Project: 2665 (Run 0, Clone 479, Gen 20)
DocJonz
- Hardware configuration: Folding with: 4x RTX 4070Ti, 1x RTX 4080 Super, 1x RTX 5070Ti
This one issued a fault right at the start and exited - three times in a row. I guess someone at Stanford might want to take a look at if nobody returns any results .......
Re: Project: 2665 (Run 0, Clone 479, Gen 20)
whats up doc,
could you post the logs if you can so we can get a better idea at whats going on??
thanks!
nick
thanks!
nick
There's no record for this WU in the database ... there's might be a problem with the WU ...
DocJonz
I would have posted them with the original message .... if I hadn't cleared out the wastebasket
hmm, well proj 2665 has had a couple work units that were simply bad imo, but since there could be many reasons on this one, we hate to stop an entire run/clone series for just one bad data point. If you end up with it again or if anyone else has noticed this one causing trouble could you let us know??
thank you!
nick
(and try NOT to delete your log
thank you!
nick
