I moved my AMD Ryzen 7 1700 proc and ASUS 3060 Ti solution to one of my F@H machines. I didn't change anything about the configuration. I merely moved the motherboard from one case to another. Since this had been my main machine for a couple of years, I didn't think there would be any issues with it, but a couple of weeks ago the 3060 TI video card started failing to fold. I got it to work once, but it is back to failing.
I run nVidia's 532.03 gaming drivers. I am running F@H version 7.6.21 on this PC.
Here is the log output from the video card:
22:21:25:WU02:FS01:Starting
22:21:25:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "D:\My Folding\Wintermute\cores/cores.foldingathome.org/win/64bit/22-0.0.20/Core_22.fah/FahCore_22.exe" -dir 02 -suffix 01 -version 706 -lifeline 29148 -checkpoint 15 -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100
22:21:25:WU02:FS01:Started FahCore on PID 21972
22:21:26:WU02:FS01:Core PID:30212
22:21:26:WU02:FS01:FahCore 0x22 started
22:21:26:WU02:FS01:0x22:*********************** Log Started 2023-05-24T22:21:26Z ***********************
22:21:26:WU02:FS01:0x22:*************************** Core22 Folding@home Core ***************************
22:21:26:WU02:FS01:0x22: Core: Core22
22:21:26:WU02:FS01:0x22: Type: 0x22
22:21:26:WU02:FS01:0x22: Version: 0.0.20
22:21:26:WU02:FS01:0x22: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
22:21:26:WU02:FS01:0x22: Copyright: 2020 foldingathome.org
22:21:26:WU02:FS01:0x22: Homepage: https://foldingathome.org/
22:21:26:WU02:FS01:0x22: Date: Jan 20 2022
22:21:26:WU02:FS01:0x22: Time: 01:15:36
22:21:26:WU02:FS01:0x22: Revision: 3f211b8a4346514edbff34e3cb1c0e0ec951373c
22:21:26:WU02:FS01:0x22: Branch: HEAD
22:21:26:WU02:FS01:0x22: Compiler: Visual C++
22:21:26:WU02:FS01:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
22:21:26:WU02:FS01:0x22: -DOPENMM_VERSION="\"7.7.0\""
22:21:26:WU02:FS01:0x22: Platform: win32 10
22:21:26:WU02:FS01:0x22: Bits: 64
22:21:26:WU02:FS01:0x22: Mode: Release
22:21:26:WU02:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
22:21:26:WU02:FS01:0x22: <peastman@stanford.edu>
22:21:26:WU02:FS01:0x22: Args: -dir 02 -suffix 01 -version 706 -lifeline 21972 -checkpoint 15
22:21:26:WU02:FS01:0x22: -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor
22:21:26:WU02:FS01:0x22: nvidia -gpu 0 -gpu-usage 100
22:21:26:WU02:FS01:0x22:************************************ libFAH ************************************
22:21:26:WU02:FS01:0x22: Time: 01:14:17
22:21:26:WU02:FS01:0x22: Revision: 9f4ad694e75c2350d4bb6b8b5b769ba27e483a2f
22:21:26:WU02:FS01:0x22:************************************ CBang *************************************
22:21:26:WU02:FS01:0x22: Time: 01:13:20
22:21:26:WU02:FS01:0x22: Revision: ab023d155b446906d55b0f6c9a1eedeea04f7a1a
22:21:26:WU02:FS01:0x22:************************************ System ************************************
22:21:26:WU02:FS01:0x22: CPU: AMD Ryzen 7 1700 Eight-Core Processor
22:21:26:WU02:FS01:0x22: CPU ID: AuthenticAMD Family 23 Model 1 Stepping 1
22:21:26:WU02:FS01:0x22: CPUs: 16
22:21:26:WU02:FS01:0x22: Memory: 31.95GiB
22:21:26:WU02:FS01:0x22:Free Memory: 14.41GiB
22:21:26:WU02:FS01:0x22: Threads: WINDOWS_THREADS
22:21:26:WU02:FS01:0x22: OS Version: 6.2
22:21:26:WU02:FS01:0x22:Has Battery: false
22:21:26:WU02:FS01:0x22: On Battery: false
22:21:26:WU02:FS01:0x22: UTC Offset: -5
22:21:26:WU02:FS01:0x22: PID: 30212
22:21:26:WU02:FS01:0x22: CWD: D:\My Folding\Wintermute\work
22:21:26:WU02:FS01:0x22:************************************ OpenMM ************************************
22:21:26:WU02:FS01:0x22: Version: 7.7.0
22:21:26:WU02:FS01:0x22:********************************************************************************
22:21:26:WU02:FS01:0x22:Project: 17636 (Run 0, Clone 35, Gen 85)
22:21:26:WU02:FS01:0x22:Digital signatures verified
22:21:26:WU02:FS01:0x22:Folding@home GPU Core22 Folding@home Core
22:21:26:WU02:FS01:0x22:Version 0.0.20
22:21:26:WU02:FS01:0x22: Checkpoint write interval: 125000 steps (5%) [20 total]
22:21:26:WU02:FS01:0x22: JSON viewer frame write interval: 25000 steps (1%) [100 total]
22:21:26:WU02:FS01:0x22: XTC frame write interval: 250000 steps (10%) [10 total]
22:21:26:WU02:FS01:0x22: Global context and integrator variables write interval: disabled
22:21:26:WU02:FS01:0x22:There are 3 platforms available.
22:21:26:WU02:FS01:0x22:Platform 0: Reference
22:21:26:WU02:FS01:0x22:Platform 1: CPU
22:21:26:WU02:FS01:0x22:Platform 2: CUDA
22:21:26:WU02:FS01:0x22: cuda-device 0 specified
22:21:26:WU02:FS01:0x22:opencl-device was set but OpenCL platform could not be found.
22:21:40:WU02:FS01:0x22:Attempting to create CUDA context:
22:21:40:WU02:FS01:0x22: Configuring platform CUDA
22:21:44:WARNING:WU02:FS01:FahCore returned an unknown error code which probably indicates that it crashed
22:21:44:WARNING:WU02:FS01:FahCore returned: UNKNOWN_ENUM (-1073740791 = 0xc0000409)Thank you.
Oliver.
