4bb6b8b5b769ba27e483a2f
15:33:20:WU01:FS01:0x22:************************************ CBang *************************************
15:33:20:WU01:FS01:0x22: Time: 01:13:20
15:33:20:WU01:FS01:0x22: Revision: ab023d155b446906d55b0f6c9a1eedeea04f7a1a
15:33:20:WU01:FS01:0x22:************************************ System ************************************
15:33:20:WU01:FS01:0x22: CPU: Intel(R) Core(TM) i7-6950X CPU @ 3.00GHz
15:33:20:WU01:FS01:0x22: CPU ID: GenuineIntel Family 6 Model 79 Stepping 1
15:33:20:WU01:FS01:0x22: CPUs: 10
15:33:20:WU01:FS01:0x22: Memory: 15.91GiB
15:33:20:WU01:FS01:0x22:Free Memory: 8.73GiB
15:33:20:WU01:FS01:0x22: Threads: WINDOWS_THREADS
15:33:20:WU01:FS01:0x22: OS Version: 6.2
15:33:20:WU01:FS01:0x22:Has Battery: false
15:33:20:WU01:FS01:0x22: On Battery: false
15:33:20:WU01:FS01:0x22: UTC Offset: 2
15:33:20:WU01:FS01:0x22: PID: 20556
15:33:20:WU01:FS01:0x22: CWD: D:\Folding\FAHClient\work
15:33:20:WU01:FS01:0x22:************************************ OpenMM ************************************
15:33:20:WU01:FS01:0x22: Version: 7.7.0
15:33:20:WU01:FS01:0x22:********************************************************************************
15:33:20:WU01:FS01:0x22:Project: 14947 (Run 2, Clone 270, Gen 46)
15:33:20:WU01:FS01:0x22:Reading tar file core.xml
15:33:20:WU01:FS01:0x22:Reading tar file integrator.xml
15:33:20:WU01:FS01:0x22:Reading tar file state.xml
15:33:20:WU01:FS01:0x22:Reading tar file system.xml
15:33:21:WU01:FS01:0x22:Digital signatures verified
15:33:21:WU01:FS01:0x22:Folding@home GPU Core22 Folding@home Core
15:33:21:WU01:FS01:0x22:Version 0.0.20
15:33:21:WU01:FS01:0x22: Checkpoint write interval: 50000 steps (5%) [20 total]
15:33:21:WU01:FS01:0x22: JSON viewer frame write interval: 10000 steps (1%) [100 total]
15:33:21:WU01:FS01:0x22: XTC frame write interval: 25000 steps (2.5%) [40 total]
15:33:21:WU01:FS01:0x22: Global context and integrator variables write interval: disabled
15:33:21:WU01:FS01:0x22:There are 4 platforms available.
15:33:21:WU01:FS01:0x22:Platform 0: Reference
15:33:21:WU01:FS01:0x22:Platform 1: CPU
15:33:21:WU01:FS01:0x22:Platform 2: OpenCL
15:33:21:WU01:FS01:0x22: opencl-device 0 specified
15:33:21:WU01:FS01:0x22:Platform 3: CUDA
15:33:21:WU01:FS01:0x22: cuda-device 0 specified
15:33:40:WU01:FS01:0x22:Attempting to create CUDA context:
15:33:40:WU01:FS01:0x22: Configuring platform CUDA
15:33:47:WU01:FS01:0x22: Using CUDA and gpu 0
15:33:47:WU01:FS01:0x22:Completed 0 out of 1000000 steps (0%)
15:33:48:WU00:FS01:Upload 37.62%
15:33:49:WU01:FS01:0x22:Checkpoint completed at step 0
15:34:11:WU01:FS01:0x22:Completed 10000 out of 1000000 steps (1%)
15:34:32:WU01:FS01:0x22:Completed 20000 out of 1000000 steps (2%)
15:34:50:WU00:FS01:Upload 37.83%
15:34:55:WU01:FS01:0x22:Completed 30000 out of 1000000 steps (3%)
15:35:04:WU00:FS01:Upload 38.04%
15:35:15:WU00:FS01:Upload 39.96%
15:35:18:WU01:FS01:0x22:Completed 40000 out of 1000000 steps (4%)
15:35:40:WU01:FS01:0x22:Completed 50000 out of 1000000 steps (5%)
15:35:42:WU01:FS01:0x22:Checkpoint completed at step 50000
15:36:04:WU01:FS01:0x22:Completed 60000 out of 1000000 steps (6%)
15:36:13:WU00:FS01:Upload 40.17%
15:36:26:WU01:FS01:0x22:Completed 70000 out of 1000000 steps (7%)
15:36:49:WU01:FS01:0x22:Completed 80000 out of 1000000 steps (8%)
15:37:11:WU01:FS01:0x22:Completed 90000 out of 1000000 steps (9%)
15:37:16:WU00:FS01:Upload 40.38%
15:37:33:WU01:FS01:0x22:Completed 100000 out of 1000000 steps (10%)
15:37:35:WU01:FS01:0x22:Checkpoint completed at step 100000
15:37:40:WU00:FS01:Upload 40.59%
15:37:52:WU00:FS01:Upload 42.51%
15:37:57:WU01:FS01:0x22:Completed 110000 out of 1000000 steps (11%)
15:38:20:WU01:FS01:0x22:Completed 120000 out of 1000000 steps (12%)
15:38:42:WU01:FS01:0x22:Completed 130000 out of 1000000 steps (13%)
15:38:57:WU00:FS01:Upload 42.72%
15:39:05:WU01:FS01:0x22:Completed 140000 out of 1000000 steps (14%)
15:39:27:WU01:FS01:0x22:Completed 150000 out of 1000000 steps (15%)
15:39:28:WU01:FS01:0x22:Checkpoint completed at step 150000
15:39:51:WU01:FS01:0x22:Completed 160000 out of 1000000 steps (16%)
15:40:02:WU00:FS01:Upload 42.93%
15:40:08:WU00:FS01:Upload 44.85%
15:40:13:WU01:FS01:0x22:Completed 170000 out of 1000000 steps (17%)
15:40:34:WU00:FS01:Upload 45.06%
15:40:36:WU01:FS01:0x22:Completed 180000 out of 1000000 steps (18%)
15:40:58:WU01:FS01:0x22:Completed 190000 out of 1000000 steps (19%)
15:41:22:WU01:FS01:0x22:Completed 200000 out of 1000000 steps (20%)
15:41:23:WU01:FS01:0x22:Checkpoint completed at step 200000
15:41:42:WU00:FS01:Upload 45.27%
15:41:46:WU01:FS01:0x22:Completed 210000 out of 1000000 steps (21%)
15:42:08:WU01:FS01:0x22:Completed 220000 out of 1000000 steps (22%)
15:42:25:WU00:FS01:Upload 45.48%
15:42:31:WU00:FS01:Upload 56.75%
15:42:31:WU01:FS01:0x22:Completed 230000 out of 1000000 steps (23%)
15:42:38:WU00:FS01:Upload 68.86%
15:42:47:WU00:FS01:Upload 71.20%
15:42:53:WU01:FS01:0x22:Completed 240000 out of 1000000 steps (24%)
15:43:15:WU01:FS01:0x22:Completed 250000 out of 1000000 steps (25%)
15:43:17:WU01:FS01:0x22:Checkpoint completed at step 250000
15:43:40:WU01:FS01:0x22:Completed 260000 out of 1000000 steps (26%)
15:43:42:WU00:FS01:Upload 71.41%
15:44:03:WU01:FS01:0x22:Completed 270000 out of 1000000 steps (27%)
15:44:25:WU01:FS01:0x22:Completed 280000 out of 1000000 steps (28%)
15:44:38:WU00:FS01:Upload 71.62%
15:44:48:WU01:FS01:0x22:Completed 290000 out of 1000000 steps (29%)
15:45:11:WU01:FS01:0x22:Completed 300000 out of 1000000 steps (30%)
15:45:13:WU01:FS01:0x22:Checkpoint completed at step 300000
15:45:29:WU00:FS01:Upload 71.84%
15:45:35:WU00:FS01:Upload 82.04%
15:45:35:WU01:FS01:0x22:Completed 310000 out of 1000000 steps (31%)
15:45:41:WU00:FS01:Upload 93.94%
15:45:47:WU00:FS01:Upload complete
15:45:47:WU00:FS01:Server responded WORK_ACK (400)
15:45:47:WU00:FS01:Final credit estimate, 220501.00 points
15:45:47:WU00:FS01:Cleaning up
See this topic - viewtopic.php?t=38869. There have been intermittent problems uploading to the Temple University servers for weeks.
I'm taking a look at it Joe_H at the link you posted. At the time it was just a coincidence the problem with Deluge. Thank you. Joe_H.
