threeqc
Posts: 5 Joined: Mon Mar 06, 2023 3:59 pm
Hardware configuration: i5-13600K RTX 3050 (MSI Ventus 2X OC)
Post
by threeqc » Mon Mar 06, 2023 5:12 pm
FAH seems to be detecting CUDA properly, but not OpenCL. The system info says it couldn't find libOpenCL.so. Any ideas on how to fix it?
nvidia-smi:
| NVIDIA-SMI 525.85.05 Driver Version: 525.85.05 CUDA Version: 12.0 |
| GPU Name Persistence-M| Bus-Id Disp.A | Volatile Uncorr. ECC |
| Fan Temp Perf Pwr:Usage/Cap| Memory-Usage | GPU-Util Compute M. |
| | | MIG M. |
| 0 NVIDIA GeForce ... Off | 00000000:01:00.0 On | N/A |
| 0% 36C P5 8W / 130W | 342MiB / 8192MiB | 5% Default |
| | | N/A |
(last bit of) clinfo:
ICD loader properties
ICD loader Name OpenCL ICD Loader
ICD loader Vendor OCL Icd free software
ICD loader Version 2.2.14
ICD loader Profile OpenCL 3.0
bikeaddict
Posts: 217 Joined: Sun May 03, 2020 1:20 am
Post
by bikeaddict » Mon Mar 06, 2023 5:54 pm
Install ocl-icd-devel (Fedora) or ocl-icd-opencl-dev (Ubuntu) or similar package.
threeqc
Post
by threeqc » Mon Mar 06, 2023 7:46 pm
bikeaddict wrote: ↑ Mon Mar 06, 2023 5:54 pm
This worked, thanks.
threeqc
Post
by threeqc » Tue Mar 07, 2023 1:24 am
Now it's doing this:
01:19:19:WU01:FS01:0x22:Error initializing CUDA: CUDA_ERROR_UNKNOWN (999) at /home/conda/feedstock_root/build_artifacts/openmm_1640541150081/work/platforms/cuda/src/CudaContext.cpp:139
I had to pause it briefly and then enter suspend mode (linux mint) and that broke the unit it spent several hours running. Then it got stuck downloading units and failing to run them. Now it just doesn't work at all.
clinfo says this now
So I guess I managed to nuke my system somehow. Great.
edit: After a reboot, clinfo works. F@H does not.
edit 2: It finds a "CUDA Device" and an "OpenCL Device", so I have no idea what's going wrong.
threeqc
Post
by threeqc » Tue Mar 28, 2023 10:54 pm
Bump
I'm still having this issue.
Posts: 2521 Joined: Mon Feb 16, 2009 4:12 am
Post
by JimboPalmer » Wed Mar 29, 2023 2:07 pm
Here is instructions on how to post a log so we know what the software thinks is happening.
viewtopic.php?p=327413&f=24#p327413
Usually the first 100 lines is enough to see the configuration.
threeqc
Post
by threeqc » Thu Mar 30, 2023 7:56 pm
JimboPalmer wrote: ↑ Wed Mar 29, 2023 2:07 pm
*********************** Log Started 2023-03-30T19:38:22Z ***********************
19:38:22:******************************* libFAH ********************************
19:38:22: Date: Oct 20 2020
19:38:22: Time: 20:36:39
19:38:22: Revision: 5ca109d295a6245e2a2f590b3d0085ad5e567aeb
19:38:22: Branch: master
19:38:22: Compiler: GNU 8.3.0
19:38:22: Options: -faligned-new -std=c++11 -fsigned-char -ffunction-sections
19:38:22: -fdata-sections -O3 -funroll-loops -fno-pie
19:38:22: Platform: linux2 5.8.0-1-amd64
19:38:22: Bits: 64
19:38:22: Mode: Release
19:38:22:****************************** FAHClient ******************************
19:38:22: Version: 7.6.21
19:38:22: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
19:38:22: Copyright: 2020 foldingathome.org
19:38:22: Homepage: https://foldingathome.org/
19:38:22: Time: 20:39:00
19:38:22: Revision: 6efbf0e138e22d3963e6a291f78dcb9c6422a278
19:38:22: Bits: 64
19:38:22: Args: --child /etc/fahclient/config.xml --run-as fahclient
19:38:22: --pid-file=/var/run/fahclient.pid --daemon
19:38:22: Config: /etc/fahclient/config.xml
19:38:22:******************************** CBang ********************************
19:38:22: Time: 18:37:59
19:38:22: Revision: 7e4ce85225d7eaeb775e87c31740181ca603de60
19:38:22: -fdata-sections -O3 -funroll-loops -fno-pie -fPIC
19:38:22: Bits: 64
19:38:22:******************************* System ********************************
19:38:22: CPU: 13th Gen Intel(R) Core(TM) i5-13600K
19:38:22: CPU ID: GenuineIntel Family 6 Model 183 Stepping 1
19:38:22: CPUs: 20
19:38:22: Memory: 15.42GiB
19:38:22: Free Memory: 14.38GiB
19:38:22: Threads: POSIX_THREADS
19:38:22: OS Version: 5.15
19:38:22: Has Battery: false
19:38:22: On Battery: false
19:38:22: UTC Offset: -4
19:38:22: PID: 1515
19:38:22: CWD: /var/lib/fahclient
19:38:22: OS: Linux 5.15.0-69-generic x86_64
19:38:22: OS Arch: AMD64
19:38:22: GPUs: 1
19:38:22: GPU 0: Bus:1 Slot:0 Func:0 NVIDIA:8 GA106 [Geforce RTX 3050]
19:38:22: CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:8.6 Driver:12.0
19:38:22:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:3.0 Driver:525.89
19:38:22:***********************************************************************
19:38:22:<config>
19:38:22: <!-- Client Control -->
19:38:22: <fold-anon v='true'/>
19:38:22:
19:38:22: <!-- Folding Slot Configuration -->
19:38:22: <gpu v='false'/>
19:38:22:
19:38:22: <!-- Network -->
19:38:22: <proxy v=':8080'/>
19:38:22:
19:38:22: <!-- Slot Control -->
19:38:22: <pause-on-start v='true'/>
19:38:22: <power v='MEDIUM'/>
19:38:22:
19:38:22: <!-- User Information -->
19:38:22: <passkey v='*****'/>
19:38:22: <team v='223518'/>
19:38:22: <user v='threeqc'/>
19:38:22:
19:38:22: <!-- Folding Slots -->
19:38:22: <slot id='0' type='CPU'/>
19:38:22:</config>
19:38:22:Trying to access database...
19:38:22:Successfully acquired database lock
19:38:22:FS00:Initialized folding slot 00: cpu:19
