RTX 3090 not folding on light power
sergiopahtc
Post by sergiopahtc »
Hello Guys
i´ve installed an rtx3090 and i cant fold on light fold power. i get the status: waiting for idle
when i set medium or full, it starts folding.
i had another nvidia card that i could set fold on light and worked.....
is there a configuration that i need to set to start folding at light power?
thanls
Re: RTX 3090 not folding on light power
Welcome to Filding@Home!
In the default configuration, that is the way F@H works in version 7.
Light uses 1/2 the CPU threads and no GPU.
Medium used all but one CPU thread and the GPU.
Full uses all CPU threads and the GPU.
In all cases the GPU is either on or off, there is no way to reduce GPU usage that is not altogether off.
There is an 'on idle' setting that runs when the OS decides the computer is idle.
sergiopahtc
Thats weird... before i changed the GPU my old nvidia folded in light power(no cpu)....
I mean... i only changed the GPU and updated the drivers....
Is there something im missing?
Post by calxalot »
In FAHControl, you might be able to right click the slot and de-select on-idle.
Post by calxalot »
You don’t need light power if you set the desired number of cpus on the cpu slot.
FAHControl > Configure > Slots or some such.
Assuming you are on Windows and using version 7.6, you can get to to Advanced Control and configure, slots, cpu and set it to 0 if you want,, then the GPU slot will be the only one that runs and set the main screen to Full.
sergiopahtc
@calxalot
I think i´m not clear enough.
Im trying to fold ONLY with my GPU, not cpu
@JimboPalmer
Of course i did that.... as i just said: it worked with my other nvidia graphic card.
Post by calxalot »
Set cpus 0 for the cpu slot, or delete it.
Set power to medium or full.
Post by calxalot »
Power light, among other things, is supposed to run gpu slots on idle.
Stop fighting it. Power light does nothing useful for you.
sergiopahtc
yes... but in medium my gpu goes crazy.... fan at 95%... temp at 95celsius....
Post by calxalot »
A GPU slot either runs or doesn’t.
Fah Power does nothing to affect it.
Power light does exactly 3 things:
- pause-on-battery is always true
- for cpu slots, -1 means use half of logical cpus
- for gpu slots, on idle defaults to true
If you need to limit your gpu, you might try power limiting the gpu with a gpu utility.
BobWilliams757
Ryzen 2400G APU
16 GB DDR4-3200
MSI GTX 1660 Super Gaming X
Post by BobWilliams757 »
sergiopahtc wrote: Wed Mar 22, 2023 12:51 am yes... but in medium my gpu goes crazy.... fan at 95%... temp at 95celsius....
Use MSI Afterburner or another app to power limit or otherwise make fan changes and such to your GPU. F@H controls see it as either on or off, the utilities let you adjust other aspects.
Fold them if you get them!
