I was wrong about the New 23.2.1 driver with a RX7900XTX
DarkFoss
Hardware configuration: AMD 5800X3D Asus ROG Strix X570-E Gaming WiFi II bios 5043 G-Skill TridentZ Neo 3600mhz Asrock Tachi RX 7900XTX Corsair rm850x psu Asus PG32UQXR/Sony Bravia 3(2024) EK Elite 360 D-rgb aio Win 11pro/Kubuntu 2404.3 LTS Kernel 6.14.x HWE Generic UPS BX1500G
Post by DarkFoss »
I replaced my 6600XT with an Asrock Tachi RX7900XTX and installed the latest drivers from AMD's site. The driver fell over half way through the 1st wu it did complete although at the speed of a RX6700XT. :cry: Wiped that driver and installed the 23.1.2 7900 series only driver and it's operating as expected. Hopefully AMD will restore OpenCL in the next unified driver release.
*EDIT*
Welp I was wrong. I thought I had the latest chipset installed 4.9 something turned out there is a newer version amd_chipset_software_4.11.15.3424.11. Once installed I used the amd driver uninstaller freshly downloaded in case the version I had was also older reboot installed the 23.2.1 Driver.
After folding a few work units I downloaded the new fah beta client. It seems to handle the new system better than the current v7 client. No thermal throttling, large power spikes ect.
Re: I was wrong about the New 23.2.1 driver with a RX7900XTX
Post by muziqaz »
fahclients have no influnce how compute side of things is happening. Both use same fahcore_22
FAH Omega tester
