Hi,
I have created a folding@home service solution which can be deployed on any AWS account:
https://github.com/sazecis/folding-as-a-service
If you have some credits in your AWS account or you just want to donate folding for 1 - 10 dollars then this could be a solution.
The service will deploy the necessary infrastructure in your account and then you can start the folding by specifying the amount of credit you want to spend. The folding will last until the amount of credit will be spent and then it will stop.
You can read more about the usage and technical solution on the README of my repo or in my blog at dev.to:
https://dev.to/sazecis/folding-as-a-service-51g4
Hope you like it and you suggest ways how to improve.
Cheers,
Csaba
BobWilliams757
Ryzen 2400G APU
32 GB DDR4-3200
MSI GTX 1660 Super Gaming X
Re: folding-as-a-service
It sounds like a well thought out solution. At times some of the deals giving by AWS services might be a great way for someone to boost their folding throughput for periods of time.
Fold them if you get them!
Mxyzptlk
- Hardware configuration: Lots... Look at my website: www.mxyzptlk.us
hmmmmmmmm.... LTT Folding month....
It defaults to team 226715, but that can be edited.
What kind of results does it produce? Like points per dollar/euro?
AZBrandon, I haven't measured that, but will do and post it here.
I have done the measurement with the current credit options:
$1
Execution time: 18h
Type: CPU - 5,700 points per day
Total points: 4,275
$3
Execution time: 15h
Type: CPU - 7,200 p/d
Type: GPU - 440,000 p/d
Total points: 260,000
$5
Execution time: 25h
Total points: 466,000
$10
Execution time: 49h
Total points: 913,000
$1
Execution time: 18h
Total points: 4,275
$3
Execution time: 15h
$5
Execution time: 25h
$10
Execution time: 49h
