Project: 3859 (Run 4398, Clone 0, Gen 2)
Began unit on July 10 12:16:35. Completed unit with following results:
[14:19:13] + Attempting to send results
[14:19:34] - Couldn't send HTTP request to server
[14:19:34] + Could not connect to Work Server (results)
[14:19:34] (128.59.74.4:8080)
[14:19:34] - Error: Could not transmit unit 04 (completed July 11) to work server.
[14:19:34] Keeping unit 04 in queue.
[14:19:34] + Attempting to send results
[14:19:55] - Couldn't send HTTP request to server
[14:19:55] + Could not connect to Work Server (results)
[14:19:55] (128.59.74.4:8080)
[14:19:55] - Error: Could not transmit unit 04 (completed July 11) to work server.
[14:19:55] + Attempting to send results
[14:20:05] - Core type used on unit not what server demands.
[14:20:05] Successfully sent unit 04 to Collection server. STILL NO RESULTS CREDITED AFTER MORE THAN TWO DAYS! When will the collection server update?
Re: Project: 3859 (Run 4398, Clone 0, Gen 2)
I see that WU was returned for full credit, but it's not bodmd98 ... is it your FAH username, or do you use something else (please tell us which one) ?
My user name IS: "bodmd98" : how can this be properly credited? Email corrective actions if any are required on my part.
viewtopic.php?f=19&t=3892&p=38193#p38193 This seems to be a problem for p 3859
i've alerted michael incase there is some sort of issue here, thanks for the posts!
nick
(could you post the header on the log too please??)
nick
[12:16:33] - Preparing to get new work unit...
[12:16:33] + Attempting to get work packet
[12:16:33] - Connecting to assignment server
[12:16:34] - Successful: assigned to (128.59.74.4).
[12:16:34] + News From Folding@Home: Welcome to Folding@Home
[12:16:34] Loaded queue successfully.
[12:16:35] + Closed connections
[12:16:35]
[12:16:35] + Processing work unit
[12:16:35] Core required: FahCore_7c.exe
[12:16:35] Core found.
[12:16:35] Working on Unit 04 [July 10 12:16:35]
[12:16:35] + Working ...
[12:16:35]
[12:16:35] *------------------------------*
[12:16:35] Folding@Home Double Gromacs Core C
[12:16:35] Version 1.00 (Thu Apr 24 19:12:09 PDT 2008)
[12:16:35]
[12:16:35] Preparing to commence simulation
[12:16:35] - Files status OK
[12:16:36] - Expanded 220754 -> 614877 (decompressed 278.5 percent)
[12:16:36]
[12:16:36] Project: 3859 (Run 4398, Clone 0, Gen 2)
[12:16:36]
[12:16:36] Assembly optimizations on if available.
[12:16:36] Entering M.D.
[12:16:42] Working on p3850_fkbprelative_ligand
[12:16:42] Completed 0 out of 1000000 steps (0)
[12:16:42] Extra SSE2 boost OK
[12:34:42] Timer requesting checkpoint
[12:43:56] Completed 10000 out of 1000000 steps (1).............................................................................................................
[12:16:35]
[12:16:35]
[12:16:35]
[12:16:36]
[12:16:36]
ENDING WITH......................................................[14:18:07] Completed 1000000 out of 1000000 steps (100)
[14:19:07]
[14:19:07] Finished Work Unit:
[14:19:07] - Reading up to 403040 from "work/wudata_04.trr": Read 403040
[14:19:07] - Reading up to 18916 from "work/wudata_04.xtc": Read 18916
[14:19:07] xvg file size: 321369
[14:19:07] logfile size: 37398
[14:19:07] Leaving Run
[14:19:10] - Writing 865415 bytes of core data to disk...
[14:19:10] ... Done.
[14:19:10] - Shutting down core
[14:19:10]
[14:19:10] Folding@home Core Shutdown: FINISHED_UNIT
[14:19:13] CoreStatus = 64 (100)
[14:19:13] Sending work to server
[14:20:05] - Preparing to get new work unit...
[14:19:07]
[14:19:10]
michael and edgar are looking into it, looking at the netload and making sure CS is working smoothly with this server etc, just anything out of the ordinary on our end. even lowering the netload might make things behave a litlte more like they should. why don't you give it some time and update us if anything changes?? (or doesn't
Still not credited for this unit. Subsequent unit working and crediting normally.
Hi bodmd98,
after digging through some log files and code I found the reason for the missing credit. It looks like that the new core used for this project with an older server code has created the weird messages in your and our logs. As our logs contained these unexpected messages the stats system didn't realize the returned work and thus no points. As this actually has happened, not only in your, but in a few more cases we are writing a script to get all the missing points assigned correctly. This will most likely take a few days so I have to ask for you patience, but I can assure you that the credits will come.
Cheers,
Ed
Cheers,
Ed
I appreciate your efforts. As all of us invest time and money and plan to expand our efforts in the future all members of the team must be motivated. Exponential growth in the scientific product demands efficiency.
That sounds awfully critical, especially when you add that smilie. In my experience, the Pande Group is a very dedicated group of individuals and (if you really mean it as I'm interpreting it) your criticism is uncalled for. I know I'm glad a bug was uncovered and fixed and I'm appreciative of Ed's efforts.bodmd98 wrote:I appreciate your efforts. As all of us invest time and money and plan to expand our efforts in the future all members of the team must be motivated. Exponential growth in the scientific product demands efficiency.
In it's polite form, the expression is "Stuff happens" and when somebody discovers and fixes a bug, it doesn't make sense to be critical.
If I misinterpreted your meaning, then just ignore this post.
