GPU full throttle, but CPU only uses 1 thread!
JEK81
Post by JEK81 »
I am folding with an overclocked GPU and CPU.
GPU is a Nvidia 3060TI Founders Edition which is folding great.
The CPU with client-type advanced set to 8 threads only folds with one thread same with -1 setting, CPU is a 10600k OC'd at a stable 5GHz.
Client 7.6.21
How do I get cpu to use more than one thread? It refuses to use more than one.
JEK81
Re: GPU full throttle, but CPU only uses 1 thread!
Post by JEK81 »
I found using bigadv helped.
Both the advanced and bigadv options are currently not being used for assignments. I am not sure how they are handled by the assignment servers. The bigadv option has not been used in at least 5 years, it is probably ignored.
There is a known bug where the very first CPU WU downloaded by a fresh install of the client sometimes would be for a single CPU thread. Once downloaded with that setting the number of threads can not be increased until a new WU is downloaded. Then it will use up to as many threads as was set at the time of the download.
JEK81
Post by JEK81 »
cpu went through with wu on bigadv but i'll switch it.
https://stats.foldingathome.org/donor/id/658607700
JEK81
Post by JEK81 »
Joe_H wrote: Mon Apr 24, 2023 2:26 am Both the advanced and bigadv options are currently not being used for assignments. I am not sure how they are handled by the assignment servers. The bigadv option has not been used in at least 5 years, it is probably ignored.
which option should i use for cpu? since bigadv and advanced is not being used?
JEK81
Post by JEK81 »
I don't understand that bigadv option is not being used.
it's working on my side and contributing
16996 (2, 133, 258) 2 hours 17 mins 35341
Work Unit (PRCG) Work Unit (ETA) Estimated Points
I'm contributing to
Project 16996
This project simulates the folding dynamics of several variants of the TrpCage mini-pro designed by Niels Andersen’s group. We are particularly interested in comparing simulation results to high-quality NMR experimental data across many different sequences, to assess the viability of simulation-based computational protein design.
JEK81 wrote: Mon Apr 24, 2023 12:12 pm I don't understand that bigadv option is not being used.
It was announced over 9 years ago that bigadv was ending, the end date was in January 2015. The option is not doing anything, it may be recognized as an option by the client code but there are no projects set to require it on the servers. The option is being ignored by the servers and a WU with a regular setting is being assigned to your client.
JEK81 wrote: Mon Apr 24, 2023 11:48 am which option should i use for cpu? since bigadv and advanced is not being used?
None. The only other option being used for assignments is "beta" and that is only supposed to be used by the recognized beta testers. That also applies for GPU projects. You can set the CPU thread count to as high as 11 with your GPU being present and having an i5-10600K. But I would recommend no higher than 6 which is the number of actual cores. Above that additional threads need to share the FPUs present in the 6 cores.
JEK81
Post by JEK81 »
Joe_H wrote: Mon Apr 24, 2023 3:13 pm
So the fah client has a cpu option to fold but its pointless to do? I am at a complete loss at this unfortunately.
So remove the cpu slot on the client?
JEK81
Post by JEK81 »
I dont know. I just removed CPU from the slot, I don't understand why its there when installed and starts to fold.
No, remove the client-type bigadv option, that is not what creates a CPU slot. In FAHControl the slot is made either a CPU or GPU slot by using the radio buttons at the left of the configuration window. The client-type option and its settings are optional and defaults to regular FAH WUs if not set explicitly for a folding slot or for all slots.
JEK81
Post by JEK81 »
Joe_H wrote: Mon Apr 24, 2023 3:28 pm No, remove the client-type bigadv option, that is not what creates a CPU slot. In FAHControl the slot is made either a CPU or GPU slot by using the radio buttons at the left of the configuration window. The client-type option and its settings are optional and defaults to regular FAH WUs if not set explicitly for a folding slot or for all slots.
Ohhh! ok. See when i first installed fah client, i was doing cpu work through another app and removed cpu slot, then when i got done, i readded the cpu slot and thought those options was mandatory to cpu fold.
gotya! ty.
JEK81
Post by JEK81 »
and yea, i had it set on 6 threads and is set for readdimg cpu slot.
