Failed to update GPUs
fz4z
Post by fz4z »
The client is running, but failed to update GPUs.
( " https://api.foldingathome.org/gpus " AND "https://api.foldingathome.org:443" can be accessed via browser. )
OS: Windows Server 2019
Browser: Google Chrome 111.0.5563.65
Log:
*********************** Log Started 2023-03-15T14:29:17Z ***********************
14:29:17:I1:*********************** Folding@home Client ***********************
14:29:17:I1:    Version: 8.1.16
14:29:17:I1:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
14:29:17:I1:        Org: foldingathome.org
14:29:17:I1:  Copyright: 2023 foldingathome.org
14:29:17:I1:   Homepage: https://foldingathome.org/
14:29:17:I1:    License: https://www.gnu.org/licenses/gpl-3.0.txt
14:29:17:I1:       Date: Mar 9 2023
14:29:17:I1:       Time: 16:38:25
14:29:17:I1:   Compiler: Visual C++
14:29:17:I1:    Options: /TP /std:c++14 /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
14:29:17:I1:   Platform: win32 10
14:29:17:I1:       Bits: 64
14:29:17:I1:       Mode: Release
14:29:17:I1:       Args: --open-web-control
14:29:17:I1:****************************** CBang ******************************
14:29:17:I1:    Version: 1.7.2
14:29:17:I1:        Org: Cauldron Development LLC
14:29:17:I1:  Copyright: Cauldron Development LLC, 2003-2023
14:29:17:I1:   Homepage: https://cauldrondevelopment.com/
14:29:17:I1:    License: GPL 2+
14:29:17:I1:       Date: Feb 7 2023
14:29:17:I1:       Time: 20:33:41
14:29:17:I1:***************************** System ******************************
14:29:17:I1:        CPU: AMD EPYC 7K62 48-Core Processor
14:29:17:I1:     CPU ID: AuthenticAMD Family 23 Model 49 Stepping 0
14:29:17:I1:       CPUs: 4
14:29:17:I1:     Memory: 8.00GiB
14:29:17:I1:Free Memory: 5.98GiB
14:29:17:I1:    Threads: WINDOWS_THREADS
14:29:17:I1: OS Version: 6.2
14:29:17:I1:Has Battery: false
14:29:17:I1: On Battery: false
14:29:17:I1: UTC Offset: 8
14:29:17:I1:        PID: 6656
14:29:17:I1:        CWD: C:\ProgramData\FAHClient
14:29:17:I1:       Exec: C:\Program Files\FAHClient\FAHClient.exe
14:29:17:I1:*******************************************************************
14:29:17:I2:<config/>
14:29:17:I1:Opening Database
14:29:17:I1:Listening for HTTP on 127.0.0.1:7396
14:29:17:I1:Generating RSA key............................................................................................................++++-.................................................................................................................................................................++++-
14:29:18:I3:id = Un1AXaZMsRGnKopKY7M32D8N3WkYeygn9fvH9CsxLUE=
14:29:18:I3:Loaded 0 wus.
14:29:18:I1:OUT1:> GET https://api.foldingathome.org/gpus HTTP/1.1
14:29:18:I3:Connecting to api.foldingathome.org:443
14:29:18:I1:Started Windows systray control
14:29:18:W :Failed to update GPUs
14:29:23:I1:OUT3:> GET https://api.foldingathome.org/gpus HTTP/1.1
14:29:23:I3:Connecting to api.foldingathome.org:443
14:29:24:W :Failed to update GPUs
14:29:36:I1:OUT4:> GET https://api.foldingathome.org/gpus HTTP/1.1
14:29:36:I3:Connecting to api.foldingathome.org:443
14:29:36:W :Failed to update GPUs
14:30:00:I1:OUT5:> GET https://api.foldingathome.org/gpus HTTP/1.1
14:30:00:I3:Connecting to api.foldingathome.org:443
14:30:01:W :Failed to update GPUs
14:30:51:I1:OUT6:> GET https://api.foldingathome.org/gpus HTTP/1.1
14:30:51:I3:Connecting to api.foldingathome.org:443
14:30:51:W :Failed to update GPUs
14:32:31:I1:OUT7:> GET https://api.foldingathome.org/gpus HTTP/1.1
14:32:31:I3:Connecting to api.foldingathome.org:443
14:32:31:W :Failed to update GPUs
14:35:51:I1:OUT8:> GET https://api.foldingathome.org/gpus HTTP/1.1
14:35:51:I3:Connecting to api.foldingathome.org:443
14:35:52:W :Failed to update GPUs
spinney
Re: Failed to update GPUs
Post by spinney »
Months later and I experienced the same issue on a paired down Windows 11 Enterprise OS. For anyone else experiencing a similar issue: I believe the issue was that "Telnet Client" was not enabled under Windows Features. After checking that and letting it install, everything began working.
