PPD half what it used to be
- Hardware configuration: Ryzen 9 3900XT: 24 cores, 128GB RAM, 1TB NVME, 4TB HDD, R9 Nano (Fiji) GPU.
Ryzen 9 3900X: 24 cores, 64GB RAM, 250GB NVME.
Xeon X5650 dual CPU server: 24 cores, 64GB RAM, 250GB NVME, R9 290(Hawaii) GPU.
Xeon X5650 dual CPU server: 24 cores, 64GB RAM, 250GB NVME.
I3-6100: 4 cores, 32GB RAM, 250GB NVME, 2 of R9 2980X (Tahiti) GPUs.
5 other smaller computers. - Location: Scotland
Not sure if this is to do with the beta, but over at curecoin they've informed me I seem to be getting half the PPD I used to (as in a few weeks back). But I'm using the same hardware, and completing the same number of WUs per day. Where was that page I was given before to check every WU is validated ok?
Re: PPD half what it used to be
Also I see bonus 0 against all my latest work units at https://apps.foldingathome.org/cpu - I thought bonus was given out if I completed before the timeout? I always do that.
You have to successfully return at least 80% of your work units to get the bonus. If you suddenly stop getting it, I would first check to make sure your passkey is still correct, then I would take a look at your log files from the last few weeks to see if you suddenly started dumping a bunch of work units.
It looks like the drop in points happened at the same time you started switching user ids, so I'd double check to make sure you didn't inadvertently change something else in your configuration at the same time you entered the new id.
I'll assume I went below 80% when I was trying GPUs on different machines, and may have dumped a fair number on computers which no longer had GPUs.
There's also a bug if you put more GPUs in a machine than the number of cores in the CPU (it's logged in Github and Joseph Coffland is looking into it), so a lot got dumped there. It was repeatedly downloading 64 core tasks because it thought I had 42 billion CPU cores - I'm guessing a negative number problem.
