Hello all,
I’ve only been folding for a bit and recently got a new computer. Used my old passkey and registered a new user. But I’ve noticed that the credited rewards compared to the rewards I should be getting are very low. I’ve finished 12 work units, estimates are normally around 600.000 per work unit but I only get like 100.000. My username is Joeymeesters in the scoreboard.
Any idea why my scores are this low? For information I’ve had a 4090 fold for 16 hours and only have 1.2 million points
Points not being credited correctly [as expected]
Re: Points not being credited correctly
Bonus points are only given after 10 completed WUs have been returned for a username and passkey pair. You also need to maintain an 80% or better return rate before the bonus deadline. So with a new username, the first 10 WUs returned will not get a bonus. The estimated points listed in the log are only based on the presence or absence of a passkey in the client configuration. The client does not have any means of validating the passkey or determining whether the username/passkey pair is qualified for the bonus.
In addition, checking your username it has 26 WU downloads and only 12 returns associated with it. You will have to return about 45 WUs successfully without any failures before this username and passkey pair will be qualified for a bonus.
Hello thanks for your reply,
That's really odd, could it be that some WU failed to submit? I did have a couple cancelled ones because the client tried to use my on board gpu, which i had to stop manually several times. I will have to wait and see then if the situation improves in a few days.
Another unit just completed but wasn't credited at all, im still at 12 WU even though number 13 finished 20 minutes ago , i'll include the error logs maybe sth is in there
*********************** Log Started 2023-03-25T14:25:19Z ***********************
14:25:20:WARNING:FS01:No CUDA or OpenCL 1.2+ support detected for GPU slot 01: gpu:16:0 Raphael [Ryzen 7000 Series iGPU]. Disabling.
14:26:06:WARNING:WU02:FS01:Slot ID 1 no longer exists and there are no other matching slots, dumping
14:26:06:WU00:FS00:0xa8:WARNING:Console control signal 1 on PID 21708
14:26:07:WARNING:WU00:FS00:Changed SMP threads from 30 to 31 this can cause some work units to fail
14:26:07:WARNING:WU00:FS00:AS lowered CPUs from 31 to 30
14:37:13:WU00:FS00:0xa8:WARNING:Console control signal 1 on PID 2232
14:37:13:WU01:FS02:0x22:WARNING:Console control signal 1 on PID 21852
15:04:14:WARNING:WU00:FS00:AS lowered CPUs from 31 to 30
15:42:56:WARNING:WU00:FS00:FahCore returned an unknown error code which probably indicates that it crashed
15:42:56:WARNING:WU00:FS00:FahCore returned: UNKNOWN_ENUM (-1073741819 = 0xc0000005)
15:42:56:WARNING:WU00:FS00:AS lowered CPUs from 31 to 30
19:50:16:WU01:FS02:0x22:WARNING:Console control signal 1 on PID 448
19:50:16:WU00:FS00:0xa8:WARNING:Console control signal 1 on PID 17936
19:50:43:WARNING:WU00:FS00:AS lowered CPUs from 31 to 30
19:57:18:WU01:FS02:0x22:WARNING:Console control signal 1 on PID 12540
19:57:18:WU00:FS00:0xa8:WARNING:Console control signal 1 on PID 1884
19:58:30:WARNING:WU00:FS00:AS lowered CPUs from 31 to 30
20:07:21:WU01:FS02:0x22:ERROR:98: Attempting to restart from last good checkpoint by restarting core.
20:07:22:WARNING:WU01:FS02:FahCore returned: CORE_RESTART (98 = 0x62)
20:16:13:WU01:FS02:0x22:WARNING:Console control signal 1 on PID 23000
20:16:13:WU00:FS00:0xa8:WARNING:Console control signal 1 on PID 3392
20:17:11:WARNING:WU00:FS00:AS lowered CPUs from 31 to 30
20:20:44:WARNING:WU00:FS00:FahCore returned an unknown error code which probably indicates that it crashed
20:20:44:WARNING:WU00:FS00:FahCore returned: UNKNOWN_ENUM (-1073741819 = 0xc0000005)
20:20:44:WARNING:WU00:FS00:AS lowered CPUs from 31 to 30
20:23:14:WARNING:WU00:FS00:FahCore returned an unknown error code which probably indicates that it crashed
20:23:14:WARNING:WU00:FS00:FahCore returned: UNKNOWN_ENUM (-1073741819 = 0xc0000005)
20:23:15:WARNING:WU00:FS00:AS lowered CPUs from 31 to 30
******************************* Date: 2023-03-25 *******************************
20:25:44:WARNING:WU00:FS00:FahCore returned an unknown error code which probably indicates that it crashed
20:25:44:WARNING:WU00:FS00:FahCore returned: UNKNOWN_ENUM (-1073741819 = 0xc0000005)
20:25:44:WARNING:WU00:FS00:AS lowered CPUs from 31 to 30
20:32:02:WU01:FS02:0x22:WARNING:Console control signal 1 on PID 5324
20:32:02:WU00:FS00:0xa8:WARNING:Console control signal 1 on PID 22508
20:33:03:WARNING:FS02:Killing WU01
21:46:23:WARNING:WU00:FS00:AS lowered CPUs from 31 to 30
21:55:57:WU01:FS02:0x22:ERROR:98: Attempting to restart from last good checkpoint by restarting core.
21:56:02:WARNING:WU01:FS02:FahCore returned an unknown error code which probably indicates that it crashed
21:56:02:WARNING:WU01:FS02:FahCore returned: UNKNOWN_ENUM (-1073740791 = 0xc0000409)
21:58:36:WARNING:WU00:FS00:FahCore returned an unknown error code which probably indicates that it crashed
21:58:36:WARNING:WU00:FS00:FahCore returned: UNKNOWN_ENUM (-1073741819 = 0xc0000005)
21:58:36:WARNING:WU00:FS00:AS lowered CPUs from 31 to 30
22:23:04:WARNING:WU01:FS02:FahCore returned an unknown error code which probably indicates that it crashed
22:23:04:WARNING:WU01:FS02:FahCore returned: WU_STALLED (127 = 0x7f)
22:26:35:WARNING:WU00:FS00:FahCore returned an unknown error code which probably indicates that it crashed
22:26:35:WARNING:WU00:FS00:FahCore returned: UNKNOWN_ENUM (-1073741819 = 0xc0000005)
22:26:35:WARNING:WU00:FS00:AS lowered CPUs from 31 to 30
22:37:46:WU01:FS02:0x22:ERROR:98: Attempting to restart from last good checkpoint by restarting core.
22:37:47:WARNING:WU01:FS02:FahCore returned: CORE_RESTART (98 = 0x62)
22:42:19:WU01:FS02:0x22:ERROR:114: Max number of attempts to resume from last checkpoint reached.
22:42:20:WARNING:WU01:FS02:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
22:48:13:WARNING:WU00:FS00:FahCore returned an unknown error code which probably indicates that it crashed
22:48:13:WARNING:WU00:FS00:FahCore returned: UNKNOWN_ENUM (-1073741819 = 0xc0000005)
22:48:13:WARNING:WU00:FS00:AS lowered CPUs from 31 to 30
22:49:31:WU02:FS02:0x22:ERROR:98: Attempting to restart from last good checkpoint by restarting core.
22:49:32:WARNING:WU02:FS02:FahCore returned: CORE_RESTART (98 = 0x62)
22:53:23:WARNING:WU00:FS00:FahCore returned an unknown error code which probably indicates that it crashed
22:53:23:WARNING:WU00:FS00:FahCore returned: UNKNOWN_ENUM (-1073741819 = 0xc0000005)
22:53:23:WARNING:WU00:FS00:AS lowered CPUs from 31 to 30
22:54:28:WARNING:WU00:FS00:FahCore returned an unknown error code which probably indicates that it crashed
22:54:28:WARNING:WU00:FS00:FahCore returned: UNKNOWN_ENUM (-1073741819 = 0xc0000005)
22:54:28:WARNING:WU00:FS00:Too many errors, failing
22:54:28:WU00:FS00:Sending unit results: id:00 state:SEND error:FAILED project:18467 run:137 clone:2 gen:2 core:0xa8 unit:0x00000002000000020000482300000089
22:54:28:WU00:FS00:Connecting to 129.32.209.203:8080
22:54:28:WU01:FS00:Connecting to assign1.foldingathome.org:80
22:54:28:WU00:FS00:Server responded WORK_ACK (400)
22:54:28:WU00:FS00:Cleaning up
BobWilliams757
Ryzen 2400G APU
32 GB DDR4-3200
MSI GTX 1660 Super Gaming X
Your system is creating errors and the work units are failing. Credit is given for completed work units, not any failed units.
You might want to do some stability testing of your system, and memory testing as well before doing any more folding.
ETA:. Looking more closely it appears you're integrated graphics is disabled due to lack of opencl or cuda drivers.
From there looks like as if you were forcing 31 threads on the CPU when it's trying to default back to 30. Generally if folding software tries to make a change there is a reason, most likely the large prime number. Set the threads to 30 or lower but avoid prime numbers.
You're 4090 isn't even showing up on this part of the log. Unless you have edited parts of the log you might want to copy and paste the first 100 lines or so of a new log when you try to fold again.
Fold them if you get them!
