WU's 19421 exceed timeout on a Rasperry Pi
- Hardware configuration: NVIDIA RTX 4080 Super
20 x Raspberry Pi 5 Model B 2GB RAM - Location: VIC, Australia
WU 19421 is exceeding the timeout of 2 days, on my Raspberry Pi hardware. It's taking about 2 days and 6.5 hours for the Pi's to complete these WUs.
The very first of these WUs was issued on April 21 @ 0:45.
Is this a problem or not?
Re: WU's 19421 exceed timeout on a Rasperry Pi
The minimum Raspberry pi is version 4. If you are on a lower version, it is unsupported.
Jimbo, had you looked at my Hardware configuration, you would have noticed that I have 10 BCM2711 processors. The Raspberry Pi 4 is the only Pi to use these processors!JimboPalmer wrote: ↑Mon Apr 24, 2023 6:24 pm The minimum Raspberry pi is version 4. If you are on a lower version, it is unsupported.
Unless you post your log, no one can look at your hardware configuration. We can only give advice based on information you provide.
Yes, that info is there. But posted in the most obtuse manner possible.ETA_2024 wrote: ↑Tue Apr 25, 2023 9:37 amJimbo, had you looked at my Hardware configuration, you would have noticed that I have 10 BCM2711 processors. The Raspberry Pi 4 is the only Pi to use these processors!JimboPalmer wrote: ↑Mon Apr 24, 2023 6:24 pm The minimum Raspberry pi is version 4. If you are on a lower version, it is unsupported.
Fixed Joe.Joe_H wrote: ↑Tue Apr 25, 2023 1:45 pmYes, that info is there. But posted in the most obtuse manner possible.ETA_2024 wrote: ↑Tue Apr 25, 2023 9:37 amJimbo, had you looked at my Hardware configuration, you would have noticed that I have 10 BCM2711 processors. The Raspberry Pi 4 is the only Pi to use these processors!JimboPalmer wrote: ↑Mon Apr 24, 2023 6:24 pm The minimum Raspberry pi is version 4. If you are on a lower version, it is unsupported.
And, I'm still waiting for an answer to my question!
Will someone please answer my question in the first post.
I notified the researcher ...
There are so many projects that shouldn't assign on RPi ...
We have added a constraint on the project to prevent this from happening. Thank you for bringing it to our attention.
I assume WUs that exceed the timeout are a problem.
Thanks toTOW and ayanb73 for fixing that problem.
They slow down the science and waste some power since the work unit will be computed twice ...
Should my Raspberry Pi's still be getting these WUs?
The last WU was assigned on May 7 @ 23:27Z
We have updated our constraint to exclude ARM and ARM64. Hopefully this should now fix the issue
