Account suspended due to spam.
adrianxw
- Hardware configuration: Intel 6700 CPU on ASUS Sabertooth Z170 motherboard with 16 GB RAM
I am unable to get work from the project. I found that my account was suspended due to spam. I don't post spam, in fact, I rarely post. Browsing the few, (26 I think), messages I have written, I see nothing that could remotely be construed to be spam. I'd be really interested to find out what on Earth is going on.
Re: Account suspended due to spam.
You are not suspended from using the forum, and your activity here is not used to suspend use of your username, team, passkey. or IP address when connecting to the servers for work. This forum while operating on a server provided by the F@h Consortium is relatively independent of the rest of the project.
What can get your access suspended to the servers are excessive connection requests such as to the project descriptions or excessive dumping of WUs. Or your IP address could have been identified as a spam source and included in a block list. You would hav to provide some of your log showing when and how your client was blocked.
You are posting from an IP that is identified as a VPN, and that is blacklisted in multiple antispam lists.
That's probably your issue (although I have no idea where you got this message from). Do use this VPN.
adrianxw
Does not seem to apply, F@H simply runs by itself in the background. When a new project starts, I would certainly research it for my own interests and to communicate to others that either run F@H already or those I am trying to recruit, this, of course, is not a daily occurrence. I don't recall ever dumping a work unit.
I certainly use a VPN, I have a very good reason for doing so which is unimportant to the discussion here. I shall continue to use the VPN. The reason for suspending me given was that I have posted spam. I have not. I resent the implication. I doubt it will make any difference, but feel free to pass on my comment to those who made the decision, along with my resignation from the project, and the good will I had shown it by recruiting others.
I certainly will not miss it. Even at the lowest level, it uses more CPU than I feel it should, and my BOINC projects pay the price.
Lazvon
- Hardware configuration: 4080 / 12700F, 3090Ti/12900KS, 3090/12900K, 3090/10940X, 3080Ti/12700K, 3080Ti/9900X, 3080Ti/9900X
You didn’t post spam probably, but someone else using your VPN provider with the same IP (or subnet/range of IPs) likely did then. Banning by IP or subnet does have to be done sometimes for persistent spammers, at least on the couple of public forums I moderate for.
You still have not given any example of being blocked, or the messages connected with that blocking. As I have already posted here, you are not blocked due to posting anything here on the forum. If you had been it would hav ben logged or your account on the forum suspended or terminated.
Now it is quite possible your IP has been blocked for spam activity done by someone else. A number of ISPs in your region are lax in spam prevention, so also are a number of providers of VPN services.
Since so far you have provided no details, there is nothing to "pass on" to anyone who can do anything to change your connection ability.
DocJonz
- Hardware configuration: Folding with: 4x RTX 4070Ti, 1x RTX 4080 Super, 1x RTX 5070Ti
adrianxw - I suspect Lazvon is right.
It is not necessarily anything you have done, but what has come from others who use the same IP.
I've had this issue (not in relation to Folding, but elsewhere), where my activity was getting blocked or recorded as spam. After investiagtion with the Host provider, it was other people who used the same IP that were causing the problem, causing the IP to be blacklisted. The solution for me was to move to a dedicated IP.
adrianxw
Somewhat ironically, I can use the forum, but seem to be unable to download work now!
There's no connection between the account on this forum and the FAH system ... if you need help with FAH client, please post some logs.
