"Detected clock skew" messages on Mac desktop
jonault
Post by jonault »
Switched to v8 on my Mac Studio yesterday. Things seem to be working fine until after I went to bed - apparently the Mac started trying to go into sleep mode because folding slowed down to a crawl & I started getting clock skew messages as if it was going to sleep & waking up repeatedly.
I can't find any setting to tell the Mac not to go to sleep; I have turned off the setting that puts the display to sleep after a certain amount of inactivity, maybe that will help. Not sure what else to try.
*********************** Log Started 2023-03-10T05:15:17Z ***********************
05:15:17:I1:*********************** Folding@home Client ***********************
05:15:17:I1: Version: 8.1.16
05:15:17:I1: Author: Joseph Coffland
05:15:17:I1: Org: foldingathome.org
05:15:17:I1: Copyright: 2023 foldingathome.org
05:15:17:I1: Homepage: https://foldingathome.org/
05:15:17:I1: License: https://www.gnu.org/licenses/gpl-3.0.txt
05:15:17:I1: Date: Mar 9 2023
05:15:17:I1: Time: 08:37:55
05:15:17:I1: Revision: ef88a00d899009283143dfb64c3f9629c0b6e31d
05:15:17:I1: Branch: master
05:15:17:I1: Compiler: GNU Apple LLVM 14.0.0 (clang-1400.0.29.202)
05:15:17:I1: Options: -std=c++17 -fsigned-char -stdlib=libc++ -O3 -funroll-loops -fno-pie
05:15:17:I1: -arch x86_64 -arch arm64 -mmacosx-version-min=10.13
05:15:17:I1: Platform: darwin 21.6.0
05:15:17:I1: Bits: 64
05:15:17:I1: Mode: Release
05:15:17:I1: Config: /Library/Application Support/FAHClient/config.xml
05:15:17:I1:****************************** CBang ******************************
05:15:17:I1: Version: 1.7.2
05:15:17:I1: Org: Cauldron Development LLC
05:15:17:I1: Copyright: Cauldron Development LLC, 2003-2023
05:15:17:I1: Homepage: https://cauldrondevelopment.com/
05:15:17:I1: License: GPL 2+
05:15:17:I1: Time: 08:37:29
05:15:17:I1: Revision: eae4b58965bdd4d54ea9eb77972674352b37a547
05:15:17:I1: -arch x86_64 -arch arm64 -mmacosx-version-min=10.13 -fPIC
05:15:17:I1:***************************** System ******************************
05:15:17:I1: CPU: Apple M1 Max
05:15:17:I1: CPU ID: Apple Family 8 Model 0 Stepping 0
05:15:17:I1: CPUs: 10
05:15:17:I1: Memory: 32.00GiB
05:15:17:I1:Free Memory: 6.30GiB
05:15:17:I1: Threads: POSIX_THREADS
05:15:17:I1: OS Version: 13.2.1
05:15:17:I1:Has Battery: false
05:15:17:I1: On Battery: false
05:15:17:I1: UTC Offset: -6
05:15:17:I1: PID: 59142
05:15:17:I1: CWD: /Library/Application Support/FAHClient
05:15:17:I1: Exec: /usr/local/bin/fah-client
05:15:17:I1:*******************************************************************
05:15:17:I2:
05:15:17:I2:
05:15:17:I2:
05:15:17:I2:
05:15:17:I2:
05:15:17:I2:
05:15:17:I2:
05:15:17:I2:
05:15:17:I2:
05:15:17:I1:Opening Database
05:15:17:I1:Listening for HTTP on 127.0.0.1:7396
05:15:17:I1:Generating RSA key................................................++++-......++++-
05:15:18:I3:id = 4gpuo1SRmQQgKld0OajpLMoQ7eHUmUy/TrqaS4Rz7Js=
05:15:18:I3:Loaded 0 wus.
05:15:18:I1:OUT1:> GET https://api.foldingathome.org/gpus HTTP/1.1
05:15:18:I3:Connecting to api.foldingathome.org:443
05:15:18:I1:OUT1:< api.foldingathome.org:443 HTTP/1.1 200 HTTP_OK
05:15:46:I1::Added new work unit: cpus:8 gpus:
05:15:46:I1::WU1:Requesting WU assignment for user Jon_Ault team 1971
05:15:47:I1:OUT3:> POST https://assign1.foldingathome.org/api/assign HTTP/1.1
05:15:47:I3:Connecting to assign1.foldingathome.org:443
05:15:47:I1:OUT3:< assign1.foldingathome.org:443 HTTP/1.1 200 HTTP_OK
05:15:47:I1::WU1:Received WU assignment _dRRTc2JUiIYWFsyK43odg6qhLifHQ6Wl5uRubEITpM
05:15:47:I1::WU1:Downloading WU
05:15:48:I1:OUT4:> POST https://vav22.fah.temple.edu/api/assign HTTP/1.1
05:15:48:I3:Connecting to vav22.fah.temple.edu:443
05:15:48:I1:OUT4:< vav22.fah.temple.edu:443 HTTP/1.1 200 HTTP_OK
05:15:49:I1::WU1:Received WU
05:15:49:I1:Downloading https://cores.foldingathome.org/fahcore-a8-osx-64bit-aarch64-0.0.12.tar.bz2.crt
05:15:49:I1:OUT5:> GET https://cores.foldingathome.org/fahcore-a8-osx-64bit-aarch64-0.0.12.tar.bz2.crt HTTP/1.1
05:15:49:I3:Connecting to cores.foldingathome.org:443
05:15:49:I1:OUT5:< cores.foldingathome.org:443 HTTP/1.1 200 OK
05:15:49:I1:Downloading https://cores.foldingathome.org/fahcore-a8-osx-64bit-aarch64-0.0.12.tar.bz2.sig
05:15:49:I1:OUT6:> GET https://cores.foldingathome.org/fahcore-a8-osx-64bit-aarch64-0.0.12.tar.bz2.sig HTTP/1.1
05:15:49:I1:OUT6:< cores.foldingathome.org:443 HTTP/1.1 200 OK
05:15:49:I1:OUT7:> GET https://cores.foldingathome.org/fahcore-a8-osx-64bit-aarch64-0.0.12.tar.bz2 HTTP/1.1
05:15:49:I1:OUT7:< cores.foldingathome.org:443 HTTP/1.1 200 OK
05:15:49:I1:Core signature valid
05:15:50:I1:Extracting cores/fahcore-a8-osx-64bit-aarch64-0.0.12/FahCore_a8
05:15:50:I1::WU1:CORE 100% 1B of 1B
05:15:50:I3::WU1:Running FahCore: "/Library/Application Support/FAHClient/cores/fahcore-a8-osx-64bit-aarch64-0.0.12/FahCore_a8" -dir _dRRTc2JUiIYWFsyK43odg6qhLifHQ6Wl5uRubEITpM -suffix 01 -version 8.1.16 -lifeline 59142 -np 8
05:15:50:I3::WU1:Started FahCore on PID 59233
05:15:50:I1::WU1:*********************** Log Started 2023-03-10T05:15:50Z ***********************
05:15:50:I1::WU1:************************** Gromacs Folding@home Core ***************************
05:15:50:I1::WU1: Core: Gromacs
05:15:50:I1::WU1: Type: 0xa8
05:15:50:I1::WU1: Version: 0.0.12
05:15:50:I1::WU1: Author: Joseph Coffland
05:15:50:I1::WU1: Copyright: 2020 foldingathome.org
05:15:50:I1::WU1: Homepage: https://foldingathome.org/
05:15:50:I1::WU1: Date: Jan 16 2021
05:15:50:I1::WU1: Time: 21:35:50
05:15:50:I1::WU1: Revision: c5816759c404e4b65f9f364c3d1ef554a67c4225
05:15:50:I1::WU1: Branch: master
05:15:50:I1::WU1: Compiler: GNU Apple LLVM 12.0.0 (clang-1200.0.32.28)
05:15:50:I1::WU1: Options: -faligned-new -std=c++14 -fsigned-char -stdlib=libc++ -O3
05:15:50:I1::WU1: -funroll-loops -fno-pie -mmacosx-version-min=11.0
05:15:50:I1::WU1: Platform: darwin 20.2.0
05:15:50:I1::WU1: Bits: 64
05:15:50:I1::WU1: Mode: Release
05:15:50:I1::WU1: SIMD: arm_neon_asimd
05:15:50:I1::WU1: OpenMP: ON
05:15:50:I1::WU1: CUDA: OFF
05:15:50:I1::WU1: Args: -dir _dRRTc2JUiIYWFsyK43odg6qhLifHQ6Wl5uRubEITpM -suffix 01
05:15:50:I1::WU1: -version 8.1.16 -lifeline 59142 -np 8
05:15:50:I1::WU1:************************************ libFAH ************************************
05:15:50:I1::WU1: Time: 21:35:27
05:15:50:I1::WU1:************************************ CBang *************************************
05:15:50:I1::WU1: Time: 21:35:02
05:15:50:I1::WU1: -funroll-loops -fno-pie -mmacosx-version-min=11.0 -fPIC
05:15:50:I1::WU1:************************************ System ************************************
05:15:50:I1::WU1: CPU: Apple A14
05:15:50:I1::WU1: CPU ID: Apple Family 8 Model 0 Stepping 0
05:15:50:I1::WU1: CPUs: 10
05:15:50:I1::WU1: Memory: 32.00GiB
05:15:50:I1::WU1:Free Memory: 5.22GiB
05:15:50:I1::WU1: Threads: POSIX_THREADS
05:15:50:I1::WU1: OS Version: 13.2
05:15:50:I1::WU1:Has Battery: false
05:15:50:I1::WU1: On Battery: false
05:15:50:I1::WU1: UTC Offset: -6
05:15:50:I1::WU1: PID: 59233
05:15:50:I1::WU1: CWD: /Library/Application Support/FAHClient/work
05:15:50:I1::WU1:********************************************************************************
05:15:50:I1::WU1:Project: 16996 (Run 59, Clone 191, Gen 180)
05:15:50:I1::WU1:Unit: 0x00000000000000000000000000000000
05:15:50:I1::WU1:Reading tar file core.xml
05:15:50:I1::WU1:Reading tar file frame180.tpr
05:15:50:I1::WU1:Digital signatures verified
05:15:50:I1::WU1:Calling: mdrun -c frame180.gro -s frame180.tpr -x frame180.xtc -cpt 5 -nt 8 -ntmpi 1
05:15:50:I1::WU1:Steps: first=450000000 total=452500000
05:15:50:I1::WU1:Completed 1 out of 2500000 steps (0%)
05:21:58:I1::WU1:Completed 25000 out of 2500000 steps (1%)
05:28:17:I1::WU1:Completed 50000 out of 2500000 steps (2%)
05:34:26:I1::WU1:Completed 75000 out of 2500000 steps (3%)
05:40:35:I1::WU1:Completed 100000 out of 2500000 steps (4%)
05:46:24:I1::WU1:Completed 125000 out of 2500000 steps (5%)
05:52:51:I1::WU1:Completed 150000 out of 2500000 steps (6%)
05:59:14:I1::WU1:Completed 175000 out of 2500000 steps (7%)
06:05:37:I1::WU1:Completed 200000 out of 2500000 steps (8%)
06:12:05:I1::WU1:Completed 225000 out of 2500000 steps (9%)
06:18:45:I1::WU1:Completed 250000 out of 2500000 steps (10%)
06:26:02:I1::WU1:Completed 275000 out of 2500000 steps (11%)
06:32:47:I1::WU1:Completed 300000 out of 2500000 steps (12%)
06:36:39:I1::WU1:Completed 325000 out of 2500000 steps (13%)
06:39:11:I1::WU1:Completed 350000 out of 2500000 steps (14%)
06:41:33:I1::WU1:Completed 375000 out of 2500000 steps (15%)
06:43:59:I1::WU1:Completed 400000 out of 2500000 steps (16%)
06:47:05:I1::WU1:Completed 425000 out of 2500000 steps (17%)
06:50:58:I1::WU1:Completed 450000 out of 2500000 steps (18%)
06:54:19:I1::WU1:Completed 475000 out of 2500000 steps (19%)
06:56:47:I1::WU1:Completed 500000 out of 2500000 steps (20%)
06:59:05:I1::WU1:Completed 525000 out of 2500000 steps (21%)
07:01:54:I1::WU1:Completed 550000 out of 2500000 steps (22%)
07:04:08:I1::WU1:Completed 575000 out of 2500000 steps (23%)
07:06:29:I1::WU1:Completed 600000 out of 2500000 steps (24%)
07:08:47:I1::WU1:Completed 625000 out of 2500000 steps (25%)
07:11:18:I1::WU1:Completed 650000 out of 2500000 steps (26%)
07:13:35:I1::WU1:Completed 675000 out of 2500000 steps (27%)
07:15:50:I1::WU1:Completed 700000 out of 2500000 steps (28%)
07:18:41:I1::WU1:Completed 725000 out of 2500000 steps (29%)
07:21:35:I1::WU1:Completed 750000 out of 2500000 steps (30%)
07:23:52:I1::WU1:Completed 775000 out of 2500000 steps (31%)
07:26:19:I1::WU1:Completed 800000 out of 2500000 steps (32%)
07:28:35:I1::WU1:Completed 825000 out of 2500000 steps (33%)
07:34:09:I1::WU1:Completed 850000 out of 2500000 steps (34%)
07:41:12:I1::WU1:Completed 875000 out of 2500000 steps (35%)
07:47:50:I1::WU1:Completed 900000 out of 2500000 steps (36%)
07:55:05:I1::WU1:Completed 925000 out of 2500000 steps (37%)
08:01:59:I1::WU1:Completed 950000 out of 2500000 steps (38%)
08:08:32:I1::WU1:Completed 975000 out of 2500000 steps (39%)
08:15:04:I1::WU1:Completed 1000000 out of 2500000 steps (40%)
08:21:55:I1::WU1:Completed 1025000 out of 2500000 steps (41%)
08:28:49:I1::WU1:Completed 1050000 out of 2500000 steps (42%)
08:35:51:I1::WU1:Completed 1075000 out of 2500000 steps (43%)
08:41:09:I1::WU1:Completed 1100000 out of 2500000 steps (44%)
08:43:32:I1::WU1:Completed 1125000 out of 2500000 steps (45%)
08:45:52:I1::WU1:Completed 1150000 out of 2500000 steps (46%)
08:48:10:I1::WU1:Completed 1175000 out of 2500000 steps (47%)
08:50:31:I1::WU1:Completed 1200000 out of 2500000 steps (48%)
08:52:59:I1::WU1:Completed 1225000 out of 2500000 steps (49%)
08:55:32:I1::WU1:Completed 1250000 out of 2500000 steps (50%)
08:58:01:I1::WU1:Completed 1275000 out of 2500000 steps (51%)
09:01:28:I1::WU1:Completed 1300000 out of 2500000 steps (52%)
09:05:05:I1::WU1:Completed 1325000 out of 2500000 steps (53%)
09:08:22:I1::WU1:Completed 1350000 out of 2500000 steps (54%)
09:12:21:I1::WU1:Completed 1375000 out of 2500000 steps (55%)
09:18:58:I1::WU1:Completed 1400000 out of 2500000 steps (56%)
09:22:22:I1::WU1:Completed 1425000 out of 2500000 steps (57%)
09:25:40:I1::WU1:Completed 1450000 out of 2500000 steps (58%)
09:29:50:I1::WU1:Completed 1475000 out of 2500000 steps (59%)
09:33:17:I1::WU1:Completed 1500000 out of 2500000 steps (60%)
09:36:46:I1::WU1:Completed 1525000 out of 2500000 steps (61%)
09:40:15:I1::WU1:Completed 1550000 out of 2500000 steps (62%)
09:43:49:I1::WU1:Completed 1575000 out of 2500000 steps (63%)
09:47:31:I1::WU1:Completed 1600000 out of 2500000 steps (64%)
09:51:24:I1::WU1:Completed 1625000 out of 2500000 steps (65%)
09:55:08:I1::WU1:Completed 1650000 out of 2500000 steps (66%)
09:58:34:I1::WU1:Completed 1675000 out of 2500000 steps (67%)
10:01:53:I1::WU1:Completed 1700000 out of 2500000 steps (68%)
10:05:10:I1::WU1:Completed 1725000 out of 2500000 steps (69%)
10:08:24:I1::WU1:Completed 1750000 out of 2500000 steps (70%)
10:11:41:I1::WU1:Completed 1775000 out of 2500000 steps (71%)
10:14:49:I1::WU1:Completed 1800000 out of 2500000 steps (72%)
10:17:54:I1::WU1:Completed 1825000 out of 2500000 steps (73%)
10:21:00:I1::WU1:Completed 1850000 out of 2500000 steps (74%)
10:24:02:I1::WU1:Completed 1875000 out of 2500000 steps (75%)
10:27:11:I1::WU1:Completed 1900000 out of 2500000 steps (76%)
10:30:16:I1::WU1:Completed 1925000 out of 2500000 steps (77%)
10:33:16:I1::WU1:Completed 1950000 out of 2500000 steps (78%)
10:36:16:I1::WU1:Completed 1975000 out of 2500000 steps (79%)
10:39:19:I1::WU1:Completed 2000000 out of 2500000 steps (80%)
10:42:19:I1::WU1:Completed 2025000 out of 2500000 steps (81%)
10:45:22:I1::WU1:Completed 2050000 out of 2500000 steps (82%)
10:48:23:I1::WU1:Completed 2075000 out of 2500000 steps (83%)
10:51:28:I1::WU1:Completed 2100000 out of 2500000 steps (84%)
10:54:26:I1::WU1:Completed 2125000 out of 2500000 steps (85%)
10:57:28:I1::WU1:Completed 2150000 out of 2500000 steps (86%)
11:01:04:I1::WU1:Completed 2175000 out of 2500000 steps (87%)
11:03:46:I1::WU1:Completed 2200000 out of 2500000 steps (88%)
11:05:04:W ::WU1:Detected clock skew (16 secs), I/O delay, laptop hibernation, other slowdown or clock change noted, adjusting time estimates
11:19:35:W ::WU1:Detected clock skew (13 mins 43 secs), I/O delay, laptop hibernation, other slowdown or clock change noted, adjusting time estimates
11:20:07:I1::WU1:Completed 2225000 out of 2500000 steps (89%)
11:35:54:W ::WU1:Detected clock skew (15 mins 23 secs), I/O delay, laptop hibernation, other slowdown or clock change noted, adjusting time estimates
11:52:59:W ::WU1:Detected clock skew (16 mins 7 secs), I/O delay, laptop hibernation, other slowdown or clock change noted, adjusting time estimates
12:09:22:W ::WU1:Detected clock skew (15 mins 27 secs), I/O delay, laptop hibernation, other slowdown or clock change noted, adjusting time estimates
12:09:36:I1::WU1:Completed 2250000 out of 2500000 steps (90%)
12:25:20:W ::WU1:Detected clock skew (15 mins 10 secs), I/O delay, laptop hibernation, other slowdown or clock change noted, adjusting time estimates
12:42:13:W ::WU1:Detected clock skew (16 mins 5 secs), I/O delay, laptop hibernation, other slowdown or clock change noted, adjusting time estimates
12:43:16:I1::WU1:Completed 2275000 out of 2500000 steps (91%)
12:59:13:W ::WU1:Detected clock skew (15 mins 46 secs), I/O delay, laptop hibernation, other slowdown or clock change noted, adjusting time estimates
13:15:39:W ::WU1:Detected clock skew (15 mins 27 secs), I/O delay, laptop hibernation, other slowdown or clock change noted, adjusting time estimates
13:32:34:W ::WU1:Detected clock skew (16 mins 7 secs), I/O delay, laptop hibernation, other slowdown or clock change noted, adjusting time estimates
13:33:10:I1::WU1:Completed 2300000 out of 2500000 steps (92%)
13:49:52:W ::WU1:Detected clock skew (16 mins 30 secs), I/O delay, laptop hibernation, other slowdown or clock change noted, adjusting time estimates
14:08:32:W ::WU1:Detected clock skew (17 mins 44 secs), I/O delay, laptop hibernation, other slowdown or clock change noted, adjusting time estimates
14:10:27:W ::WU1:Detected clock skew (1 min 7 secs), I/O delay, laptop hibernation, other slowdown or clock change noted, adjusting time estimates
14:11:02:I1::WU1:Completed 2325000 out of 2500000 steps (93%)
14:15:47:W ::WU1:Detected clock skew (4 mins 24 secs), I/O delay, laptop hibernation, other slowdown or clock change noted, adjusting time estimates
14:32:01:W ::WU1:Detected clock skew (15 mins 26 secs), I/O delay, laptop hibernation, other slowdown or clock change noted, adjusting time estimates
14:50:24:W ::WU1:Detected clock skew (17 mins 11 secs), I/O delay, laptop hibernation, other slowdown or clock change noted, adjusting time estimates
14:50:32:I1::WU1:Completed 2350000 out of 2500000 steps (94%)
15:06:57:W ::WU1:Detected clock skew (15 mins 35 secs), I/O delay, laptop hibernation, other slowdown or clock change noted, adjusting time estimates
15:25:03:W ::WU1:Detected clock skew (17 mins 10 secs), I/O delay, laptop hibernation, other slowdown or clock change noted, adjusting time estimates
15:25:46:I1::WU1:Completed 2375000 out of 2500000 steps (95%)
15:37:35:W ::WU1:Detected clock skew (11 mins 44 secs), I/O delay, laptop hibernation, other slowdown or clock change noted, adjusting time estimates
15:40:14:I1::WU1:Completed 2400000 out of 2500000 steps (96%)
15:41:14:W ::WU1:Detected clock skew (23 secs), I/O delay, laptop hibernation, other slowdown or clock change noted, adjusting time estimates
15:43:27:W ::WU1:Detected clock skew (17 secs), I/O delay, laptop hibernation, other slowdown or clock change noted, adjusting time estimates
15:45:01:W ::WU1:Detected clock skew (42 secs), I/O delay, laptop hibernation, other slowdown or clock change noted, adjusting time estimates
15:46:41:W ::WU1:Detected clock skew (43 secs), I/O delay, laptop hibernation, other slowdown or clock change noted, adjusting time estimates
15:49:34:W ::WU1:Detected clock skew (1 min 3 secs), I/O delay, laptop hibernation, other slowdown or clock change noted, adjusting time estimates
15:51:42:W ::WU1:Detected clock skew (1 min 18 secs), I/O delay, laptop hibernation, other slowdown or clock change noted, adjusting time estimates
15:52:01:I1::WU1:Completed 2425000 out of 2500000 steps (97%)
15:53:59:W ::WU1:Detected clock skew (1 min 21 secs), I/O delay, laptop hibernation, other slowdown or clock change noted, adjusting time estimates
15:55:07:W ::WU1:Detected clock skew (20 secs), I/O delay, laptop hibernation, other slowdown or clock change noted, adjusting time estimates
15:57:11:W ::WU1:Detected clock skew (1 min 7 secs), I/O delay, laptop hibernation, other slowdown or clock change noted, adjusting time estimates
16:03:45:W ::WU1:Detected clock skew (5 mins 48 secs), I/O delay, laptop hibernation, other slowdown or clock change noted, adjusting time estimates
16:05:19:W ::WU1:Detected clock skew (38 secs), I/O delay, laptop hibernation, other slowdown or clock change noted, adjusting time estimates
16:05:28:I1::WU1:Completed 2450000 out of 2500000 steps (98%)
16:06:46:W ::WU1:Detected clock skew (39 secs), I/O delay, laptop hibernation, other slowdown or clock change noted, adjusting time estimates
16:08:42:W ::WU1:Detected clock skew (60 secs), I/O delay, laptop hibernation, other slowdown or clock change noted, adjusting time estimates
16:09:48:W ::WU1:Detected clock skew (18 secs), I/O delay, laptop hibernation, other slowdown or clock change noted, adjusting time estimates
16:11:14:W ::WU1:Detected clock skew (30 secs), I/O delay, laptop hibernation, other slowdown or clock change noted, adjusting time estimates
16:18:36:W ::WU1:Detected clock skew (6 mins 34 secs), I/O delay, laptop hibernation, other slowdown or clock change noted, adjusting time estimates
16:18:59:I1::WU1:Completed 2475000 out of 2500000 steps (99%)
16:21:16:W ::WU1:Detected clock skew (43 secs), I/O delay, laptop hibernation, other slowdown or clock change noted, adjusting time estimates
16:22:50:W ::WU1:Detected clock skew (38 secs), I/O delay, laptop hibernation, other slowdown or clock change noted, adjusting time estimates
16:24:03:W ::WU1:Detected clock skew (24 secs), I/O delay, laptop hibernation, other slowdown or clock change noted, adjusting time estimates
16:25:24:W ::WU1:Detected clock skew (24 secs), I/O delay, laptop hibernation, other slowdown or clock change noted, adjusting time estimates
16:26:56:W ::WU1:Detected clock skew (44 secs), I/O delay, laptop hibernation, other slowdown or clock change noted, adjusting time estimates
16:28:15:W ::WU1:Detected clock skew (23 secs), I/O delay, laptop hibernation, other slowdown or clock change noted, adjusting time estimates
17:19:14:W ::WU1:Detected clock skew (49 mins 45 secs), I/O delay, laptop hibernation, other slowdown or clock change noted, adjusting time estimates
17:19:42:I1::WU1:Completed 2500000 out of 2500000 steps (100%)
17:19:44:I1::WU1:Saving result file ../logfile_01.txt
17:19:44:I1::WU1:Saving result file frame180.gro
17:19:44:I1::WU1:Saving result file frame180.xtc
17:19:44:I1::WU1:Saving result file md.log
17:19:44:I1::WU1:Saving result file science.log
17:19:44:I1::WU1:Saving result file state.cpt
17:19:44:I1::WU1:Folding@home Core Shutdown: FINISHED_UNIT
17:19:44:I1::WU1:Core returned FINISHED_UNIT (100)
17:19:44:I1::Added new work unit: cpus:8 gpus:
17:19:44:I1::WU1:Uploading WU results
17:19:44:I1:OUT47:> POST https://vav22.fah.temple.edu/api/results HTTP/1.1
17:19:44:I3:Connecting to vav22.fah.temple.edu:443
17:19:44:I1::WU2:Requesting WU assignment for user Jon_Ault team 1971
17:19:44:I1:OUT48:> POST https://assign2.foldingathome.org/api/assign HTTP/1.1
17:19:44:I3:Connecting to assign2.foldingathome.org:443
17:19:45:I1:OUT48:< assign2.foldingathome.org:443 HTTP/1.1 200 HTTP_OK
17:19:45:I1::WU2:Received WU assignment 6Lqncfq65OhmDHjUUmXicouyXdlAQ3Xk0kzkHVnpNa0
17:19:45:I1::WU2:Downloading WU
17:19:45:I1:OUT49:> POST https://vav20.fah.temple.edu/api/assign HTTP/1.1
17:19:45:I3:Connecting to vav20.fah.temple.edu:443
17:19:45:I1:OUT49:< vav20.fah.temple.edu:443 HTTP/1.1 200 HTTP_OK
17:19:45:I1::WU2:CORE 100% 1B of 1B
17:19:45:I3::WU2:Running FahCore: "/Library/Application Support/FAHClient/cores/fahcore-a8-osx-64bit-aarch64-0.0.12/FahCore_a8" -dir 6Lqncfq65OhmDHjUUmXicouyXdlAQ3Xk0kzkHVnpNa0 -suffix 01 -version 8.1.16 -lifeline 59142 -np 8
17:19:45:I3::WU2:Started FahCore on PID 64181
17:19:46:I1::WU2:*********************** Log Started 2023-03-10T17:19:46Z ***********************
17:19:46:I1::WU2:************************** Gromacs Folding@home Core ***************************
17:19:46:I1::WU2: Core: Gromacs
17:19:46:I1::WU2: Type: 0xa8
17:19:46:I1::WU2: Version: 0.0.12
17:19:46:I1::WU2: Author: Joseph Coffland
17:19:46:I1::WU2: Copyright: 2020 foldingathome.org
17:19:46:I1::WU2: Homepage: https://foldingathome.org/
17:19:46:I1::WU2: Date: Jan 16 2021
17:19:46:I1::WU2: Time: 21:35:50
17:19:46:I1::WU2: Revision: c5816759c404e4b65f9f364c3d1ef554a67c4225
17:19:46:I1::WU2: Branch: master
17:19:46:I1::WU2: Compiler: GNU Apple LLVM 12.0.0 (clang-1200.0.32.28)
17:19:46:I1::WU2: Options: -faligned-new -std=c++14 -fsigned-char -stdlib=libc++ -O3
17:19:46:I1::WU2: -funroll-loops -fno-pie -mmacosx-version-min=11.0
17:19:46:I1::WU2: Platform: darwin 20.2.0
17:19:46:I1::WU2: Bits: 64
17:19:46:I1::WU2: Mode: Release
17:19:46:I1::WU2: SIMD: arm_neon_asimd
17:19:46:I1::WU2: OpenMP: ON
17:19:46:I1::WU2: CUDA: OFF
17:19:46:I1::WU2: Args: -dir 6Lqncfq65OhmDHjUUmXicouyXdlAQ3Xk0kzkHVnpNa0 -suffix 01
17:19:46:I1::WU2: -version 8.1.16 -lifeline 59142 -np 8
17:19:46:I1::WU2:************************************ libFAH ************************************
17:19:46:I1::WU2: Time: 21:35:27
17:19:46:I1::WU2:************************************ CBang *************************************
17:19:46:I1::WU2: Time: 21:35:02
17:19:46:I1::WU2: -funroll-loops -fno-pie -mmacosx-version-min=11.0 -fPIC
17:19:46:I1::WU2:************************************ System ************************************
17:19:46:I1::WU2: CPU: Apple A14
17:19:46:I1::WU2: CPU ID: Apple Family 8 Model 0 Stepping 0
17:19:46:I1::WU2: CPUs: 10
17:19:46:I1::WU2: Memory: 32.00GiB
17:19:46:I1::WU2:Free Memory: 10.19GiB
17:19:46:I1::WU2: Threads: POSIX_THREADS
17:19:46:I1::WU2: OS Version: 13.2
17:19:46:I1::WU2:Has Battery: false
17:19:46:I1::WU2: On Battery: false
17:19:46:I1::WU2: UTC Offset: -6
17:19:46:I1::WU2: PID: 64181
17:19:46:I1::WU2: CWD: /Library/Application Support/FAHClient/work
17:19:46:I1::WU2:********************************************************************************
17:19:46:I1::WU2:Project: 18404 (Run 30, Clone 0, Gen 205)
17:19:46:I1::WU2:Unit: 0x00000000000000000000000000000000
17:19:46:I1::WU2:Reading tar file core.xml
17:19:46:I1::WU2:Reading tar file frame205.tpr
17:19:46:I1::WU2:Digital signatures verified
17:19:46:I1::WU2:Calling: mdrun -c frame205.gro -s frame205.tpr -x frame205.xtc -cpt 5 -nt 8 -ntmpi 1
17:19:46:I1::WU2:Steps: first=2050000000 total=2060000000
17:19:46:I1::WU2:Completed 1 out of 10000000 steps (0%)
17:19:50:I1:OUT47:< vav22.fah.temple.edu:443 HTTP/1.1 200 HTTP_OK
17:19:50:I1::WU1:Credited
17:20:58:W ::WU2:Detected clock skew (46 secs), I/O delay, laptop hibernation, other slowdown or clock change noted, adjusting time estimates
17:22:21:W ::WU2:Detected clock skew (35 secs), I/O delay, laptop hibernation, other slowdown or clock change noted, adjusting time estimates
17:23:33:W ::WU2:Detected clock skew (16 secs), I/O delay, laptop hibernation, other slowdown or clock change noted, adjusting time estimates
17:24:57:W ::WU2:Detected clock skew (36 secs), I/O delay, laptop hibernation, other slowdown or clock change noted, adjusting time estimates
17:26:12:W ::WU2:Detected clock skew (19 secs), I/O delay, laptop hibernation, other slowdown or clock change noted, adjusting time estimates
17:29:06:W ::WU2:Detected clock skew (37 secs), I/O delay, laptop hibernation, other slowdown or clock change noted, adjusting time estimates
17:30:44:W ::WU2:Detected clock skew (50 secs), I/O delay, laptop hibernation, other slowdown or clock change noted, adjusting time estimates
17:32:40:W ::WU2:Detected clock skew (60 secs), I/O delay, laptop hibernation, other slowdown or clock change noted, adjusting time estimates
17:49:48:W ::WU2:Detected clock skew (16 mins 20 secs), I/O delay, laptop hibernation, other slowdown or clock change noted, adjusting time estimates
18:01:55:W ::WU2:Detected clock skew (11 mins 11 secs), I/O delay, laptop hibernation, other slowdown or clock change noted, adjusting time estimates
18:08:29:W ::WU2:Detected clock skew (5 mins 45 secs), I/O delay, laptop hibernation, other slowdown or clock change noted, adjusting time estimates
18:09:07:I1::WU2:Completed 100000 out of 10000000 steps (1%)
18:10:42:W ::WU2:Detected clock skew (17 secs), I/O delay, laptop hibernation, other slowdown or clock change noted, adjusting time estimates
18:16:57:I1::WU2:Completed 200000 out of 10000000 steps (2%)
18:23:55:I1::WU2:Completed 300000 out of 10000000 steps (3%)
18:31:27:I1::WU2:Completed 400000 out of 10000000 steps (4%)
18:38:26:I1::WU2:Completed 500000 out of 10000000 steps (5%)
Re: "Detected clock skew" messages on Mac desktop
Post by calxalot »
Open System Settings and search for sleep.
I don’t remember where it is on macos 13, and I’m away from my computers for a few hours.
jonault
Post by jonault »
Under Display settings, the Advanced button revealed an option for "Prevent automatic sleeping when the display is off"; I'll try enabling that. Nothing else that turned up when searching for "sleep" seemed relevant.
Post by calxalot »
That's it. Got me too on my M1 mini.
With macOS 12 or earlier, the setting is in Energy Saver.
Seems odd that Apple hid it.
Note, v8 does not disable sleep as v7 did. There is a request for it:
https://github.com/FoldingAtHome/fah-cl ... issues/125
