lufah - Little Utility for FAH v8
https://github.com/kbernhagen/lufah
This is a python command line utility script that should
work on macOS, Linux, and Windows.
Requirements
- python 3.8+
Install
- pip3 install lufah
There are so many ways to install python, that I will not attempt to tell how.
Please use Google or your favorite search engine.
Requirements
- python 3.8+
Install
Marcos FRM
Re: lufah - Little Utility for FAH v8
Cannot get/set some configs:
User, team, passkey, and cause work.
$ lufah . info
Host: alma
Client: 8.4.2
OS: linux 4.18
CPU: 4 cores, amd64, "Intel(R) Core(TM) i7-4770 CPU @ 3.40GHz"
$ lufah . config on-idle
null
$ lufah . config keep-awake
null
$ lufah . config cpus
null
$ lufah . config cpus 4
ERROR: cannot set "cpus" on group NoneCode: Select all
$ lufah --version
0.4.3-
Some config items are only valid for groups on v8.3+
I think everything but user, team, passkey, cause
Try
lufah / config cpus 4
I didn’t think it was wise to allow some keys to be set on all groups. Nor to allow some and not others.
If you need to use lufah with v8.4, I can push another release that supports progress and eta. Only matters for the units command.
Marcos FRM
Marcos FRM
Noob question: can I dump a WU?
No, because the api requires the uuid of the unit. I was lazy and didn’t think making folks type the uuid was cool.
Suggestions are welcome.
Marcos FRM
Perhaps a "dump-all" command.
Ok. Sounds dangerous. Maybe make it interactive or require a —force flag.
Marcos FRM
It would be helpful to have 'timeout' and 'deadline' information in the output of the 'units' command. Or only 'deadline', to know when the WU will be automatically dumped if not completed in time.
Ok. It will be > 80 columns. I added Core type, which made it 79.
Maybe I should use python os.get_terminal_size()
It would be nice if it could display the total estimated PPD for a group. I didn't test this in many configurations and I'm not the best Python programmer but this patch works for me:
diff --git a/src/lufah/commands/core/units.py b/src/lufah/commands/core/units.py
index 6de1415..a01743f 100644
--- a/src/lufah/commands/core/units.py
+++ b/src/lufah/commands/core/units.py
@@ -210,8 +210,15 @@ def units_table_lines(clients: list[FahClient]) -> list[str]:
else:
for group in groups:
name_group = f"{name}/{group}"
- lines.append(f"{name_group:<25} " + _group_status(client, group))
units = units_for_group(client, group)
+ status = _group_status(client, group)
+ if units:
+ ppd_total = 0
+ for unit in units:
+ ppd_total += unit.get("ppd", 0)
+ else:
+ ppd_total = ""
+ lines.append(f"{name_group:<25} " + f"{status:<26}" + f"{ppd_total}")
if not units:
continue
for unit in units:
Sure.
My groups have one or zero units.
Would you only want a total when >1 unit in a group?
Would it be interesting to have an all groups total when there are multiple units?
