Problems Uploading WU
Jack S
Post by Jack S »
I have been having problems with uploading WU's. Some will upload with no problem and others will not at all. At this time I have 3 in the queue which will not up load. 2 are 7-8 months old and 1 3 days. I have seen some comments on forced manual up load and mention of deleting old items from queue. How do I do those things? and any idea why up load won't work?
Thanks
Re: Up loading WU
Please post your FAHlog.txt ... it will help us if we can see what errors you're getting ...
Jack S
Re: Up loading WU
Post by Jack S »
OK, I'm new at this. How do I post the log file?
anandhanju
Re: Up loading WU
Post by anandhanju »
Copy the contents of the log file stored in your Folding folder and paste it into your post when replying. Then select the entire block of text you just pasted, hit the code button on the reply screen and voila! thats it.
The quick reply feature at the bottom of this page doesnt show the code buttons.
Jack S
Re: Up loading WU
Post by Jack S »
Boy, I sure hate to sound stupid, but I don't know how to copy & paste, or where to find the file. I know I can find the log file by right clicking the icon on the bar, is that it?
Thanks
Re: Up loading WU
Yes.
Press ctrl+a to select all.
Press ctrl+c to copy.
Press crtl+v to paste.
A little more information would be helpful. Which fah client? What OS, stuff like that. Thanks.
Jack S
Re: Problems Uploading WU
Post by Jack S »
Thanks for info, hope this works. OS is XP Pro SP3, folding 5.03
[18:58:07] Verified work/wudata_07.trr
[18:58:07] Verified work/wudata_07.xtc
[18:58:07] Completed 592012 out of 1000000 steps (59)
[18:58:09] - Couldn't send HTTP request to server
[18:58:09] + Could not connect to Work Server (results)
[18:58:09] (171.64.122.120:8080)
[18:58:09] - Error: Could not transmit unit 02 (completed December 4) to work server.
[18:58:09] + Attempting to send results
[19:00:13] - Couldn't send HTTP request to server
[19:00:13] + Could not connect to Work Server (results)
[19:00:13] (171.65.103.100:8080)
[19:00:13] Could not transmit unit 02 to Collection server; keeping in queue.
[19:00:13] + Attempting to send results
[19:00:34] - Couldn't send HTTP request to server
[19:00:34] + Could not connect to Work Server (results)
[19:00:34] (171.64.122.120:8080)
[19:00:34] - Error: Could not transmit unit 03 (completed December 15) to work server.
[19:00:34] + Attempting to send results
[19:01:08] Timer requesting checkpoint
[19:02:43] - Couldn't send HTTP request to server
[19:02:43] + Could not connect to Work Server (results)
[19:02:43] (171.65.103.100:8080)
[19:02:43] Could not transmit unit 03 to Collection server; keeping in queue.
[19:02:43] + Attempting to send results
[19:02:44] - Couldn't send HTTP request to server
[19:02:44] + Could not connect to Work Server (results)
[19:02:44] (171.64.65.65:8080)
[19:02:44] - Error: Could not transmit unit 04 (completed July 4) to work server.
[19:02:44] + Attempting to send results
[19:04:08] Timer requesting checkpoint
[19:06:06] - Server does not have record of this unit. Will try again later.
[19:06:06] Could not transmit unit 04 to Collection server; keeping in queue.
Jack S
Post by Jack S »
Since there has been no further info,I assume there no answer to the up load problem. How about my other questions, how do I delete the old items from the queue and do a manual up load?
Thanks
Jack
codysluder
Post by codysluder »
There is no manual uploading, although you might be able to send it to a teammate who may be able to upload it from their machine. (That would be a good test to see if the problem is in your machine or at Stanford.)
The client has a command line flag -delete N and you could use it three times, for N=2, N=3, and N=4. The wiki has detailed instructions about how to use command line flags.
Nobody has asked you to disable your firewall or security software and try uploading. That might be blocking your upload.
Jack S
Post by Jack S »
Can anyone tell me how to remove WU from the queue? These are old WU which will not upload.
codysluder
Two things: You need to read what I wrote (above) and you need to figure out why those WUs didn't upload when they were new.
1) Use the -delete N flag.
2) Have the "old WUs" expired? Have you turned OFF the setting for Use IE Settings?
