Error 125 on an RX 580
saltspect
Post by saltspect »
Computer specs: intel i3 12100 4 cores 8 threads 3.3 GHz (has internal gpu that I suspect is causing issues), 32 gb of ram, RX 580 graphics card with latest drivers installed (version 22.20.29.10-221130a-387206C-AMD-Software-Adrenalin-Edition, says it has OpenCL API 2.0 support)
Network: wireless (not having any issues)
OS: Windows 11 version 22H2
Stable, not overclocked
Software: Folding@home client version 7.6.21
WU details: just using the defaults, nothing in beta
I believe that the OpenCL information for my internal gpu is causing issues for my discrete graphics card (RX580). I may be completely wrong about this, as I have tried to troubleshoot for the last few hours on my own by scouring anything I can find regarding drivers, the config file, slot options, client options, and core options. Nothing has made it better so I deleted everything, installed it fresh, and ran it to generate a log file. The only alteration was to delete the cpu slot to avoid muddying the log file (I don't want to use it for this anyways). The log file is below. I am going to sleep off the stress of not understanding this before I come back so I apologize if I don't try out what is suggested in a timely manner. If this is a stupid question or the solution is simple please express as such with the best emoticons you can. Thank you in advance! :biggrin: (-.-)zzZZ
*********************** Log Started 2023-02-18T06:59:54Z ***********************
06:59:54:******************************* libFAH ********************************
06:59:54:           Date: Oct 20 2020
06:59:54:           Time: 13:36:55
06:59:54:       Revision: 5ca109d295a6245e2a2f590b3d0085ad5e567aeb
06:59:54:         Branch: master
06:59:54:       Compiler: Visual C++ 2015
06:59:54:        Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
06:59:54:       Platform: win32 10
06:59:54:           Bits: 32
06:59:54:           Mode: Release
06:59:54:****************************** FAHClient ******************************
06:59:54:        Version: 7.6.21
06:59:54:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
06:59:54:      Copyright: 2020 foldingathome.org
06:59:54:       Homepage: https://foldingathome.org/
06:59:54:           Time: 13:41:04
06:59:54:       Revision: 6efbf0e138e22d3963e6a291f78dcb9c6422a278
06:59:54:           Bits: 32
06:59:54:           Args: --open-web-control
06:59:54:         Config: C:\ProgramData\FAHClient\config.xml
06:59:54:******************************** CBang ********************************
06:59:54:           Time: 11:36:18
06:59:54:       Revision: 7e4ce85225d7eaeb775e87c31740181ca603de60
06:59:54:           Bits: 32
06:59:54:******************************* System ********************************
06:59:54:            CPU: 12th Gen Intel(R) Core(TM) i3-12100
06:59:54:         CPU ID: GenuineIntel Family 6 Model 151 Stepping 5
06:59:54:           CPUs: 8
06:59:54:         Memory: 31.75GiB
06:59:54:    Free Memory: 25.97GiB
06:59:54:        Threads: WINDOWS_THREADS
06:59:54:     OS Version: 6.2
06:59:54:    Has Battery: false
06:59:54:     On Battery: false
06:59:54:     UTC Offset: -6
06:59:54:            PID: 1812
06:59:54:            CWD: C:\ProgramData\FAHClient
06:59:54:  Win32 Service: false
06:59:54:             OS: Windows 10 Home
06:59:54:        OS Arch: AMD64
06:59:54:           GPUs: 1
06:59:54:          GPU 0: Bus:1 Slot:0 Func:0 AMD:4 Ellesmere XT [RX 470/480/570/580/590]
06:59:54:           CUDA: Not detected: Failed to open dynamic library 'nvcuda.dll': The
06:59:54:                 specified module could not be found.
06:59:54:
06:59:54:OpenCL Device 0: Platform:0 Device:0 Bus:NA Slot:NA Compute:3.0 Driver:31.0
06:59:54:OpenCL Device 1: Platform:1 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:3444.0
06:59:54:***********************************************************************
06:59:54:<config>
06:59:54:  <!-- Network -->
06:59:54:  <proxy v=':8080'/>
06:59:54:
06:59:54:  <!-- Folding Slots -->
06:59:54:  <slot id='1' type='GPU'>
06:59:54:    <pci-bus v='1'/>
06:59:54:    <pci-slot v='0'/>
06:59:54:  </slot>
06:59:54:</config>
06:59:54:Trying to access database...
06:59:54:Successfully acquired database lock
06:59:54:FS01:Initialized folding slot 01: gpu:1:0 Ellesmere XT [RX 470/480/570/580/590]
06:59:54:WU01:FS01:Starting
06:59:54:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.20/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 706 -lifeline 1812 -checkpoint 15 -opencl-platform 1 -opencl-device 0 -gpu-vendor amd -gpu 0 -gpu-usage 100
06:59:54:WU01:FS01:Started FahCore on PID 5772
06:59:54:WU01:FS01:Core PID:3364
06:59:54:WU01:FS01:FahCore 0x22 started
06:59:54:WU01:FS01:0x22:*********************** Log Started 2023-02-18T06:59:54Z ***********************
06:59:54:WU01:FS01:0x22:*************************** Core22 Folding@home Core ***************************
06:59:54:WU01:FS01:0x22:       Core: Core22
06:59:54:WU01:FS01:0x22:       Type: 0x22
06:59:54:WU01:FS01:0x22:    Version: 0.0.20
06:59:54:WU01:FS01:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
06:59:54:WU01:FS01:0x22:  Copyright: 2020 foldingathome.org
06:59:54:WU01:FS01:0x22:   Homepage: https://foldingathome.org/
06:59:54:WU01:FS01:0x22:       Date: Jan 20 2022
06:59:54:WU01:FS01:0x22:       Time: 01:15:36
06:59:54:WU01:FS01:0x22:   Revision: 3f211b8a4346514edbff34e3cb1c0e0ec951373c
06:59:54:WU01:FS01:0x22:     Branch: HEAD
06:59:54:WU01:FS01:0x22:   Compiler: Visual C++
06:59:54:WU01:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
06:59:54:WU01:FS01:0x22:             -DOPENMM_VERSION="\"7.7.0\""
06:59:54:WU01:FS01:0x22:   Platform: win32 10
06:59:54:WU01:FS01:0x22:       Bits: 64
06:59:54:WU01:FS01:0x22:       Mode: Release
06:59:54:WU01:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
06:59:54:WU01:FS01:0x22:             <peastman@stanford.edu>
06:59:54:WU01:FS01:0x22:       Args: -dir 01 -suffix 01 -version 706 -lifeline 5772 -checkpoint 15
06:59:54:WU01:FS01:0x22:             -opencl-platform 1 -opencl-device 0 -gpu-vendor amd -gpu 0
06:59:54:WU01:FS01:0x22:             -gpu-usage 100
06:59:54:WU01:FS01:0x22:************************************ libFAH ************************************
06:59:54:WU01:FS01:0x22:       Time: 01:14:17
06:59:54:WU01:FS01:0x22:   Revision: 9f4ad694e75c2350d4bb6b8b5b769ba27e483a2f
06:59:54:WU01:FS01:0x22:************************************ CBang *************************************
06:59:54:WU01:FS01:0x22:       Time: 01:13:20
06:59:54:WU01:FS01:0x22:   Revision: ab023d155b446906d55b0f6c9a1eedeea04f7a1a
06:59:54:WU01:FS01:0x22:************************************ System ************************************
06:59:54:WU01:FS01:0x22:        CPU: 12th Gen Intel(R) Core(TM) i3-12100
06:59:54:WU01:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 151 Stepping 5
06:59:54:WU01:FS01:0x22:       CPUs: 8
06:59:54:WU01:FS01:0x22:     Memory: 31.75GiB
06:59:54:WU01:FS01:0x22:Free Memory: 25.93GiB
06:59:54:WU01:FS01:0x22:    Threads: WINDOWS_THREADS
06:59:54:WU01:FS01:0x22: OS Version: 6.2
06:59:54:WU01:FS01:0x22:Has Battery: false
06:59:54:WU01:FS01:0x22: On Battery: false
06:59:54:WU01:FS01:0x22: UTC Offset: -6
06:59:54:WU01:FS01:0x22:        PID: 3364
06:59:54:WU01:FS01:0x22:        CWD: C:\ProgramData\FAHClient\work
06:59:54:WU01:FS01:0x22:************************************ OpenMM ************************************
06:59:54:WU01:FS01:0x22:    Version: 7.7.0
06:59:54:WU01:FS01:0x22:********************************************************************************
06:59:54:WU01:FS01:0x22:Project: 18719 (Run 0, Clone 1310, Gen 8)
06:59:54:WU01:FS01:0x22:Digital signatures verified
06:59:54:WU01:FS01:0x22:Folding@home GPU Core22 Folding@home Core
06:59:54:WU01:FS01:0x22:Version 0.0.20
06:59:54:WU01:FS01:0x22:  Checkpoint write interval: 250000 steps (5%) [20 total]
06:59:54:WU01:FS01:0x22:  JSON viewer frame write interval: 50000 steps (1%) [100 total]
06:59:54:WU01:FS01:0x22:  XTC frame write interval: 50000 steps (1%) [100 total]
06:59:54:WU01:FS01:0x22:  Global context and integrator variables write interval: disabled
06:59:54:WU01:FS01:0x22:There are 3 platforms available.
06:59:54:WU01:FS01:0x22:Platform 0: Reference
06:59:54:WU01:FS01:0x22:Platform 1: CPU
06:59:54:WU01:FS01:0x22:Platform 2: OpenCL
06:59:54:WU01:FS01:0x22:  opencl-device 0 specified
06:59:55:4:127.0.0.1:New Web session
06:59:59:WU01:FS01:0x22:Attempting to create OpenCL context:
06:59:59:WU01:FS01:0x22:  Configuring platform OpenCL
06:59:59:WU01:FS01:0x22:Failed to create OpenCL context:
06:59:59:WU01:FS01:0x22:No compatible OpenCL platform is available
06:59:59:WU01:FS01:0x22:ERROR:125: Failed to create a GPU-enabled OpenMM Context.
06:59:59:WU01:FS01:0x22:Saving result file ..\logfile_01.txt
06:59:59:WU01:FS01:0x22:Saving result file science.log
06:59:59:WU01:FS01:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
07:00:01:WARNING:WU01:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
07:00:01:WU01:FS01:Sending unit results: id:01 state:SEND error:FAULTY project:18719 run:0 clone:1310 gen:8 core:0x22 unit:0x0000051e000000080000491f00000000
07:00:01:WU01:FS01:Uploading 16.00KiB to 34.72.228.44
07:00:01:WU01:FS01:Connecting to 34.72.228.44:8080
07:00:01:WU01:FS01:Upload complete
07:00:02:WU00:FS01:Connecting to assign1.foldingathome.org:80
07:00:02:WU01:FS01:Server responded WORK_ACK (400)
07:00:02:WU01:FS01:Cleaning up
07:00:02:WU00:FS01:Assigned to work server 129.32.209.202
07:00:02:WU00:FS01:Requesting new work unit for slot 01: gpu:1:0 Ellesmere XT [RX 470/480/570/580/590] from 129.32.209.202
07:00:02:WU00:FS01:Connecting to 129.32.209.202:8080
07:00:03:WU00:FS01:Downloading 17.09MiB
07:00:18:WU00:FS01:Download complete
07:00:18:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:18454 run:17 clone:35 gen:376 core:0x22 unit:0x00000023000001780000481600000011
07:00:18:WU00:FS01:Starting
07:00:18:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.20/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 706 -lifeline 1812 -checkpoint 15 -opencl-platform 1 -opencl-device 0 -gpu-vendor amd -gpu 0 -gpu-usage 100
07:00:18:WU00:FS01:Started FahCore on PID 8208
07:00:18:WU00:FS01:Core PID:9512
07:00:18:WU00:FS01:FahCore 0x22 started
07:00:18:WU00:FS01:0x22:*********************** Log Started 2023-02-18T07:00:18Z ***********************
07:00:18:WU00:FS01:0x22:*************************** Core22 Folding@home Core ***************************
07:00:18:WU00:FS01:0x22:       Core: Core22
07:00:18:WU00:FS01:0x22:       Type: 0x22
07:00:18:WU00:FS01:0x22:    Version: 0.0.20
07:00:18:WU00:FS01:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
07:00:18:WU00:FS01:0x22:  Copyright: 2020 foldingathome.org
07:00:18:WU00:FS01:0x22:   Homepage: https://foldingathome.org/
07:00:18:WU00:FS01:0x22:       Date: Jan 20 2022
07:00:18:WU00:FS01:0x22:       Time: 01:15:36
07:00:18:WU00:FS01:0x22:   Revision: 3f211b8a4346514edbff34e3cb1c0e0ec951373c
07:00:18:WU00:FS01:0x22:     Branch: HEAD
07:00:18:WU00:FS01:0x22:   Compiler: Visual C++
07:00:18:WU00:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
07:00:18:WU00:FS01:0x22:             -DOPENMM_VERSION="\"7.7.0\""
07:00:18:WU00:FS01:0x22:   Platform: win32 10
07:00:18:WU00:FS01:0x22:       Bits: 64
07:00:18:WU00:FS01:0x22:       Mode: Release
07:00:18:WU00:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
07:00:18:WU00:FS01:0x22:             <peastman@stanford.edu>
07:00:18:WU00:FS01:0x22:       Args: -dir 00 -suffix 01 -version 706 -lifeline 8208 -checkpoint 15
07:00:18:WU00:FS01:0x22:             -opencl-platform 1 -opencl-device 0 -gpu-vendor amd -gpu 0
07:00:18:WU00:FS01:0x22:             -gpu-usage 100
07:00:18:WU00:FS01:0x22:************************************ libFAH ************************************
07:00:18:WU00:FS01:0x22:       Time: 01:14:17
07:00:18:WU00:FS01:0x22:   Revision: 9f4ad694e75c2350d4bb6b8b5b769ba27e483a2f
07:00:18:WU00:FS01:0x22:************************************ CBang *************************************
07:00:18:WU00:FS01:0x22:       Time: 01:13:20
07:00:18:WU00:FS01:0x22:   Revision: ab023d155b446906d55b0f6c9a1eedeea04f7a1a
07:00:18:WU00:FS01:0x22:************************************ System ************************************
07:00:18:WU00:FS01:0x22:        CPU: 12th Gen Intel(R) Core(TM) i3-12100
07:00:18:WU00:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 151 Stepping 5
07:00:18:WU00:FS01:0x22:       CPUs: 8
07:00:18:WU00:FS01:0x22:     Memory: 31.75GiB
07:00:18:WU00:FS01:0x22:Free Memory: 25.79GiB
07:00:18:WU00:FS01:0x22:    Threads: WINDOWS_THREADS
07:00:18:WU00:FS01:0x22: OS Version: 6.2
07:00:18:WU00:FS01:0x22:Has Battery: false
07:00:18:WU00:FS01:0x22: On Battery: false
07:00:18:WU00:FS01:0x22: UTC Offset: -6
07:00:18:WU00:FS01:0x22:        PID: 9512
07:00:18:WU00:FS01:0x22:        CWD: C:\ProgramData\FAHClient\work
07:00:18:WU00:FS01:0x22:************************************ OpenMM ************************************
07:00:18:WU00:FS01:0x22:    Version: 7.7.0
07:00:18:WU00:FS01:0x22:********************************************************************************
07:00:18:WU00:FS01:0x22:Project: 18454 (Run 17, Clone 35, Gen 376)
07:00:18:WU00:FS01:0x22:Reading tar file core.xml
07:00:18:WU00:FS01:0x22:Reading tar file integrator.xml
07:00:18:WU00:FS01:0x22:Reading tar file state.xml
07:00:18:WU00:FS01:0x22:Reading tar file system.xml
07:00:18:WU00:FS01:0x22:Digital signatures verified
07:00:18:WU00:FS01:0x22:Folding@home GPU Core22 Folding@home Core
07:00:18:WU00:FS01:0x22:Version 0.0.20
07:00:20:WU00:FS01:0x22:  Checkpoint write interval: 100000 steps (2%) [50 total]
07:00:20:WU00:FS01:0x22:  JSON viewer frame write interval: 50000 steps (1%) [100 total]
07:00:20:WU00:FS01:0x22:  XTC frame write interval: 500000 steps (10%) [10 total]
07:00:20:WU00:FS01:0x22:  Global context and integrator variables write interval: disabled
07:00:20:WU00:FS01:0x22:There are 3 platforms available.
07:00:20:WU00:FS01:0x22:Platform 0: Reference
07:00:20:WU00:FS01:0x22:Platform 1: CPU
07:00:20:WU00:FS01:0x22:Platform 2: OpenCL
07:00:20:WU00:FS01:0x22:  opencl-device 0 specified
07:00:21:WU00:FS01:0x22:Attempting to create OpenCL context:
07:00:21:WU00:FS01:0x22:  Configuring platform OpenCL
07:00:21:WU00:FS01:0x22:Failed to create OpenCL context:
07:00:21:WU00:FS01:0x22:No compatible OpenCL platform is available
07:00:21:WU00:FS01:0x22:ERROR:125: Failed to create a GPU-enabled OpenMM Context.
07:00:21:WU00:FS01:0x22:Saving result file ..\logfile_01.txt
07:00:21:WU00:FS01:0x22:Saving result file science.log
07:00:21:WU00:FS01:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
07:00:21:WARNING:WU00:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
07:00:21:WU00:FS01:Sending unit results: id:00 state:SEND error:FAULTY project:18454 run:17 clone:35 gen:376 core:0x22 unit:0x00000023000001780000481600000011
07:00:21:WU00:FS01:Uploading 11.50KiB to 129.32.209.202
07:00:21:WU00:FS01:Connecting to 129.32.209.202:8080
07:00:22:WU00:FS01:Upload complete
07:00:22:WU00:FS01:Server responded WORK_ACK (400)
07:00:22:WU00:FS01:Cleaning up
07:00:22:WU01:FS01:Connecting to assign1.foldingathome.org:80
07:00:22:WU01:FS01:Assigned to work server 34.72.228.44
07:00:22:WU01:FS01:Requesting new work unit for slot 01: gpu:1:0 Ellesmere XT [RX 470/480/570/580/590] from 34.72.228.44
07:00:22:WU01:FS01:Connecting to 34.72.228.44:8080
07:00:23:WU01:FS01:Downloading 5.73MiB
07:00:26:WU01:FS01:Download complete
07:00:26:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:18721 run:9 clone:14 gen:2 core:0x22 unit:0x0000000e000000020000492100000009
07:00:26:WU01:FS01:Starting
07:00:26:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.20/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 706 -lifeline 1812 -checkpoint 15 -opencl-platform 1 -opencl-device 0 -gpu-vendor amd -gpu 0 -gpu-usage 100
07:00:26:WU01:FS01:Started FahCore on PID 8680
07:00:26:WU01:FS01:Core PID:10192
07:00:26:WU01:FS01:FahCore 0x22 started
07:00:27:WU01:FS01:0x22:*********************** Log Started 2023-02-18T07:00:26Z ***********************
07:00:27:WU01:FS01:0x22:*************************** Core22 Folding@home Core ***************************
07:00:27:WU01:FS01:0x22:       Core: Core22
07:00:27:WU01:FS01:0x22:       Type: 0x22
07:00:27:WU01:FS01:0x22:    Version: 0.0.20
07:00:27:WU01:FS01:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
07:00:27:WU01:FS01:0x22:  Copyright: 2020 foldingathome.org
07:00:27:WU01:FS01:0x22:   Homepage: https://foldingathome.org/
07:00:27:WU01:FS01:0x22:       Date: Jan 20 2022
07:00:27:WU01:FS01:0x22:       Time: 01:15:36
07:00:27:WU01:FS01:0x22:   Revision: 3f211b8a4346514edbff34e3cb1c0e0ec951373c
07:00:27:WU01:FS01:0x22:     Branch: HEAD
07:00:27:WU01:FS01:0x22:   Compiler: Visual C++
07:00:27:WU01:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
07:00:27:WU01:FS01:0x22:             -DOPENMM_VERSION="\"7.7.0\""
07:00:27:WU01:FS01:0x22:   Platform: win32 10
07:00:27:WU01:FS01:0x22:       Bits: 64
07:00:27:WU01:FS01:0x22:       Mode: Release
07:00:27:WU01:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
07:00:27:WU01:FS01:0x22:             <peastman@stanford.edu>
07:00:27:WU01:FS01:0x22:       Args: -dir 01 -suffix 01 -version 706 -lifeline 8680 -checkpoint 15
07:00:27:WU01:FS01:0x22:             -opencl-platform 1 -opencl-device 0 -gpu-vendor amd -gpu 0
07:00:27:WU01:FS01:0x22:             -gpu-usage 100
07:00:27:WU01:FS01:0x22:************************************ libFAH ************************************
07:00:27:WU01:FS01:0x22:       Time: 01:14:17
07:00:27:WU01:FS01:0x22:   Revision: 9f4ad694e75c2350d4bb6b8b5b769ba27e483a2f
07:00:27:WU01:FS01:0x22:************************************ CBang *************************************
07:00:27:WU01:FS01:0x22:       Time: 01:13:20
07:00:27:WU01:FS01:0x22:   Revision: ab023d155b446906d55b0f6c9a1eedeea04f7a1a
07:00:27:WU01:FS01:0x22:************************************ System ************************************
07:00:27:WU01:FS01:0x22:        CPU: 12th Gen Intel(R) Core(TM) i3-12100
07:00:27:WU01:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 151 Stepping 5
07:00:27:WU01:FS01:0x22:       CPUs: 8
07:00:27:WU01:FS01:0x22:     Memory: 31.75GiB
07:00:27:WU01:FS01:0x22:Free Memory: 25.76GiB
07:00:27:WU01:FS01:0x22:    Threads: WINDOWS_THREADS
07:00:27:WU01:FS01:0x22: OS Version: 6.2
07:00:27:WU01:FS01:0x22:Has Battery: false
07:00:27:WU01:FS01:0x22: On Battery: false
07:00:27:WU01:FS01:0x22: UTC Offset: -6
07:00:27:WU01:FS01:0x22:        PID: 10192
07:00:27:WU01:FS01:0x22:        CWD: C:\ProgramData\FAHClient\work
07:00:27:WU01:FS01:0x22:************************************ OpenMM ************************************
07:00:27:WU01:FS01:0x22:    Version: 7.7.0
07:00:27:WU01:FS01:0x22:********************************************************************************
07:00:27:WU01:FS01:0x22:Project: 18721 (Run 9, Clone 14, Gen 2)
07:00:27:WU01:FS01:0x22:Reading tar file core.xml
07:00:27:WU01:FS01:0x22:Reading tar file integrator.xml.bz2
07:00:27:WU01:FS01:0x22:Reading tar file state.xml.bz2
07:00:27:WU01:FS01:0x22:Reading tar file system.xml.bz2
07:00:27:WU01:FS01:0x22:Digital signatures verified
07:00:27:WU01:FS01:0x22:Folding@home GPU Core22 Folding@home Core
07:00:27:WU01:FS01:0x22:Version 0.0.20
07:00:28:WU01:FS01:0x22:  Checkpoint write interval: 250000 steps (5%) [20 total]
07:00:28:WU01:FS01:0x22:  JSON viewer frame write interval: 50000 steps (1%) [100 total]
07:00:28:WU01:FS01:0x22:  XTC frame write interval: 50000 steps (1%) [100 total]
07:00:28:WU01:FS01:0x22:  Global context and integrator variables write interval: disabled
07:00:28:WU01:FS01:0x22:There are 3 platforms available.
07:00:28:WU01:FS01:0x22:Platform 0: Reference
07:00:28:WU01:FS01:0x22:Platform 1: CPU
07:00:28:WU01:FS01:0x22:Platform 2: OpenCL
07:00:28:WU01:FS01:0x22:  opencl-device 0 specified
07:00:32:WU01:FS01:0x22:Attempting to create OpenCL context:
07:00:32:WU01:FS01:0x22:  Configuring platform OpenCL
07:00:32:WU01:FS01:0x22:Failed to create OpenCL context:
07:00:32:WU01:FS01:0x22:No compatible OpenCL platform is available
07:00:32:WU01:FS01:0x22:ERROR:125: Failed to create a GPU-enabled OpenMM Context.
07:00:32:WU01:FS01:0x22:Saving result file ..\logfile_01.txt
07:00:32:WU01:FS01:0x22:Saving result file science.log
07:00:32:WU01:FS01:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
07:00:35:WARNING:WU01:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
07:00:35:WU01:FS01:Sending unit results: id:01 state:SEND error:FAULTY project:18721 run:9 clone:14 gen:2 core:0x22 unit:0x0000000e000000020000492100000009
07:00:35:WU01:FS01:Uploading 11.50KiB to 34.72.228.44
07:00:35:WU01:FS01:Connecting to 34.72.228.44:8080
07:00:35:WU01:FS01:Upload complete
07:00:35:WU01:FS01:Server responded WORK_ACK (400)
07:00:35:WU01:FS01:Cleaning up
07:00:35:WU00:FS01:Connecting to assign1.foldingathome.org:80
07:00:36:WU00:FS01:Assigned to work server 129.32.209.202
07:00:36:WU00:FS01:Requesting new work unit for slot 01: gpu:1:0 Ellesmere XT [RX 470/480/570/580/590] from 129.32.209.202
07:00:36:WU00:FS01:Connecting to 129.32.209.202:8080
07:00:36:WU00:FS01:Downloading 41.72MiB
07:01:08:WU00:FS01:Download complete
07:01:09:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:18447 run:3 clone:75 gen:741 core:0x22 unit:0x0000004b000002e50000480f00000003
07:01:09:WU00:FS01:Starting
07:01:09:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.20/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 706 -lifeline 1812 -checkpoint 15 -opencl-platform 1 -opencl-device 0 -gpu-vendor amd -gpu 0 -gpu-usage 100
07:01:09:WU00:FS01:Started FahCore on PID 276
07:01:09:WU00:FS01:Core PID:9628
07:01:09:WU00:FS01:FahCore 0x22 started
07:01:09:WU00:FS01:0x22:*********************** Log Started 2023-02-18T07:01:09Z ***********************
07:01:09:WU00:FS01:0x22:*************************** Core22 Folding@home Core ***************************
07:01:09:WU00:FS01:0x22:       Core: Core22
07:01:09:WU00:FS01:0x22:       Type: 0x22
07:01:09:WU00:FS01:0x22:    Version: 0.0.20
07:01:09:WU00:FS01:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
07:01:09:WU00:FS01:0x22:  Copyright: 2020 foldingathome.org
07:01:09:WU00:FS01:0x22:   Homepage: https://foldingathome.org/
07:01:09:WU00:FS01:0x22:       Date: Jan 20 2022
07:01:09:WU00:FS01:0x22:       Time: 01:15:36
07:01:09:WU00:FS01:0x22:   Revision: 3f211b8a4346514edbff34e3cb1c0e0ec951373c
07:01:09:WU00:FS01:0x22:     Branch: HEAD
07:01:09:WU00:FS01:0x22:   Compiler: Visual C++
07:01:09:WU00:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
07:01:09:WU00:FS01:0x22:             -DOPENMM_VERSION="\"7.7.0\""
07:01:09:WU00:FS01:0x22:   Platform: win32 10
07:01:09:WU00:FS01:0x22:       Bits: 64
07:01:09:WU00:FS01:0x22:       Mode: Release
07:01:09:WU00:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
07:01:09:WU00:FS01:0x22:             <peastman@stanford.edu>
07:01:09:WU00:FS01:0x22:       Args: -dir 00 -suffix 01 -version 706 -lifeline 276 -checkpoint 15
07:01:09:WU00:FS01:0x22:             -opencl-platform 1 -opencl-device 0 -gpu-vendor amd -gpu 0
07:01:09:WU00:FS01:0x22:             -gpu-usage 100
07:01:09:WU00:FS01:0x22:************************************ libFAH ************************************
07:01:09:WU00:FS01:0x22:       Time: 01:14:17
07:01:09:WU00:FS01:0x22:   Revision: 9f4ad694e75c2350d4bb6b8b5b769ba27e483a2f
07:01:09:WU00:FS01:0x22:************************************ CBang *************************************
07:01:09:WU00:FS01:0x22:       Time: 01:13:20
07:01:09:WU00:FS01:0x22:   Revision: ab023d155b446906d55b0f6c9a1eedeea04f7a1a
07:01:09:WU00:FS01:0x22:************************************ System ************************************
07:01:09:WU00:FS01:0x22:        CPU: 12th Gen Intel(R) Core(TM) i3-12100
07:01:09:WU00:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 151 Stepping 5
07:01:09:WU00:FS01:0x22:       CPUs: 8
07:01:09:WU00:FS01:0x22:     Memory: 31.75GiB
07:01:09:WU00:FS01:0x22:Free Memory: 25.78GiB
07:01:09:WU00:FS01:0x22:    Threads: WINDOWS_THREADS
07:01:09:WU00:FS01:0x22: OS Version: 6.2
07:01:09:WU00:FS01:0x22:Has Battery: false
07:01:09:WU00:FS01:0x22: On Battery: false
07:01:09:WU00:FS01:0x22: UTC Offset: -6
07:01:09:WU00:FS01:0x22:        PID: 9628
07:01:09:WU00:FS01:0x22:        CWD: C:\ProgramData\FAHClient\work
07:01:09:WU00:FS01:0x22:************************************ OpenMM ************************************
07:01:09:WU00:FS01:0x22:    Version: 7.7.0
07:01:09:WU00:FS01:0x22:********************************************************************************
07:01:09:WU00:FS01:0x22:Project: 18447 (Run 3, Clone 75, Gen 741)
07:01:09:WU00:FS01:0x22:Reading tar file core.xml
07:01:09:WU00:FS01:0x22:Reading tar file integrator.xml
07:01:09:WU00:FS01:0x22:Reading tar file state.xml
07:01:09:WU00:FS01:0x22:Reading tar file system.xml
07:01:09:WU00:FS01:0x22:Digital signatures verified
07:01:09:WU00:FS01:0x22:Folding@home GPU Core22 Folding@home Core
07:01:09:WU00:FS01:0x22:Version 0.0.20
07:01:11:WU00:FS01:0x22:  Checkpoint write interval: 50000 steps (2%) [50 total]
07:01:11:WU00:FS01:0x22:  JSON viewer frame write interval: 25000 steps (1%) [100 total]
07:01:11:WU00:FS01:0x22:  XTC frame write interval: 2500000 steps (1e+02%) [1 total]
07:01:11:WU00:FS01:0x22:  Global context and integrator variables write interval: disabled
07:01:11:WU00:FS01:0x22:There are 3 platforms available.
07:01:11:WU00:FS01:0x22:Platform 0: Reference
07:01:11:WU00:FS01:0x22:Platform 1: CPU
07:01:11:WU00:FS01:0x22:Platform 2: OpenCL
07:01:11:WU00:FS01:0x22:  opencl-device 0 specified
07:01:14:WU00:FS01:0x22:Attempting to create OpenCL context:
07:01:14:WU00:FS01:0x22:  Configuring platform OpenCL
07:01:14:WU00:FS01:0x22:Failed to create OpenCL context:
07:01:14:WU00:FS01:0x22:No compatible OpenCL platform is available
07:01:14:WU00:FS01:0x22:ERROR:125: Failed to create a GPU-enabled OpenMM Context.
07:01:14:WU00:FS01:0x22:Saving result file ..\logfile_01.txt
07:01:14:WU00:FS01:0x22:Saving result file science.log
07:01:14:WU00:FS01:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
07:01:15:WARNING:WU00:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
07:01:15:WU00:FS01:Sending unit results: id:00 state:SEND error:FAULTY project:18447 run:3 clone:75 gen:741 core:0x22 unit:0x0000004b000002e50000480f00000003
07:01:15:WU00:FS01:Uploading 11.50KiB to 129.32.209.202
07:01:15:WU00:FS01:Connecting to 129.32.209.202:8080
07:01:15:WU00:FS01:Upload complete
07:01:15:WU00:FS01:Server responded WORK_ACK (400)
07:01:15:WU00:FS01:Cleaning up
07:01:16:WU01:FS01:Connecting to assign1.foldingathome.org:80
07:01:16:WU01:FS01:Assigned to work server 129.32.209.202
07:01:16:WU01:FS01:Requesting new work unit for slot 01: gpu:1:0 Ellesmere XT [RX 470/480/570/580/590] from 129.32.209.202
07:01:16:WU01:FS01:Connecting to 129.32.209.202:8080
07:01:17:WU01:FS01:Downloading 22.96MiB
07:01:23:WU01:FS01:Download 35.40%
07:01:29:WU01:FS01:Download 75.42%
07:01:32:WU01:FS01:Download complete
07:01:32:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:18452 run:6 clone:43 gen:51 core:0x22 unit:0x0000002b000000330000481400000006
07:01:32:WU01:FS01:Starting
07:01:32:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.20/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 706 -lifeline 1812 -checkpoint 15 -opencl-platform 1 -opencl-device 0 -gpu-vendor amd -gpu 0 -gpu-usage 100
07:01:32:WU01:FS01:Started FahCore on PID 9720
07:01:32:WU01:FS01:Core PID:6496
07:01:32:WU01:FS01:FahCore 0x22 started
07:01:33:WU01:FS01:0x22:*********************** Log Started 2023-02-18T07:01:32Z ***********************
07:01:33:WU01:FS01:0x22:*************************** Core22 Folding@home Core ***************************
07:01:33:WU01:FS01:0x22:       Core: Core22
07:01:33:WU01:FS01:0x22:       Type: 0x22
07:01:33:WU01:FS01:0x22:    Version: 0.0.20
07:01:33:WU01:FS01:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
07:01:33:WU01:FS01:0x22:  Copyright: 2020 foldingathome.org
07:01:33:WU01:FS01:0x22:   Homepage: https://foldingathome.org/
07:01:33:WU01:FS01:0x22:       Date: Jan 20 2022
07:01:33:WU01:FS01:0x22:       Time: 01:15:36
07:01:33:WU01:FS01:0x22:   Revision: 3f211b8a4346514edbff34e3cb1c0e0ec951373c
07:01:33:WU01:FS01:0x22:     Branch: HEAD
07:01:33:WU01:FS01:0x22:   Compiler: Visual C++
07:01:33:WU01:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
07:01:33:WU01:FS01:0x22:             -DOPENMM_VERSION="\"7.7.0\""
07:01:33:WU01:FS01:0x22:   Platform: win32 10
07:01:33:WU01:FS01:0x22:       Bits: 64
07:01:33:WU01:FS01:0x22:       Mode: Release
07:01:33:WU01:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
07:01:33:WU01:FS01:0x22:             <peastman@stanford.edu>
07:01:33:WU01:FS01:0x22:       Args: -dir 01 -suffix 01 -version 706 -lifeline 9720 -checkpoint 15
07:01:33:WU01:FS01:0x22:             -opencl-platform 1 -opencl-device 0 -gpu-vendor amd -gpu 0
07:01:33:WU01:FS01:0x22:             -gpu-usage 100
07:01:33:WU01:FS01:0x22:************************************ libFAH ************************************
07:01:33:WU01:FS01:0x22:       Time: 01:14:17
07:01:33:WU01:FS01:0x22:   Revision: 9f4ad694e75c2350d4bb6b8b5b769ba27e483a2f
07:01:33:WU01:FS01:0x22:************************************ CBang *************************************
07:01:33:WU01:FS01:0x22:       Time: 01:13:20
07:01:33:WU01:FS01:0x22:   Revision: ab023d155b446906d55b0f6c9a1eedeea04f7a1a
07:01:33:WU01:FS01:0x22:************************************ System ************************************
07:01:33:WU01:FS01:0x22:        CPU: 12th Gen Intel(R) Core(TM) i3-12100
07:01:33:WU01:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 151 Stepping 5
07:01:33:WU01:FS01:0x22:       CPUs: 8
07:01:33:WU01:FS01:0x22:     Memory: 31.75GiB
07:01:33:WU01:FS01:0x22:Free Memory: 25.75GiB
07:01:33:WU01:FS01:0x22:    Threads: WINDOWS_THREADS
07:01:33:WU01:FS01:0x22: OS Version: 6.2
07:01:33:WU01:FS01:0x22:Has Battery: false
07:01:33:WU01:FS01:0x22: On Battery: false
07:01:33:WU01:FS01:0x22: UTC Offset: -6
07:01:33:WU01:FS01:0x22:        PID: 6496
07:01:33:WU01:FS01:0x22:        CWD: C:\ProgramData\FAHClient\work
07:01:33:WU01:FS01:0x22:************************************ OpenMM ************************************
07:01:33:WU01:FS01:0x22:    Version: 7.7.0
07:01:33:WU01:FS01:0x22:********************************************************************************
07:01:33:WU01:FS01:0x22:Project: 18452 (Run 6, Clone 43, Gen 51)
07:01:33:WU01:FS01:0x22:Reading tar file core.xml
07:01:33:WU01:FS01:0x22:Reading tar file integrator.xml
07:01:33:WU01:FS01:0x22:Reading tar file state.xml
07:01:33:WU01:FS01:0x22:Reading tar file system.xml
07:01:33:WU01:FS01:0x22:Digital signatures verified
07:01:33:WU01:FS01:0x22:Folding@home GPU Core22 Folding@home Core
07:01:33:WU01:FS01:0x22:Version 0.0.20
07:01:35:WU01:FS01:0x22:  Checkpoint write interval: 100000 steps (2%) [50 total]
07:01:35:WU01:FS01:0x22:  JSON viewer frame write interval: 50000 steps (1%) [100 total]
07:01:35:WU01:FS01:0x22:  XTC frame write interval: 250000 steps (5%) [20 total]
07:01:35:WU01:FS01:0x22:  Global context and integrator variables write interval: disabled
07:01:35:WU01:FS01:0x22:There are 3 platforms available.
07:01:35:WU01:FS01:0x22:Platform 0: Reference
07:01:35:WU01:FS01:0x22:Platform 1: CPU
07:01:35:WU01:FS01:0x22:Platform 2: OpenCL
07:01:35:WU01:FS01:0x22:  opencl-device 0 specified
07:01:36:WU01:FS01:0x22:Attempting to create OpenCL context:
07:01:36:WU01:FS01:0x22:  Configuring platform OpenCL
07:01:36:WU01:FS01:0x22:Failed to create OpenCL context:
07:01:36:WU01:FS01:0x22:No compatible OpenCL platform is available
07:01:36:WU01:FS01:0x22:ERROR:125: Failed to create a GPU-enabled OpenMM Context.
07:01:36:WU01:FS01:0x22:Saving result file ..\logfile_01.txt
07:01:36:WU01:FS01:0x22:Saving result file science.log
07:01:36:WU01:FS01:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
07:01:37:WARNING:WU01:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
07:01:37:WU01:FS01:Sending unit results: id:01 state:SEND error:FAULTY project:18452 run:6 clone:43 gen:51 core:0x22 unit:0x0000002b000000330000481400000006
07:01:37:WU01:FS01:Uploading 11.00KiB to 129.32.209.202
07:01:37:WU01:FS01:Connecting to 129.32.209.202:8080
07:01:37:WU01:FS01:Upload complete
07:01:37:WU01:FS01:Server responded WORK_ACK (400)
07:01:37:WU01:FS01:Cleaning up
07:01:37:WU00:FS01:Connecting to assign1.foldingathome.org:80
07:01:37:WU00:FS01:Assigned to work server 34.72.228.44
07:01:37:WU00:FS01:Requesting new work unit for slot 01: gpu:1:0 Ellesmere XT [RX 470/480/570/580/590] from 34.72.228.44
07:01:37:WU00:FS01:Connecting to 34.72.228.44:8080
07:01:38:WU00:FS01:Downloading 5.74MiB
07:01:41:WU00:FS01:Download complete
07:01:41:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:18719 run:0 clone:1858 gen:10 core:0x22 unit:0x000007420000000a0000491f00000000
07:01:41:WU00:FS01:Starting
07:01:41:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.20/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 706 -lifeline 1812 -checkpoint 15 -opencl-platform 1 -opencl-device 0 -gpu-vendor amd -gpu 0 -gpu-usage 100
07:01:41:WU00:FS01:Started FahCore on PID 8340
07:01:41:WU00:FS01:Core PID:316
07:01:41:WU00:FS01:FahCore 0x22 started
07:01:42:WU00:FS01:0x22:*********************** Log Started 2023-02-18T07:01:41Z ***********************
07:01:42:WU00:FS01:0x22:*************************** Core22 Folding@home Core ***************************
07:01:42:WU00:FS01:0x22:       Core: Core22
07:01:42:WU00:FS01:0x22:       Type: 0x22
07:01:42:WU00:FS01:0x22:    Version: 0.0.20
07:01:42:WU00:FS01:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
07:01:42:WU00:FS01:0x22:  Copyright: 2020 foldingathome.org
07:01:42:WU00:FS01:0x22:   Homepage: https://foldingathome.org/
07:01:42:WU00:FS01:0x22:       Date: Jan 20 2022
07:01:42:WU00:FS01:0x22:       Time: 01:15:36
07:01:42:WU00:FS01:0x22:   Revision: 3f211b8a4346514edbff34e3cb1c0e0ec951373c
07:01:42:WU00:FS01:0x22:     Branch: HEAD
07:01:42:WU00:FS01:0x22:   Compiler: Visual C++
07:01:42:WU00:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
07:01:42:WU00:FS01:0x22:             -DOPENMM_VERSION="\"7.7.0\""
07:01:42:WU00:FS01:0x22:   Platform: win32 10
07:01:42:WU00:FS01:0x22:       Bits: 64
07:01:42:WU00:FS01:0x22:       Mode: Release
07:01:42:WU00:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
07:01:42:WU00:FS01:0x22:             <peastman@stanford.edu>
07:01:42:WU00:FS01:0x22:       Args: -dir 00 -suffix 01 -version 706 -lifeline 8340 -checkpoint 15
07:01:42:WU00:FS01:0x22:             -opencl-platform 1 -opencl-device 0 -gpu-vendor amd -gpu 0
07:01:42:WU00:FS01:0x22:             -gpu-usage 100
07:01:42:WU00:FS01:0x22:************************************ libFAH ************************************
07:01:42:WU00:FS01:0x22:       Time: 01:14:17
07:01:42:WU00:FS01:0x22:   Revision: 9f4ad694e75c2350d4bb6b8b5b769ba27e483a2f
07:01:42:WU00:FS01:0x22:************************************ CBang *************************************
07:01:42:WU00:FS01:0x22:       Time: 01:13:20
07:01:42:WU00:FS01:0x22:   Revision: ab023d155b446906d55b0f6c9a1eedeea04f7a1a
07:01:42:WU00:FS01:0x22:************************************ System ************************************
07:01:42:WU00:FS01:0x22:        CPU: 12th Gen Intel(R) Core(TM) i3-12100
07:01:42:WU00:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 151 Stepping 5
07:01:42:WU00:FS01:0x22:       CPUs: 8
07:01:42:WU00:FS01:0x22:     Memory: 31.75GiB
07:01:42:WU00:FS01:0x22:Free Memory: 25.76GiB
07:01:42:WU00:FS01:0x22:    Threads: WINDOWS_THREADS
07:01:42:WU00:FS01:0x22: OS Version: 6.2
07:01:42:WU00:FS01:0x22:Has Battery: false
07:01:42:WU00:FS01:0x22: On Battery: false
07:01:42:WU00:FS01:0x22: UTC Offset: -6
07:01:42:WU00:FS01:0x22:        PID: 316
07:01:42:WU00:FS01:0x22:        CWD: C:\ProgramData\FAHClient\work
07:01:42:WU00:FS01:0x22:************************************ OpenMM ************************************
07:01:42:WU00:FS01:0x22:    Version: 7.7.0
07:01:42:WU00:FS01:0x22:********************************************************************************
07:01:42:WU00:FS01:0x22:Project: 18719 (Run 0, Clone 1858, Gen 10)
07:01:42:WU00:FS01:0x22:Reading tar file core.xml
07:01:42:WU00:FS01:0x22:Reading tar file integrator.xml.bz2
07:01:42:WU00:FS01:0x22:Reading tar file state.xml.bz2
07:01:42:WU00:FS01:0x22:Reading tar file system.xml.bz2
07:01:42:WU00:FS01:0x22:Digital signatures verified
07:01:42:WU00:FS01:0x22:Folding@home GPU Core22 Folding@home Core
07:01:42:WU00:FS01:0x22:Version 0.0.20
07:01:43:WU00:FS01:0x22:  Checkpoint write interval: 250000 steps (5%) [20 total]
07:01:43:WU00:FS01:0x22:  JSON viewer frame write interval: 50000 steps (1%) [100 total]
07:01:43:WU00:FS01:0x22:  XTC frame write interval: 50000 steps (1%) [100 total]
07:01:43:WU00:FS01:0x22:  Global context and integrator variables write interval: disabled
07:01:43:WU00:FS01:0x22:There are 3 platforms available.
07:01:43:WU00:FS01:0x22:Platform 0: Reference
07:01:43:WU00:FS01:0x22:Platform 1: CPU
07:01:43:WU00:FS01:0x22:Platform 2: OpenCL
07:01:43:WU00:FS01:0x22:  opencl-device 0 specified
07:01:47:WU00:FS01:0x22:Attempting to create OpenCL context:
07:01:47:WU00:FS01:0x22:  Configuring platform OpenCL
07:01:47:WU00:FS01:0x22:Failed to create OpenCL context:
07:01:47:WU00:FS01:0x22:No compatible OpenCL platform is available
07:01:47:WU00:FS01:0x22:ERROR:125: Failed to create a GPU-enabled OpenMM Context.
07:01:47:WU00:FS01:0x22:Saving result file ..\logfile_01.txt
07:01:47:WU00:FS01:0x22:Saving result file science.log
07:01:47:WU00:FS01:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
07:01:50:WARNING:WU00:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
07:01:50:WU00:FS01:Sending unit results: id:00 state:SEND error:FAULTY project:18719 run:0 clone:1858 gen:10 core:0x22 unit:0x000007420000000a0000491f00000000
07:01:50:WU00:FS01:Uploading 11.50KiB to 34.72.228.44
07:01:50:WU00:FS01:Connecting to 34.72.228.44:8080
07:01:50:WU00:FS01:Upload complete
07:01:50:WU00:FS01:Server responded WORK_ACK (400)
07:01:50:WU00:FS01:Cleaning up
07:01:50:WU01:FS01:Connecting to assign1.foldingathome.org:80
07:01:51:WU01:FS01:Assigned to work server 129.32.209.202
07:01:51:WU01:FS01:Requesting new work unit for slot 01: gpu:1:0 Ellesmere XT [RX 470/480/570/580/590] from 129.32.209.202
07:01:51:WU01:FS01:Connecting to 129.32.209.202:8080
07:01:51:WU01:FS01:Downloading 41.65MiB
07:01:57:WU01:FS01:Download 15.91%
07:02:03:WU01:FS01:Download 33.46%
07:02:09:WU01:FS01:Download 49.22%
07:02:15:WU01:FS01:Download 66.78%
07:02:21:WU01:FS01:Download 88.23%
07:02:24:WU01:FS01:Download complete
07:02:24:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:18447 run:5 clone:200 gen:554 core:0x22 unit:0x000000c80000022a0000480f00000005
07:02:24:WU01:FS01:Starting
07:02:24:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.20/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 706 -lifeline 1812 -checkpoint 15 -opencl-platform 1 -opencl-device 0 -gpu-vendor amd -gpu 0 -gpu-usage 100
07:02:24:WU01:FS01:Started FahCore on PID 5928
07:02:24:WU01:FS01:Core PID:1776
07:02:24:WU01:FS01:FahCore 0x22 started
07:02:25:WU01:FS01:0x22:*********************** Log Started 2023-02-18T07:02:24Z ***********************
07:02:25:WU01:FS01:0x22:*************************** Core22 Folding@home Core ***************************
07:02:25:WU01:FS01:0x22:       Core: Core22
07:02:25:WU01:FS01:0x22:       Type: 0x22
07:02:25:WU01:FS01:0x22:    Version: 0.0.20
07:02:25:WU01:FS01:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
07:02:25:WU01:FS01:0x22:  Copyright: 2020 foldingathome.org
07:02:25:WU01:FS01:0x22:   Homepage: https://foldingathome.org/
07:02:25:WU01:FS01:0x22:       Date: Jan 20 2022
07:02:25:WU01:FS01:0x22:       Time: 01:15:36
07:02:25:WU01:FS01:0x22:   Revision: 3f211b8a4346514edbff34e3cb1c0e0ec951373c
07:02:25:WU01:FS01:0x22:     Branch: HEAD
07:02:25:WU01:FS01:0x22:   Compiler: Visual C++
07:02:25:WU01:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
07:02:25:WU01:FS01:0x22:             -DOPENMM_VERSION="\"7.7.0\""
07:02:25:WU01:FS01:0x22:   Platform: win32 10
07:02:25:WU01:FS01:0x22:       Bits: 64
07:02:25:WU01:FS01:0x22:       Mode: Release
07:02:25:WU01:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
07:02:25:WU01:FS01:0x22:             <peastman@stanford.edu>
07:02:25:WU01:FS01:0x22:       Args: -dir 01 -suffix 01 -version 706 -lifeline 5928 -checkpoint 15
07:02:25:WU01:FS01:0x22:             -opencl-platform 1 -opencl-device 0 -gpu-vendor amd -gpu 0
07:02:25:WU01:FS01:0x22:             -gpu-usage 100
07:02:25:WU01:FS01:0x22:************************************ libFAH ************************************
07:02:25:WU01:FS01:0x22:       Time: 01:14:17
07:02:25:WU01:FS01:0x22:   Revision: 9f4ad694e75c2350d4bb6b8b5b769ba27e483a2f
07:02:25:WU01:FS01:0x22:************************************ CBang *************************************
07:02:25:WU01:FS01:0x22:       Time: 01:13:20
07:02:25:WU01:FS01:0x22:   Revision: ab023d155b446906d55b0f6c9a1eedeea04f7a1a
07:02:25:WU01:FS01:0x22:************************************ System ************************************
07:02:25:WU01:FS01:0x22:        CPU: 12th Gen Intel(R) Core(TM) i3-12100
07:02:25:WU01:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 151 Stepping 5
07:02:25:WU01:FS01:0x22:       CPUs: 8
07:02:25:WU01:FS01:0x22:     Memory: 31.75GiB
07:02:25:WU01:FS01:0x22:Free Memory: 25.74GiB
07:02:25:WU01:FS01:0x22:    Threads: WINDOWS_THREADS
07:02:25:WU01:FS01:0x22: OS Version: 6.2
07:02:25:WU01:FS01:0x22:Has Battery: false
07:02:25:WU01:FS01:0x22: On Battery: false
07:02:25:WU01:FS01:0x22: UTC Offset: -6
07:02:25:WU01:FS01:0x22:        PID: 1776
07:02:25:WU01:FS01:0x22:        CWD: C:\ProgramData\FAHClient\work
07:02:25:WU01:FS01:0x22:************************************ OpenMM ************************************
07:02:25:WU01:FS01:0x22:    Version: 7.7.0
07:02:25:WU01:FS01:0x22:********************************************************************************
07:02:25:WU01:FS01:0x22:Project: 18447 (Run 5, Clone 200, Gen 554)
07:02:25:WU01:FS01:0x22:Reading tar file core.xml
07:02:25:WU01:FS01:0x22:Reading tar file integrator.xml
07:02:25:WU01:FS01:0x22:Reading tar file state.xml
07:02:25:WU01:FS01:0x22:Reading tar file system.xml
07:02:25:WU01:FS01:0x22:Digital signatures verified
07:02:25:WU01:FS01:0x22:Folding@home GPU Core22 Folding@home Core
07:02:25:WU01:FS01:0x22:Version 0.0.20
07:02:26:WU01:FS01:0x22:  Checkpoint write interval: 50000 steps (2%) [50 total]
07:02:26:WU01:FS01:0x22:  JSON viewer frame write interval: 25000 steps (1%) [100 total]
07:02:26:WU01:FS01:0x22:  XTC frame write interval: 2500000 steps (1e+02%) [1 total]
07:02:26:WU01:FS01:0x22:  Global context and integrator variables write interval: disabled
07:02:26:WU01:FS01:0x22:There are 3 platforms available.
07:02:26:WU01:FS01:0x22:Platform 0: Reference
07:02:26:WU01:FS01:0x22:Platform 1: CPU
07:02:26:WU01:FS01:0x22:Platform 2: OpenCL
07:02:26:WU01:FS01:0x22:  opencl-device 0 specified
07:02:30:WU01:FS01:0x22:Attempting to create OpenCL context:
07:02:30:WU01:FS01:0x22:  Configuring platform OpenCL
07:02:30:WU01:FS01:0x22:Failed to create OpenCL context:
07:02:30:WU01:FS01:0x22:No compatible OpenCL platform is available
07:02:30:WU01:FS01:0x22:ERROR:125: Failed to create a GPU-enabled OpenMM Context.
07:02:30:WU01:FS01:0x22:Saving result file ..\logfile_01.txt
07:02:30:WU01:FS01:0x22:Saving result file science.log
07:02:30:WU01:FS01:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
07:02:30:WARNING:WU01:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
07:02:30:WU01:FS01:Sending unit results: id:01 state:SEND error:FAULTY project:18447 run:5 clone:200 gen:554 core:0x22 unit:0x000000c80000022a0000480f00000005
07:02:30:WU01:FS01:Uploading 11.50KiB to 129.32.209.202
07:02:30:WU01:FS01:Connecting to 129.32.209.202:8080
07:02:30:WU01:FS01:Upload complete
07:02:31:WU01:FS01:Server responded WORK_ACK (400)
07:02:31:WU01:FS01:Cleaning up
07:02:31:WU00:FS01:Connecting to assign1.foldingathome.org:80
07:02:31:WU00:FS01:Assigned to work server 34.72.228.44
07:02:31:WU00:FS01:Requesting new work unit for slot 01: gpu:1:0 Ellesmere XT [RX 470/480/570/580/590] from 34.72.228.44
07:02:31:WU00:FS01:Connecting to 34.72.228.44:8080
07:02:32:WU00:FS01:Downloading 5.74MiB
07:02:44:WU00:FS01:Download 100.00%
07:02:44:WU00:FS01:Download complete
07:02:44:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:18721 run:40 clone:27 gen:2 core:0x22 unit:0x0000001b000000020000492100000028
07:02:44:WU00:FS01:Starting
07:02:44:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.20/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 706 -lifeline 1812 -checkpoint 15 -opencl-platform 1 -opencl-device 0 -gpu-vendor amd -gpu 0 -gpu-usage 100
07:02:44:WU00:FS01:Started FahCore on PID 552
07:02:44:WU00:FS01:Core PID:2948
07:02:44:WU00:FS01:FahCore 0x22 started
07:02:45:WU00:FS01:0x22:*********************** Log Started 2023-02-18T07:02:44Z ***********************
07:02:45:WU00:FS01:0x22:*************************** Core22 Folding@home Core ***************************
07:02:45:WU00:FS01:0x22:       Core: Core22
07:02:45:WU00:FS01:0x22:       Type: 0x22
07:02:45:WU00:FS01:0x22:    Version: 0.0.20
07:02:45:WU00:FS01:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
07:02:45:WU00:FS01:0x22:  Copyright: 2020 foldingathome.org
07:02:45:WU00:FS01:0x22:   Homepage: https://foldingathome.org/
07:02:45:WU00:FS01:0x22:       Date: Jan 20 2022
07:02:45:WU00:FS01:0x22:       Time: 01:15:36
07:02:45:WU00:FS01:0x22:   Revision: 3f211b8a4346514edbff34e3cb1c0e0ec951373c
07:02:45:WU00:FS01:0x22:     Branch: HEAD
07:02:45:WU00:FS01:0x22:   Compiler: Visual C++
07:02:45:WU00:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
07:02:45:WU00:FS01:0x22:             -DOPENMM_VERSION="\"7.7.0\""
07:02:45:WU00:FS01:0x22:   Platform: win32 10
07:02:45:WU00:FS01:0x22:       Bits: 64
07:02:45:WU00:FS01:0x22:       Mode: Release
07:02:45:WU00:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
07:02:45:WU00:FS01:0x22:             <peastman@stanford.edu>
07:02:45:WU00:FS01:0x22:       Args: -dir 00 -suffix 01 -version 706 -lifeline 552 -checkpoint 15
07:02:45:WU00:FS01:0x22:             -opencl-platform 1 -opencl-device 0 -gpu-vendor amd -gpu 0
07:02:45:WU00:FS01:0x22:             -gpu-usage 100
07:02:45:WU00:FS01:0x22:************************************ libFAH ************************************
07:02:45:WU00:FS01:0x22:       Time: 01:14:17
07:02:45:WU00:FS01:0x22:   Revision: 9f4ad694e75c2350d4bb6b8b5b769ba27e483a2f
07:02:45:WU00:FS01:0x22:************************************ CBang *************************************
07:02:45:WU00:FS01:0x22:       Time: 01:13:20
07:02:45:WU00:FS01:0x22:   Revision: ab023d155b446906d55b0f6c9a1eedeea04f7a1a
07:02:45:WU00:FS01:0x22:************************************ System ************************************
07:02:45:WU00:FS01:0x22:        CPU: 12th Gen Intel(R) Core(TM) i3-12100
07:02:45:WU00:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 151 Stepping 5
07:02:45:WU00:FS01:0x22:       CPUs: 8
07:02:45:WU00:FS01:0x22:     Memory: 31.75GiB
07:02:45:WU00:FS01:0x22:Free Memory: 25.74GiB
07:02:45:WU00:FS01:0x22:    Threads: WINDOWS_THREADS
07:02:45:WU00:FS01:0x22: OS Version: 6.2
07:02:45:WU00:FS01:0x22:Has Battery: false
07:02:45:WU00:FS01:0x22: On Battery: false
07:02:45:WU00:FS01:0x22: UTC Offset: -6
07:02:45:WU00:FS01:0x22:        PID: 2948
07:02:45:WU00:FS01:0x22:        CWD: C:\ProgramData\FAHClient\work
07:02:45:WU00:FS01:0x22:************************************ OpenMM ************************************
07:02:45:WU00:FS01:0x22:    Version: 7.7.0
07:02:45:WU00:FS01:0x22:********************************************************************************
07:02:45:WU00:FS01:0x22:Project: 18721 (Run 40, Clone 27, Gen 2)
07:02:45:WU00:FS01:0x22:Reading tar file core.xml
07:02:45:WU00:FS01:0x22:Reading tar file integrator.xml.bz2
07:02:45:WU00:FS01:0x22:Reading tar file state.xml.bz2
07:02:45:WU00:FS01:0x22:Reading tar file system.xml.bz2
07:02:45:WU00:FS01:0x22:Digital signatures verified
07:02:45:WU00:FS01:0x22:Folding@home GPU Core22 Folding@home Core
07:02:45:WU00:FS01:0x22:Version 0.0.20
07:02:46:WU00:FS01:0x22:  Checkpoint write interval: 250000 steps (5%) [20 total]
07:02:46:WU00:FS01:0x22:  JSON viewer frame write interval: 50000 steps (1%) [100 total]
07:02:46:WU00:FS01:0x22:  XTC frame write interval: 50000 steps (1%) [100 total]
07:02:46:WU00:FS01:0x22:  Global context and integrator variables write interval: disabled
07:02:46:WU00:FS01:0x22:There are 3 platforms available.
07:02:46:WU00:FS01:0x22:Platform 0: Reference
07:02:46:WU00:FS01:0x22:Platform 1: CPU
07:02:46:WU00:FS01:0x22:Platform 2: OpenCL
07:02:46:WU00:FS01:0x22:  opencl-device 0 specified
07:02:51:WU00:FS01:0x22:Attempting to create OpenCL context:
07:02:51:WU00:FS01:0x22:  Configuring platform OpenCL
07:02:51:WU00:FS01:0x22:Failed to create OpenCL context:
07:02:51:WU00:FS01:0x22:No compatible OpenCL platform is available
07:02:51:WU00:FS01:0x22:ERROR:125: Failed to create a GPU-enabled OpenMM Context.
07:02:51:WU00:FS01:0x22:Saving result file ..\logfile_01.txt
07:02:51:WU00:FS01:0x22:Saving result file science.log
07:02:51:WU00:FS01:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
07:02:53:WARNING:WU00:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
07:02:53:WU00:FS01:Sending unit results: id:00 state:SEND error:FAULTY project:18721 run:40 clone:27 gen:2 core:0x22 unit:0x0000001b000000020000492100000028
07:02:53:WU00:FS01:Uploading 11.50KiB to 34.72.228.44
07:02:53:WU00:FS01:Connecting to 34.72.228.44:8080
07:02:53:WU00:FS01:Upload complete
07:02:53:WU00:FS01:Server responded WORK_ACK (400)
07:02:53:WU00:FS01:Cleaning up
07:02:53:WU01:FS01:Connecting to assign1.foldingathome.org:80
07:02:54:WU01:FS01:Assigned to work server 34.72.228.44
07:02:54:WU01:FS01:Requesting new work unit for slot 01: gpu:1:0 Ellesmere XT [RX 470/480/570/580/590] from 34.72.228.44
07:02:54:WU01:FS01:Connecting to 34.72.228.44:8080
07:02:54:WU01:FS01:Downloading 5.73MiB
07:02:59:WU01:FS01:Download complete
07:02:59:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:18719 run:0 clone:1251 gen:11 core:0x22 unit:0x000004e30000000b0000491f00000000
07:02:59:WU01:FS01:Starting
07:02:59:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.20/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 706 -lifeline 1812 -checkpoint 15 -opencl-platform 1 -opencl-device 0 -gpu-vendor amd -gpu 0 -gpu-usage 100
07:02:59:WU01:FS01:Started FahCore on PID 5408
07:02:59:WU01:FS01:Core PID:10232
07:02:59:WU01:FS01:FahCore 0x22 started
---deleted for space, same as the others---
07:04:01:WU00:FS01:Sending unit results: id:00 state:SEND error:FAULTY project:18449 run:1 clone:104 gen:641 core:0x22 unit:0x00000068000002810000481100000001
07:04:01:WU00:FS01:Uploading 11.50KiB to 129.32.209.202
07:04:01:WU00:FS01:Connecting to 129.32.209.202:8080
07:04:01:WU00:FS01:Upload complete
07:04:01:WU00:FS01:Server responded WORK_ACK (400)
07:04:01:WU00:FS01:Cleaning up
Re: Error 125 on an RX 580
You may be right about the iGPU on your Intel processor causing problems. In the past this has been reported by others doing folding. Fixes that I recall include disabling it in the BIOS, uninstalling the video drivers for the Intel iGPU, and reordering the OpenCL DLL entries in the registry. That last item is from Windows apparently directing use of the OpenCL DLL to the first one listed, not necessarily the correct one for the hardware being connected with.
The only other thing I can think of is driver version. AMD has occasionally broken OpenCL in specific versions, or ended full support of OpenCL for older GPUs. So sometimes installing a newer or older version downloaded directly from AMD is needed.
Hope this gives you some ideas to try, I am fuzzy on the details as I currently am only running macOS and Linux myself.
saltspect
Post by saltspect »
Thank you so much! I uninstalled the internal gpu in the device manager and restarted the client and it is now working. I tried to go into the windows registry to see if I could fix the order but I couldn't find the appropriate place. Most of what I found when researching it referenced a "Khronos" folder that I could not find, and supposedly newer AMD drivers can remove it or break it when they are installed. I could see all of the OpenCL.dll files when I did a search of System32, but they were in several locations and had no obvious index when viewed with the file explorer. I assume that the way windows is passing the information to the client lacks a way to check and correct for correlation/compatibility, and if this is something that can be addressed on the client side it would greatly improve ease of use. If something happens after I reboot the system tomorrow I will update with anything relevant. (⁀ᗢ⁀)
