Cannot fold on Manjaro with 6900XT
GinGear
Post by GinGear »
packages installed:
https://aur.archlinux.org/packages/foldingathome
https://aur.archlinux.org/packages/fahcontrol-gtk3-git
https://aur.archlinux.org/packages/opencl-amd
07:40:37:WU02:FS01:Download complete
07:40:37:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:18213 run:4190 clone:1 gen:20 core:0x22 unit:0x0000000100000014000047250000105e
07:40:37:WU02:FS01:Starting
07:40:37:WU02:FS01:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/private/fah/cores/cores.foldingathome.org/lin/64bit/22-0.0.20/Core_22.fah/FahCore_22 -dir 02 -suffix 01 -version 706 -lifeline 2559 -checkpoint 15 -opencl-platform 0 -opencl-device 0 -gpu-vendor amd -gpu 0 -gpu-usage 100
07:40:37:WU02:FS01:Started FahCore on PID 2626
07:40:37:WU02:FS01:Core PID:2630
07:40:37:WU02:FS01:FahCore 0x22 started
07:40:38:WU02:FS01:0x22:*********************** Log Started 2023-02-26T07:40:37Z ***********************
07:40:38:WU02:FS01:0x22:*************************** Core22 Folding@home Core ***************************
07:40:38:WU02:FS01:0x22:       Core: Core22
07:40:38:WU02:FS01:0x22:       Type: 0x22
07:40:38:WU02:FS01:0x22:    Version: 0.0.20
07:40:38:WU02:FS01:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
07:40:38:WU02:FS01:0x22:  Copyright: 2020 foldingathome.org
07:40:38:WU02:FS01:0x22:   Homepage: https://foldingathome.org/
07:40:38:WU02:FS01:0x22:       Date: Jan 20 2022
07:40:38:WU02:FS01:0x22:       Time: 00:57:52
07:40:38:WU02:FS01:0x22:   Revision: 3f211b8a4346514edbff34e3cb1c0e0ec951373c
07:40:38:WU02:FS01:0x22:     Branch: HEAD
07:40:38:WU02:FS01:0x22:   Compiler: GNU 9.4.0
07:40:38:WU02:FS01:0x22:    Options: -faligned-new -std=c++11 -fsigned-char -ffunction-sections
07:40:38:WU02:FS01:0x22:             -fdata-sections -O3 -funroll-loops -fno-pie
07:40:38:WU02:FS01:0x22:             -DOPENMM_VERSION="\"7.7.0\""
07:40:38:WU02:FS01:0x22:   Platform: linux 5.11.0-1025-azure
07:40:38:WU02:FS01:0x22:       Bits: 64
07:40:38:WU02:FS01:0x22:       Mode: Release
07:40:38:WU02:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
07:40:38:WU02:FS01:0x22:             <peastman@stanford.edu>
07:40:38:WU02:FS01:0x22:       Args: -dir 02 -suffix 01 -version 706 -lifeline 2626 -checkpoint 15
07:40:38:WU02:FS01:0x22:             -opencl-platform 0 -opencl-device 0 -gpu-vendor amd -gpu 0
07:40:38:WU02:FS01:0x22:             -gpu-usage 100
07:40:38:WU02:FS01:0x22:************************************ libFAH ************************************
07:40:38:WU02:FS01:0x22:       Time: 00:57:22
07:40:38:WU02:FS01:0x22:   Revision: 9f4ad694e75c2350d4bb6b8b5b769ba27e483a2f
07:40:38:WU02:FS01:0x22:************************************ CBang *************************************
07:40:38:WU02:FS01:0x22:       Time: 00:57:00
07:40:38:WU02:FS01:0x22:   Revision: ab023d155b446906d55b0f6c9a1eedeea04f7a1a
07:40:38:WU02:FS01:0x22:             -fdata-sections -O3 -funroll-loops -fno-pie -fPIC
07:40:38:WU02:FS01:0x22:************************************ System ************************************
07:40:38:WU02:FS01:0x22:        CPU: AMD Ryzen 9 5950X 16-Core Processor
07:40:38:WU02:FS01:0x22:     CPU ID: AuthenticAMD Family 25 Model 33 Stepping 2
07:40:38:WU02:FS01:0x22:       CPUs: 32
07:40:38:WU02:FS01:0x22:     Memory: 62.71GiB
07:40:38:WU02:FS01:0x22:Free Memory: 58.17GiB
07:40:38:WU02:FS01:0x22:    Threads: POSIX_THREADS
07:40:38:WU02:FS01:0x22: OS Version: 6.1
07:40:38:WU02:FS01:0x22:Has Battery: false
07:40:38:WU02:FS01:0x22: On Battery: false
07:40:38:WU02:FS01:0x22: UTC Offset: -6
07:40:38:WU02:FS01:0x22:        PID: 2630
07:40:38:WU02:FS01:0x22:        CWD: /var/lib/private/fah/work
07:40:38:WU02:FS01:0x22:************************************ OpenMM ************************************
07:40:38:WU02:FS01:0x22:    Version: 7.7.0
07:40:38:WU02:FS01:0x22:********************************************************************************
07:40:38:WU02:FS01:0x22:Project: 18213 (Run 4190, Clone 1, Gen 20)
07:40:38:WU02:FS01:0x22:Reading tar file core.xml
07:40:38:WU02:FS01:0x22:Reading tar file integrator.xml
07:40:38:WU02:FS01:0x22:Reading tar file state.xml
07:40:38:WU02:FS01:0x22:Reading tar file system.xml
07:40:38:WU02:FS01:0x22:Digital signatures verified
07:40:38:WU02:FS01:0x22:Folding@home GPU Core22 Folding@home Core
07:40:38:WU02:FS01:0x22:Version 0.0.20
07:40:38:WU02:FS01:0x22:  Checkpoint write interval: 25000 steps (2%) [50 total]
07:40:38:WU02:FS01:0x22:  JSON viewer frame write interval: 12500 steps (1%) [100 total]
07:40:38:WU02:FS01:0x22:  XTC frame write interval: 20000 steps (1.6%) [62 total]
07:40:38:WU02:FS01:0x22:  Global context and integrator variables write interval: disabled
07:40:38:WU02:FS01:0x22:There are 2 platforms available.
07:40:38:WU02:FS01:0x22:Platform 0: Reference
07:40:38:WU02:FS01:0x22:Platform 1: CPU
07:40:38:WU02:FS01:0x22:opencl-device was set but OpenCL platform could not be found.
07:40:38:WU02:FS01:0x22:ERROR:126: Neither CUDA nor OpenCL is available.
07:40:38:WU02:FS01:0x22:Saving result file ../logfile_01.txt
07:40:38:WU02:FS01:0x22:Saving result file science.log
07:40:38:WU02:FS01:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
07:40:39:WARNING:WU02:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
07:40:39:WU02:FS01:Sending unit results: id:02 state:SEND error:FAULTY project:18213 run:4190 clone:1 gen:20 core:0x22 unit:0x0000000100000014000047250000105e
07:40:39:WU02:FS01:Uploading 2.04KiB to 206.223.170.146
07:40:39:WU02:FS01:Connecting to 206.223.170.146:8080
07:40:39:WU02:FS01:Upload complete
07:40:39:WU02:FS01:Server responded WORK_ACK (400)
07:40:39:WU02:FS01:Cleaning up
07:40:39:WU01:FS01:Connecting to assign1.foldingathome.org:80
07:40:39:WU01:FS01:Assigned to work server 129.32.209.202
07:40:39:WU01:FS01:Requesting new work unit for slot 01: gpu:14:0 Navi 21 [Radeon RX 6800/6800XT/6900XT] from 129.32.209.202
07:40:39:WU01:FS01:Connecting to 129.32.209.202:8080
07:40:40:WU01:FS01:Downloading 56.81MiB
07:40:41:WU01:FS01:Download complete
07:40:41:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:18448 run:2 clone:50 gen:711 core:0x22 unit:0x00000032000002c70000481000000002
07:40:41:WU01:FS01:Starting
07:40:41:WU01:FS01:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/private/fah/cores/cores.foldingathome.org/lin/64bit/22-0.0.20/Core_22.fah/FahCore_22 -dir 01 -suffix 01 -version 706 -lifeline 2559 -checkpoint 15 -opencl-platform 0 -opencl-device 0 -gpu-vendor amd -gpu 0 -gpu-usage 100
07:40:41:WU01:FS01:Started FahCore on PID 2633
07:40:41:WU01:FS01:Core PID:2637
07:40:41:WU01:FS01:FahCore 0x22 started
07:40:42:WARNING:WU01:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
07:40:42:WU01:FS01:Sending unit results: id:01 state:SEND error:FAULTY project:18448 run:2 clone:50 gen:711 core:0x22 unit:0x00000032000002c70000481000000002
07:40:42:WU01:FS01:Uploading 9.50KiB to 129.32.209.202
07:40:42:WU01:FS01:Connecting to 129.32.209.202:8080
07:40:42:WU01:FS01:Upload complete
07:40:42:WU01:FS01:Server responded WORK_ACK (400)
07:40:42:WU01:FS01:Cleaning up
07:40:42:WU02:FS01:Connecting to assign1.foldingathome.org:80
07:40:42:WU02:FS01:Assigned to work server 206.223.170.146
07:40:42:WU02:FS01:Requesting new work unit for slot 01: gpu:14:0 Navi 21 [Radeon RX 6800/6800XT/6900XT] from 206.223.170.146
07:40:42:WU02:FS01:Connecting to 206.223.170.146:8080
07:40:53:WU00:FS00:0xa8:Completed 110000 out of 250000 steps (44%)
07:40:53:WU02:FS01:Downloading 26.58MiB
07:40:57:WU02:FS01:Download complete
07:40:57:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:18213 run:4194 clone:1 gen:20 core:0x22 unit:0x00000001000000140000472500001062
07:40:57:WU02:FS01:Starting
07:40:57:WU02:FS01:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/private/fah/cores/cores.foldingathome.org/lin/64bit/22-0.0.20/Core_22.fah/FahCore_22 -dir 02 -suffix 01 -version 706 -lifeline 2559 -checkpoint 15 -opencl-platform 0 -opencl-device 0 -gpu-vendor amd -gpu 0 -gpu-usage 100
07:40:57:WU02:FS01:Started FahCore on PID 2640
07:40:57:WU02:FS01:Core PID:2644
07:40:57:WU02:FS01:FahCore 0x22 started
07:40:58:WU02:FS01:0x22:*********************** Log Started 2023-02-26T07:40:57Z ***********************
07:40:58:WU02:FS01:0x22:*************************** Core22 Folding@home Core ***************************
07:40:58:WU02:FS01:0x22:       Core: Core22
07:40:58:WU02:FS01:0x22:       Type: 0x22
07:40:58:WU02:FS01:0x22:    Version: 0.0.20
07:40:58:WU02:FS01:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
07:40:58:WU02:FS01:0x22:  Copyright: 2020 foldingathome.org
07:40:58:WU02:FS01:0x22:   Homepage: https://foldingathome.org/
07:40:58:WU02:FS01:0x22:       Date: Jan 20 2022
07:40:58:WU02:FS01:0x22:       Time: 00:57:52
07:40:58:WU02:FS01:0x22:   Revision: 3f211b8a4346514edbff34e3cb1c0e0ec951373c
07:40:58:WU02:FS01:0x22:     Branch: HEAD
07:40:58:WU02:FS01:0x22:   Compiler: GNU 9.4.0
07:40:58:WU02:FS01:0x22:    Options: -faligned-new -std=c++11 -fsigned-char -ffunction-sections
07:40:58:WU02:FS01:0x22:             -fdata-sections -O3 -funroll-loops -fno-pie
07:40:58:WU02:FS01:0x22:             -DOPENMM_VERSION="\"7.7.0\""
07:40:58:WU02:FS01:0x22:   Platform: linux 5.11.0-1025-azure
07:40:58:WU02:FS01:0x22:       Bits: 64
07:40:58:WU02:FS01:0x22:       Mode: Release
07:40:58:WU02:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
07:40:58:WU02:FS01:0x22:             <peastman@stanford.edu>
07:40:58:WU02:FS01:0x22:       Args: -dir 02 -suffix 01 -version 706 -lifeline 2640 -checkpoint 15
07:40:58:WU02:FS01:0x22:             -opencl-platform 0 -opencl-device 0 -gpu-vendor amd -gpu 0
07:40:58:WU02:FS01:0x22:             -gpu-usage 100
07:40:58:WU02:FS01:0x22:************************************ libFAH ************************************
07:40:58:WU02:FS01:0x22:       Time: 00:57:22
07:40:58:WU02:FS01:0x22:   Revision: 9f4ad694e75c2350d4bb6b8b5b769ba27e483a2f
07:40:58:WU02:FS01:0x22:************************************ CBang *************************************
07:40:58:WU02:FS01:0x22:       Time: 00:57:00
07:40:58:WU02:FS01:0x22:   Revision: ab023d155b446906d55b0f6c9a1eedeea04f7a1a
07:40:58:WU02:FS01:0x22:             -fdata-sections -O3 -funroll-loops -fno-pie -fPIC
07:40:58:WU02:FS01:0x22:************************************ System ************************************
07:40:58:WU02:FS01:0x22:        CPU: AMD Ryzen 9 5950X 16-Core Processor
07:40:58:WU02:FS01:0x22:     CPU ID: AuthenticAMD Family 25 Model 33 Stepping 2
07:40:58:WU02:FS01:0x22:       CPUs: 32
07:40:58:WU02:FS01:0x22:     Memory: 62.71GiB
07:40:58:WU02:FS01:0x22:Free Memory: 58.17GiB
07:40:58:WU02:FS01:0x22:    Threads: POSIX_THREADS
07:40:58:WU02:FS01:0x22: OS Version: 6.1
07:40:58:WU02:FS01:0x22:Has Battery: false
07:40:58:WU02:FS01:0x22: On Battery: false
07:40:58:WU02:FS01:0x22: UTC Offset: -6
07:40:58:WU02:FS01:0x22:        PID: 2644
07:40:58:WU02:FS01:0x22:        CWD: /var/lib/private/fah/work
07:40:58:WU02:FS01:0x22:************************************ OpenMM ************************************
07:40:58:WU02:FS01:0x22:    Version: 7.7.0
07:40:58:WU02:FS01:0x22:********************************************************************************
07:40:58:WU02:FS01:0x22:Project: 18213 (Run 4194, Clone 1, Gen 20)
07:40:58:WU02:FS01:0x22:Reading tar file core.xml
07:40:58:WU02:FS01:0x22:Reading tar file integrator.xml
07:40:58:WU02:FS01:0x22:Reading tar file state.xml
07:40:58:WU02:FS01:0x22:Reading tar file system.xml
07:40:58:WU02:FS01:0x22:Digital signatures verified
07:40:58:WU02:FS01:0x22:Folding@home GPU Core22 Folding@home Core
07:40:58:WU02:FS01:0x22:Version 0.0.20
07:40:58:WU02:FS01:0x22:  Checkpoint write interval: 25000 steps (2%) [50 total]
07:40:58:WU02:FS01:0x22:  JSON viewer frame write interval: 12500 steps (1%) [100 total]
07:40:58:WU02:FS01:0x22:  XTC frame write interval: 20000 steps (1.6%) [62 total]
07:40:58:WU02:FS01:0x22:  Global context and integrator variables write interval: disabled
07:40:58:WU02:FS01:0x22:There are 2 platforms available.
07:40:58:WU02:FS01:0x22:Platform 0: Reference
07:40:58:WU02:FS01:0x22:Platform 1: CPU
07:40:58:WU02:FS01:0x22:opencl-device was set but OpenCL platform could not be found.
07:40:58:WU02:FS01:0x22:ERROR:126: Neither CUDA nor OpenCL is available.
07:40:58:WU02:FS01:0x22:Saving result file ../logfile_01.txt
07:40:58:WU02:FS01:0x22:Saving result file science.log
07:40:58:WU02:FS01:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
07:40:59:WARNING:WU02:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
07:40:59:WU02:FS01:Sending unit results: id:02 state:SEND error:FAULTY project:18213 run:4194 clone:1 gen:20 core:0x22 unit:0x00000001000000140000472500001062
07:40:59:WU02:FS01:Uploading 2.04KiB to 206.223.170.146
07:40:59:WU02:FS01:Connecting to 206.223.170.146:8080
07:40:59:WU02:FS01:Upload complete
07:40:59:WU02:FS01:Server responded WORK_ACK (400)
07:40:59:WU02:FS01:Cleaning up
07:40:59:WU01:FS01:Connecting to assign1.foldingathome.org:80
07:40:59:WU01:FS01:Assigned to work server 206.223.170.146
07:40:59:WU01:FS01:Requesting new work unit for slot 01: gpu:14:0 Navi 21 [Radeon RX 6800/6800XT/6900XT] from 206.223.170.146
07:40:59:WU01:FS01:Connecting to 206.223.170.146:8080
07:41:10:WU01:FS01:Downloading 26.57MiB
07:41:12:WU01:FS01:Download complete
07:41:12:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:18213 run:24876 clone:1 gen:17 core:0x22 unit:0x0000000100000011000047250000612c
07:41:12:WU01:FS01:Starting
07:41:12:WU01:FS01:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/private/fah/cores/cores.foldingathome.org/lin/64bit/22-0.0.20/Core_22.fah/FahCore_22 -dir 01 -suffix 01 -version 706 -lifeline 2559 -checkpoint 15 -opencl-platform 0 -opencl-device 0 -gpu-vendor amd -gpu 0 -gpu-usage 100
07:41:12:WU01:FS01:Started FahCore on PID 2647
07:41:12:WU01:FS01:Core PID:2651
07:41:12:WU01:FS01:FahCore 0x22 started
07:41:13:WU01:FS01:0x22:*********************** Log Started 2023-02-26T07:41:12Z ***********************
07:41:13:WU01:FS01:0x22:*************************** Core22 Folding@home Core ***************************
07:41:13:WU01:FS01:0x22:       Core: Core22
07:41:13:WU01:FS01:0x22:       Type: 0x22
07:41:13:WU01:FS01:0x22:    Version: 0.0.20
07:41:13:WU01:FS01:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
07:41:13:WU01:FS01:0x22:  Copyright: 2020 foldingathome.org
07:41:13:WU01:FS01:0x22:   Homepage: https://foldingathome.org/
07:41:13:WU01:FS01:0x22:       Date: Jan 20 2022
07:41:13:WU01:FS01:0x22:       Time: 00:57:52
07:41:13:WU01:FS01:0x22:   Revision: 3f211b8a4346514edbff34e3cb1c0e0ec951373c
07:41:13:WU01:FS01:0x22:     Branch: HEAD
07:41:13:WU01:FS01:0x22:   Compiler: GNU 9.4.0
07:41:13:WU01:FS01:0x22:    Options: -faligned-new -std=c++11 -fsigned-char -ffunction-sections
07:41:13:WU01:FS01:0x22:             -fdata-sections -O3 -funroll-loops -fno-pie
07:41:13:WU01:FS01:0x22:             -DOPENMM_VERSION="\"7.7.0\""
07:41:13:WU01:FS01:0x22:   Platform: linux 5.11.0-1025-azure
07:41:13:WU01:FS01:0x22:       Bits: 64
07:41:13:WU01:FS01:0x22:       Mode: Release
07:41:13:WU01:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
07:41:13:WU01:FS01:0x22:             <peastman@stanford.edu>
07:41:13:WU01:FS01:0x22:       Args: -dir 01 -suffix 01 -version 706 -lifeline 2647 -checkpoint 15
07:41:13:WU01:FS01:0x22:             -opencl-platform 0 -opencl-device 0 -gpu-vendor amd -gpu 0
07:41:13:WU01:FS01:0x22:             -gpu-usage 100
07:41:13:WU01:FS01:0x22:************************************ libFAH ************************************
07:41:13:WU01:FS01:0x22:       Time: 00:57:22
07:41:13:WU01:FS01:0x22:   Revision: 9f4ad694e75c2350d4bb6b8b5b769ba27e483a2f
07:41:13:WU01:FS01:0x22:************************************ CBang *************************************
07:41:13:WU01:FS01:0x22:       Time: 00:57:00
07:41:13:WU01:FS01:0x22:   Revision: ab023d155b446906d55b0f6c9a1eedeea04f7a1a
07:41:13:WU01:FS01:0x22:             -fdata-sections -O3 -funroll-loops -fno-pie -fPIC
07:41:13:WU01:FS01:0x22:************************************ System ************************************
07:41:13:WU01:FS01:0x22:        CPU: AMD Ryzen 9 5950X 16-Core Processor
07:41:13:WU01:FS01:0x22:     CPU ID: AuthenticAMD Family 25 Model 33 Stepping 2
07:41:13:WU01:FS01:0x22:       CPUs: 32
07:41:13:WU01:FS01:0x22:     Memory: 62.71GiB
07:41:13:WU01:FS01:0x22:Free Memory: 58.16GiB
07:41:13:WU01:FS01:0x22:    Threads: POSIX_THREADS
07:41:13:WU01:FS01:0x22: OS Version: 6.1
07:41:13:WU01:FS01:0x22:Has Battery: false
07:41:13:WU01:FS01:0x22: On Battery: false
07:41:13:WU01:FS01:0x22: UTC Offset: -6
07:41:13:WU01:FS01:0x22:        PID: 2651
07:41:13:WU01:FS01:0x22:        CWD: /var/lib/private/fah/work
07:41:13:WU01:FS01:0x22:************************************ OpenMM ************************************
07:41:13:WU01:FS01:0x22:    Version: 7.7.0
07:41:13:WU01:FS01:0x22:********************************************************************************
07:41:13:WU01:FS01:0x22:Project: 18213 (Run 24876, Clone 1, Gen 17)
07:41:13:WU01:FS01:0x22:Reading tar file core.xml
07:41:13:WU01:FS01:0x22:Reading tar file integrator.xml
07:41:13:WU01:FS01:0x22:Reading tar file state.xml
07:41:13:WU01:FS01:0x22:Reading tar file system.xml
07:41:13:WU01:FS01:0x22:Digital signatures verified
07:41:13:WU01:FS01:0x22:Folding@home GPU Core22 Folding@home Core
07:41:13:WU01:FS01:0x22:Version 0.0.20
07:41:13:WU01:FS01:0x22:  Checkpoint write interval: 25000 steps (2%) [50 total]
07:41:13:WU01:FS01:0x22:  JSON viewer frame write interval: 12500 steps (1%) [100 total]
07:41:13:WU01:FS01:0x22:  XTC frame write interval: 20000 steps (1.6%) [62 total]
07:41:13:WU01:FS01:0x22:  Global context and integrator variables write interval: disabled
07:41:13:WU01:FS01:0x22:There are 2 platforms available.
07:41:13:WU01:FS01:0x22:Platform 0: Reference
07:41:13:WU01:FS01:0x22:Platform 1: CPU
07:41:13:WU01:FS01:0x22:opencl-device was set but OpenCL platform could not be found.
07:41:13:WU01:FS01:0x22:ERROR:126: Neither CUDA nor OpenCL is available.
07:41:13:WU01:FS01:0x22:Saving result file ../logfile_01.txt
07:41:13:WU01:FS01:0x22:Saving result file science.log
07:41:13:WU01:FS01:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
07:41:14:WARNING:WU01:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
07:41:14:WU01:FS01:Sending unit results: id:01 state:SEND error:FAULTY project:18213 run:24876 clone:1 gen:17 core:0x22 unit:0x0000000100000011000047250000612c
07:41:14:WU01:FS01:Uploading 2.04KiB to 206.223.170.146
07:41:14:WU01:FS01:Connecting to 206.223.170.146:8080
07:41:14:WU01:FS01:Upload complete
07:41:14:WU01:FS01:Server responded WORK_ACK (400)
07:41:14:WU01:FS01:Cleaning up
07:41:14:WU02:FS01:Connecting to assign1.foldingathome.org:80
07:41:14:WU02:FS01:Assigned to work server 206.223.170.146
07:41:14:WU02:FS01:Requesting new work unit for slot 01: gpu:14:0 Navi 21 [Radeon RX 6800/6800XT/6900XT] from 206.223.170.146
07:41:14:WU02:FS01:Connecting to 206.223.170.146:8080
07:41:25:WU02:FS01:Downloading 26.57MiB
07:41:28:WU02:FS01:Download complete
07:41:28:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:18213 run:19877 clone:1 gen:18 core:0x22 unit:0x00000001000000120000472500004da5
07:41:28:WU02:FS01:Starting
07:41:28:WU02:FS01:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/private/fah/cores/cores.foldingathome.org/lin/64bit/22-0.0.20/Core_22.fah/FahCore_22 -dir 02 -suffix 01 -version 706 -lifeline 2559 -checkpoint 15 -opencl-platform 0 -opencl-device 0 -gpu-vendor amd -gpu 0 -gpu-usage 100
07:41:28:WU02:FS01:Started FahCore on PID 2659
07:41:28:WU02:FS01:Core PID:2663
07:41:28:WU02:FS01:FahCore 0x22 started
07:41:28:WU02:FS01:0x22:*********************** Log Started 2023-02-26T07:41:28Z ***********************
07:41:28:WU02:FS01:0x22:*************************** Core22 Folding@home Core ***************************
07:41:28:WU02:FS01:0x22:       Core: Core22
07:41:28:WU02:FS01:0x22:       Type: 0x22
07:41:28:WU02:FS01:0x22:    Version: 0.0.20
07:41:28:WU02:FS01:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
07:41:28:WU02:FS01:0x22:  Copyright: 2020 foldingathome.org
07:41:28:WU02:FS01:0x22:   Homepage: https://foldingathome.org/
07:41:28:WU02:FS01:0x22:       Date: Jan 20 2022
07:41:28:WU02:FS01:0x22:       Time: 00:57:52
07:41:28:WU02:FS01:0x22:   Revision: 3f211b8a4346514edbff34e3cb1c0e0ec951373c
07:41:28:WU02:FS01:0x22:     Branch: HEAD
07:41:28:WU02:FS01:0x22:   Compiler: GNU 9.4.0
07:41:28:WU02:FS01:0x22:    Options: -faligned-new -std=c++11 -fsigned-char -ffunction-sections
07:41:28:WU02:FS01:0x22:             -fdata-sections -O3 -funroll-loops -fno-pie
07:41:28:WU02:FS01:0x22:             -DOPENMM_VERSION="\"7.7.0\""
07:41:28:WU02:FS01:0x22:   Platform: linux 5.11.0-1025-azure
07:41:28:WU02:FS01:0x22:       Bits: 64
07:41:28:WU02:FS01:0x22:       Mode: Release
07:41:28:WU02:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
07:41:28:WU02:FS01:0x22:             <peastman@stanford.edu>
07:41:28:WU02:FS01:0x22:       Args: -dir 02 -suffix 01 -version 706 -lifeline 2659 -checkpoint 15
07:41:28:WU02:FS01:0x22:             -opencl-platform 0 -opencl-device 0 -gpu-vendor amd -gpu 0
07:41:28:WU02:FS01:0x22:             -gpu-usage 100
07:41:28:WU02:FS01:0x22:************************************ libFAH ************************************
07:41:28:WU02:FS01:0x22:       Time: 00:57:22
07:41:28:WU02:FS01:0x22:   Revision: 9f4ad694e75c2350d4bb6b8b5b769ba27e483a2f
07:41:28:WU02:FS01:0x22:************************************ CBang *************************************
07:41:28:WU02:FS01:0x22:       Time: 00:57:00
07:41:28:WU02:FS01:0x22:   Revision: ab023d155b446906d55b0f6c9a1eedeea04f7a1a
07:41:28:WU02:FS01:0x22:             -fdata-sections -O3 -funroll-loops -fno-pie -fPIC
07:41:28:WU02:FS01:0x22:************************************ System ************************************
07:41:28:WU02:FS01:0x22:        CPU: AMD Ryzen 9 5950X 16-Core Processor
07:41:28:WU02:FS01:0x22:     CPU ID: AuthenticAMD Family 25 Model 33 Stepping 2
07:41:28:WU02:FS01:0x22:       CPUs: 32
07:41:28:WU02:FS01:0x22:     Memory: 62.71GiB
07:41:28:WU02:FS01:0x22:Free Memory: 58.16GiB
07:41:28:WU02:FS01:0x22:    Threads: POSIX_THREADS
07:41:28:WU02:FS01:0x22: OS Version: 6.1
07:41:28:WU02:FS01:0x22:Has Battery: false
07:41:28:WU02:FS01:0x22: On Battery: false
07:41:28:WU02:FS01:0x22: UTC Offset: -6
07:41:28:WU02:FS01:0x22:        PID: 2663
07:41:28:WU02:FS01:0x22:        CWD: /var/lib/private/fah/work
07:41:28:WU02:FS01:0x22:************************************ OpenMM ************************************
07:41:28:WU02:FS01:0x22:    Version: 7.7.0
07:41:28:WU02:FS01:0x22:********************************************************************************
07:41:28:WU02:FS01:0x22:Project: 18213 (Run 19877, Clone 1, Gen 18)
07:41:28:WU02:FS01:0x22:Reading tar file core.xml
07:41:28:WU02:FS01:0x22:Reading tar file integrator.xml
07:41:28:WU02:FS01:0x22:Reading tar file state.xml
07:41:28:WU02:FS01:0x22:Reading tar file system.xml
07:41:29:WU02:FS01:0x22:Digital signatures verified
07:41:29:WU02:FS01:0x22:Folding@home GPU Core22 Folding@home Core
07:41:29:WU02:FS01:0x22:Version 0.0.20
07:41:29:WU02:FS01:0x22:  Checkpoint write interval: 25000 steps (2%) [50 total]
07:41:29:WU02:FS01:0x22:  JSON viewer frame write interval: 12500 steps (1%) [100 total]
07:41:29:WU02:FS01:0x22:  XTC frame write interval: 20000 steps (1.6%) [62 total]
07:41:29:WU02:FS01:0x22:  Global context and integrator variables write interval: disabled
07:41:29:WU02:FS01:0x22:There are 2 platforms available.
07:41:29:WU02:FS01:0x22:Platform 0: Reference
07:41:29:WU02:FS01:0x22:Platform 1: CPU
07:41:29:WU02:FS01:0x22:opencl-device was set but OpenCL platform could not be found.
07:41:29:WU02:FS01:0x22:ERROR:126: Neither CUDA nor OpenCL is available.
07:41:29:WU02:FS01:0x22:Saving result file ../logfile_01.txt
07:41:29:WU02:FS01:0x22:Saving result file science.log
07:41:29:WU02:FS01:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
07:41:29:WARNING:WU02:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
07:41:29:WU02:FS01:Sending unit results: id:02 state:SEND error:FAULTY project:18213 run:19877 clone:1 gen:18 core:0x22 unit:0x00000001000000120000472500004da5
07:41:29:WU02:FS01:Uploading 2.04KiB to 206.223.170.146
07:41:29:WU02:FS01:Connecting to 206.223.170.146:8080
07:41:29:WU02:FS01:Upload complete
07:41:29:WU02:FS01:Server responded WORK_ACK (400)
07:41:29:WU02:FS01:Cleaning up
07:41:29:WU01:FS01:Connecting to assign1.foldingathome.org:80
07:41:30:WU01:FS01:Assigned to work server 129.32.209.202
07:41:30:WU01:FS01:Requesting new work unit for slot 01: gpu:14:0 Navi 21 [Radeon RX 6800/6800XT/6900XT] from 129.32.209.202
07:41:30:WU01:FS01:Connecting to 129.32.209.202:8080
07:41:30:WU01:FS01:Downloading 57.00MiB
07:41:32:WU01:FS01:Download complete
07:41:32:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:18448 run:11 clone:12 gen:895 core:0x22 unit:0x0000000c0000037f000048100000000b
07:41:32:WU01:FS01:Starting
07:41:32:WU01:FS01:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/private/fah/cores/cores.foldingathome.org/lin/64bit/22-0.0.20/Core_22.fah/FahCore_22 -dir 01 -suffix 01 -version 706 -lifeline 2559 -checkpoint 15 -opencl-platform 0 -opencl-device 0 -gpu-vendor amd -gpu 0 -gpu-usage 100
07:41:32:WU01:FS01:Started FahCore on PID 2666
07:41:32:WU01:FS01:Core PID:2670
07:41:32:WU01:FS01:FahCore 0x22 started
07:41:32:WARNING:WU01:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
07:41:32:WU01:FS01:Sending unit results: id:01 state:SEND error:FAULTY project:18448 run:11 clone:12 gen:895 core:0x22 unit:0x0000000c0000037f000048100000000b
07:41:32:WU01:FS01:Uploading 9.50KiB to 129.32.209.202
07:41:32:WU01:FS01:Connecting to 129.32.209.202:8080
07:41:32:WU01:FS01:Upload complete
07:41:33:WU01:FS01:Server responded WORK_ACK (400)
07:41:33:WU01:FS01:Cleaning up
07:41:33:WU02:FS01:Connecting to assign1.foldingathome.org:80
07:41:33:WU02:FS01:Assigned to work server 34.72.228.44
07:41:33:WU02:FS01:Requesting new work unit for slot 01: gpu:14:0 Navi 21 [Radeon RX 6800/6800XT/6900XT] from 34.72.228.44
07:41:33:WU02:FS01:Connecting to 34.72.228.44:8080
07:41:33:WU02:FS01:Downloading 5.74MiB
07:41:34:WU02:FS01:Download complete
07:41:34:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:18723 run:38 clone:16 gen:15 core:0x22 unit:0x000000100000000f0000492300000026
07:41:34:WU02:FS01:Starting
07:41:34:WU02:FS01:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/private/fah/cores/cores.foldingathome.org/lin/64bit/22-0.0.20/Core_22.fah/FahCore_22 -dir 02 -suffix 01 -version 706 -lifeline 2559 -checkpoint 15 -opencl-platform 0 -opencl-device 0 -gpu-vendor amd -gpu 0 -gpu-usage 100
07:41:34:WU02:FS01:Started FahCore on PID 2673
07:41:34:WU02:FS01:Core PID:2677
07:41:34:WU02:FS01:FahCore 0x22 started
07:41:34:WARNING:WU02:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
07:41:34:WU02:FS01:Sending unit results: id:02 state:SEND error:FAULTY project:18723 run:38 clone:16 gen:15 core:0x22 unit:0x000000100000000f0000492300000026
07:41:34:WU02:FS01:Uploading 9.50KiB to 34.72.228.44
07:41:34:WU02:FS01:Connecting to 34.72.228.44:8080
07:41:34:WU02:FS01:Upload complete
07:41:34:WU02:FS01:Server responded WORK_ACK (400)
07:41:34:WU02:FS01:Cleaning up
07:41:34:WU01:FS01:Connecting to assign1.foldingathome.org:80
07:41:35:WU01:FS01:Assigned to work server 206.223.170.146
07:41:35:WU01:FS01:Requesting new work unit for slot 01: gpu:14:0 Navi 21 [Radeon RX 6800/6800XT/6900XT] from 206.223.170.146
07:41:35:WU01:FS01:Connecting to 206.223.170.146:8080
07:41:35:WU00:FS00:0xa8:Completed 112500 out of 250000 steps (45%)
07:41:46:WU01:FS01:Downloading 26.58MiB
07:41:49:WU01:FS01:Download complete
07:41:49:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:18213 run:6097 clone:1 gen:19 core:0x22 unit:0x000000010000001300004725000017d1
07:41:49:WU01:FS01:Starting
07:41:49:WU01:FS01:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/private/fah/cores/cores.foldingathome.org/lin/64bit/22-0.0.20/Core_22.fah/FahCore_22 -dir 01 -suffix 01 -version 706 -lifeline 2559 -checkpoint 15 -opencl-platform 0 -opencl-device 0 -gpu-vendor amd -gpu 0 -gpu-usage 100
07:41:49:WU01:FS01:Started FahCore on PID 2685
07:41:49:WU01:FS01:Core PID:2689
07:41:49:WU01:FS01:FahCore 0x22 started
07:41:49:WU01:FS01:0x22:*********************** Log Started 2023-02-26T07:41:49Z ***********************
07:41:49:WU01:FS01:0x22:*************************** Core22 Folding@home Core ***************************
07:41:49:WU01:FS01:0x22:       Core: Core22
07:41:49:WU01:FS01:0x22:       Type: 0x22
07:41:49:WU01:FS01:0x22:    Version: 0.0.20
07:41:49:WU01:FS01:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
07:41:49:WU01:FS01:0x22:  Copyright: 2020 foldingathome.org
07:41:49:WU01:FS01:0x22:   Homepage: https://foldingathome.org/
07:41:49:WU01:FS01:0x22:       Date: Jan 20 2022
07:41:49:WU01:FS01:0x22:       Time: 00:57:52
07:41:49:WU01:FS01:0x22:   Revision: 3f211b8a4346514edbff34e3cb1c0e0ec951373c
07:41:49:WU01:FS01:0x22:     Branch: HEAD
07:41:49:WU01:FS01:0x22:   Compiler: GNU 9.4.0
07:41:49:WU01:FS01:0x22:    Options: -faligned-new -std=c++11 -fsigned-char -ffunction-sections
07:41:49:WU01:FS01:0x22:             -fdata-sections -O3 -funroll-loops -fno-pie
07:41:49:WU01:FS01:0x22:             -DOPENMM_VERSION="\"7.7.0\""
07:41:49:WU01:FS01:0x22:   Platform: linux 5.11.0-1025-azure
07:41:49:WU01:FS01:0x22:       Bits: 64
07:41:49:WU01:FS01:0x22:       Mode: Release
07:41:49:WU01:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
07:41:49:WU01:FS01:0x22:             <peastman@stanford.edu>
07:41:49:WU01:FS01:0x22:       Args: -dir 01 -suffix 01 -version 706 -lifeline 2685 -checkpoint 15
07:41:49:WU01:FS01:0x22:             -opencl-platform 0 -opencl-device 0 -gpu-vendor amd -gpu 0
07:41:49:WU01:FS01:0x22:             -gpu-usage 100
07:41:49:WU01:FS01:0x22:************************************ libFAH ************************************
07:41:49:WU01:FS01:0x22:       Time: 00:57:22
07:41:49:WU01:FS01:0x22:   Revision: 9f4ad694e75c2350d4bb6b8b5b769ba27e483a2f
07:41:49:WU01:FS01:0x22:************************************ CBang *************************************
07:41:49:WU01:FS01:0x22:       Time: 00:57:00
07:41:49:WU01:FS01:0x22:   Revision: ab023d155b446906d55b0f6c9a1eedeea04f7a1a
07:41:49:WU01:FS01:0x22:             -fdata-sections -O3 -funroll-loops -fno-pie -fPIC
07:41:49:WU01:FS01:0x22:************************************ System ************************************
07:41:49:WU01:FS01:0x22:        CPU: AMD Ryzen 9 5950X 16-Core Processor
07:41:49:WU01:FS01:0x22:     CPU ID: AuthenticAMD Family 25 Model 33 Stepping 2
07:41:49:WU01:FS01:0x22:       CPUs: 32
07:41:49:WU01:FS01:0x22:     Memory: 62.71GiB
07:41:49:WU01:FS01:0x22:Free Memory: 58.13GiB
07:41:49:WU01:FS01:0x22:    Threads: POSIX_THREADS
07:41:49:WU01:FS01:0x22: OS Version: 6.1
07:41:49:WU01:FS01:0x22:Has Battery: false
07:41:49:WU01:FS01:0x22: On Battery: false
07:41:49:WU01:FS01:0x22: UTC Offset: -6
07:41:49:WU01:FS01:0x22:        PID: 2689
07:41:49:WU01:FS01:0x22:        CWD: /var/lib/private/fah/work
07:41:49:WU01:FS01:0x22:************************************ OpenMM ************************************
07:41:49:WU01:FS01:0x22:    Version: 7.7.0
07:41:49:WU01:FS01:0x22:********************************************************************************
07:41:49:WU01:FS01:0x22:Project: 18213 (Run 6097, Clone 1, Gen 19)
07:41:49:WU01:FS01:0x22:Reading tar file core.xml
07:41:49:WU01:FS01:0x22:Reading tar file integrator.xml
07:41:49:WU01:FS01:0x22:Reading tar file state.xml
07:41:50:WU01:FS01:0x22:Reading tar file system.xml
07:41:50:WU01:FS01:0x22:Digital signatures verified
07:41:50:WU01:FS01:0x22:Folding@home GPU Core22 Folding@home Core
07:41:50:WU01:FS01:0x22:Version 0.0.20
07:41:50:WU01:FS01:0x22:  Checkpoint write interval: 25000 steps (2%) [50 total]
07:41:50:WU01:FS01:0x22:  JSON viewer frame write interval: 12500 steps (1%) [100 total]
07:41:50:WU01:FS01:0x22:  XTC frame write interval: 20000 steps (1.6%) [62 total]
07:41:50:WU01:FS01:0x22:  Global context and integrator variables write interval: disabled
07:41:50:WU01:FS01:0x22:There are 2 platforms available.
07:41:50:WU01:FS01:0x22:Platform 0: Reference
07:41:50:WU01:FS01:0x22:Platform 1: CPU
07:41:50:WU01:FS01:0x22:opencl-device was set but OpenCL platform could not be found.
07:41:50:WU01:FS01:0x22:ERROR:126: Neither CUDA nor OpenCL is available.
07:41:50:WU01:FS01:0x22:Saving result file ../logfile_01.txt
07:41:50:WU01:FS01:0x22:Saving result file science.log
07:41:50:WU01:FS01:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
07:41:50:WARNING:WU01:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
07:41:50:WU01:FS01:Sending unit results: id:01 state:SEND error:FAULTY project:18213 run:6097 clone:1 gen:19 core:0x22 unit:0x000000010000001300004725000017d1
07:41:50:WU01:FS01:Uploading 2.04KiB to 206.223.170.146
07:41:50:WU01:FS01:Connecting to 206.223.170.146:8080
07:41:51:WU01:FS01:Upload complete
07:41:51:WU01:FS01:Server responded WORK_ACK (400)
07:41:51:WU01:FS01:Cleaning up
07:41:51:WU02:FS01:Connecting to assign1.foldingathome.org:80
07:41:51:WU02:FS01:Assigned to work server 128.174.73.78
07:41:51:WU02:FS01:Requesting new work unit for slot 01: gpu:14:0 Navi 21 [Radeon RX 6800/6800XT/6900XT] from 128.174.73.78
07:41:51:WU02:FS01:Connecting to 128.174.73.78:8080
07:41:58:WU02:FS01:Downloading 20.06MiB
07:41:58:WU02:FS01:Download complete
07:41:58:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:19329 run:0 clone:41 gen:28 core:0x22 unit:0x000000290000001c00004b8100000000
07:41:58:WU02:FS01:Starting
07:41:58:WU02:FS01:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/private/fah/cores/cores.foldingathome.org/lin/64bit/22-0.0.20/Core_22.fah/FahCore_22 -dir 02 -suffix 01 -version 706 -lifeline 2559 -checkpoint 15 -opencl-platform 0 -opencl-device 0 -gpu-vendor amd -gpu 0 -gpu-usage 100
07:41:58:WU02:FS01:Started FahCore on PID 2693
07:41:58:WU02:FS01:Core PID:2697
07:41:58:WU02:FS01:FahCore 0x22 started
07:41:59:WU02:FS01:0x22:*********************** Log Started 2023-02-26T07:41:58Z ***********************
07:41:59:WU02:FS01:0x22:*************************** Core22 Folding@home Core ***************************
07:41:59:WU02:FS01:0x22:       Core: Core22
07:41:59:WU02:FS01:0x22:       Type: 0x22
07:41:59:WU02:FS01:0x22:    Version: 0.0.20
07:41:59:WU02:FS01:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
07:41:59:WU02:FS01:0x22:  Copyright: 2020 foldingathome.org
07:41:59:WU02:FS01:0x22:   Homepage: https://foldingathome.org/
07:41:59:WU02:FS01:0x22:       Date: Jan 20 2022
07:41:59:WU02:FS01:0x22:       Time: 00:57:52
07:41:59:WU02:FS01:0x22:   Revision: 3f211b8a4346514edbff34e3cb1c0e0ec951373c
07:41:59:WU02:FS01:0x22:     Branch: HEAD
07:41:59:WU02:FS01:0x22:   Compiler: GNU 9.4.0
07:41:59:WU02:FS01:0x22:    Options: -faligned-new -std=c++11 -fsigned-char -ffunction-sections
07:41:59:WU02:FS01:0x22:             -fdata-sections -O3 -funroll-loops -fno-pie
07:41:59:WU02:FS01:0x22:             -DOPENMM_VERSION="\"7.7.0\""
07:41:59:WU02:FS01:0x22:   Platform: linux 5.11.0-1025-azure
07:41:59:WU02:FS01:0x22:       Bits: 64
07:41:59:WU02:FS01:0x22:       Mode: Release
07:41:59:WU02:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
07:41:59:WU02:FS01:0x22:             <peastman@stanford.edu>
07:41:59:WU02:FS01:0x22:       Args: -dir 02 -suffix 01 -version 706 -lifeline 2693 -checkpoint 15
07:41:59:WU02:FS01:0x22:             -opencl-platform 0 -opencl-device 0 -gpu-vendor amd -gpu 0
07:41:59:WU02:FS01:0x22:             -gpu-usage 100
07:41:59:WU02:FS01:0x22:************************************ libFAH ************************************
07:41:59:WU02:FS01:0x22:       Time: 00:57:22
07:41:59:WU02:FS01:0x22:   Revision: 9f4ad694e75c2350d4bb6b8b5b769ba27e483a2f
07:41:59:WU02:FS01:0x22:************************************ CBang *************************************
07:41:59:WU02:FS01:0x22:       Time: 00:57:00
07:41:59:WU02:FS01:0x22:   Revision: ab023d155b446906d55b0f6c9a1eedeea04f7a1a
07:41:59:WU02:FS01:0x22:             -fdata-sections -O3 -funroll-loops -fno-pie -fPIC
07:41:59:WU02:FS01:0x22:************************************ System ************************************
07:41:59:WU02:FS01:0x22:        CPU: AMD Ryzen 9 5950X 16-Core Processor
07:41:59:WU02:FS01:0x22:     CPU ID: AuthenticAMD Family 25 Model 33 Stepping 2
07:41:59:WU02:FS01:0x22:       CPUs: 32
07:41:59:WU02:FS01:0x22:     Memory: 62.71GiB
07:41:59:WU02:FS01:0x22:Free Memory: 58.10GiB
07:41:59:WU02:FS01:0x22:    Threads: POSIX_THREADS
07:41:59:WU02:FS01:0x22: OS Version: 6.1
07:41:59:WU02:FS01:0x22:Has Battery: false
07:41:59:WU02:FS01:0x22: On Battery: false
07:41:59:WU02:FS01:0x22: UTC Offset: -6
07:41:59:WU02:FS01:0x22:        PID: 2697
07:41:59:WU02:FS01:0x22:        CWD: /var/lib/private/fah/work
07:41:59:WU02:FS01:0x22:************************************ OpenMM ************************************
07:41:59:WU02:FS01:0x22:    Version: 7.7.0
07:41:59:WU02:FS01:0x22:********************************************************************************
07:41:59:WU02:FS01:0x22:Project: 19329 (Run 0, Clone 41, Gen 28)
07:41:59:WU02:FS01:0x22:Reading tar file core.xml
07:41:59:WU02:FS01:0x22:Reading tar file integrator.xml
07:41:59:WU02:FS01:0x22:Reading tar file state.xml
07:41:59:WU02:FS01:0x22:Reading tar file system.xml
07:41:59:WU02:FS01:0x22:Digital signatures verified
07:41:59:WU02:FS01:0x22:Folding@home GPU Core22 Folding@home Core
07:41:59:WU02:FS01:0x22:Version 0.0.20
07:41:59:WU02:FS01:0x22:  Checkpoint write interval: 50000 steps (5%) [20 total]
07:41:59:WU02:FS01:0x22:  JSON viewer frame write interval: 10000 steps (1%) [100 total]
07:41:59:WU02:FS01:0x22:  XTC frame write interval: 25000 steps (2.5%) [40 total]
07:41:59:WU02:FS01:0x22:  Global context and integrator variables write interval: disabled
07:41:59:WU02:FS01:0x22:There are 2 platforms available.
07:41:59:WU02:FS01:0x22:Platform 0: Reference
07:41:59:WU02:FS01:0x22:Platform 1: CPU
07:41:59:WU02:FS01:0x22:opencl-device was set but OpenCL platform could not be found.
07:41:59:WU02:FS01:0x22:ERROR:126: Neither CUDA nor OpenCL is available.
07:41:59:WU02:FS01:0x22:Saving result file ../logfile_01.txt
07:41:59:WU02:FS01:0x22:Saving result file science.log
07:41:59:WU02:FS01:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
07:42:00:WARNING:WU02:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
07:42:00:WU02:FS01:Sending unit results: id:02 state:SEND error:FAULTY project:19329 run:0 clone:41 gen:28 core:0x22 unit:0x000000290000001c00004b8100000000
07:42:00:WU02:FS01:Uploading 2.04KiB to 128.174.73.78
07:42:00:WU02:FS01:Connecting to 128.174.73.78:8080
07:42:00:WU02:FS01:Upload complete
07:42:00:WU02:FS01:Server responded WORK_ACK (400)
07:42:00:WU02:FS01:Cleaning up
07:42:19:WU00:FS00:0xa8:Completed 115000 out of 250000 steps (46%)
07:43:03:WU00:FS00:0xa8:Completed 117500 out of 250000 steps (47%)
07:43:49:WU00:FS00:0xa8:Completed 120000 out of 250000 steps (48%)
Can someone help me with this? I would like to fold with my gpu.
distant_thunder_89
Re: Cannot fold on Manjaro with 6900XT
Post by distant_thunder_89 »
See this, it resolved the same problem as yours with my RX 6800 on Manjaro (platform OpenCL not found):
viewtopic.php?p=358294
I have rocm-opencl-runtime installed from official repository, not opencl-amd. Note that I had to drop my overclock to 2450 from 2500 to be able to fold, otherwise the GPU would keep tripping. With a 125W limit I am about 2.2 Mil PPD.
EDIT: originally posted the wrong link to a 6700 XT discussion, the one with the solution is a 6750 XT one.
GinGear
Post by GinGear »
I am gonna be honest, I'm not that savvy with Linux as I don't use it that often (as apparent from my extremely large gap in reply-time); but I don't have either of those folders mentioned in that solution.
as you can see here, it looks like everything is contained in the binary and service; unless they were talking about replacing the file when building fah?
Or should I run it as a snap, or docker, and that will let me edit said file and fold using my gpu?
tchiers
Post by tchiers »
Looks like https://aur.archlinux.org/packages/foldingathome uses
/var/lib/fah/cores/cores.foldingathome.org/ ...
and
/usr/lib/libstdc++.so.6
so just slightly different locations
Jotunn
Post by Jotunn »
tchiers wrote: Mon Mar 20, 2023 3:06 am Looks like https://aur.archlinux.org/packages/foldingathome uses
and
I have also discovered that it can be found in /var/lib/private/fah/cores/...
To do this in this situation, which I found myself in, you will need the ability to open a root terminal window. If you have KDE, there is a Dolphin Service menu called Root Actions Service Menu that allows opening a terminal window as root. Go from there. Also note that I am running in base Arch, with mesa-git and opencl-amd. F@H didn't seem to like rocm-opencl-runtime.
Post by muziqaz »
This is an issue with old libstdc++ bundled with fahcore. There is a new version in the works which will have updated library.
FAH Omega tester
