After 22H2 Update, FAH No Longer Keeps Computer Awake
Coronablaster
Post by Coronablaster »
Upon installing Win10 Pro update 22H2, the computer now puts itself to sleep when left unattended, whereas it used to run FAH in the background and only turn off the display. None of the sleep settings are changed. What happened, and how do I fix this?
The computer is an Early 2008 Apple MacPro Dual Processor (8 cores) with 28GB RAM and an aftermarket Windows graphics card tweaked to boot on Macs. Runs gloriously.
(I'm not actually a new donor. Been running FAH for over three years, but this forum seems to be the place to post a question about the basic operation of the software.)
Re: After 22H2 Update, FAH No Longer Keeps Computer Awake
Post by calxalot »
Is this v7 or v8?
Disabling sleep is not currently implemented in v8.
